Modbus init fail
I have tried init modbus RTU on my nRF9160 with SDK2.5.2 using max485 module but i have faced an error.
This is the error:
*** Booting nRF Connect SDK v2.5.2 ***
[00:00:00.253,417] <inf> modbus_test: Starting Program...
[00:00:00.253,448] <inf> modbus_test: Iface name: ZEPHYR_MODBUS_SERIAL
[00:00:00.253,448] <inf> modbus_test: Client iface: 0
[00:00:00.253,479] <err> modbus_serial: Failed to configure UART
[00:00:00.253,479] <err> modbus: Failed to init MODBUS over serial line
[00:00:00.253,509] <err> modbus_test: Modbus RTU client initialization failed
This is my app.overlay
 * Copyright (c) 2024 Your Name
     * Set zephyr,console to uart0, which is the VCOM port on many nRF9160 devkits.
     * This keeps your logging separate from the Modbus communication.
    chosen {
        zephyr,console = &uart0;
 * UART1: Configured for Modbus RTU communication.
 * Pinout matches your original configuration:
 * TX: P0.03
 * RX: P0.05
&uart1 {
    status = "okay";
    current-speed = <9600>; /* Common baud rate for Modbus */
    parity = "even";       /* Common parity for Modbus */
    /* Pin control for active and sleep states */
    pinctrl-0 = <&uart1_default>;
    pinctrl-1 = <&uart1_sleep>;
    modbus0: modbus_serial {
		de-gpios = <&gpio0 2 GPIO_ACTIVE_HIGH>; /* DE control on P0.04 */
		re-gpios = <&gpio0 4 GPIO_ACTIVE_LOW>;  /* RE control on P0.06 */
        compatible = "zephyr,modbus-serial";
        status = "okay";
        label = "ZEPHYR_MODBUS_SERIAL";
 * UART0: Used for console output (logging).
 * This configuration is standard for the nRF9160 DK.
&uart0 {
    status = "okay";
    current-speed = <115200>;
    pinctrl-0 = <&uart0_default>;
    pinctrl-1 = <&uart0_sleep>;
 * Pin control definitions for all peripherals.
&pinctrl {
    /* Active state pins for Modbus UART */
    uart1_default: uart1_default {
        group1 {
            /* TX pin from your original configuration */
            psels = <NRF_PSEL(UART_TX, 0, 3)>;
        group2 {
            /* RX pin from your original configuration */
            psels = <NRF_PSEL(UART_RX, 0, 5)>;
            bias-pull-up; /* Good practice for RX lines */
    /* Sleep state pins for Modbus UART */
    uart1_sleep: uart1_sleep {
        group1 {
            psels = <NRF_PSEL(UART_TX, 0, 3)>,
            low-power-enable;
This is my main.c:
#include <zephyr/kernel.h>
#include <zephyr/sys/util.h>
#include <zephyr/modbus/modbus.h>
LOG_MODULE_REGISTER(modbus_test, LOG_LEVEL_INF);
static int client_iface;
const static struct modbus_iface_param client_param = {
	.mode = MODBUS_MODE_RTU,
	.rx_timeout = 50000,
	.serial =
			.baud = 9600,
			.parity = UART_CFG_PARITY_EVEN,
#define MODBUS_NODE DT_COMPAT_GET_ANY_STATUS_OKAY(zephyr_modbus_serial)
#define SLAVE_ID 1
#define REG_ADDR 0x1132
static int init_modbus_client(void)
	const char *iface_name = DT_LABEL(MODBUS_NODE);
	LOG_INF("Iface name: %s", iface_name);
	client_iface = modbus_iface_get_by_name(iface_name);
    if (client_iface < 0)
        LOG_ERR("Couldn't get client iface");
        return -1;
	LOG_INF("Client iface: %d", client_iface);
	return modbus_init_client(client_iface, client_param);
void main(void)
	uint16_t reg_val;
	int err;
	LOG_INF("Starting Program...");
	if (init_modbus_client() != 0)
		LOG_ERR("Modbus RTU client initialization failed");
		return 0;
	err = modbus_read_holding_regs(client_iface, SLAVE_ID, REG_ADDR, &reg_val, 1);
	if (err != 0)
		LOG_ERR("FC03 failed with %d", err);
		return 0;
		LOG_INF("Reg[4402]=%u", reg_val);
and this is my prj.conf:
#                       FINAL prj.conf
CONFIG_LOG=y
# GPIO
CONFIG_GPIO=y
# UART
CONFIG_SERIAL=y
CONFIG_UART_INTERRUPT_DRIVEN=n
CONFIG_UART_ASYNC_API=y
CONFIG_MODBUS=y
CONFIG_MODBUS_ROLE_CLIENT=y
