Nrf52820 SPI SLAVE
Hello, I want to use the nRF52820 as a slave device. I've left my code, prj.conf, and DTS files below, but the spi_transceive function seems to be getting stuck. What could be wrong? Is my main code correct? Thank you in advance.
CONFIG_CLOCK_CONTROL=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=n
CONFIG_GPIO=y
CONFIG_SPI=y
CONFIG_SPI_SLAVE=y
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_DEFAULT_LEVEL=2
CONFIG_LOG_PRINTK=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
#include <zephyr/kernel.h>
#include <zephyr/drivers/spi.h>
#include <string.h> // memset için
#define SPI_NODE DT_NODELABEL(spi0)
static const struct spi_config spi_cfg = {
    .operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB | SPI_OP_MODE_SLAVE
               | SPI_MODE_CPOL | SPI_MODE_CPHA,
    .frequency = 800000, // slave'de çoğu zaman dikkate alınmaz ama doldurulmalı
    .slave = 0,
const struct device *spi_dev;
static void spi_init(void)
    spi_dev = DEVICE_DT_GET(SPI_NODE);
    if (!device_is_ready(spi_dev)) {
        printk("SPI device %s not ready!\n", spi_dev->name);
        return;
    printk("SPI device %s ready.\n", spi_dev->name);
void spi_test_send(void)
    int err;
    static uint8_t tx_buffer[] = "Hello from AliveCor!";
    static uint8_t rx_buffer[sizeof(tx_buffer)] = {0};
    // Her transferde RX buffer sıfırlansın
    memset(rx_buffer, 0, sizeof(rx_buffer));
    const struct spi_buf tx_buf = {
        .buf = tx_buffer,
        .len = sizeof(tx_buffer)
    const struct spi_buf_set tx = {
        .buffers = &tx_buf,
        .count = 1
    struct spi_buf rx_buf = {
        .buf = rx_buffer,
        .len = sizeof(rx_buffer),
    const struct spi_buf_set rx = {
        .buffers = &rx_buf,
        .count = 1
    printk("Waiting SPI master...\n");
    err = spi_transceive(spi_dev, &spi_cfg, &tx, &rx);
    if (err) {
        printk("SPI error: %d\n", err);
    } else {
        printk("TX sent: [");
        for (size_t i = 0; i < sizeof(tx_buffer); i++) {
            printk("%02X ", tx_buffer[i]);
        printk("]\n");
        printk("RX recv: [");
        for (size_t i = 0; i < sizeof(rx_buffer); i++) {
            printk("%02X ", rx_buffer[i]);
        printk("]\n");
void main(void)
    printk("SPI SLAVE test, board: %s\n", CONFIG_BOARD);
    spi_init();
    while (1) {
        spi_test_send();
        k_sleep(K_MSEC(1000));
/dts-v1/;
#include <nordic/nrf52820_qdaa.dtsi>
#include "TST-pinctrl.dtsi"
    model = "testing";
    compatible = "BY,TST";
    chosen {
        zephyr,sram = &sram0;
        zephyr,flash = &flash0;
        zephyr,code-partition = &slot0_partition;
        zephyr,console = &cdc_acm_uart0;
        zephyr,shell-uart = &cdc_acm_uart0;
        zephyr,uart-mcumgr = &cdc_acm_uart0;
    leds {
        compatible = "gpio-leds";
        led0: led_0 {
            gpios = <&gpio0 28 GPIO_ACTIVE_HIGH>;
            label = "Green LED 0";
        led1: led_1 {
            gpios = <&gpio0 30 GPIO_ACTIVE_HIGH>;
            label = "Green LED 1";
    aliases {
        led0 = &led0;
        led1 = &led1;
&flash0 {
    partitions {
        #address-cells = <1>;
        #size-cells = <1>;
        boot_partition: partition@0 {
            label = "mcuboot";
            reg = <0x00000000 DT_SIZE_K(48)>;
        slot0_partition: partition@c000 {
            label = "image-0";
            reg = <0x0000c000 DT_SIZE_K(92)>;
        slot1_partition: partition@23000 {
            label = "image-1";
            reg = <0x00023000 DT_SIZE_K(92)>;
        storage_partition: partition@3a000 {
            label = "storage";
            reg = <0x0003a000 DT_SIZE_K(24)>;
&gpiote {
    status = "okay";
&gpio0 {
    status = "okay";
&clock {
    status = "okay";
zephyr_udc0: &usbd {
    compatible = "nordic,nrf-usbd";
    status = "okay";
&usbd {
    cdc_acm_uart0: cdc_acm_uart0 {
        compatible = "zephyr,cdc-acm-uart";
        label = "CDC_ACM_0";
&spi1 {
    compatible = "nordic,nrf-spi";
    status = "okay";
    pinctrl-0 = <&spi1_default>;
    pinctrl-1 = <&spi1_sleep>;
    cs-gpios = <&gpio0 2 GPIO_ACTIVE_LOW>;
&radio {
    status = "okay";
&spi0 {
	status = "okay";
    compatible = "nordic,nrf-spis";
    pinctrl-0 = <&spi0_default>;
    pinctrl-1 = <&spi0_sleep>;
    cs-gpios = <&gpio0 14 GPIO_ACTIVE_LOW>;
    def-char = <0xFF>;
&pinctrl{
        spi1_default: spi1_default {
            group1 {
            psels = <NRF_PSEL(SPIM_SCK, 0, 0)>,
            <NRF_PSEL(SPIM_MOSI, 0, 4)>,
            <NRF_PSEL(SPIM_MISO, 0, 1)>;
            spi1_sleep: spi1_sleep {
            group1 {
            low-power-enable;
        spi0_default: spi0_default {
            group1 {
            psels = <NRF_PSEL(SPIS_SCK, 0, 5)>,
            <NRF_PSEL(SPIS_MOSI, 0, 7)>,
            <NRF_PSEL(SPIS_MISO, 0, 6)>;
            spi0_sleep: spi0_sleep {
            group1 {
            low-power-enable;
