Can't enable RTT trace
I need to do some RTT trace logging, but I can’t enable it. I am trying to create minimal example code, and for this purpose I am using the UDP sample.
I added these lines to prj.conf to enable the RTT console:
# Console
CONFIG_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=4096
And these lines to enable trace:
# Enable trace
CONFIG_NRF_MODEM_LIB_TRACE=y
CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_RTT=y
The console is working, but the trace is not being captured. What could be the problem?
To start the trace capture, I am using the following command:
nrfjprog --reset && JLinkRTTLogger -Device NRF9160_XXAA -If SWD -Speed 50000 modemtraces.bin
And I get the output
@Eizenss-Mac-mini udp % nrfjprog --reset && JLinkRTTLogger -Device NRF9160_XXAA -If SWD -Speed 50000 modemtraces.bin
Applying system reset.
Run.
SEGGER J-Link RTT Logger
Compiled Jun 4 2025 12:16:00
(c) 2016-2017 SEGGER Microcontroller GmbH, www.segger.com
Solutions for real time microcontroller applications
Default logfile path: /Users/eizenspoiss/Library/Application Support/SEGGER
Shutting down... Done.%
Test setup:
  • nRF9160 DK
  • macOS
  • SDK version 2.5.0
PS:
I used this ticket as guide
https://devzone.nordicsemi.com/f/nordic-q-a/104983/how-to-capture-nrf9160-modem-traces-using-rtt
