nRF9151 DK + SIM card registration rejected
Hello all,
I've just bought nRF9151 DK and went with Quick Start. I loaded nRF Cloud multi-service sample.
Sample runs and connect to network. Sometimes it sends data (location + temperature) but only once.
After that I got disconnect from network and end up in attaching state forever.
The behavior of the sim cards is totally the same (Onomondo and wireless logic).
I saw that in Czech Republic eDRX and PSM is not support for LTE-M either NB-IOT.
Should I somehow disable these features?
I am including log file.
*** Booting My Application v2.1.0-dev-ae1ee57f3906 ***
*** Using nRF Connect SDK v3.0.0-3bfc46578e42 ***
*** Using Zephyr OS v4.0.99-a0e545cb437a ***
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Image index: 0, Swap type: none
I: Bootloader chainload address offset: 0x18000
I: Image version: v0.0.0
All pins have been configured as non-secure
Booting TF-M v2.1.1-ncs4
[Sec Thread] Secure image initializing!
TF-M isolation level is: 0x00000001
TF-M Float ABI: Hard
Lazy stacking enabled
[00:00:00.253,784] <inf> spi_nor: gd25wb256e3ir@1: 32 MiBy flash
*** Booting nRF Connect SDK v3.0.0-3bfc46578e42 ***
[00:00:00.261,474] <inf> main: nRF Cloud multi-service sample has started, version: 1.0.0, protocol: CoAP
[00:00:00.261,505] <inf> application: Reset reason: 0x1
[00:00:00.261,779] <inf> cloud_connection: Enabling connectivity...
[00:00:00.522,888] <inf> nrf_modem_lib_trace: Trace thread ready
[00:00:00.530,792] <inf> nrf_modem_lib_trace: Trace level override: 2
[00:00:00.631,225] <inf> cloud_connection: Setting up nRF Cloud library...
[00:00:00.719,848] <inf> nrf_cloud_info: Device ID: 50343956-3037-4a98-8010-1617c7895929
[00:00:00.720,428] <inf> nrf_cloud_info: IMEI:      359404230087661
[00:00:00.806,701] <inf> nrf_cloud_info: UUID:      50343956-3037-4a98-8010-1617c7895929
[00:00:00.807,159] <inf> nrf_cloud_info: Modem FW:  mfw_nrf91x1_2.0.2
[00:00:00.807,220] <inf> nrf_cloud_info: Protocol:          CoAP
[00:00:00.807,250] <inf> nrf_cloud_info: Download protocol: HTTPS
[00:00:00.807,250] <inf> nrf_cloud_info: Sec tag:           16842753
[00:00:00.807,281] <inf> nrf_cloud_info: CoAP JWT Sec tag:  16842753
[00:00:00.807,312] <inf> nrf_cloud_info: Host name:         coap.nrfcloud.com
[00:00:01.149,108] <inf> nrf_cloud_credentials: Sec Tag: 16842753; CA: Yes, Client Cert: Yes, Private Key: Yes
[00:00:01.149,169] <inf> nrf_cloud_credentials: CA Size: 1792, AWS: Likely, CoAP: Likely
[00:00:01.149,169] <inf> cloud_connection: Waiting for network ready...
[00:00:07.759,368] <inf> cloud_connection: Network connectivity gained!
[00:00:08.759,613] <inf> cloud_provisioning: Initializing the nRF Provisioning library...
[00:00:08.759,643] <inf> nrf_provisioning_coap: Init CoAP client
[00:00:08.759,918] <inf> cloud_connection: Network is ready
[00:00:08.797,485] <inf> nrf_provisioning: Checking for provisioning commands in 2s seconds
[00:00:10.797,576] <inf> cloud_provisioning: Provisioning is active.
[00:00:10.986,541] <inf> nrf_provisioning_coap: DTLS setup
[00:00:12.430,816] <inf> nrf_provisioning_coap: Connected
[00:00:13.268,768] <inf> nrf_provisioning_coap: Requesting commands
[00:00:13.524,902] <inf> nrf_provisioning_coap: No more commands to process on server side
[00:00:13.527,038] <err> net_coap: No client found for socket 3
[00:00:13.527,984] <inf> nrf_provisioning: Checking for provisioning commands in 1804s seconds
[00:00:18.527,221] <inf> cloud_provisioning: Provisioning is idle.
[00:00:18.527,282] <inf> cloud_connection: Connecting to nRF Cloud
[00:00:19.956,634] <inf> nrf_cloud_coap_transport: Request authorization with JWT
[00:00:20.308,990] <inf> nrf_cloud_coap_transport: Authorization result_code: 2.01
[00:00:20.309,143] <inf> nrf_cloud_coap_transport: Authorized
[00:00:20.309,387] <inf> nrf_cloud_coap_transport: DTLS CID is active
[00:00:26.416,412] <inf> cloud_connection: Connected to nRF Cloud
[00:00:26.416,473] <inf> cloud_connection: Reducing provisioning check interval to 30 minutes
[00:00:26.416,564] <inf> shadow_support_coap: Checking for shadow delta...
[00:00:26.417,816] <inf> nrf_cloud_fota_poll: Checking for FOTA job...
[00:00:26.417,846] <inf> application: Waiting for modem to determine current date and time
[00:00:26.417,877] <inf> application: Current date and time determined
[00:00:26.417,907] <inf> nrf_cloud_log: Changing cloud logging enabled to:1
[00:00:26.709,411] <inf> shadow_config: Sending reported configuration
[00:00:32.499,969] <inf> application: Temperature is 23 degrees C
[00:00:32.500,213] <inf> nrf_cloud_pgps: Storage base:0xEB000, size:86016
[00:00:32.502,105] <inf> nrf_cloud_pgps: Checking P-GPS header: Schema version:1, type:10, num:1, count:42
[00:00:32.502,136] <inf> nrf_cloud_pgps:   size:2006, period (minutes):240, GPS day:16643, GPS time:72000
[00:00:32.502,166] <inf> nrf_cloud_pgps: Checking stored P-GPS data; count:42, period_min:240
[00:00:32.502,655] <inf> nrf_cloud_pgps: Checking if P-GPS data is expired...
[00:00:32.502,716] <inf> nrf_cloud_pgps: Found valid prediction, day:16644, time:57600
[00:00:32.502,746] <inf> nrf_cloud_pgps: P-GPS data is up to date.
[00:00:38.870,056] <inf> nrf_cloud_fota_poll: No pending FOTA job
[00:00:38.870,086] <inf> fota_support_coap: Checking for FOTA job in 120 seconds
[00:00:39.718,414] <inf> nrf_cloud_pgps: Searching for prediction
[00:00:39.718,505] <inf> nrf_cloud_pgps: Searching for prediction
[00:00:39.718,597] <inf> nrf_cloud_pgps: GPS unit needs ephemerides. Injecting 32.
[00:00:42.789,855] <inf> shadow_support_coap: Checking for shadow delta...
[00:00:45.692,565] <inf> shadow_support_coap: Checking shadow again in 120 seconds
[00:01:19.805,236] <inf> location: Method specific timeout expired
[00:01:19.806,121] <inf> location: Location retrieval failed using 'GNSS', trying with 'Cellular' next
[00:01:25.928,192] <wrn> lte_lc: Registration rejected, EMM cause: 15, Cell ID: 84631298, Tracking area: 1320, LTE mode: 7
[00:01:25.928,314] <inf> nrf_provisioning: Disconnected from network - provisioning paused
[00:01:25.928,619] <inf> cloud_connection: Network connectivity lost!
[00:01:25.928,741] <inf> cloud_connection: Disconnected from nRF Cloud
[00:01:25.928,741] <inf> cloud_connection: Retrying in 30 seconds...
[00:01:25.928,802] <err> nrf_cloud_coap: Location response decoding error: -140
[00:01:25.928,833] <err> location: Failed to acquire location using cloud location, error: -140
[00:01:25.928,894] <err> location: Location acquisition failed and fallbacks are also done
[00:01:28.798,736] <wrn> lte_lc: Registration rejected, EMM cause: 9, Cell ID: 84631309, Tracking area: 9550, LTE mode: 7
[00:01:28.798,797] <inf> nrf_provisioning: Disconnected from network - provisioning paused
[00:01:29.899,719] <wrn> lte_lc: Registration rejected, EMM cause: 15, Cell ID: 84631309, Tracking area: 9550, LTE mode: 7
[00:01:55.928,863] <inf> cloud_connection: Waiting for network ready...
[00:02:32.500,000] <inf> application: Temperature is 22 degrees C
[00:03:14.432,281] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
[00:03:20.208,526] <wrn> lte_lc: Registration rejected, EMM cause: 15, Cell ID: 84631469, Tracking area: 65000, LTE mode: 9
[00:04:32.500,061] <inf> application: Temperature is 22 degrees C
[00:04:41.546,142] <wrn> lte_lc: Registration rejected, EMM cause: 13, Cell ID: 1072417, Tracking area: 47030, LTE mode: 9
[00:05:27.558,837] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
[00:06:32.500,122] <inf> application: Temperature is 24 degrees C
[00:06:32.501,434] <err> nrf_cloud_alert: Error sending alert via CoAP: -13
[00:06:32.501,495] <inf> application: Temperature limit 24.000000 C exceeded: now 24.025000 C.
[00:07:56.045,928] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
[00:08:05.963,500] <inf> location: Method specific timeout expired
[00:08:05.963,531] <wrn> location: GNSS timed out possibly due to too short GNSS time windows
[00:08:05.964,416] <inf> location: Location retrieval failed using 'GNSS', trying with 'Cellular' next
[00:08:11.596,069] <wrn> location: Default PDN context is NOT active, cannot retrieve a location
[00:08:11.596,130] <err> location: Location acquisition failed and fallbacks are also done
[00:08:32.500,183] <inf> application: Temperature is 23 degrees C
[00:10:32.500,244] <inf> application: Temperature is 22 degrees C
[00:11:36.216,552] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
[00:12:32.500,274] <inf> application: Temperature is 23 degrees C
[00:14:32.500,335] <inf> application: Temperature is 22 degrees C
[00:14:32.500,457] <inf> application: Temperature now below limit: 22.375000 C.
[00:14:55.089,843] <inf> location: Method specific timeout expired
[00:14:55.089,874] <wrn> location: GNSS timed out possibly due to too short GNSS time windows
[00:14:55.090,637] <inf> location: Location retrieval failed using 'GNSS', trying with 'Cellular' next
[00:15:08.395,751] <wrn> location: Default PDN context is NOT active, cannot retrieve a location
[00:15:08.395,812] <err> location: Location acquisition failed and fallbacks are also done
[00:16:12.709,808] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
[00:16:32.500,427] <inf> application: Temperature is 23 degrees C
[00:18:32.500,488] <inf> application: Temperature is 22 degrees C
[00:18:46.317,260] <wrn> lte_lc: Registration rejected, EMM cause: 19, Cell ID: 84631383, Tracking area: 11320, LTE mode: 9
uart:~$
Thank you for help.
Br, Jachym
