BMA4XX driver bug
Hi
I found another bug in the BMA4XX driver.
When using "CONFIG_BMA4XX_TEMPERATURE=y" there is a compilation failure.
Line 621 of bma4xx.c:
		rc = bma4xx_get_shift(SENSOR_CHAN_DIE_TEMP, 0, &out->shift);
 Unfortunately the first argument of the function tries to use "SENSOR_CHAN_DIE_TEMP" which is a "int16", but the first argument of the function is a "Two Word Struct" so results in a compilation failure.
Line 597 calls the function correctly:
		rc = bma4xx_get_shift((struct sensor_chan_spec){.chan_type = SENSOR_CHAN_ACCEL_XYZ,
								.chan_idx = 0},
				      header->accel_fs, &out->shift);
So I think line 621 function call needs to be changed to follow function call on Line 597 Eg:
		rc = bma4xx_get_shift((struct sensor_chan_spec){.chan_type = SENSOR_CHAN_DIE_TEMP,
								.chan_idx = 0},  0, &out->shift);
Regards
Chris
