S120 starting
hello,
i am using s120 softdevice along with nrf6310 mother board, the problem is i am dumping the code into the device, but i am having doubt how to verify that it is scanning or not, since it is not displaying anything on the LCD or on the console(UART), is there any application note how to work with the S120 softdevice along with the experimental codes
regards, Rangineni balu
  • It seems from this question that you've gotten things working. Did you ever find out what exactly was wrong in this case? Feel free to post your solution in a separate answer and accept that, to show that this question has been solved.
  • hi, thanks for your reply
    now it is working as expected, the reason for this is i am using SDK V5.1 and softdevice V5.2.1 for the pheripheral, thats the reason its not working, after that i found out that with SDK V5.1 we have to use s110 v6.0, after trying V6.0 its working properly.
    again its better if you provide and design note or application note for working with the S120 softdevice for software development
    thanks and regards, rangineni balu
