nRF9151 DK + SIM card registration rejected
Hello all,
I've just bought nRF9151 DK and went with Quick Start. I loaded nRF Cloud multi-service sample.
Sample runs and connect to network. Sometimes it sends data (location + temperature) but only once.
After that I got disconnect from network and end up in attaching state forever.
The behavior of the sim cards is totally the same (Onomondo and wireless logic).
I saw that in Czech Republic eDRX and PSM is not support for LTE-M either NB-IOT.
Should I somehow disable these features?
I am including log file.
*** Booting My Application v2.1.0-dev-ae1ee57f3906 ***
*** Using nRF Connect SDK v3.0.0-3bfc46578e42 ***
*** Using Zephyr OS v4.0.99-a0e545cb437a ***
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Image index: 0, Swap type: none
I: Bootloader chainload address offset: 0x18000
I: Image version: v0.0.0
All pins have been configured as non-secure
Booting TF-M v2.1.1-ncs4
[Sec Thread] Secure image initializing!
TF-M isolation level is: 0x00000001
TF-M Float ABI: Hard
Lazy stacking enabled
[00:00:00.253,784] <inf> spi_nor: gd25wb256e3ir@1: 32 MiBy flash
*** Booting nRF Connect SDK v3.0.0-3bfc46578e42 ***
[00:00:00.261,474] <inf> main: nRF Cloud multi-service sample has started, version: 1.0.0, protocol: CoAP
[00:00:00.261,505] <inf> application: Reset reason: 0x1
[00:00:00.261,779] <inf> cloud_connection: Enabling connectivity...
[00:00:00.522,888] <inf> nrf_modem_lib_trace: Trace thread ready
[00:00:00.530,792] <inf> nrf_modem_lib_trace: Trace level override: 2
[00:00:00.631,225] <inf> cloud_connection: Setting up nRF Cloud library...
[00:00:00.719,848] <inf> nrf_cloud_info: Device ID: 50343956-3037-4a98-8010-1617c7895929
[00:00:00.720,428] <inf> nrf_cloud_info: IMEI:      359404230087661
[00:00:00.806,701] <inf> nrf_cloud_info: UUID:      50343956-3037-4a98-8010-1617c7895929
[00:00:00.807,159] <inf> nrf_cloud_info: Modem FW:  mfw_nrf91x1_2.0.2
[00:00:00.807,220] <inf> nrf_cloud_info: Protocol:          CoAP
[00:00:00.807,250] <inf> nrf_cloud_info: Download protocol: HTTPS
[00:00:00.807,250] <inf> nrf_cloud_info: Sec tag:           16842753
[00:00:00.807,281] <inf> nrf_cloud_info: CoAP JWT Sec tag:  16842753
[00:00:00.807,312] <inf> nrf_cloud_info: Host name:         coap.nrfcloud.com
[00:00:01.149,108] <inf> nrf_cloud_credentials: Sec Tag: 16842753; CA: Yes, Client Cert: Yes, Private Key: Yes
[00:00:01.149,169] <inf> nrf_cloud_credentials: CA Size: 1792, AWS: Likely, CoAP: Likely
[00:00:01.149,169] <inf> cloud_connection: Waiting for network ready...
[00:00:07.759,368] <inf> cloud_connection: Network connectivity gained!
[00:00:08.759,613] <inf> cloud_provisioning: Initializing the nRF Provisioning library...
[00:00:08.759,643] <inf> nrf_provisioning_coap: Init CoAP client
[00:00:08.759,918] <inf> cloud_connection: Network is ready
[00:00:08.797,485] <inf> nrf_provisioning: Checking for provisioning commands in 2s seconds
[00:00:10.797,576] <inf> cloud_provisioning: Provisioning is active.
[00:00:10.986,541] <inf> nrf_provisioning_coap: DTLS setup
[00:00:12.430,816] <inf> nrf_provisioning_coap: Connected
[00:00:13.268,768] <inf> nrf_provisioning_coap: Requesting commands
[00:00:13.524,902] <inf> nrf_provisioning_coap: No more commands to process on server side
[00:00:13.527,038] <err> net_coap: No client found for socket 3
[00:00:13.527,984] <inf> nrf_provisioning: Checking for provisioning commands in 1804s seconds
[00:00:18.527,221] <inf> cloud_provisioning: Provisioning is idle.
[00:00:18.527,282] <inf> cloud_connection: Connecting to nRF Cloud
[00:00:19.956,634] <inf> nrf_cloud_coap_transport: Request authorization with JWT
[00:00:20.308,990] <inf> nrf_cloud_coap_transport: Authorization result_code: 2.01
[00:00:20.309,143] <inf> nrf_cloud_coap_transport: Authorized
[00:00:20.309,387] <inf> nrf_cloud_coap_transport: DTLS CID is active
[00:00:26.416,412] <inf> cloud_connection: Connected to nRF Cloud
[00:00:26.416,473] <inf> cloud_connection: Reducing provisioning check interval to 30 minutes
[00:00:26.416,564] <inf> shadow_support_coap: Checking for shadow delta...
[00:00:26.417,816] <inf> nrf_cloud_fota_poll: Checking for FOTA job...
[00:00:26.417,846] <inf> application: Waiting for modem to determine current date and time
[00:00:26.417,877] <inf> application: Current date and time determined
[00:00:26.417,907] <inf> nrf_cloud_log: Changing cloud logging enabled to:1
[00:00:26.709,411] <inf> shadow_config: Sending reported configuration
[00:00:32.499,969] <inf> application: Temperature is 23 degrees C
[00:00:32.500,213] <inf> nrf_cloud_pgps: Storage base:0xEB000, size:86016
[00:00:32.502,105] <inf> nrf_cloud_pgps: Checking P-GPS header: Schema version:1, type:10, num:1, count:42
[00:00:32.502,136] <inf> nrf_cloud_pgps:   size:2006, period (minutes):240, GPS day:16643, GPS time:72000
[00:00:32.502,166] <inf> nrf_cloud_pgps: Checking stored P-GPS data; count:42, period_min:240
[00:00:32.502,655] <inf> nrf_cloud_pgps: Checking if P-GPS data is expired...
[00:00:32.502,716] <inf> nrf_cloud_pgps: Found valid prediction, day:16644, time:57600
[00:00:32.502,746] <inf> nrf_cloud_pgps: P-GPS data is up to date.
[00:00:38.870,056] <inf> nrf_cloud_fota_poll: No pending FOTA job
[00:00:38.870,086] <inf> fota_support_coap: Checking for FOTA job in 120 seconds
[00:00:39.718,414] <inf> nrf_cloud_pgps: Searching for prediction
[00:00:39.718,505] <inf> nrf_cloud_pgps: Searching for prediction
[00:00:39.718,597] <inf> nrf_cloud_pgps: GPS unit needs ephemerides. Injecting 32.
[00:00:42.789,855] <inf> shadow_support_coap: Checking for shadow delta...
[00:00:45.692,565] <inf> shadow_support_coap: Checking shadow again in 120 seconds
[00:01:19.805,236] <inf> location: Method specific timeout expired
[00:01:19.806,121] <inf> location: Location retrieval failed using 'GNSS', trying with 'Cellular' next
[00:01:25.928,192] <wrn> lte_lc: Registration rejected, EMM cause: 15, Cell ID: 84631298, Tracking area: 1320, LTE mode: 7
[00:01:25.928,314] <inf> nrf_provisioning: Disconnected from network - provisioning paused
[00:01:25.928,619] <inf> cloud_connection: Network connectivity lost!
[00:01:25.928,741] <inf> cloud_connection: Disconnected from nRF Cloud
[00:01:25.928,741] <inf> cloud_connection: Retrying in 30 seconds...
[00:01:25.928,802] <err> nrf_cloud_coap: Location response decoding error: -140
[00:01:25.928,833] <err> location: Failed to acquire location using cloud location, error: -140
[00:01:25.928,894] <err> location: Location acquisition failed and fallbacks are also done
[00:01:28.798,736] <wrn> lte_lc: Registration rejected, EMM cause: 9, Cell ID: 84631309, Tracking area: 9550, LTE mode: 7
[00:01:28.798,797] <inf> nrf_provisioning: Disconnected from network - provisioning paused
[00:01:29.899,719] <wrn> lte_lc: Registration rejected, EMM cause: 15, Cell ID: 84631309, Tracking area: 9550, LTE mode: 7
[00:01:55.928,863] <inf> cloud_connection: Waiting for network ready...
[00:02:32.500,000] <inf> application: Temperature is 22 degrees C
[00:03:14.432,281] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
[00:03:20.208,526] <wrn> lte_lc: Registration rejected, EMM cause: 15, Cell ID: 84631469, Tracking area: 65000, LTE mode: 9
[00:04:32.500,061] <inf> application: Temperature is 22 degrees C
[00:04:41.546,142] <wrn> lte_lc: Registration rejected, EMM cause: 13, Cell ID: 1072417, Tracking area: 47030, LTE mode: 9
[00:05:27.558,837] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
[00:06:32.500,122] <inf> application: Temperature is 24 degrees C
[00:06:32.501,434] <err> nrf_cloud_alert: Error sending alert via CoAP: -13
[00:06:32.501,495] <inf> application: Temperature limit 24.000000 C exceeded: now 24.025000 C.
[00:07:56.045,928] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
[00:08:05.963,500] <inf> location: Method specific timeout expired
[00:08:05.963,531] <wrn> location: GNSS timed out possibly due to too short GNSS time windows
[00:08:05.964,416] <inf> location: Location retrieval failed using 'GNSS', trying with 'Cellular' next
[00:08:11.596,069] <wrn> location: Default PDN context is NOT active, cannot retrieve a location
[00:08:11.596,130] <err> location: Location acquisition failed and fallbacks are also done
[00:08:32.500,183] <inf> application: Temperature is 23 degrees C
[00:10:32.500,244] <inf> application: Temperature is 22 degrees C
[00:11:36.216,552] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
[00:12:32.500,274] <inf> application: Temperature is 23 degrees C
[00:14:32.500,335] <inf> application: Temperature is 22 degrees C
[00:14:32.500,457] <inf> application: Temperature now below limit: 22.375000 C.
[00:14:55.089,843] <inf> location: Method specific timeout expired
[00:14:55.089,874] <wrn> location: GNSS timed out possibly due to too short GNSS time windows
[00:14:55.090,637] <inf> location: Location retrieval failed using 'GNSS', trying with 'Cellular' next
[00:15:08.395,751] <wrn> location: Default PDN context is NOT active, cannot retrieve a location
[00:15:08.395,812] <err> location: Location acquisition failed and fallbacks are also done
[00:16:12.709,808] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
[00:16:32.500,427] <inf> application: Temperature is 23 degrees C
[00:18:32.500,488] <inf> application: Temperature is 22 degrees C
[00:18:46.317,260] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
uart:~$
Thank you for help.
Br, Jachym
    Yes, your device is being rejected by the network, on both NB-IoT and LTE-M. There are several EMM reject causes provided (in ascending order).
    Cause #9 – UE identity cannot be derived by the network.
          This EMM cause is sent to the UE when the network cannot derive the UE’s identity from the GUTI/S-TMSI/P-TMSI and RAI e.g. no matching identity/context in the network or failure to validate the UE’s identity due to integrity check failure of the received message.
    Cause #13 – Roaming not allowed in this tracking area
          This EMM cause is sent to an UE which requests service, or if the network initiates a detach request, in a tracking area of a PLMN which by subscription offers roaming to that UE but not in that tracking area.
    Cause #15 – No suitable cells in tracking area
          This EMM cause is sent to the UE if it requests service, or if the network initiates a detach request, in a tracking area where the UE, by subscription, is not allowed to operate, but when it should find another allowed tracking area or location area in the same PLMN or an equivalent PLMN.
    NOTE 3:  Cause #15 and cause #12 differ in the fact that cause #12 does not trigger the UE to search for another allowed tracking area on the same PLMN.
    Cause #19 – ESM failure
          This EMM cause is sent to the UE when there is a failure in the ESM message contained in the EMM message.
    Could you please provide a modem trace from your device when you see these issues?
    One thing to test is using a local SIM from e.g. Eurotel or Vodafone CZ. See GSMA Mobile Deployment map for LTE-M and NB-IoT coverage in Czech Republic. Looking at the coverage map of the Onomondo SIM it seems that they do not have roaming coverage in Czech Republic, but Wireless Logic seemingly has.
    Øyvind
  • Hello Øyvind,
    Thank you for quick response.
    I see this issue every time, it is not sporadic. Unfortunately right know I don't have another SIM so I have to order one from Vodafone.
    I include modem traces as you request (used SIM Wireless Logic)
    Google disc - traces
    BR,
    Jachym
  • Hello, and thanks for providing the modem trace!
    Looking through the modem trace it can seem that there is an issue with the IP. The device reports ESM: 50
    Cause #50 – PDN type IPv4 only allowed
          This ESM cause is used by the network to indicate that only PDN type IPv4 is allowed for the requested PDN connectivity.
    In prj.conf, please ensure:
    CONFIG_NET_IPV4=y
    CONFIG_NET_IPV6=n
    Let me know how that works for you
    Øyvind
    Unfortunately, activating only IPv4 is even worse. DK will not connect to the network at all.
    I am attaching traces (the new ones are with the IPv4_ prefix): Google disc - traces
    BR,
    Jachym
  • Thanks for testing.
    I will need to investigate and discuss this internally to why your device is still rejected by network.
    Øyvind
