Matter Light bulb sample project modify for Matter over Thread keeping WiFi for AWS
I would like to modify the Matter: Light Bulb sample project, which comes as a dual Matter + AWS integration all running on WiFi. I would like to modify this project so that the Matter is running over Thread, and the WiFi continues to be used for the AWS integration.
This is the project: docs.nordicsemi.com/.../README.html
Ideally, we have Matter-over-thread as sleepy end device, and WiFi-AWS using legacy power save mode.
  • Hi nabeela,
    I will look into this and follow up with you this week.
    Hieu
  • Thanks - to add a bit more context - if we can make the above Matter: Light Bulb sample work like the Matter: Lock sample where it allows Thread or WiFi switching for Matter -- but in any case keep WiFi for AWS working.
    Matter: Door lock
  • Hi nabeela,
    The reason the Thread-Wi-Fi switching feature is brought up is because the memory requirement for it is going to reflect Matter over Thread + Wi-Fi.
    As mentioned, that alone consumes almost all of the nRF5340's flash memory. You will then have to add AWS on top of that,.
    nabeela said:
    Is that doable? Is it possible to do this with just modifying the necessary Kconfig, project config, and board config / overlay (using either the nRF7002DK which also has a 5340 on it, or the 5340DK with 7002EK).
    Without external flash, and without DFU: It is difficult and recommended against, because no DFU support doesn't make for a good product.
    With external flash, with DFU: It is even more difficult, because the bootloader takes ~32kB or more. Furthermore, the memory required is so large that even if you can fit AWS in today, debug builds for development purposes will most likely be not possible, and future updates will be challenging. While not recommended against, still not recommended.
    Without external flash, with DFU: No, that is entirely not possible.
  • got it thank you -- one last question that is related but a different strategy:
    Would I be able to store 2 firmware images - one for a Matter only firmware (either wifi or thread, not switchable), and a separate image that is wifi only (for AWS integration - such as AWS IoT example).
    if default image (matter firmware) is in the internal flash, and the secondary image (AWS IoT Wifi) is in the external flash, and a user can switch the working image. Maybe external flash can keep both image, but only one is loaded to nRF5340 at any one time - like a DFU operation, but 2 images are pre-loaded to external flash and user can switch between them.
    There is a product in the market that does this (I don't think it's using Nordic chipset, but it's an example)
    https://www.kwikset.com/products/detail/halo-select-touchscreen-wi-fi-and-matter-enabled-smart-lock
    If that's not at all possible, no problem.
  • Yes, it is possible, but maintaining that might be tricky.
    The idea is that you use two-slot DFU with MCUboot with swapping, and keep the "alternate" application in the secondary slot.
    The "main" application in the primary slot can trigger a test swap. At the next reset, the "alternate" application will be swapped to the primary slot and boot.
    If the "alternate" application needs to survive power cycles and/or reset, it can mark itself confirmed. Then, it becomes the "main" application, and the previous "main" app becomes "alternate."
    If the "alternate" application doesn't mark itself confirmed, at the next reset, it will be swapped back.
    Note that DFU will still download the updated application onto the secondary slot, overwriting any "alternate" application staying there at the time. You will need to devise a plan around that.
  • awesome thank you for that explanation, I'll dig into that and see if it's a viable solution to explore.
    If you do have some links handy for the MCUboot two-slot DFU, please share.
    thanks again.
  • We have online courses for getting started with the nRF Connect SDK here: Nordic Developer Academy.
    DFU is covered in Lesson 9 of the nRF Connect SDK Intermediate course.
    This is also a good starting point: Bootloaders and DFU.
