compiling ble_peripheral_ble_app_template example
Hei,
I would like to compile ble_app_template example which is located in nRF5_SDK_v11 library. I get the following warning "Could not create/access path '._build' !" when the entire program is loaded in Keil and subsequently when I press the build button I get immediately error which is related to the previous warning "Create Path '._build' failed.". I do not know how I can solve this problem. I will be thankfull for any information about that.
Best regards
Samo
  • I saw something similar recently and I'm not sure I remember what I did, but I think deleting the "_build" folder located in "ble_app_template\pca100xx\s1xx\arm5_no_packs" and recompiling solved the problem.
  • The problem is that i do not have "_build" file in the existing folder. Do you have any other recommendation?
    • What kind of operating system are you using?
    • I have heard that people have problem with their file paths. Do you use special characters? Do you have a very long file path?
    • Are you using Keil Pack installer or the zipped SDK folder structure?
    • It's a long shot, but could this be relevant?
  • Thanks for advice. I solve the problem. My file directoy was located in C:\Program Files (x86)... and the problem was some of there characters in the path (I assume that brackets cause the problem). I changed the path and everything works fine.
