Thingy:53 doesn't work with NRF7002EB shield
I've recently picked up Thingy 53 and NRF7002EB shield and wanted to play around with it, but I have a problem during project configuration.
When I add -DSHIELD=nrf7002eb to cmake options during build the project doesn't build - using any sample.
The error is:
-- Application: /home/zdun8/ncs/v3.0.2/nrf/samples/nrf5340/empty_net_core
-- CMake version: 3.21.0
-- Found Python3: /home/zdun8/ncs/toolchains/7cbc0036f4/usr/local/bin/python (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: /home/zdun8/.cache/zephyr
-- Zephyr version: 4.0.99 (/home/zdun8/ncs/v3.0.2/zephyr)
-- Board: thingy53, qualifiers: nrf5340/cpunet
-- Shield(s): nrf7002eb
-- Found host-tools: zephyr 0.17.0 (/home/zdun8/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (/home/zdun8/ncs/toolchains/7cbc0036f4/opt/zephyr-sdk)
-- Found Dtc: /home/zdun8/ncs/toolchains/7cbc0036f4/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
-- Found BOARD.dts: /home/zdun8/ncs/v3.0.2/zephyr/boards/nordic/thingy53/thingy53_nrf5340_cpunet.dts
-- Found devicetree overlay: /home/zdun8/ncs/v3.0.2/zephyr/boards/shields/nrf7002eb/nrf7002eb.overlay
See also "/home/zdun8/projets/hello_world/build/CMakeFiles/CMakeOutput.log".
devicetree error: /home/zdun8/ncs/v3.0.2/zephyr/boards/shields/nrf7002eb/nrf7002eb.overlay:15 (column 1): parse error: undefined node label 'edge_connector_spi'
CMake Error at /home/zdun8/ncs/v3.0.2/zephyr/cmake/modules/dts.cmake:305 (execute_process):
  execute_process failed command indexes:
I debugged it a bit and it seems that for the thingy53 cpunet, there is no edge_connector_spi defined as for cpuapp.
I know this shield is not supported for other devkits apart from Thingy 53 but it seems even for thingy 53 it's not the case.
I'm using SDK 3.0.2.
Does anyone has an idea how to fix this?
Thanks!
  •  Funnily enough, I just stumbled on this with the exact same issue.
    [Success] With CMAKE option `-D_SHIELD=nrf7002eb`:
    [283/548] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [284/548] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [285/548] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdio/remove.c.obj
    [286/548] Building C object zephyr/subsys/net/lib/dns/CMakeFiles/subsys__net__lib__dns.dir/dns_pack.c.obj
    [287/548] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [288/548] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [289/548] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [290/548] Linking C static library zephyr/arch/common/libarch__common.a
    [291/548] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [292/548] Building C object zephyr/lib/os/zvfs/CMakeFiles/lib__os__zvfs.dir/zvfs_eventfd.c.obj
    [293/548] Building C object zephyr/lib/os/zvfs/CMakeFiles/lib__os__zvfs.dir/zvfs_poll.c.obj
    [294/548] Building C object zephyr/lib/os/zvfs/CMakeFiles/lib__os__zvfs.dir/zvfs_select.c.obj
    [295/548] Generating ../../../include/generated/posix/strsignal_table.h
    [296/548] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf.c.obj
    [297/548] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf_simple.c.obj
    [298/548] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [299/548] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [300/548] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [301/548] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [302/548] Linking C static library zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    [303/548] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [304/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/aio.c.obj
    [305/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/barrier.c.obj
    [306/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/eventfd.c.obj
    [307/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/fnmatch.c.obj
    [308/548] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [309/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/getopt/getopt.c.obj
    [310/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/getentropy.c.obj
    [311/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/getopt/getopt_common.c.obj
    [312/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/perror.c.obj
    [313/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/file_system_r.c.obj
    [314/548] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [315/548] Linking C static library zephyr/lib/os/zvfs/liblib__os__zvfs.a
    [316/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/fd_mgmt.c.obj
    [317/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/device_io.c.obj
    [318/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/fs.c.obj
    [319/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/fsync.c.obj
    [320/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/mqueue.c.obj
    [321/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/sleep.c.obj
    [322/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/multi_process.c.obj
    [323/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/signal.c.obj
    [324/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/confstr.c.obj
    [325/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/net.c.obj
    [326/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/env.c.obj
    [327/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/sysconf.c.obj
    [328/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/timespec_to_timeout.c.obj
    [329/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/timer.c.obj
    [330/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/clock.c.obj
    [331/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/rwlock.c.obj
    [332/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/spinlock.c.obj
    [333/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/cond.c.obj
    [334/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/key.c.obj
    [335/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/semaphore.c.obj
    [336/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/grp.c.obj
    [337/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/mutex.c.obj
    [338/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/pwd.c.obj
    [339/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/getopt/getopt_long.c.obj
    [340/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/pthread.c.obj
    [341/548] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [342/548] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [343/548] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/nrf53_cpunet_mgmt.c.obj
    [344/548] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/soc.c.obj
    [345/548] Building C object zephyr/boards/nordic/thingy53/CMakeFiles/boards__nordic__thingy53.dir/board.c.obj
    [346/548] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/sync_rtc.c.obj
    [347/548] Building C object zephyr/subsys/debug/coredump/CMakeFiles/subsys__debug__coredump.dir/coredump_core.c.obj
    [348/548] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs_impl.c.obj
    [349/548] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs.c.obj
    [350/548] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/random_entropy_device.c.obj
    [351/548] Building C object zephyr/subsys/debug/coredump/CMakeFiles/subsys__debug__coredump.dir/coredump_memory_regions.c.obj
    [352/548] Building C object zephyr/subsys/debug/coredump/CMakeFiles/subsys__debug__coredump.dir/coredump_backend_logging.c.obj
    [353/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets.c.obj
    [354/548] Linking C static library zephyr/lib/net_buf/liblib__net_buf.a
    [355/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/hostname.c.obj
    [356/548] Linking C static library zephyr/libzephyr.a
    [357/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/getnameinfo.c.obj
    [358/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_misc.c.obj
    [359/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_inet.c.obj
    [360/548] Linking C static library zephyr/boards/nordic/thingy53/libboards__nordic__thingy53.a
    [361/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/getaddrinfo.c.obj
    [362/548] Linking C static library zephyr/soc/soc/nrf5340/libsoc__nordic.a
    [363/548] Linking C static library zephyr/subsys/random/libsubsys__random.a
    [364/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_packet.c.obj
    [365/548] Linking C static library zephyr/subsys/fs/libsubsys__fs.a
    [366/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_service.c.obj
    [367/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/socketpair.c.obj
    [368/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/net_shell.c.obj
    [369/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/allocs.c.obj
    [370/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/arp.c.obj
    [371/548] Linking C static library zephyr/subsys/debug/coredump/libsubsys__debug__coredump.a
    [372/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/capture.c.obj
    [373/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/gptp.c.obj
    [374/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/conn.c.obj
    [375/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/http.c.obj
    [376/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/dhcpv4.c.obj
    [377/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/dhcpv6.c.obj
    [378/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/cm.c.obj
    [379/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/dns.c.obj
    [380/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/iface.c.obj
    [381/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/ipv4.c.obj
    [382/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/events.c.obj
    [383/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/ipv6.c.obj
    [384/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/pkt.c.obj
    [385/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/mem.c.obj
    [386/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/nbr.c.obj
    [387/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/ping.c.obj
    [388/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/pmtu.c.obj
    [389/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/route.c.obj
    [390/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/ppp.c.obj
    [391/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/resume.c.obj
    [392/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/sockets.c.obj
    [393/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/stats.c.obj
    [394/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/suspend.c.obj
    [395/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/tcp.c.obj
    [396/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/udp.c.obj
    [397/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/virtual.c.obj
    [398/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/websocket.c.obj
    [399/548] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/shell/vlan.c.obj
    [400/548] Building C object zephyr/subsys/net/l2/ethernet/CMakeFiles/subsys__net__l2__ethernet.dir/ethernet.c.obj
    [401/548] Building C object zephyr/subsys/net/l2/ethernet/CMakeFiles/subsys__net__l2__ethernet.dir/ethernet_stats.c.obj
    [402/548] Building C object zephyr/subsys/net/l2/ethernet/CMakeFiles/subsys__net__l2__ethernet.dir/arp.c.obj
    [403/548] Building C object zephyr/subsys/net/l2/wifi/CMakeFiles/subsys__net__l2__wifi.dir/wifi_mgmt.c.obj
    [404/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj
    [405/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj
    [406/548] Building C object zephyr/subsys/net/l2/wifi/CMakeFiles/subsys__net__l2__wifi.dir/wifi_utils.c.obj
    [407/548] Building C object zephyr/subsys/net/l2/wifi/CMakeFiles/subsys__net__l2__wifi.dir/wifi_shell.c.obj
    [408/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj
    [409/548] Building C object zephyr/subsys/net/l2/wifi/CMakeFiles/subsys__net__l2__wifi.dir/wifi_nm.c.obj
    [410/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj
    [411/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_mgmt.c.obj
    [412/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_context.c.obj
    [413/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_pkt.c.obj
    [414/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_tc.c.obj
    [415/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/icmp.c.obj
    [416/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/connection.c.obj
    [417/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/icmpv4.c.obj
    [418/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv4.c.obj
    [419/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/icmpv6.c.obj
    [420/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/igmp.c.obj
    [421/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/nbr.c.obj
    [422/548] Linking C static library zephyr/subsys/net/l2/ethernet/libsubsys__net__l2__ethernet.a
    [423/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv6_mld.c.obj
    [424/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv6.c.obj
    [425/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv6_nbr.c.obj
    [426/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/route.c.obj
    [427/548] Linking C static library zephyr/subsys/net/l2/wifi/libsubsys__net__l2__wifi.a
    [428/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/udp.c.obj
    [429/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_stats.c.obj
    [430/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/packet_socket.c.obj
    [431/548] Building C object zephyr/subsys/net/lib/wifi_credentials/CMakeFiles/wifi_credentials.dir/wifi_credentials.c.obj
    [432/548] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/tcp.c.obj
    [433/548] Building C object zephyr/subsys/net/lib/wifi_credentials/CMakeFiles/wifi_credentials.dir/wifi_credentials_shell.c.obj
    [434/548] Building C object zephyr/subsys/net/lib/wifi_credentials/CMakeFiles/wifi_credentials.dir/wifi_credentials_backend_settings.c.obj
    [435/548] Linking C static library zephyr/subsys/net/libsubsys__net.a
    [436/548] Building C object zephyr/subsys/net/lib/dhcpv4/CMakeFiles/subsys__net__lib__dhcpv4.dir/dhcpv4.c.obj
    [437/548] Building C object zephyr/subsys/net/lib/dns/CMakeFiles/subsys__net__lib__dns.dir/dispatcher.c.obj
    [438/548] Building C object zephyr/drivers/usb/common/nrf_usbd_common/CMakeFiles/drivers__usb__common__nrf_usbd_common.dir/nrf_usbd_common.c.obj
    [439/548] Building C object zephyr/drivers/usb/device/CMakeFiles/drivers__usb__device.dir/usb_dc_nrfx.c.obj
    [440/548] Building C object zephyr/subsys/net/lib/dns/CMakeFiles/subsys__net__lib__dns.dir/resolve.c.obj
    [441/548] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [442/548] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/opt/nordic/ncs/v3.0.2/nrf/drivers/entropy/entropy_cc3xx.c.obj
    [443/548] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [444/548] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
    [445/548] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [446/548] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/uname.c.obj
    [447/548] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/nrf_qspi_nor.c.obj
    [448/548] Linking C static library zephyr/drivers/usb/common/nrf_usbd_common/libdrivers__usb__common__nrf_usbd_common.a
    [449/548] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [450/548] Linking C static library zephyr/subsys/net/lib/wifi_credentials/libwifi_credentials.a
    [451/548] Linking C static library zephyr/subsys/net/lib/dhcpv4/libsubsys__net__lib__dhcpv4.a
    [452/548] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [453/548] Linking C static library zephyr/drivers/usb/device/libdrivers__usb__device.a
    [454/548] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [455/548] Linking C static library zephyr/subsys/net/lib/dns/libsubsys__net__lib__dns.a
    [456/548] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_weak_impl.c.obj
    [457/548] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
    [458/548] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj
    [459/548] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_nrf.c.obj
    [460/548] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj
    [461/548] Building C object zephyr/drivers/mbox/CMakeFiles/drivers__mbox.dir/mbox_nrfx_ipc.c.obj
    [462/548] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [463/548] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [464/548] Building C object zephyr/drivers/regulator/CMakeFiles/drivers__regulator.dir/regulator_common.c.obj
    [465/548] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/opt/nordic/ncs/v3.0.2/zephyr/misc/empty_file.c.obj
    [466/548] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim_common.c.obj
    [467/548] Building C object zephyr/drivers/regulator/CMakeFiles/drivers__regulator.dir/regulator_fixed.c.obj
    [468/548] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_common.c.obj
    [469/548] Linking C static library zephyr/subsys/net/ip/libsubsys__net__ip.a
    [470/548] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [471/548] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [472/548] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    [473/548] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [474/548] Linking C static library zephyr/drivers/mbox/libdrivers__mbox.a
    [475/548] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/psa_crypto_init.c.obj
    [476/548] Linking C static library zephyr/drivers/hwinfo/libdrivers__hwinfo.a
    [477/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.c.obj
    [478/548] Linking C static library zephyr/lib/posix/options/liblib__posix__options.a
    [479/548] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [480/548] Building C object modules/nrf/drivers/hw_cc3xx/CMakeFiles/..__nrf__drivers__hw_cc3xx.dir/hw_cc3xx.c.obj
    [481/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [482/548] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [483/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [484/548] Linking C static library zephyr/drivers/regulator/libdrivers__regulator.a
    [485/548] Linking C static library zephyr/drivers/i2c/libdrivers__i2c.a
    [486/548] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [487/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [488/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj
    [489/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [490/548] Linking C static library zephyr/drivers/spi/libdrivers__spi.a
    [491/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [492/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [493/548] Linking C static library modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a
    [494/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [495/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
    [496/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [497/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_usbreg.c.obj
    [498/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_power.c.obj
    [499/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj
    [500/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_qspi.c.obj
    [501/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj
    [502/548] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
    [503/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [504/548] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [505/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [506/548] Linking C static library modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a
    [507/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [508/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [509/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [510/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [511/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [512/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [513/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [514/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [515/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [516/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [517/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [518/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [519/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [520/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [521/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [522/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [523/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [524/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [525/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [526/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/priority_queues.c.obj
    [527/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [528/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [529/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [530/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread_monitor.c.obj
    [531/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeslicing.c.obj
    [532/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [533/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [534/548] Building C object CMakeFiles/app.dir/src/main.c.obj
    [535/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [536/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [537/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [538/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [539/548] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [540/548] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [541/548] Linking C static library app/libapp.a
    [542/548] Linking C static library zephyr/kernel/libkernel.a
    [543/548] Linking C executable zephyr/zephyr_pre0.elf
    [544/548] Generating linker.cmd
    [545/548] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [546/548] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [547/548] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [548/548] Linking C executable zephyr/zephyr.elf
               FLASH:      600676 B     916992 B     65.51%
                 RAM:      161240 B       440 KB     35.79%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/shell/zephyr/zephyr.elf for board: thingy53
    image.py: sign the payload
    [23/47] Performing build step for 'mcuboot'
    [1/344] Preparing syscall dependency handling
    [2/344] Generating ../../zephyr/include/generated/app_commit.h
    [3/344] Generating ../../zephyr/include/generated/zephyr_commit.h
    [4/344] Generating ../../zephyr/include/generated/ncs_commit.h
    [5/344] Generating include/generated/zephyr/app_version.h
    [6/344] Generating ../../zephyr/include/generated/ncs_version.h
    [7/344] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 (/opt/nordic/ncs/v3.0.2/zephyr), build: v4.0.99-ncs1-2
    [8/344] Generating misc/generated/syscalls_subdirs.trigger
    [9/344] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [10/344] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [11/344] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [12/344] Generating include/generated/zephyr/driver-validation.h
    [13/344] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [14/344] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [15/344] Generating include/generated/zephyr/offsets.h
    [16/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32_sw.c.obj
    [17/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc24_sw.c.obj
    [18/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc7_sw.c.obj
    [19/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc16_sw.c.obj
    [20/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc8_sw.c.obj
    [21/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc4_sw.c.obj
    [22/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32c_sw.c.obj
    [23/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [24/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [25/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [26/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [27/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [28/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/base64.c.obj
    [29/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [30/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
    [31/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [32/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [33/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [34/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [35/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [36/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [37/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [38/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [39/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/ring_buffer.c.obj
    [40/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [41/344] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [42/344] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [43/344] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [44/344] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [45/344] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
    [46/344] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [47/344] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_descriptor.c.obj
    [48/344] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_device.c.obj
    [49/344] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [50/344] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_transfer.c.obj
    [51/344] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_work_q.c.obj
    [52/344] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [53/344] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/class/cdc_acm.c.obj
    [54/344] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj
    [55/344] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
    [56/344] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj
    [57/344] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/boot_serial/src/zcbor_bulk.c.obj
    [58/344] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [59/344] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [60/344] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [61/344] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [62/344] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [63/344] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [64/344] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [65/344] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj
    [66/344] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [67/344] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [68/344] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [69/344] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [70/344] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [71/344] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [72/344] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [73/344] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [74/344] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [75/344] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [76/344] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [77/344] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [78/344] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [79/344] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [80/344] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj
    [81/344] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/gmtime_r.c.obj
    [82/344] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj
    [83/344] Linking C static library zephyr/arch/common/libisr_tables.a
    [84/344] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj
    [85/344] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [86/344] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/asctime.c.obj
    [87/344] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [88/344] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/localtime_r_utc.c.obj
    [89/344] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [90/344] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/ctime.c.obj
    [91/344] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/string/strnlen.c.obj
    [92/344] Generating linker_zephyr_pre0.cmd
    [93/344] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [94/344] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [95/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [96/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [97/344] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [98/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [99/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [100/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [101/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [102/344] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [103/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [104/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [105/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [106/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [107/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [108/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [109/344] Linking C static library zephyr/arch/common/libarch__common.a
    [110/344] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [111/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [112/344] Linking C static library zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    [113/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [114/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [115/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [116/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [117/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [118/344] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [119/344] Linking C static library zephyr/libzephyr.a
    [120/344] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/soc.c.obj
    [121/344] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [122/344] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/nrf53_cpunet_mgmt.c.obj
    [123/344] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [124/344] Building C object zephyr/boards/nordic/thingy53/CMakeFiles/boards__nordic__thingy53.dir/board.c.obj
    [125/344] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [126/344] Building C object zephyr/drivers/usb/common/nrf_usbd_common/CMakeFiles/drivers__usb__common__nrf_usbd_common.dir/nrf_usbd_common.c.obj
    [127/344] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [128/344] Building C object zephyr/drivers/usb/device/CMakeFiles/drivers__usb__device.dir/usb_dc_nrfx.c.obj
    [129/344] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
    [130/344] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/nrf_qspi_nor.c.obj
    [131/344] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_simulator.c.obj
    [132/344] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [133/344] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [134/344] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_weak_impl.c.obj
    [135/344] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [136/344] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_nrf.c.obj
    [137/344] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [138/344] Linking C static library zephyr/boards/nordic/thingy53/libboards__nordic__thingy53.a
    [139/344] Linking C static library zephyr/soc/soc/nrf5340/libsoc__nordic.a
    [140/344] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [141/344] Building C object zephyr/drivers/regulator/CMakeFiles/drivers__regulator.dir/regulator_fixed.c.obj
    [142/344] Building C object zephyr/drivers/regulator/CMakeFiles/drivers__regulator.dir/regulator_common.c.obj
    [143/344] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [144/344] Linking C static library zephyr/drivers/usb/common/nrf_usbd_common/libdrivers__usb__common__nrf_usbd_common.a
    [145/344] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/opt/nordic/ncs/v3.0.2/zephyr/misc/empty_file.c.obj
    [146/344] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [147/344] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [148/344] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [149/344] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [150/344] Linking C static library zephyr/drivers/usb/device/libdrivers__usb__device.a
    [151/344] Linking C static library zephyr/drivers/hwinfo/libdrivers__hwinfo.a
    [152/344] Building C object modules/nrf/subsys/pcd/CMakeFiles/..__nrf__subsys__pcd.dir/src/pcd.c.obj
    [153/344] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
    [154/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/net_sockets.c.obj
    [155/344] Building C object modules/nrf/drivers/hw_cc3xx/CMakeFiles/..__nrf__drivers__hw_cc3xx.dir/hw_cc3xx.c.obj
    [156/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_cache.c.obj
    [157/344] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [158/344] Building C object modules/nrf/modules/mcuboot/hooks/CMakeFiles/..__nrf__modules__mcuboot__hooks.dir/nrf53_hooks.c.obj
    [159/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj
    [160/344] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [161/344] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [162/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_client.c.obj
    [163/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_cookie.c.obj
    [164/344] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [165/344] Linking C static library zephyr/drivers/regulator/libdrivers__regulator.a
    [166/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_msg.c.obj
    [167/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_ticket.c.obj
    [168/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_tls12_client.c.obj
    [169/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_debug_helpers_generated.c.obj
    [170/344] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [171/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_tls13_client.c.obj
    [172/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_tls12_server.c.obj
    [173/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_tls13_generic.c.obj
    [174/344] Linking C static library modules/nrf/subsys/pcd/lib..__nrf__subsys__pcd.a
    [175/344] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a
    [176/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj
    [177/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_tls13_server.c.obj
    [178/344] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ssl_tls.c.obj
    [179/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSX509.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/x509.c.obj
    [180/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSX509.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/x509_create.c.obj
    [181/344] Linking C static library modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a
    [182/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSX509.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/x509_crl.c.obj
    [183/344] Linking C static library modules/nrf/modules/mcuboot/hooks/lib..__nrf__modules__mcuboot__hooks.a
    [184/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSX509.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/x509_crt.c.obj
    [185/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSX509.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/x509_csr.c.obj
    [186/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSX509.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/x509write_crt.c.obj
    [187/344] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [188/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSX509.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/x509write_csr.c.obj
    [189/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pem.c.obj
    [190/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pkcs5.c.obj
    [191/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSX509.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/x509write.c.obj
    [192/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pkcs12.c.obj
    [193/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pkparse.c.obj
    [194/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pkwrite.c.obj
    [195/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pk.c.obj
    [196/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pk_ecc.c.obj
    [197/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/aes.c.obj
    [198/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/aesni.c.obj
    [199/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/aria.c.obj
    [200/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/asn1parse.c.obj
    [201/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pk_wrap.c.obj
    [202/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/asn1write.c.obj
    [203/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/bignum_mod_raw.c.obj
    [204/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/base64.c.obj
    [205/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/bignum_core.c.obj
    [206/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/bignum_mod.c.obj
    [207/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/bignum.c.obj
    [208/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/camellia.c.obj
    [209/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ccm.c.obj
    [210/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/block_cipher.c.obj
    [211/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/chacha20.c.obj
    [212/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/chachapoly.c.obj
    [213/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/cipher_wrap.c.obj
    [214/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/cipher.c.obj
    [215/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/cmac.c.obj
    [216/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/debug.c.obj
    [217/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/constant_time.c.obj
    [218/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ctr_drbg.c.obj
    [219/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/dhm.c.obj
    [220/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/des.c.obj
    [221/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecdh.c.obj
    [222/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecdsa.c.obj
    [223/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecjpake.c.obj
    [224/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecp_curves_new.c.obj
    [225/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecp_curves.c.obj
    [226/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecp.c.obj
    [227/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/entropy_poll.c.obj
    [228/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/entropy.c.obj
    [229/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/error.c.obj
    [230/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/gcm.c.obj
    [231/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/hkdf.c.obj
    [232/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/hmac_drbg.c.obj
    [233/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/lmots.c.obj
    [234/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/lms.c.obj
    [235/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/md5.c.obj
    [236/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/mps_reader.c.obj
    [237/344] Linking C static library modules/mbedtls/libmbedTLSX509.a
    [238/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/md.c.obj
    [239/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
    [240/344] Linking C static library modules/mbedtls/libmbedTLSCrypto.a
    [241/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/mps_trace.c.obj
    [242/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/nist_kw.c.obj
    [243/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/padlock.c.obj
    [244/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/oid.c.obj
    [245/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/platform_util.c.obj
    [246/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/platform.c.obj
    [247/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/poly1305.c.obj
    [248/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj
    [249/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/psa_util.c.obj
    [250/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ripemd160.c.obj
    [251/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/sha1.c.obj
    [252/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/sha256.c.obj
    [253/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/sha512.c.obj
    [254/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/sha3.c.obj
    [255/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/rsa.c.obj
    [256/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/threading.c.obj
    [257/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/timing.c.obj
    [258/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/version_features.c.obj
    [259/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/version.c.obj
    [260/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.c.obj
    [261/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [262/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [263/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [264/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj
    [265/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [266/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/zephyr_entropy.c.obj
    [267/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [268/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [269/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [270/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/zephyr_init.c.obj
    [271/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [272/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_power.c.obj
    [273/344] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/opt/nordic/ncs/v3.0.2/modules/lib/zcbor/src/zcbor_common.c.obj
    [274/344] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/opt/nordic/ncs/v3.0.2/modules/lib/zcbor/src/zcbor_encode.c.obj
    [275/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_qspi.c.obj
    [276/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_usbreg.c.obj
    [277/344] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/opt/nordic/ncs/v3.0.2/modules/lib/zcbor/src/zcbor_decode.c.obj
    [278/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [279/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [280/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [281/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [282/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [283/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [284/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [285/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [286/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [287/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [288/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [289/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [290/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [291/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [292/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [293/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [294/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [295/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [296/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [297/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/priority_queues.c.obj
    [298/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [299/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [300/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [301/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [302/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [303/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [304/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [305/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [306/344] Linking C static library modules/zcbor/libmodules__zcbor.a
    [307/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [308/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [309/344] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [310/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [311/344] Linking C static library modules/mbedtls/libmbedTLSBase.a
    [312/344] Linking C static library zephyr/kernel/libkernel.a
    [313/344] Linking C static library modules/mbedtls/libmodules__mbedtls.a
    [314/344] Generating zephyr/autogen-pubkey.c
    [315/344] Building C object CMakeFiles/app.dir/keys.c.obj
    [316/344] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [317/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj
    [318/344] Building C object CMakeFiles/app.dir/io.c.obj
    [319/344] Building C object CMakeFiles/app.dir/os.c.obj
    [320/344] Building C object CMakeFiles/app.dir/boot_serial_extension_zephyr_basic.c.obj
    [321/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    [322/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    [323/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    [324/344] Building C object CMakeFiles/app.dir/main.c.obj
    [325/344] Building C object CMakeFiles/app.dir/boot_serial_extensions.c.obj
    [326/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
    [327/344] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
    [328/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
    [329/344] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [330/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
    [331/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    [332/344] Building C object CMakeFiles/app.dir/arm_cleanup.c.obj
    [333/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
    [334/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    [335/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    [336/344] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
    [337/344] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
    [338/344] Linking C static library app/libapp.a
    [339/344] Linking C executable zephyr/zephyr_pre0.elf
    [340/344] Generating linker.cmd
    [341/344] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [342/344] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [343/344] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [344/344] Linking C executable zephyr/zephyr.elf
               FLASH:       64840 B        64 KB     98.94%
                 RAM:      364824 B       440 KB     80.97%
    Generating files from /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/mcuboot/zephyr/zephyr.elf for board: thingy53
    [26/47] cd /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/_sysbuild && /opt/nordic/ncs/toolchains/ef4fc6722e/Cellar/cmake/3.21.0/bin/cmake -E true
    [27/47] Performing build step for 'b0n'
    [1/146] Preparing syscall dependency handling
    [2/146] Generating ../../zephyr/include/generated/ncs_commit.h
    [3/146] Generating ../../zephyr/include/generated/zephyr_commit.h
    [4/146] Generating ../../zephyr/include/generated/ncs_version.h
    [5/146] Generating misc/generated/syscalls_subdirs.trigger
    [6/146] Generating include/generated/zephyr/version.h
    [7/146] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [8/146] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [9/146] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [10/146] Generating include/generated/zephyr/driver-validation.h
    [11/146] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [12/146] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [13/146] Generating include/generated/zephyr/offsets.h
    [14/146] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
    [15/146] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [16/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [17/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
    [18/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
    [19/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
    [20/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/chk_fail.c.obj
    [21/146] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [22/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [23/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [24/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [25/146] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [26/146] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [27/146] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [28/146] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [29/146] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [30/146] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [31/146] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [32/146] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [33/146] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [34/146] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/soc.c.obj
    [35/146] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [36/146] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [37/146] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_acl.c.obj
    [38/146] Building C object modules/nrf/subsys/bootloader/bl_boot/CMakeFiles/..__nrf__subsys__bootloader__bl_boot.dir/bl_boot.c.obj
    [39/146] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [40/146] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [41/146] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [42/146] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_oberon_hash.c.obj
    [43/146] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto.c.obj
    [44/146] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [45/146] Building C object modules/nrf/subsys/bootloader/bl_storage/CMakeFiles/..__nrf__subsys__bootloader__bl_storage.dir/bl_storage.c.obj
    [46/146] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [47/146] Building C object modules/nrf/subsys/bootloader/bl_validation/CMakeFiles/..__nrf__subsys__bootloader__bl_validation.dir/bl_validation.c.obj
    [48/146] Building C object modules/nrf/subsys/pcd/CMakeFiles/..__nrf__subsys__pcd.dir/src/pcd.c.obj
    [49/146] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [50/146] Linking C static library modules/nrf/subsys/bootloader/bl_boot/lib..__nrf__subsys__bootloader__bl_boot.a
    [51/146] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [52/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/mdk/system_nrf5340_network.c.obj
    [53/146] Linking C static library zephyr/soc/soc/nrf5340/libsoc__nordic.a
    [54/146] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a
    [55/146] Building C object CMakeFiles/app.dir/src/main.c.obj
    [56/146] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [57/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [58/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [59/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj
    [60/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [61/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [62/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [63/146] Linking C static library modules/nrf/subsys/bootloader/bl_crypto/lib..__nrf__subsys__bootloader__bl_crypto.a
    [64/146] Linking C static library modules/nrf/subsys/bootloader/bl_validation/lib..__nrf__subsys__bootloader__bl_validation.a
    [65/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [66/146] Linking C static library modules/nrf/subsys/bootloader/bl_storage/lib..__nrf__subsys__bootloader__bl_storage.a
    [67/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [68/146] Linking C static library modules/nrf/subsys/pcd/lib..__nrf__subsys__pcd.a
    [69/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [70/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [71/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [72/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [73/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [74/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [75/146] Linking C static library app/libapp.a
    [76/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [77/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [78/146] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [79/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [80/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [81/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [82/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [83/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [84/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [85/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [86/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/nothread.c.obj
    [87/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [88/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [89/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [90/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [91/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [92/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [93/146] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [94/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [95/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [96/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [97/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [98/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [99/146] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [100/146] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [101/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [102/146] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [103/146] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/stream/stream_flash.c.obj
    [104/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [105/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [106/146] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj
    [107/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [108/146] Linking C static library zephyr/kernel/libkernel.a
    [109/146] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/nrf/lib/boot_banner/banner.c.obj
    [110/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [111/146] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [112/146] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [113/146] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [114/146] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [115/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [116/146] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [117/146] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [118/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [119/146] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
    [120/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [121/146] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [122/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [123/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [124/146] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [125/146] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [126/146] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [127/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [128/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [129/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [130/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [131/146] Generating linker_zephyr_pre0.cmd
    [132/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [133/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [134/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [135/146] Linking C static library zephyr/arch/common/libisr_tables.a
    [136/146] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [137/146] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [138/146] Linking C static library zephyr/libzephyr.a
    [139/146] Linking C static library zephyr/arch/common/libarch__common.a
    [140/146] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [141/146] Linking C executable zephyr/zephyr_pre0.elf
    [142/146] Generating linker.cmd
    [143/146] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [144/146] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [145/146] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [146/146] Linking C executable zephyr/zephyr.elf
               FLASH:       19408 B      34176 B     56.79%
                 RAM:        3464 B        64 KB      5.29%
               SRAM1:          0 GB        64 KB      0.00%
    Generating files from /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/b0n/zephyr/zephyr.elf for board: thingy53
    [31/47] Generating ../merged.hex
    [32/47] Performing build step for 'empty_net_core'
    [1/145] Preparing syscall dependency handling
    [2/145] Generating ../../zephyr/include/generated/zephyr_commit.h
    [3/145] Generating ../../zephyr/include/generated/ncs_commit.h
    [4/145] Generating ../../zephyr/include/generated/ncs_version.h
    [5/145] Generating misc/generated/syscalls_subdirs.trigger
    [6/145] Generating include/generated/zephyr/version.h
    [7/145] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [8/145] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [9/145] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [10/145] Generating include/generated/zephyr/driver-validation.h
    [11/145] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [12/145] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [13/145] Generating include/generated/zephyr/offsets.h
    [14/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [15/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [16/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [17/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [18/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [19/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [20/145] Building C object CMakeFiles/app.dir/src/main.c.obj
    [21/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [22/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [23/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [24/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [25/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [26/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [27/145] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [28/145] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [29/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [30/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [31/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [32/145] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
    [33/145] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [34/145] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/nrf/lib/boot_banner/banner.c.obj
    [35/145] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [36/145] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [37/145] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [38/145] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [39/145] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [40/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [41/145] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [42/145] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
    [43/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [44/145] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [45/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [46/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [47/145] Generating linker_zephyr_pre0.cmd
    [48/145] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [49/145] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [50/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [51/145] Linking C static library app/libapp.a
    [52/145] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [53/145] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
    [54/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [55/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [56/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [57/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [58/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [59/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [60/145] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [61/145] Linking C static library zephyr/arch/common/libisr_tables.a
    [62/145] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj
    [63/145] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj
    [64/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
    [65/145] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj
    [66/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
    [67/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
    [68/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/chk_fail.c.obj
    [69/145] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [70/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [71/145] Linking C static library zephyr/libzephyr.a
    [72/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [73/145] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [74/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [75/145] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [76/145] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [77/145] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [78/145] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [79/145] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [80/145] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [81/145] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/soc.c.obj
    [82/145] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [83/145] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [84/145] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [85/145] Linking C static library zephyr/arch/common/libarch__common.a
    [86/145] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [87/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/mdk/system_nrf5340_network.c.obj
    [88/145] Linking C static library zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    [89/145] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [90/145] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [91/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [92/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [93/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [94/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj
    [95/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [96/145] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [97/145] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [98/145] Linking C static library zephyr/soc/soc/nrf5340/libsoc__nordic.a
    [99/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [100/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [101/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [102/145] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [103/145] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [104/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [105/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [106/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [107/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [108/145] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [109/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [110/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [111/145] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [112/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [113/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [114/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [115/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [116/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [117/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [118/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [119/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [120/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [121/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [122/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [123/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [124/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [125/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [126/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [127/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [128/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [129/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/priority_queues.c.obj
    [130/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [131/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [132/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeslicing.c.obj
    [133/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [134/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [135/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [136/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [137/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [138/145] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [139/145] Linking C static library zephyr/kernel/libkernel.a
    [140/145] Linking C executable zephyr/zephyr_pre0.elf
    [141/145] Generating linker.cmd
    [142/145] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [143/145] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [144/145] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [145/145] Linking C executable zephyr/zephyr.elf
               FLASH:         18 KB       222 KB      8.11%
                 RAM:        4216 B        64 KB      6.43%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/empty_net_core/zephyr/zephyr.elf for board: thingy53
    [36/47] Generating ../b0n_container.hex
    [38/47] No install step for 'empty_net_core'
    [39/47] Completed 'empty_net_core'
    [40/47] cd /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/_sysbuild && /opt/nordic/ncs/toolchains/ef4fc6722e/Cellar/cmake/3.21.0/bin/cmake -E true
    [40/47] Creating data to be provisioned to the Bootloader, storing to net_provision.hex
    [41/47] Creating signature of application
    [42/47] Creating validation for zephyr.hex, storing to signed_by_b0_empty_net_core.hex
    [44/47] Generating ../merged_CPUNET.hex
    [45/47] Generating ../signed_by_mcuboot_and_b0_empty_net_core.bin
    image.py: sign the payload
    [46/47] Generating ../signed_by_mcuboot_and_b0_empty_net_core.hex
    [47/47] Generating ../dfu_application.zip
    [Error] With CMAKE option `-DSHIELD=nrf7002eb`:
    [212/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSX509.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/x509_crt.c.obj
    [213/344] Linking C static library modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a
    [214/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSX509.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/x509write_csr.c.obj
    [215/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pem.c.obj
    [216/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pkcs12.c.obj
    [217/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pkcs5.c.obj
    [218/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pkwrite.c.obj
    [219/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pkparse.c.obj
    [220/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pk.c.obj
    [221/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/aes.c.obj
    [222/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/aesni.c.obj
    [223/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pk_wrap.c.obj
    [224/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/pk_ecc.c.obj
    [225/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/aria.c.obj
    [226/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/base64.c.obj
    [227/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/asn1parse.c.obj
    [228/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/asn1write.c.obj
    [229/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/bignum_core.c.obj
    [230/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/bignum_mod.c.obj
    [231/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/bignum_mod_raw.c.obj
    [232/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/bignum.c.obj
    [233/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/camellia.c.obj
    [234/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/block_cipher.c.obj
    [235/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/chacha20.c.obj
    [236/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/chachapoly.c.obj
    [237/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/cipher_wrap.c.obj
    [238/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ccm.c.obj
    [239/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/cmac.c.obj
    [240/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/cipher.c.obj
    [241/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/constant_time.c.obj
    [242/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ctr_drbg.c.obj
    [243/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/debug.c.obj
    [244/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/dhm.c.obj
    [245/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecdh.c.obj
    [246/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecdsa.c.obj
    [247/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecjpake.c.obj
    [248/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/des.c.obj
    [249/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecp_curves_new.c.obj
    [250/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecp_curves.c.obj
    [251/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ecp.c.obj
    [252/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/entropy_poll.c.obj
    [253/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/entropy.c.obj
    [254/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/error.c.obj
    [255/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/gcm.c.obj
    [256/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/hkdf.c.obj
    [257/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/lmots.c.obj
    [258/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/hmac_drbg.c.obj
    [259/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/lms.c.obj
    [260/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/md5.c.obj
    [261/344] Linking C static library modules/mbedtls/libmbedTLSX509.a
    [262/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/md.c.obj
    [263/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
    [264/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/mps_trace.c.obj
    [265/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/nist_kw.c.obj
    [266/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/mps_reader.c.obj
    [267/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/padlock.c.obj
    [268/344] Linking C static library modules/mbedtls/libmbedTLSCrypto.a
    [269/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/oid.c.obj
    [270/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/platform_util.c.obj
    [271/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/platform.c.obj
    [272/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/poly1305.c.obj
    [273/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/psa_util.c.obj
    [274/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/ripemd160.c.obj
    [275/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj
    [276/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/sha1.c.obj
    [277/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/sha512.c.obj
    [278/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/rsa.c.obj
    [279/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/sha256.c.obj
    [280/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/sha3.c.obj
    [281/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/threading.c.obj
    [282/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/timing.c.obj
    [283/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/version.c.obj
    [284/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.c.obj
    [285/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls/library/version_features.c.obj
    [286/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/zephyr_entropy.c.obj
    [287/344] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/zephyr_init.c.obj
    [288/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [289/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [290/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [291/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [292/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj
    [293/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [294/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [295/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [296/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [297/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_power.c.obj
    [298/344] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/opt/nordic/ncs/v3.0.2/modules/lib/zcbor/src/zcbor_common.c.obj
    [299/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_qspi.c.obj
    [300/344] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/opt/nordic/ncs/v3.0.2/modules/lib/zcbor/src/zcbor_decode.c.obj
    [301/344] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/opt/nordic/ncs/v3.0.2/modules/lib/zcbor/src/zcbor_encode.c.obj
    [302/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_usbreg.c.obj
    [303/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [304/344] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [305/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [306/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [307/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [308/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [309/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [310/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [311/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [312/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [313/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [314/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [315/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [316/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [317/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [318/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [319/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [320/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [321/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [322/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [323/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [324/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [325/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [326/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [327/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/priority_queues.c.obj
    [328/344] Linking C static library modules/zcbor/libmodules__zcbor.a
    [329/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [330/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [331/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [332/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [333/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [334/344] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [335/344] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [336/344] Linking C static library modules/mbedtls/libmbedTLSBase.a
    [337/344] Linking C static library modules/mbedtls/libmodules__mbedtls.a
    [338/344] Linking C static library zephyr/kernel/libkernel.a
    [2/146] Generating ../../zephyr/include/generated/zephyr_commit.h
    [3/146] Generating ../../zephyr/include/generated/ncs_commit.h
    [5/146] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 (/opt/nordic/ncs/v3.0.2/zephyr), build: v4.0.99-ncs1-2
    [6/146] Generating misc/generated/syscalls_subdirs.trigger
    [14/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [15/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [16/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [17/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [18/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [19/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [20/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [21/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [22/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [23/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [24/146] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [25/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [26/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [27/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [28/146] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [29/146] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [30/146] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/stream/stream_flash.c.obj
    [31/146] Building C object CMakeFiles/app.dir/src/main.c.obj
    [32/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [33/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [34/146] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj
    [35/146] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [36/146] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/nrf/lib/boot_banner/banner.c.obj
    [37/146] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [38/146] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [39/146] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [40/146] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [41/146] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [42/146] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
    [43/146] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [44/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [45/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [46/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [47/146] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [48/146] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [49/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [50/146] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [51/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [52/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [53/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [54/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [55/146] Generating linker_zephyr_pre0.cmd
    [56/146] Linking C static library app/libapp.a
    [57/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [58/146] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
    [59/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [60/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [61/146] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [62/146] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [63/146] Linking C static library zephyr/arch/common/libisr_tables.a
    [64/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
    [65/146] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [66/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/chk_fail.c.obj
    [67/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [68/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
    [69/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [70/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
    [71/146] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [72/146] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [73/146] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [74/146] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [75/146] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [76/146] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [77/146] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [78/146] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [79/146] Linking C static library zephyr/libzephyr.a
    [80/146] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/soc.c.obj
    [81/146] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [82/146] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [83/146] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [84/146] Linking C static library zephyr/arch/common/libarch__common.a
    [85/146] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [86/146] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [87/146] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [88/146] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [89/146] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_acl.c.obj
    [90/146] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [91/146] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [92/146] Building C object modules/nrf/subsys/bootloader/bl_boot/CMakeFiles/..__nrf__subsys__bootloader__bl_boot.dir/bl_boot.c.obj
    [93/146] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_oberon_hash.c.obj
    [94/146] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto.c.obj
    [95/146] Building C object modules/nrf/subsys/bootloader/bl_validation/CMakeFiles/..__nrf__subsys__bootloader__bl_validation.dir/bl_validation.c.obj
    [96/146] Building C object modules/nrf/subsys/bootloader/bl_storage/CMakeFiles/..__nrf__subsys__bootloader__bl_storage.dir/bl_storage.c.obj
    [97/146] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [98/146] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [99/146] Building C object modules/nrf/subsys/pcd/CMakeFiles/..__nrf__subsys__pcd.dir/src/pcd.c.obj
    [100/146] Linking C static library zephyr/soc/soc/nrf5340/libsoc__nordic.a
    [101/146] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [102/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/mdk/system_nrf5340_network.c.obj
    [103/146] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [104/146] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [105/146] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [106/146] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a
    [107/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [108/146] Linking C static library modules/nrf/subsys/bootloader/bl_boot/lib..__nrf__subsys__bootloader__bl_boot.a
    [109/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [110/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [111/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj
    [112/146] Linking C static library modules/nrf/subsys/bootloader/bl_validation/lib..__nrf__subsys__bootloader__bl_validation.a
    [113/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [114/146] Linking C static library modules/nrf/subsys/bootloader/bl_crypto/lib..__nrf__subsys__bootloader__bl_crypto.a
    [115/146] Linking C static library modules/nrf/subsys/bootloader/bl_storage/lib..__nrf__subsys__bootloader__bl_storage.a
    [116/146] Linking C static library modules/nrf/subsys/pcd/lib..__nrf__subsys__pcd.a
    [117/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [118/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [119/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [120/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [121/146] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [122/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [123/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [124/146] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [125/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [126/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [127/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [128/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [129/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [130/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [131/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [132/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [133/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [134/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/nothread.c.obj
    [135/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [136/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [137/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [138/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [139/146] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [140/146] Linking C static library zephyr/kernel/libkernel.a
    [5/145] Generating include/generated/zephyr/version.h
    [6/145] Generating misc/generated/syscalls_subdirs.trigger
    [14/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [15/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [16/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [19/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [20/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [21/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [22/145] Building C object CMakeFiles/app.dir/src/main.c.obj
    [24/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [25/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [26/145] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [27/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [29/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [30/145] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
    [31/145] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.2/nrf/lib/boot_banner/banner.c.obj
    [32/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [34/145] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [35/145] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [36/145] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [38/145] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [39/145] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [40/145] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
    [41/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [42/145] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [43/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [44/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [45/145] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [46/145] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [47/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [48/145] Generating linker_zephyr_pre0.cmd
    [49/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [50/145] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [51/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [52/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [53/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [54/145] Linking C static library app/libapp.a
    [55/145] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [56/145] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
    [57/145] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [61/145] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj
    [62/145] Linking C static library zephyr/arch/common/libisr_tables.a
    [63/145] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj
    [64/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
    [65/145] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj
    [66/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
    [67/145] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [69/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
    [70/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [71/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [72/145] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [74/145] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [75/145] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [76/145] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [77/145] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [78/145] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/soc.c.obj
    [79/145] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [80/145] Linking C static library zephyr/libzephyr.a
    [81/145] Linking C static library zephyr/arch/common/libarch__common.a
    [82/145] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [83/145] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [84/145] Linking C static library zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    [85/145] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [87/145] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [88/145] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [89/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/mdk/system_nrf5340_network.c.obj
    [90/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [91/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [92/145] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [93/145] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [94/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [95/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj
    [96/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [97/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [98/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [99/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [100/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [101/145] Linking C static library zephyr/soc/soc/nrf5340/libsoc__nordic.a
    [102/145] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.2/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [103/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [104/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [105/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [106/145] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [107/145] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [109/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [110/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [111/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [112/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [113/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [115/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [116/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [117/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [118/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [119/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [120/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [121/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [122/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [123/145] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [124/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [127/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [128/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/priority_queues.c.obj
    [129/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [130/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [131/145] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [132/145] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [133/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [134/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeslicing.c.obj
    [135/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [136/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [137/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [138/145] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
     *  Executing task: nRF Connect: Generate config thingy53/nrf5340/cpuapp for /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell
    Building shell
    west build --build-dir /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell --pristine --board thingy53/nrf5340/cpuapp --sysbuild -- -DSHIELD=nrf7002eb -DBOARD_ROOT=/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/[email protected]/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: /Users/rav/Library/Caches/zephyr
    -- Board: thingy53, qualifiers: nrf5340/cpuapp
    -- Shield(s): nrf7002eb
    Parsing /opt/nordic/ncs/v3.0.2/zephyr/share/sysbuild/Kconfig
    Loaded configuration '/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/_sysbuild/empty.conf'
    Merged configuration '/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/sysbuild.conf'
    Configuration saved to '/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/zephyr/.config'
    Kconfig header saved to '/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: /opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/python (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Found host-tools: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /opt/nordic/ncs/v3.0.2/zephyr/boards/nordic/thingy53/thingy53_nrf5340_cpuapp.dts
    -- Found devicetree overlay: /opt/nordic/ncs/v3.0.2/zephyr/boards/shields/nrf7002eb/nrf7002eb.overlay
    -- Found devicetree overlay: /opt/nordic/ncs/v3.0.2/zephyr/boards/shields/nrf7002eb/boards/thingy53_nrf5340_cpuapp.overlay
    -- Found devicetree overlay: /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/sysbuild/mcuboot/app.overlay
    -- Found devicetree overlay: /opt/nordic/ncs/v3.0.2/nrf/modules/mcuboot/flash_sim.overlay
    -- Generated zephyr.dts: /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/mcuboot/zephyr/dts.cmake
    warning: MBEDTLS_CFG_FILE (defined at
    /opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/Kconfig:426,
    /opt/nordic/ncs/v3.0.2/nrf/subsys/nrf_security/Kconfig:67, modules/mbedtls/Kconfig:59,
    modules/mbedtls/Kconfig:59) was assigned the value 'mcuboot-mbedtls-cfg.h' but got the value
    'config-tls-generic.h'. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_CFG_FILE and/or look up
    MBEDTLS_CFG_FILE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    warning: LOG_DEFAULT_LEVEL (defined at subsys/logging/Kconfig.filtering:13) was assigned the value
    '0' but got the value ''. Check these unsatisfied dependencies: LOG (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_DEFAULT_LEVEL and/or look up
    LOG_DEFAULT_LEVEL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    warning: The choice symbol MCUBOOT_LOG_LEVEL_INF (defined at
    subsys/logging/Kconfig.template.log_config:17) was selected (set =y), but no symbol ended up as the
    choice selection. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MCUBOOT_LOG_LEVEL_INF
    and/or look up MCUBOOT_LOG_LEVEL_INF in the menuconfig/guiconfig interface. The Application
    Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
    the manual might be helpful too.
    warning: The choice symbol LOG_MODE_MINIMAL (defined at subsys/logging/Kconfig.mode:29) was selected
    (set =y), but no symbol ended up as the choice selection. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_MODE_MINIMAL and/or look up
    LOG_MODE_MINIMAL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    warning: Deprecated symbol DEPRECATED_UART_NRFX_UARTE_LEGACY_SHIM is enabled.
    Parsing /opt/nordic/ncs/v3.0.2/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration '/opt/nordic/ncs/v3.0.2/zephyr/boards/nordic/thingy53/thingy53_nrf5340_cpuapp_defconfig'
    Merged configuration '/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/sysbuild/mcuboot/prj.conf'
    Merged configuration '/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/sysbuild/mcuboot/boards/thingy53_nrf5340_cpuapp.conf'
    Merged configuration '/opt/nordic/ncs/v3.0.2/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
    Merged configuration '/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to '/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/mcuboot/zephyr/.config'
    Kconfig header saved to '/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Using ccache: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/ccache
    MCUBoot bootloader key file: /opt/nordic/ncs/v3.0.2/bootloader/mcuboot/root-rsa-2048.pem
    CMake Warning at CMakeLists.txt:393 (message):
      WARNING: Using default MCUboot signing key file, this file is for debug use
      only and is not secure!
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/mcuboot
       * Running CMake for empty_net_core *
    -- Application: /opt/nordic/ncs/v3.0.2/nrf/samples/nrf5340/empty_net_core
    -- Board: thingy53, qualifiers: nrf5340/cpunet
    -- Found BOARD.dts: /opt/nordic/ncs/v3.0.2/zephyr/boards/nordic/thingy53/thingy53_nrf5340_cpunet.dts
    See also "/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build/CMakeFiles/CMakeOutput.log".
    devicetree error: /opt/nordic/ncs/v3.0.2/zephyr/boards/shields/nrf7002eb/nrf7002eb.overlay:15 (column 1): parse error: undefined node label 'edge_connector_spi'
    CMake Error at /opt/nordic/ncs/v3.0.2/zephyr/cmake/modules/dts.cmake:305 (execute_process):
      execute_process failed command indexes:
        1: "Child return code: 1"
      /opt/nordic/ncs/v3.0.2/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
      /opt/nordic/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      /opt/nordic/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:9 (find_package)
    CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
      CMake configure failed for Zephyr project: empty_net_core
      Location: /opt/nordic/ncs/v3.0.2/nrf/samples/nrf5340/empty_net_core
      cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
      cmake/modules/sysbuild_default.cmake:21 (include)
      /opt/nordic/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      /opt/nordic/ncs/v3.0.2/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/[email protected]/bin/python3.12 -B/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell/build -GNinja -DBOARD=thingy53/nrf5340/cpuapp -DSHIELD=nrf7002eb -DBOARD_ROOT=/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell -S/opt/nordic/ncs/v3.0.2/zephyr/share/sysbuild -DAPP_DIR:PATH=/Users/rav/git-repositories/personal/nrf/thingy53/tests/shell
     *  The terminal process terminated with exit code: 1.
  • Yes, see above the logs. Your suggestion worked and the documentation is either outdated or something changed with the SDK
  • Ah I see, that's great. I was a bit unsure since the option was written as "-D_SHIELD=nrf7002eb", lacking the application name. That's good then. Thank you rsispal Slight smile
  • Apologies, yes, it just occurred to me I'd stripped out the application name from multiple tests. I can confirm the application name is necessary and it had to match the project() in CMakeLists.txt
    i.e. -Dhello_world_SHIELD=nrf7002eb
    One other thing i notice is there's inconsistencies in the wifi examples with not all having a sysbuild.conf with SB_CONFIG_WIFI_NRF70=y, causing the nrf70 not to initialise at all
  • Many samples build succesfully with just -D_SHIELD but I couldn’t make any work tbh
