Flushing the LTE modem trace buffer
Dear Nordic,
We’ve developed an application which runs on an nRF9151 DK using NCS 2.8.2. The device is running modem fw nrf91x1_2.0.2. Our application has enabled modem traces using the following Kconfig settings:
  • CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_UART=y
  • CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_UART_CHUNK_SZ=8191
  • CONFIG_NRF_MODEM_LIB_TRACE_STACK_SIZE=768
  • CONFIG_NRF_MODEM_LIB_TRACE_LEVEL_OVERRIDE=y
  • CONFIG_NRF_MODEM_LIB_TRACE_LEVEL_FULL=y
  • CONFIG_NRF_MODEM_LIB_TRACE_LEVEL=2
  • CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_SUSPEND_DELAY_MS=5000
The nRF9151 is connected to a linux machine via a USB cable. The linux machine is running Ubuntu 22.04. On the linux machine the nRF9151 presents two serial ports (/dev/ttyACM0 and /dev/ttyACM1). The first serial port allows us to connect to the console port of our application. The second port allows us to read the modem traces. To capture and decode the LTE modem traces we are running the command nrfutil trace lte --input-serialport port=/dev/ttyACM1,flow_control=flow_control_type --output-pcapng pcap_file.pcap. The version information for nrfutil is the following:
  • nrfutil -V
  • nrfutil 8.0.0 (54d8087 2025-01-07)
  • commit-hash: 54d8087a38b73b6e56942fb1b024b62365f06731
  • commit-date: 2025-01-07
  • host: x86_64-unknown-linux-gnu
  • build-timestamp: 2025-01-07T14:26:42.070728557Z
  • classification: nrf-external
  • nrfutil trace -V
  • nrfutil-trace 4.0.1 (4c291c5 2025-04-29)
  • commit-hash: 4c291c53eb3b9a9aa0a4dc9c080ed6e274e6a31d
  • commit-date: 2025-04-29
  • build-timestamp: 2025-04-30T13:29:07.326959894Z
We’ve developed some test code which controls the application over the /dev/ttyACM0 port. Within the test code we have a for loop which contains the following pseudo code:
  • #flow_control = ‘none’
  • #flow_control = ‘software’
  • flow_control = ‘hardware’
  • for ii 0:N-1
    • Start modem trace using the command nrfutil trace lte --input-serialport port=/dev/ttyACM1,flow_control=flow_control_type --output-pcapng pcap_file_{ii}.pcap
    • Upload data to our cloud service
      • Device goes into RRC connected
      • Upload data
      • Wait for the device to go into RRC idle
    • sleep 10 (10 seconds)
    • Stop the modem trace
The issue we’re running into is that about 20% of the time the pcap_file_{ii}.pcap files generated are empty. We tried the different flow control values (i.e., ‘none’,’software’,’hardware’) but that didn’t help. We’ve also tried prepending the following linux commands to the nrfutil command but this didn’t help either:
  • stdbuf -o0
  • stdbuf -oL
  • stdbuf -i0 -o0 -e0
Our current thinking is that either the application or the modem itself is buffering the modem traces.
Can you offer some guidance on how to resolve this issue?
Thank you.
Peter
  • Hi Peter,
    Looking in to this and have forwarded the question to our devz, will update.
    But the documentation says that the modem buffers the data.
    The trace backend needs to handle trace data at ~1 Mbps to avoid filling up the buffer in the modem. If the modem buffer is full, the modem drops modem traces until the buffer has space available again.
    Ref: https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/libraries/modem/nrf_modem_lib/nrf_modem_lib_trace.html#modem_trace_flash_backend
    Jonathan
  • Update from devz:
    Do they have the Device Tree overlay as given in the nrf91-modem-trace-uart snippet?
    /* Enable uart1 for tracing. */
    &uart1 {
    status = "okay";
    current-speed = < 1000000 >;
    chosen {
    nordic,modem-trace-uart = &uart1;
    If not, modem will likely drop a lot of trace messages because of the uart baud rate. Not sure if that can explain the PCAP being completely blank though. Enabling HWFC would help on loosing traces in the board controller if RTT is enabled, as RTT has priority.
    Jonathan
  • The HWFC is not the issue, enabled or not the difference would be if the trace data is silently dropped or that the dropped data is registered as a dropped event. But the trace data is gone either way.
    This happens if RTT is used and since RTT holdes priority it will take over while the buffer is filled up, if the buffer is full the trace data will be dropped
    Having HWFC enabled does not enable a greater risk of missing traces if RTT is on, though it would be more visible in the binary trace than if HWFC is disabled.
    An alterative route is to use other pins for for UART and use UART to serial and get the data that way. But there can be issues here as baudrate used is 1 000 000.
    Jonathan
  • I don't understand.  We are not using RTT, we are using the UART backend.  It is connected to uart1.  THe behavior seems to be the same with and without HW flow control.
    It seems to be sending data to the host PC since I can observe the serial data line toggling on an oscilloscope. However, the nrfutil trace application reports "0 bytes".
    It was a possible partial explanation on why the data was gone sometimes, if RTT was used it could cause data being dropped.  But since you are not using RTT this is not the likely case. But data would be droppede either way with HWFC on or off. Its just if a response is created or not when the data is dropped.
    Will try to find an explanation for this, but do you have a logic analyzer, or can you check the data that is being transmitted?
    Jonathan
  • Hi Jonathan,
    We re-ran our tests using the Cellular Monitor v2.4.4 application and don't see the issue of the trace files sometimes being empty.  The tests were carried out on the same linux computer used to generate the results detailed earlier. In addition, the same application code was installed on the 9151DK. The results seem to suggest that running the nrfutil trace lte ... command at the linux command line sometime behaves differently than when using the Cellular Monitor application to capture modem traces. Using the Cellular Monitor application is not an option for us because we're doing things in a scripted test automation framework.
    Peter
  • Hi Peter,
    Where do you inspect with the oscilloscope? Between the device and board controller, or between the board controller and computer?
    Do you have access to an external UART to serial bridge to try with (connected where you now have the oscilloscope)?
    Will check with the developers of the tool here and get back to you.
    Jonathan
  • Hi Peter,
    Jonathan
