We are experiencing a weird issue on our custom boards which have a nrf9151 chip
We are using emnify sims and have experienced the following:
- On some boards, when connecting to specific networks, the device starts up for 10-20 seconds before restarting in a loop indefinitely. This is before network connection is established.
- This is only happening on select boards and select networks. ie, we can ban AT&T and force the device to connect to t-mobile which fixes the issue (at least where we are in the short term).
- The issue seems to affect by location (ie boards work perfectly at the office, but don't out in the field).
- If I block the AT&T network, after it has been looping, we often get into the 30min lockout.
I have added three traces below. They are:
- Trace1 is AT&T on a board that is not having issues (as far as we are aware). This operates as expected.
- Trace2 is same sim on a board which is having issues - it gets in a bad device resetting loop
- Trace3 is putting it back into a good board but there is a modem reset loop lockout
I have also added a log of the resetting behaviour with modem logs enabled.
Any suggestions / advice would be appreciated.
Trace1.binTrace2.binTrace3.bin
# SEGGER J-Link RTT Viewer V8.12d Terminal Log File # Compiled: 13:08:01 on Jan 29 2025 # Logging started @ 10 Aug 2025 19:54:29 00> 00> [00:00:00.253,479] <inf> buzzer: Initializing buzzer 00> [00:00:00.253,540] <inf> ems: Initializing ADC 00> [00:00:00.253,570] <inf> ems: ADC initialized successfully 00> [00:00:00.253,601] <inf> ems: Initializing EMS Controller 00> [00:00:00.253,814] <err> bat_mon: Fuel gauge device not ready 00> [00:00:00.253,906] <inf> mflt: Reset Reason, RESETREAS=0x10001 00> [00:00:00.253,936] <inf> mflt: Reset Causes: 00> [00:00:00.253,967] <inf> mflt: Pin Reset 00> [00:00:00.255,157] <inf> mflt: GNU Build ID: 5100eb0e7637ca1ccf989d825cd93b00d566cdd3 00> [00:00:00.256,530] <inf> spi_nor: mx25r6435f@0: 8 MiBy flash 00> [00:00:00.259,429] <inf> quectel_lcx6g: Resuming 00> [00:00:01.261,016] <inf> quectel_lcx6g: GNSS firmware version: LC76GPANR12A04S 00> [00:00:15.202,545] <dbg> nrf_modem: +CEREG: 2,"3801","00DB0603",7 00> [00:00:15.202,758] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"3801","00DB0603",7 00> [00:00:15.202,789] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:15.202,850] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"3801","00DB0603",7 00> [00:00:15.202,911] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:15.203,033] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:15.203,063] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=0 00> [00:00:15.203,063] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.203,125] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.203,125] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.203,155] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.203,216] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.203,216] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.203,247] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=4 00> [00:00:15.203,247] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.203,277] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.203,277] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.203,277] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.203,338] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.203,338] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.203,369] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=5 00> [00:00:15.203,369] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.203,369] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.203,399] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.203,399] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.203,430] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.203,460] <inf> comms: LTE event: 5 00> [00:00:15.203,460] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.227,600] <dbg> nrf_modem: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:15.227,783] <dbg> at_monitor: at_monitor_task: AT notif: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:15.227,813] <dbg> at_monitor: at_monitor_task: Dispatching to 0x43539 00> [00:00:15.227,844] <dbg> lte_lc: at_handler_mdmev: %MDMEV notification 00> [00:00:15.227,874] <dbg> lte_lc: mdmev_parse: Occurrence found: PRACH CE-LEVEL 0 00> 00> [00:00:15.227,905] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=11 00> [00:00:15.227,905] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.227,935] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.227,935] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.227,935] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.227,966] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.227,996] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.298,095] <dbg> nrf_modem: +CSCON: 1 00> [00:00:15.298,248] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 1 00> [00:00:15.298,278] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:15.298,309] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:15.298,370] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:15.298,370] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.298,370] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.298,400] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.298,400] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.298,431] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.298,461] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.606,292] <dbg> nrf_modem: +CEREG: 2,"3801","00DB0603",7,0,11 00> [00:00:15.606,506] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"3801","00DB0603",7,0,11 00> [00:00:15.606,536] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:15.606,597] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"3801","00DB0603",7,0,11 00> [00:00:15.606,658] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:15.606,811] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:15.606,872] <wrn> lte_lc: Registration rejected, EMM cause: 11, Cell ID: 14353923, Tracking area: 14337, LTE mode: 7 00> [00:00:15.627,563] <dbg> nrf_modem: +CSCON: 0 00> [00:00:15.627,777] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 0 00> [00:00:15.627,807] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:15.627,838] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:15.627,899] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:15.627,899] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.627,929] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.627,929] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.627,929] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.627,960] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.627,960] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.770,904] <dbg> nrf_modem: +CEREG: 2,"55F5","02056306",7 00> [00:00:15.771,118] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"55F5","02056306",7 00> [00:00:15.771,118] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:15.771,179] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"55F5","02056306",7 00> [00:00:15.771,240] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:15.771,392] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:15.771,423] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=4 00> [00:00:15.771,423] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.771,423] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.771,453] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.771,484] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.771,514] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.771,514] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.795,318] <dbg> nrf_modem: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:15.795,501] <dbg> at_monitor: at_monitor_task: AT notif: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:15.795,532] <dbg> at_monitor: at_monitor_task: Dispatching to 0x43539 00> [00:00:15.795,562] <dbg> lte_lc: at_handler_mdmev: %MDMEV notification 00> [00:00:15.795,593] <dbg> lte_lc: mdmev_parse: Occurrence found: PRACH CE-LEVEL 0 00> 00> [00:00:15.795,623] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=11 00> [00:00:15.795,623] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.795,654] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.795,654] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.795,654] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.795,684] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.795,715] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.831,481] <dbg> nrf_modem: +CSCON: 1 00> [00:00:15.831,665] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 1 00> [00:00:15.831,695] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:15.831,695] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:15.831,756] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:15.831,787] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.831,787] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.831,787] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.831,817] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.831,817] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.831,848] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:16.861,328] <dbg> nrf_modem: +CEREG: 2,"55F5","02056306",7,0,11 00> [00:00:16.861,541] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"55F5","02056306",7,0,11 00> [00:00:16.861,572] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:16.861,633] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"55F5","02056306",7,0,11 00> [00:00:16.861,694] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:16.861,846] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:16.861,907] <wrn> lte_lc: Registration rejected, EMM cause: 11, Cell ID: 33907462, Tracking area: 22005, LTE mode: 7 00> [00:00:16.889,587] <dbg> nrf_modem: +CSCON: 0 00> [00:00:16.889,770] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 0 00> [00:00:16.889,801] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:16.889,831] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:16.889,892] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:16.889,892] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:16.889,892] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:16.889,923] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:16.889,923] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:16.889,953] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:16.889,953] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:21.269,226] <wrn> modem_chat: get_easy_status_script: timed out 00> [00:00:21.269,317] <err> quectel_lcx6g: Failed to run get_easy_status_script 00> [00:00:21.269,317] <inf> gnss: GNSS Easy status: enabled=0, status=0 00> [00:00:41.269,561] <wrn> modem_chat: get_easy_status_script: timed out 00> [00:00:41.269,653] <err> quectel_lcx6g: Failed to run get_easy_status_script 00> [00:00:41.269,653] <inf> gnss: GNSS Easy status: enabled=0, status=0 00> [00:01:01.269,897] <wrn> modem_chat: get_easy_status_script: timed out 00> [00:01:01.269,989] <err> quectel_lcx6g: Failed to run get_easy_status_script 00> [00:01:01.269,989] <inf> gnss: GNSS Easy status: enabled=0, status=0 00> [00:01:05.767,089] <dbg> nrf_modem: +CEREG: 2,"041C","00F33D10",7 00> [00:01:05.767,303] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"041C","00F33D10",7 00> [00:01:05.767,333] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:01:05.767,364] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"041C","00F33D10",7 00> [00:01:05.767,425] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:01:05.767,578] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:01:05.767,608] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=4 00> [00:01:05.767,608] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:01:05.767,608] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:01:05.767,639] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:01:05.767,669] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:01:05.767,700] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:01:05.767,700] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:01:09.640,319] <dbg> nrf_modem: %MDMEV: PRACH CE-LEVEL 0 00> [00:01:09.640,563] <dbg> at_monitor: at_monitor_task: AT notif: %MDMEV: PRACH CE-LEVEL 0 00> [00:01:09.640,594] <dbg> at_monitor: at_monitor_task: Dispatching to 0x43539 00> [00:01:09.640,625] <dbg> lte_lc: at_handler_mdmev: %MDMEV notification 00> [00:01:09.640,655] <dbg> lte_lc: mdmev_parse: Occurrence found: PRACH CE-LEVEL 0 00> 00> [00:01:09.640,686] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=11 00> [00:01:09.640,686] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:01:09.640,686] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:01:09.640,716] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:01:09.640,716] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:01:09.640,747] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:01:09.640,777] <dbg> lte_lc: event_handler_list_dispatch: Done 00> 00> [00:00:00.253,509] <inf> buzzer: Initializing buzzer 00> [00:00:00.253,570] <inf> ems: Initializing ADC 00> [00:00:00.253,601] <inf> ems: ADC initialized successfully 00> [00:00:00.253,601] <inf> ems: Initializing EMS Controller 00> [00:00:00.253,845] <err> bat_mon: Fuel gauge device not ready 00> [00:00:00.253,906] <inf> mflt: Reset Reason, RESETREAS=0x0 00> [00:00:00.253,967] <inf> mflt: Reset Causes: 00> [00:00:00.253,997] <inf> mflt: Power on Reset 00> [00:00:00.255,157] <inf> mflt: GNU Build ID: 5100eb0e7637ca1ccf989d825cd93b00d566cdd3 00> [00:00:00.256,530] <inf> spi_nor: mx25r6435f@0: 8 MiBy flash 00> [00:00:00.259,429] <inf> quectel_lcx6g: Resuming 00> [00:00:01.260,955] <inf> quectel_lcx6g: GNSS firmware version: LC76GPANR12A04S 00> [00:00:13.675,109] <dbg> nrf_modem: +CEREG: 2,"3801","00DB0603",7 00> [00:00:13.675,323] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"3801","00DB0603",7 00> [00:00:13.675,354] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:13.675,384] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"3801","00DB0603",7 00> [00:00:13.675,445] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:13.675,598] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:13.675,628] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=0 00> [00:00:13.675,628] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:13.675,689] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:13.675,689] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:13.675,720] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:13.675,750] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:13.675,781] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:13.675,842] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=4 00> [00:00:13.675,842] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:13.675,872] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:13.675,872] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:13.675,903] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:13.675,933] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:13.675,933] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:13.675,964] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=5 00> [00:00:13.675,964] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:13.675,994] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:13.675,994] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:13.676,025] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:13.676,025] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:13.676,055] <inf> comms: LTE event: 5 00> [00:00:13.676,055] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:13.701,141] <dbg> nrf_modem: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:13.701,354] <dbg> at_monitor: at_monitor_task: AT notif: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:13.701,385] <dbg> at_monitor: at_monitor_task: Dispatching to 0x43539 00> [00:00:13.701,416] <dbg> lte_lc: at_handler_mdmev: %MDMEV notification 00> [00:00:13.701,446] <dbg> lte_lc: mdmev_parse: Occurrence found: PRACH CE-LEVEL 0 00> 00> [00:00:13.701,477] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=11 00> [00:00:13.701,477] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:13.701,477] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:13.701,507] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:13.701,507] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:13.701,538] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:13.701,568] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:13.774,536] <dbg> nrf_modem: +CSCON: 1 00> [00:00:13.774,719] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 1 00> [00:00:13.774,749] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:13.774,780] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:13.774,810] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:13.774,841] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:13.774,841] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:13.774,871] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:13.774,871] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:13.774,902] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:13.774,932] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:14.193,847] <dbg> nrf_modem: +CEREG: 2,"3801","00DB0603",7,0,11 00> [00:00:14.194,061] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"3801","00DB0603",7,0,11 00> [00:00:14.194,061] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:14.194,122] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"3801","00DB0603",7,0,11 00> [00:00:14.194,183] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:14.194,335] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:14.194,396] <wrn> lte_lc: Registration rejected, EMM cause: 11, Cell ID: 14353923, Tracking area: 14337, LTE mode: 7 00> [00:00:14.267,181] <dbg> nrf_modem: +CSCON: 0 00> [00:00:14.267,333] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 0 00> [00:00:14.267,364] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:14.267,395] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:14.267,456] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:14.267,456] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:14.267,486] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:14.267,486] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:14.267,486] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:14.267,517] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:14.267,517] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:14.403,442] <dbg> nrf_modem: +CEREG: 2,"55F5","02056306",7 00> [00:00:14.403,656] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"55F5","02056306",7 00> [00:00:14.403,686] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:14.403,747] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"55F5","02056306",7 00> [00:00:14.403,808] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:14.403,930] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:14.403,961] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=4 00> [00:00:14.403,961] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:14.403,991] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:14.403,991] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:14.404,022] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:14.404,052] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:14.404,083] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:14.428,253] <dbg> nrf_modem: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:14.428,466] <dbg> at_monitor: at_monitor_task: AT notif: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:14.428,497] <dbg> at_monitor: at_monitor_task: Dispatching to 0x43539 00> [00:00:14.428,497] <dbg> lte_lc: at_handler_mdmev: %MDMEV notification 00> [00:00:14.428,558] <dbg> lte_lc: mdmev_parse: Occurrence found: PRACH CE-LEVEL 0 00> 00> [00:00:14.428,558] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=11 00> [00:00:14.428,588] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:14.428,588] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:14.428,588] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:14.428,619] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:14.428,649] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:14.428,649] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:14.463,043] <dbg> nrf_modem: +CSCON: 1 00> [00:00:14.463,226] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 1 00> [00:00:14.463,256] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:14.463,256] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:14.463,317] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:14.463,348] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:14.463,348] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:14.463,378] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:14.463,378] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:14.463,378] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:14.463,409] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.420,074] <dbg> nrf_modem: +CEREG: 2,"55F5","02056306",7,0,11 00> [00:00:15.420,257] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"55F5","02056306",7,0,11 00> [00:00:15.420,288] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:15.420,349] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"55F5","02056306",7,0,11 00> [00:00:15.420,410] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:15.420,562] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:15.420,623] <wrn> lte_lc: Registration rejected, EMM cause: 11, Cell ID: 33907462, Tracking area: 22005, LTE mode: 7 00> [00:00:15.443,176] <dbg> nrf_modem: +CSCON: 0 00> [00:00:15.443,328] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 0 00> [00:00:15.443,359] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:15.443,389] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:15.443,450] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:15.443,481] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.443,481] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.443,481] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.443,511] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.443,511] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.443,542] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:21.269,165] <wrn> modem_chat: get_easy_status_script: timed out 00> [00:00:21.269,256] <err> quectel_lcx6g: Failed to run get_easy_status_script 00> [00:00:21.269,256] <inf> gnss: GNSS Easy status: enabled=0, status=0 00> [00:00:41.269,500] <wrn> modem_chat: get_easy_status_script: timed out 00> [00:00:41.269,592] <err> quectel_lcx6g: Failed to run get_easy_status_script 00> [00:00:41.269,592] <inf> gnss: GNSS Easy status: enabled=0, status=0 00> [00:01:01.269,836] <wrn> modem_chat: get_easy_status_script: timed out 00> [00:01:01.269,927] <err> quectel_lcx6g: Failed to run get_easy_status_script 00> [00:01:01.269,927] <inf> gnss: GNSS Easy status: enabled=0, status=0 00> [00:01:05.205,047] <dbg> nrf_modem: +CEREG: 2,"041C","00F3070F",7 00> [00:01:05.205,230] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"041C","00F3070F",7 00> [00:01:05.205,261] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:01:05.205,322] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"041C","00F3070F",7 00> [00:01:05.205,383] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:01:05.205,505] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:01:05.205,535] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=4 00> [00:01:05.205,535] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:01:05.205,566] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:01:05.205,566] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:01:05.205,596] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:01:05.205,627] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:01:05.205,657] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:01:05.872,863] <dbg> nrf_modem: %MDMEV: PRACH CE-LEVEL 0 00> [00:01:05.873,077] <dbg> at_monitor: at_monitor_task: AT notif: %MDMEV: PRACH CE-LEVEL 0 00> [00:01:05.873,107] <dbg> at_monitor: at_monitor_task: Dispatching to 0x43539 00> [00:01:05.873,138] <dbg> lte_lc: at_handler_mdmev: %MDMEV notification 00> [00:01:05.873,168] <dbg> lte_lc: mdmev_parse: Occurrence found: PRACH CE-LEVEL 0 00> 00> [00:01:05.873,199] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=11 00> [00:01:05.873,199] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:01:05.873,199] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:01:05.873,229] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:01:05.873,229] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:01:05.873,260] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:01:05.873,291] <dbg> lte_lc: event_handler_list_dispatch: Done 00> 00> [00:00:00.253,540] <inf> buzzer: Initializing buzzer 00> [00:00:00.253,601] <inf> ems: Initializing ADC 00> [00:00:00.253,631] <inf> ems: ADC initialized successfully 00> [00:00:00.253,631] <inf> ems: Initializing EMS Controller 00> [00:00:00.253,875] <err> bat_mon: Fuel gauge device not ready 00> [00:00:00.253,936] <inf> mflt: Reset Reason, RESETREAS=0x0 00> [00:00:00.253,997] <inf> mflt: Reset Causes: 00> [00:00:00.254,028] <inf> mflt: Power on Reset 00> [00:00:00.255,187] <inf> mflt: GNU Build ID: 5100eb0e7637ca1ccf989d825cd93b00d566cdd3 00> [00:00:00.256,622] <inf> spi_nor: mx25r6435f@0: 8 MiBy flash 00> [00:00:00.259,490] <inf> quectel_lcx6g: Resuming 00> [00:00:01.260,955] <inf> quectel_lcx6g: GNSS firmware version: LC76GPANR12A04S 00> [00:00:15.518,066] <dbg> nrf_modem: +CEREG: 2,"3801","00DB0603",7 00> [00:00:15.518,249] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"3801","00DB0603",7 00> [00:00:15.518,280] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:15.518,341] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"3801","00DB0603",7 00> [00:00:15.518,402] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:15.518,524] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:15.518,554] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=0 00> [00:00:15.518,554] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.518,615] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.518,646] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.518,676] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.518,707] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.518,707] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.518,737] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=4 00> [00:00:15.518,737] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.518,768] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.518,768] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.518,798] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.518,829] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.518,829] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.518,859] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=5 00> [00:00:15.518,859] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.518,890] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.518,890] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.518,890] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.518,920] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.518,951] <inf> comms: LTE event: 5 00> [00:00:15.518,951] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.539,093] <dbg> nrf_modem: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:15.539,276] <dbg> at_monitor: at_monitor_task: AT notif: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:15.539,306] <dbg> at_monitor: at_monitor_task: Dispatching to 0x43539 00> [00:00:15.539,337] <dbg> lte_lc: at_handler_mdmev: %MDMEV notification 00> [00:00:15.539,367] <dbg> lte_lc: mdmev_parse: Occurrence found: PRACH CE-LEVEL 0 00> 00> [00:00:15.539,398] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=11 00> [00:00:15.539,398] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.539,428] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.539,428] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.539,459] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.539,489] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.539,489] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.593,566] <dbg> nrf_modem: +CSCON: 1 00> [00:00:15.593,750] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 1 00> [00:00:15.593,780] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:15.593,811] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:15.593,841] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:15.593,872] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.593,872] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.593,902] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.593,902] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.593,933] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.593,963] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:15.901,794] <dbg> nrf_modem: +CEREG: 2,"3801","00DB0603",7,0,11 00> [00:00:15.902,008] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"3801","00DB0603",7,0,11 00> [00:00:15.902,008] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:15.902,069] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"3801","00DB0603",7,0,11 00> [00:00:15.902,130] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:15.902,282] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:15.902,343] <wrn> lte_lc: Registration rejected, EMM cause: 11, Cell ID: 14353923, Tracking area: 14337, LTE mode: 7 00> [00:00:15.997,100] <dbg> nrf_modem: +CSCON: 0 00> [00:00:15.997,253] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 0 00> [00:00:15.997,283] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:15.997,314] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:15.997,375] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:15.997,406] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:15.997,406] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:15.997,406] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:15.997,436] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:15.997,436] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:15.997,467] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:16.086,364] <dbg> nrf_modem: +CEREG: 2,"55F5","02056306",7 00> [00:00:16.086,578] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"55F5","02056306",7 00> [00:00:16.086,608] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:16.086,669] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"55F5","02056306",7 00> [00:00:16.086,730] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:16.086,853] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:16.086,883] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=4 00> [00:00:16.086,883] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:16.086,914] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:16.086,914] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:16.086,944] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:16.086,975] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:16.087,005] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:16.111,175] <dbg> nrf_modem: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:16.111,358] <dbg> at_monitor: at_monitor_task: AT notif: %MDMEV: PRACH CE-LEVEL 0 00> [00:00:16.111,389] <dbg> at_monitor: at_monitor_task: Dispatching to 0x43539 00> [00:00:16.111,419] <dbg> lte_lc: at_handler_mdmev: %MDMEV notification 00> [00:00:16.111,450] <dbg> lte_lc: mdmev_parse: Occurrence found: PRACH CE-LEVEL 0 00> 00> [00:00:16.111,480] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=11 00> [00:00:16.111,480] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:16.111,511] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:16.111,511] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:16.111,511] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:16.111,541] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:16.111,572] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:16.145,965] <dbg> nrf_modem: +CSCON: 1 00> [00:00:16.146,148] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 1 00> [00:00:16.146,179] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:16.146,209] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:16.146,240] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:16.146,270] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:16.146,270] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:16.146,301] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:16.146,301] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:16.146,331] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:16.146,362] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:17.238,739] <dbg> nrf_modem: +CEREG: 2,"55F5","02056306",7,0,11 00> [00:00:17.238,922] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"55F5","02056306",7,0,11 00> [00:00:17.238,952] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:00:17.239,013] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"55F5","02056306",7,0,11 00> [00:00:17.239,074] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:00:17.239,227] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:00:17.239,288] <wrn> lte_lc: Registration rejected, EMM cause: 11, Cell ID: 33907462, Tracking area: 22005, LTE mode: 7 00> [00:00:17.285,491] <dbg> nrf_modem: +CSCON: 0 00> [00:00:17.285,644] <dbg> at_monitor: at_monitor_task: AT notif: +CSCON: 0 00> [00:00:17.285,675] <dbg> at_monitor: at_monitor_task: Dispatching to 0x4338d 00> [00:00:17.285,705] <dbg> lte_lc: at_handler_cscon: +CSCON notification 00> [00:00:17.285,766] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=3 00> [00:00:17.285,766] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:00:17.285,797] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:00:17.285,797] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:00:17.285,797] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:00:17.285,827] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:00:17.285,827] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:00:21.269,165] <wrn> modem_chat: get_easy_status_script: timed out 00> [00:00:21.269,256] <err> quectel_lcx6g: Failed to run get_easy_status_script 00> [00:00:21.269,256] <inf> gnss: GNSS Easy status: enabled=0, status=0 00> [00:00:41.269,500] <wrn> modem_chat: get_easy_status_script: timed out 00> [00:00:41.269,592] <err> quectel_lcx6g: Failed to run get_easy_status_script 00> [00:00:41.269,592] <inf> gnss: GNSS Easy status: enabled=0, status=0 00> [00:01:01.269,836] <wrn> modem_chat: get_easy_status_script: timed out 00> [00:01:01.269,927] <err> quectel_lcx6g: Failed to run get_easy_status_script 00> [00:01:01.269,927] <inf> gnss: GNSS Easy status: enabled=0, status=0 00> [00:01:06.402,557] <dbg> nrf_modem: +CEREG: 2,"041C","00F33D10",7 00> [00:01:06.402,770] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 2,"041C","00F33D10",7 00> [00:01:06.402,801] <dbg> at_monitor: at_monitor_task: Dispatching to 0x42ab9 00> [00:01:06.402,862] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"041C","00F33D10",7 00> [00:01:06.402,923] <dbg> lte_lc: parse_cereg: Network registration status: 2 00> [00:01:06.403,045] <dbg> lte_lc: parse_cereg: LTE mode: 7 00> [00:01:06.403,076] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=4 00> [00:01:06.403,076] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:01:06.403,106] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:01:06.403,106] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:01:06.403,137] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:01:06.403,167] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:01:06.403,198] <dbg> lte_lc: event_handler_list_dispatch: Done 00> [00:01:10.266,784] <dbg> nrf_modem: Service has port: 443 00> [00:01:10.266,876] <inf> nrf_modem: getaddrinfo() fam: 0x1, type 0x1, proto 0x6 00> [00:01:10.273,101] <inf> nrf_modem: RPC_IP_GETADDRINFO_RES, result RPC_IP_ERR_NO_ROUTE 00> [00:01:10.273,284] <err> mflt: DNS lookup for chunks-nrf.memfault.com failed: -11 00> [00:01:10.915,832] <dbg> nrf_modem: %MDMEV: PRACH CE-LEVEL 0 00> [00:01:10.916,015] <dbg> at_monitor: at_monitor_task: AT notif: %MDMEV: PRACH CE-LEVEL 0 00> [00:01:10.916,046] <dbg> at_monitor: at_monitor_task: Dispatching to 0x43539 00> [00:01:10.916,076] <dbg> lte_lc: at_handler_mdmev: %MDMEV notification 00> [00:01:10.916,107] <dbg> lte_lc: mdmev_parse: Occurrence found: PRACH CE-LEVEL 0 00> 00> [00:01:10.916,137] <dbg> lte_lc: event_handler_list_dispatch: Dispatching event: type=11 00> [00:01:10.916,137] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004FA71 00> [00:01:10.916,137] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0001CB15 00> [00:01:10.916,168] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x00045AB9 00> [00:01:10.916,168] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x0004BDF9 00> [00:01:10.916,198] <dbg> lte_lc: event_handler_list_dispatch: - handler=0x000221F9 00> [00:01:10.916,229] <dbg> lte_lc: event_handler_list_dispatch: Done (Connection lost) # Logging stopped @ 10 Aug 2025 19:59:20
