Matter Time sync cluster
Application: Matter product using nRF54L15, SDK 3.0.0
Ecosystem: Matter product joins Apple HomePod
I am not able to get  time/date delivered  via Matter to the product.
1.  Time Sync Cluster has been enabled using ZAP tool. Server is checked off.
2. FeatureMap bit map: Bit 0=1, Server supports time Zone, NTPC: server supports NTP client,  TSC: Time Sync client cluster is present.
3. To read time,  the below has been added.
    System::Clock::Microseconds64 utcTime;
    auto chipError = System::SystemClock().GetClock_RealTime(utcTime);
    if(chipError == CHIP_NO_ERROR)
        printk("Read  time=%lld \n", utcTime.count());
    else printk("Not able to read time: chipError=%s \n", chipError.AsString());
4. Generate ZAP files,  and build.
5. When executed, I get  the error:
Read Calendar and Time Info ---->Not able to read time: chipError=Error CHIP:0x00000003
Not able to read time; Chip Error=3
Please let me know what is not correct.  Do we have any documentation or sample code?
Thanks in advance.
Subu
  • Addition info, after further investigation and testing.
    1. The matter end node (our product) get the time at the time of commissioning. I do not get the error CHIP:0x00000003, and the time returned by System::SystemClock().GetClock_RealTime(utcTime) is good.
    2. if  the end node is power cycled/rebooted, the end node does not get the time from Apple ecosystem. It looks like  either the commissioner or Apple controller is sending the time as part of or after commissioning.
    Unfortunately, we do not  have a RTC in our product and we want to get the time after the matter end node rejoins the network. Please provide a solution or recommendation. I  have explored the below:
    1. Get the time from  Thread network using otNetworkTimeGet(utcTime)
    #include <openthread/network_time.h>
    otInstance *instance = chip::DeviceLayer::ThreadStackMgrImpl().OTInstance();
    uint64_t aNetworkTime;
    otNetworkTimeStatus status = otNetworkTimeGet(instance, &aNetworkTime);
    However, the build produces the error "undefined reference to `otNetworkTimeGet'".  What is needed to enable this? The .h file is accessible but not the source code. Tried CONFIG_OPENTHREAD_TIME_SYNC=y without success.
    2. What are the other options? Is it possible to use SNTP or SD-DNS  or query the time servers in the network from  the Thread end device?
    3. Is it possible to force the matter controller write the time after connected?
    Thanks.
    Subu
  • Hi Subu,
    You are correct that the time is sent from the commissioner to the device during commissioning.
    If the border router supports the NTPClient feature, the device should do a time synchronization after restart using NTP. Since this is not happening in your case, it seems like this feature is not supported by the border router. In that case, you can either perform time synchronization using a trusted time source or implement an NTP mechanism in the application.
    For the trusted time source, this would be done by sending the SetTrustedTimeSource command to the device to configure another node in the network as the trusted time source. Upon a reboot, the device will automatically ask the trusted time source for the UTC time. However, I don't know how this can be done with Apple Home.
    For the NTP approach, you can implement a mechanism where your device tries to obtain the time from an NTP server through IP, for example, from the border router, and save it as "local time".
    I recommend reading chapter 11.17 Time Syncrhonization Cluster in the Matter core specification, especially from 11.17.12 and out, as this provides information on how to do time sync during operation, time sync maintenance, and implementation guidance.
    Which version of the nRF Connect SDK are you using, and are you using a sample? I tested your code in the template and door lock samples in nRF Connect SDK v3.0.2, and both built successfully without any undefined reference errors.
    Marte
  • Hi Marte, Thanks for the answers,  I am using nRF Connect SDK v3.0.0. and it throws undefined reference to `otNetworkTimeGet'. Thanks,
    Can you share the complete build log when doing a pristine build and the generated .config file (build/<app_name>/zephyr/.config)?
    I tried with v3.0.0, but I don't get undefined reference there either.
    Marte
  • HI , please see below:
    CONFIG_LOCK_MAX_NUM_USERS=50
    CONFIG_LOCK_MAX_NUM_CREDENTIALS_PER_USER=2
    CONFIG_LOCK_MAX_NUM_CREDENTIALS_PER_TYPE=25
    CONFIG_LOCK_MAX_CREDENTIAL_LENGTH=10
    # CONFIG_LOCK_PASS_CREDENTIALS_TO_SET_LOCK_STATE is not set
    CONFIG_LOCK_SCHEDULES=y
    CONFIG_LOCK_MAX_WEEKDAY_SCHEDULES_PER_USER=5
    CONFIG_LOCK_MAX_YEARDAY_SCHEDULES_PER_USER=5
    CONFIG_LOCK_MAX_HOLIDAY_SCHEDULES=5
    CONFIG_LOCK_ENABLE_DEBUG=y
    CONFIG_LOCK_PRINT_STORAGE_STATUS=y
    CONFIG_SHELL_CMD_BUFF_SIZE=300
    CONFIG_STATE_LEDS=y
    CONFIG_CHIP_ENABLE_ICD_SUPPORT=y
    CONFIG_OPENTHREAD_DEFAULT_TX_POWER=0
    CONFIG_NCS_SAMPLE_MATTER_PERSISTENT_STORAGE=y
    CONFIG_NCS_SAMPLE_MATTER_SECURE_STORAGE_BACKEND=y
    CONFIG_NCS_SAMPLE_MATTER_SETTINGS_STORAGE_BACKEND=y
    CONFIG_NCS_SAMPLE_MATTER_SECURE_STORAGE_MAX_ENTRY_NUMBER=64
    CONFIG_TRUSTED_STORAGE_BACKEND_AEAD_MAX_DATA_SIZE=2048
    CONFIG_OPENTHREAD_THREAD_STACK_SIZE=7168
    CONFIG_CHIP_TASK_STACK_SIZE=10240
    CONFIG_MAIN_STACK_SIZE=9600
    # CONFIG_CHIP_WIFI is not set
    # CONFIG_CHIP_QSPI_NOR is not set
    CONFIG_CHIP_SPI_NOR=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_CHIP_MEMORY_PROFILING is not set
    # CONFIG_CHIP_NUS is not set
    CONFIG_BT_BONDABLE=y
    CONFIG_BT_RX_STACK_SIZE=4096
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_BT_DEVICE_APPEARANCE=0
    # CONFIG_BT_FIXED_PASSKEY is not set
    CONFIG_CHIP_DFU_OVER_BT_SMP=y
    CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT=6
    CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS=y
    CONFIG_MCUMGR_GRP_IMG_UPLOAD_CHECK_HOOK=y
    CONFIG_MCUMGR_SMP_COMMAND_STATUS_HOOKS=y
    CONFIG_BT_L2CAP_TX_MTU=512
    CONFIG_BT_BUF_ACL_RX_SIZE=502
    CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=1024
    CONFIG_MCUMGR_GRP_ZBASIC=y
    CONFIG_MCUMGR_GRP_ZBASIC_STORAGE_ERASE=y
    # CONFIG_CHIP_LAST_FABRIC_REMOVED_NONE is not set
    # CONFIG_CHIP_LAST_FABRIC_REMOVED_ERASE_AND_REBOOT is not set
    # CONFIG_CHIP_LAST_FABRIC_REMOVED_ERASE_AND_PAIRING_START is not set
    CONFIG_CHIP_LAST_FABRIC_REMOVED_ERASE_ONLY=y
    CONFIG_CHIP_LAST_FABRIC_REMOVED_ACTION_DELAY=1000
    CONFIG_ASSERT=y
    CONFIG_ASSERT_NO_COND_INFO=y
    CONFIG_ASSERT_NO_MSG_INFO=y
    CONFIG_HW_STACK_PROTECTION=y
    CONFIG_POSIX_MAX_FDS=16
    CONFIG_INIT_STACKS=y
    CONFIG_HEAP_MEM_POOL_SIZE=0
    # CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
    CONFIG_CHIP_MALLOC_SYS_HEAP_SIZE=10240
    CONFIG_MPSL_WORK_STACK_SIZE=2048
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_ZMS_LOOKUP_CACHE_SIZE=512
    CONFIG_DYNAMIC_INTERRUPTS=y
    CONFIG_DYNAMIC_DIRECT_INTERRUPTS=y
    CONFIG_MPSL_DYNAMIC_INTERRUPTS=y
    CONFIG_NET_IPV6_MLD=y
    # CONFIG_NET_IPV6_NBR_CACHE is not set
    CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=6
    CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=14
    CONFIG_NET_IF_IPV6_PREFIX_COUNT=2
    CONFIG_NET_PKT_RX_COUNT=8
    CONFIG_NET_PKT_TX_COUNT=8
    CONFIG_NET_BUF_RX_COUNT=16
    CONFIG_NET_BUF_TX_COUNT=16
    CONFIG_NET_SOCKETS_POLL_MAX=0
    CONFIG_BT=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=36
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=36
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=500
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=1000
    CONFIG_BT_GATT_DYNAMIC_DB=y
    CONFIG_BT_DEVICE_NAME_DYNAMIC=y
    CONFIG_BT_DEVICE_NAME_MAX=15
    CONFIG_BT_MAX_CONN=3
    CONFIG_BT_BUF_ACL_TX_SIZE=502
    CONFIG_BT_BUF_ACL_RX_COUNT_EXTRA=4
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    # CONFIG_BT_CTLR_LE_ENC is not set
    # CONFIG_BT_DEVICE_NAME_GATT_WRITABLE is not set
    # CONFIG_BT_GATT_CACHING is not set
    # CONFIG_BT_CTLR_PHY_2M is not set
    CONFIG_CHIP_NFC_COMMISSIONING=y
    # CONFIG_NFC_THREAD_CALLBACK is not set
    CONFIG_CHIP_OTA_REQUESTOR=y
    # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    CONFIG_DFU_MULTI_IMAGE_MAX_IMAGE_COUNT=2
    CONFIG_NET_L2_OPENTHREAD=y
    CONFIG_IEEE802154_NRF5_RX_STACK_SIZE=1024
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_HEAP_SIZE=8192
    CONFIG_CHIP_CRYPTO_PSA=y
    # CONFIG_PSA_CRYPTO_DRIVER_OBERON is not set
    CONFIG_PSA_CRYPTO_DRIVER_CRACEN=y
    CONFIG_PSA_WANT_ALG_SHA_224=y
    CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT=64
    # CONFIG_NRF_SECURITY_ADVANCED is not set
    # CONFIG_MBEDTLS_MD_C is not set
    # CONFIG_MBEDTLS_PK_C is not set
    CONFIG_MBEDTLS_AES_ONLY_128_BIT_KEY_LENGTH=y
    CONFIG_LOG=y
    CONFIG_CHIP_APP_LOG_LEVEL=5
    CONFIG_LOG_DEFAULT_LEVEL=1
    CONFIG_CHIP_LOG_SIZE_OPTIMIZATION=y
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_SHELL=y
    CONFIG_SHELL_STACK_SIZE=2048
    CONFIG_SHELL_MINIMAL=y
    # CONFIG_KERNEL_SHELL is not set
    # CONFIG_SHELL_WILDCARD is not set
    # CONFIG_SENSOR_SHELL is not set
    # CONFIG_DEVICE_SHELL is not set
    # CONFIG_DEVMEM_SHELL is not set
    # CONFIG_MCUBOOT_SHELL is not set
    # CONFIG_CLOCK_CONTROL_NRF_SHELL is not set
    # CONFIG_FLASH_SHELL is not set
    # CONFIG_HWINFO_SHELL is not set
    # CONFIG_OPENTHREAD_SHELL is not set
    CONFIG_NCS_SAMPLE_MATTER_APP_TASK_QUEUE_SIZE=10
    CONFIG_NCS_SAMPLE_MATTER_APP_TASK_MAX_SIZE=16
    # CONFIG_NCS_SAMPLE_MATTER_CUSTOM_BLUETOOTH_ADVERTISING is not set
    # CONFIG_NCS_SAMPLE_MATTER_OPERATIONAL_KEYS_MIGRATION_TO_ITS is not set
    # CONFIG_NCS_SAMPLE_MATTER_SETTINGS_SHELL is not set
    CONFIG_NCS_SAMPLE_MATTER_TEST_EVENT_TRIGGERS=y
    CONFIG_NCS_SAMPLE_MATTER_TEST_EVENT_TRIGGERS_MAX=8
    CONFIG_NCS_SAMPLE_MATTER_TEST_EVENT_TRIGGERS_REGISTER_DEFAULTS=y
    CONFIG_NCS_SAMPLE_MATTER_TEST_EVENT_TRIGGERS_MAX_TRIGGERS_DELEGATES=2
    CONFIG_NCS_SAMPLE_MATTER_ZAP_FILES_PATH="src/default_zap"
    CONFIG_NCS_SAMPLE_MATTER_STORAGE_MAX_KEY_LEN=18
    CONFIG_NCS_SAMPLE_MATTER_SECURE_STORAGE_PSA_KEY_VALUE_OFFSET=0x40000
    # CONFIG_NCS_SAMPLE_MATTER_WATCHDOG is not set
    # CONFIG_NCS_SAMPLE_MATTER_DIAGNOSTIC_LOGS is not set
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_NET_L2_ETHERNET is not set
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    CONFIG_NET_IPV6=y
    # CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set
    CONFIG_BT_HCI_VS=y
    CONFIG_ROM_START_OFFSET=0
    # CONFIG_BT_CTLR is not set
    CONFIG_NUM_IRQS=271
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=1000000
    CONFIG_FLASH_SIZE=1524
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_SOC_RESET_HOOK=y
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_CLOCK_CONTROL=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=31250
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_XIP=y
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_COUNTER=y
    # CONFIG_SHARED_INTERRUPTS is not set
    CONFIG_PM_DEVICE=y
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_BT_AUTO_PHY_UPDATE=y
    CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
    CONFIG_FPU=y
    # CONFIG_BT_USER_PHY_UPDATE is not set
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_USE_DT_CODE_PARTITION=y
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_CACHE_MANAGEMENT=y
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_GEN_ISR_TABLES=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_FLASH_LOAD_OFFSET=0x10000
    CONFIG_REGULATOR=y
    # CONFIG_PM_DEVICE_SYSTEM_MANAGED is not set
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    # CONFIG_BUILD_OUTPUT_S19 is not set
    CONFIG_FLASH_FILL_BUFFER_SIZE=32
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_NET_UDP_CHECKSUM=y
    # CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set
    # CONFIG_HCI_NXP_SET_CAL_DATA is not set
    CONFIG_MFD=y
    # CONFIG_HCI_NXP_RX_THREAD is not set
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    CONFIG_SPI=y
    # CONFIG_NET_L2_IEEE802154 is not set
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    # CONFIG_MEMC is not set
    CONFIG_CACHE=y
    CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_ROMSTART_RELOCATION_ROM is not set
    CONFIG_DCACHE_LINE_SIZE=32
    # CONFIG_RESET is not set
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    # CONFIG_NRF_RTC_TIMER is not set
    CONFIG_IEEE802154_NRF5=y
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_SHELL_BACKEND_SERIAL=y
    CONFIG_CACHE_NRF_CACHE=y
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_PM_DEVICE_POWER_DOMAIN=y
    CONFIG_PM_DEVICE_RUNTIME=y
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    # CONFIG_SYSCON is not set
    CONFIG_SERIAL_INIT_PRIORITY=50
    CONFIG_ENTROPY_INIT_PRIORITY=50
    # CONFIG_INTC_MTK_ADSP is not set
    # CONFIG_MTK_ADSP_TIMER is not set
    CONFIG_CONSOLE=y
    # CONFIG_WINSTREAM is not set
    CONFIG_SOC_TOOLCHAIN_NAME="amd_acp_6_0_adsp"
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_REBOOT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_GEN_IRQ_START_VECTOR=0
    CONFIG_SRAM_OFFSET=0
    # CONFIG_POWER_DOMAIN is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_SPI_NOR=y
    # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
    # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
    CONFIG_BOOTLOADER_MCUBOOT=y
    # CONFIG_SCHED_CPU_MASK is not set
    # CONFIG_WATCHDOG is not set
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_BT_BUF_ACL_TX_COUNT=3
    CONFIG_BT_BUF_CMD_TX_SIZE=255
    CONFIG_BT_BUF_EVT_RX_SIZE=68
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_CLOCK_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_BT_HCI_SDC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NPM2100_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NPM2100_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NPM2100_REGULATOR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NPM2100_VBAT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NPM2100_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GRTC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_LFXO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PPIB_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF54L_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_RRAM_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_PSA_CRYPTO_RNG_ENABLED=y
    # end of Devicetree Info
    # Modules
    # CONFIG_BUILD_ONLY_NO_BLOBS is not set
    # Available modules.
    # nrf (/opt/nordic/ncs/v3.0.2/nrf)
    CONFIG_OPENTHREAD_LIBRARY_AVAILABLE=y
    CONFIG_NEWLIB_LIBC_NANO=y
    CONFIG_NUM_METAIRQ_PRIORITIES=1
    CONFIG_LOG_BUFFER_SIZE=4048
    CONFIG_OPENTHREAD_MANUAL_START=y
    CONFIG_MBEDTLS_ENTROPY_C=y
    CONFIG_NRF_802154_ENCRYPTION=y
    CONFIG_NET_PKT_TXTIME=y
    CONFIG_NET_PKT_TIMESTAMP=y
    CONFIG_IEEE802154_NRF5_DELAY_TRX_ACC=50
    CONFIG_IEEE802154_CSL_ENDPOINT=y
    CONFIG_NET_RX_STACK_SIZE=1500
    CONFIG_NET_TX_STACK_SIZE=1200
    CONFIG_OPENTHREAD_BLE_TCAT_THREAD_STACK_SIZE=5120
    CONFIG_OPENTHREAD_NUM_MESSAGE_BUFFERS=64
    CONFIG_ZMS=y
    # CONFIG_NVS is not set
    CONFIG_MBEDTLS=y
    # CONFIG_MBEDTLS_TLS_VERSION_1_2 is not set
    CONFIG_MBEDTLS_MAC_SHA256_ENABLED=y
    # CONFIG_MBEDTLS_CTR_DRBG_ENABLED is not set
    # CONFIG_MBEDTLS_TLS_LIBRARY is not set
    # CONFIG_MBEDTLS_X509_LIBRARY is not set
    CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C=y
    # CONFIG_MBEDTLS_LEGACY_CRYPTO_C is not set
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_BT_BUF_CMD_TX_COUNT=2
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    CONFIG_NRF_SECURITY_ENABLER=y
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_BACKEND_MCUBOOT=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_VALIDATION=y
    # Subsystems
    # Bootloader
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x460
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7800
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y
    CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_COMPANY_ID_NORDIC=0x0059
    CONFIG_BT_COMPANY_ID=0x0059
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_LONG_WQ_STACK_SIZE=2100
    CONFIG_BT_LL_SOFTDEVICE=y
    CONFIG_BT_CTLR_DF_SUPPORT=y
    # SoftDevice Controller
    CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1536
    # CONFIG_BT_CTLR_SDC_LLPM is not set
    # CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=3
    # CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
    # CONFIG_BT_CTLR_SDC_CONN_EVENT_EXTEND_DEFAULT is not set
    # CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
    CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PRIO=6
    # CONFIG_BT_CTLR_DF is not set
    CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y
    CONFIG_BT_CTLR_FAL_SIZE=8
    # CONFIG_BT_CTLR_SDC_EVENT_TRIGGER is not set
    # CONFIG_BT_CTLR_SDC_CONN_ANCHOR_POINT_REPORT is not set
    # CONFIG_BT_UNINIT_MPSL_ON_DISABLE is not set
    # CONFIG_BT_CTLR_CHANNEL_SOUNDING is not set
    # CONFIG_BT_CTLR_SDC_LE_POWER_CLASS_1 is not set
    CONFIG_BT_LL_SOFTDEVICE_INIT_PRIORITY=40
    # end of SoftDevice Controller
    # CONFIG_BT_RADIO_NOTIFICATION_CONN_CB is not set
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_CONN_CTX is not set
    CONFIG_BT_EXT_ADV_MAX_ADV_SET=1
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    CONFIG_BT_GATT_AUTO_SEC_REQ=y
    # end of Bluetooth Services
    # BLE over nRF RPC
    # CONFIG_BT_RPC is not set
    # CONFIG_BT_SHELL is not set
    # CONFIG_BT_RPC_STACK is not set
    # CONFIG_BT_CENTRAL is not set
    # CONFIG_BT_OBSERVER is not set
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    CONFIG_BT_EXT_ADV=y
    # CONFIG_BT_EXT_ADV_LEGACY_SUPPORT is not set
    # CONFIG_BT_PER_ADV is not set
    CONFIG_BT_LOG=y
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_LOG_LEVEL_INF is not set
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    CONFIG_BT_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_LOG_LEVEL=1
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL=1
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
    CONFIG_BT_RPA_LOG_LEVEL=1
    # CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RPA_LOG_LEVEL_INF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CRYPTO_LOG_LEVEL=1
    # CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_ATT_LOG_LEVEL=1
    # CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_GATT_LOG_LEVEL=1
    # CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_GATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
    CONFIG_BT_L2CAP_LOG_LEVEL=1
    # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SETTINGS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SETTINGS_LOG_LEVEL=1
    # CONFIG_BT_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HCI_CORE_LOG_LEVEL=1
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CONN_LOG_LEVEL=1
    # CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONN_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_INHERIT is not set
    CONFIG_BT_KEYS_LOG_LEVEL=4
    # CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
    CONFIG_BT_KEYS_LOG_LEVEL_DBG=y
    # CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SMP_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SMP_LOG_LEVEL=1
    # CONFIG_BT_SMP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SMP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SMP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SERVICE_LOG_LEVEL=1
    # CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_DIS=y
    CONFIG_BT_DIS_SETTINGS=y
    CONFIG_BT_DIS_STR_MAX=21
    CONFIG_BT_DIS_MODEL="Click-lock"
    CONFIG_BT_DIS_MODEL_DEPRECATED_USED=y
    CONFIG_BT_DIS_MANUF="MTI Inc"
    CONFIG_BT_DIS_MANUF_DEPRECATED_USED=y
    # CONFIG_BT_DIS_PNP is not set
    CONFIG_BT_DIS_SERIAL_NUMBER=y
    CONFIG_BT_DIS_SERIAL_NUMBER_STR="00001234"
    CONFIG_BT_DIS_FW_REV=y
    CONFIG_BT_DIS_FW_REV_STR="0.0.1+0"
    CONFIG_BT_DIS_HW_REV=y
    CONFIG_BT_DIS_HW_REV_STR="PF-1.0"
    CONFIG_BT_DIS_SW_REV=y
    CONFIG_BT_DIS_SW_REV_STR="MatterLock-0.0.1"
    # CONFIG_BT_DIS_UDI is not set
    # CONFIG_BT_DIS_SYSTEM_ID is not set
    # CONFIG_BT_DIS_IEEE_RCDL is not set
    # CONFIG_BT_CTS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_ZEPHYR_NUS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_BAS_BLS is not set
    CONFIG_BT_BUF_ACL_RX_COUNT=0
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=58
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
    CONFIG_BT_HAS_HCI_VS=y
    # CONFIG_BT_HCI_VS_FATAL_ERROR is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_RPA=y
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    CONFIG_BT_HCI_ERR_TO_STR=y
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    CONFIG_BT_LONG_WQ=y
    CONFIG_BT_LONG_WQ_PRIO=10
    CONFIG_BT_LONG_WQ_INIT_PRIO=50
    CONFIG_BT_HCI_HOST=y
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_CONN_TX_NOTIFY_WQ is not set
    # CONFIG_BT_AUDIO is not set
    # CONFIG_BT_HOST_CRYPTO is not set
    CONFIG_BT_SETTINGS=y
    CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=y
    CONFIG_BT_SETTINGS_DELAYED_STORE=y
    CONFIG_BT_SETTINGS_DELAYED_STORE_MS=1000
    CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE=y
    CONFIG_BT_SETTINGS_USE_PRINTK=y
    CONFIG_BT_SETTINGS_CCC_STORE_MAX=48
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_LIM_ADV_TIMEOUT=30
    CONFIG_BT_CONN_TX_USER_DATA_SIZE=16
    CONFIG_BT_CONN_FRAG_COUNT=3
    CONFIG_BT_CONN_TX_MAX=3
    # CONFIG_BT_CONN_PARAM_ANY is not set
    # CONFIG_BT_CONN_CHECK_NULL_BEFORE_CREATE is not set
    # CONFIG_BT_USER_DATA_LEN_UPDATE is not set
    # CONFIG_BT_REMOTE_INFO is not set
    CONFIG_BT_SMP=y
    # CONFIG_BT_SECURITY_ERR_TO_STR is not set
    # CONFIG_BT_SMP_ERR_TO_STR is not set
    # CONFIG_BT_PASSKEY_KEYPRESS is not set
    CONFIG_BT_PRIVACY=y
    # CONFIG_BT_PRIVACY_RANDOMIZE_IR is not set
    CONFIG_BT_RPA_TIMEOUT=900
    # CONFIG_BT_RPA_TIMEOUT_DYNAMIC is not set
    # CONFIG_BT_RPA_SHARING is not set
    # CONFIG_BT_SIGNING is not set
    CONFIG_BT_SMP_APP_PAIRING_ACCEPT=y
    CONFIG_BT_SMP_SC_PAIR_ONLY=y
    # CONFIG_BT_SMP_SC_ONLY is not set
    CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y
    # CONFIG_BT_ID_UNPAIR_MATCHING_BONDS is not set
    # CONFIG_BT_USE_DEBUG_KEYS is not set
    # CONFIG_BT_BONDING_REQUIRED is not set
    CONFIG_BT_BONDABLE_PER_CONNECTION=y
    # CONFIG_BT_STORE_DEBUG_KEYS is not set
    CONFIG_BT_SMP_ENFORCE_MITM=y
    CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
    # CONFIG_BT_KEYS_SAVE_AGING_COUNTER_ON_PAIRING is not set
    CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=16
    CONFIG_BT_L2CAP_TX_BUF_COUNT=3
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    # CONFIG_BT_L2CAP_DYNAMIC_CHANNEL is not set
    # CONFIG_BT_L2CAP_SEG_RECV is not set
    # CONFIG_BT_L2CAP_RECONFIGURE_EXPLICIT is not set
    # CONFIG_BT_ATT_ERR_TO_STR is not set
    CONFIG_BT_ATT_TX_COUNT=3
    CONFIG_BT_ATT_PREPARE_COUNT=0
    CONFIG_BT_ATT_RETRY_ON_SEC_ERR=y
    # CONFIG_BT_ATT_SENT_CB_AFTER_TX is not set
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    # CONFIG_BT_GATT_CLIENT is not set
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
    # CONFIG_BT_GATT_AUTHORIZATION_CUSTOM is not set
    CONFIG_BT_MAX_PAIRED=6
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    CONFIG_BT_DEVICE_NAME="MTI_PadLock"
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_ID_MAX=2
    # CONFIG_BT_DF is not set
    CONFIG_BT_ECC=y
    # CONFIG_BT_HOST_CCM is not set
    CONFIG_BT_LOG_SNIFFER_INFO=y
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_CLASSIC is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    CONFIG_BT_CRYPTO=y
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    CONFIG_DFU_MULTI_IMAGE=y
    CONFIG_DFU_TARGET=y
    CONFIG_DFU_TARGET_MCUBOOT=y
    CONFIG_DFU_TARGET_STREAM=y
    # CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_OFF is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_ERR is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_WRN is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_INF is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_DBG is not set
    CONFIG_DFU_TARGET_LOG_LEVEL_DEFAULT=y
    CONFIG_DFU_TARGET_LOG_LEVEL=1
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_EMDS is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # CONFIG_NRF_CLOUD is not set
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_DOWNLOADER is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # OpenThread
    CONFIG_NORDIC_SECURITY_PROMPTLESS=y
    CONFIG_OPENTHREAD_NRF_SECURITY_PSA_CHOICE=y
    # CONFIG_OPENTHREAD_NRF_SECURITY_CHOICE is not set
    CONFIG_OPENTHREAD_NRF_SECURITY_PSA=y
    CONFIG_OPENTHREAD_MBEDTLS_LIB_NAME="mbedtls_external"
    # CONFIG_OPENTHREAD_MBEDTLS_DEBUG is not set
    CONFIG_OPENTHREAD_RADIO_WORKQUEUE_STACK_SIZE=1024
    # end of OpenThread
    # CONFIG_OPENTHREAD_RPC is not set
    CONFIG_OPENTHREAD_REPORT=y
    CONFIG_OPENTHREAD_REPORT_BUILD_ARTEFACT_NAME="ot_report.txt"
    # end of Networking
    # NFC
    CONFIG_NFC_NDEF=y
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    CONFIG_NFC_NDEF_MSG=y
    CONFIG_NFC_NDEF_RECORD=y
    # CONFIG_NFC_NDEF_LE_OOB_REC is not set
    # CONFIG_NFC_NDEF_TEXT_RECORD is not set
    # CONFIG_NFC_NDEF_TNEP_RECORD is not set
    CONFIG_NFC_NDEF_URI_MSG=y
    CONFIG_NFC_NDEF_URI_REC=y
    # CONFIG_NFC_NDEF_CH_MSG is not set
    # CONFIG_NFC_NDEF_CH_REC is not set
    # CONFIG_NFC_NDEF_LAUNCHAPP_MSG is not set
    # CONFIG_NFC_NDEF_LAUNCHAPP_REC is not set
    CONFIG_NDEF_FILE_SIZE=1024
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    CONFIG_NFC_PLATFORM=y
    CONFIG_NFCT_IRQ_PRIORITY=1
    # CONFIG_NFC_PLATFORM_LOG_LEVEL_OFF is not set
    # CONFIG_NFC_PLATFORM_LOG_LEVEL_ERR is not set
    # CONFIG_NFC_PLATFORM_LOG_LEVEL_WRN is not set
    # CONFIG_NFC_PLATFORM_LOG_LEVEL_INF is not set
    # CONFIG_NFC_PLATFORM_LOG_LEVEL_DBG is not set
    CONFIG_NFC_PLATFORM_LOG_LEVEL_DEFAULT=y
    CONFIG_NFC_PLATFORM_LOG_LEVEL=1
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # CONFIG_NFC_RPC is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    CONFIG_MPSL_FEM_API_AVAILABLE=y
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=1
    CONFIG_MPSL_THREAD_COOP_PRIO=0
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=28
    CONFIG_MPSL_HFCLK_LATENCY=854
    CONFIG_MPSL_CALIBRATION_PERIOD=4000
    CONFIG_MPSL_INIT_PRIORITY=40
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=1
    # CONFIG_MPSL_PIN_DEBUG is not set
    # CONFIG_MPSL_USE_EXTERNAL_CLOCK_CONTROL is not set
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_SIZE=256
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0
    CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0
    # Zephyr subsystem configurations
    CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000
    # CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL is not set
    CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x1000
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_ENABLED=y
    CONFIG_PM_EXTERNAL_FLASH_PATH="/soc/peripheral@50000000/spi@4a000/w25q16jv@0"
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=16777216
    CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x40000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # Full Modem Firmware Update Management(FMFU)
    # end of Full Modem Firmware Update Management(FMFU)
    # Additional MCUmgr configuration
    # Additional MCUmgr group configuration
    # Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr group configuration
    # end of Additional MCUmgr configuration
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    CONFIG_NRF_802154_RADIO_CONFIG=y
    CONFIG_NRF_802154_RADIO_CONFIG_PRIO=91
    CONFIG_NRF_802154_ACK_TIMEOUT_CUSTOM_US=0
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    CONFIG_NRF_SECURITY=y
    # Nordic-added meta types
    CONFIG_PSA_HAS_AEAD_SUPPORT=y
    CONFIG_PSA_HAS_ASYM_SIGN_SUPPORT=y
    CONFIG_PSA_HAS_CIPHER_SUPPORT=y
    CONFIG_PSA_HAS_HASH_SUPPORT=y
    CONFIG_PSA_HAS_KEY_AGREEMENT=y
    CONFIG_PSA_HAS_KEY_DERIVATION=y
    CONFIG_PSA_HAS_KEY_SUPPORT=y
    CONFIG_PSA_HAS_MAC_SUPPORT=y
    CONFIG_PSA_HAS_PAKE_SUPPORT=y
    # Nordic added alg types
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER=y
    # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_HMAC is not set
    CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_CMAC=y
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y
    # CONFIG_PSA_WANT_ALG_CHACHA20 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_AES_KW is not set
    # CONFIG_PSA_WANT_ALG_AES_KWP is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE_PT is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE is not set
    # Nordic added ECC curve types
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    # Nordic addded RNG configuration
    CONFIG_PSA_WANT_GENERATE_RANDOM=y
    # Nordic added key types
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set
    CONFIG_MBEDTLS_PSA_CRYPTO_BUILTIN_KEYS=y
    CONFIG_MBEDTLS_CFG_FILE="nrf-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-user-config.h"
    CONFIG_MBEDTLS_ENTROPY_POLL=y
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_PSA_CORE_OBERON=y
    # CONFIG_PSA_CORE_LITE is not set
    # PSA Driver Support
    CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y
    # Choose DRBG algorithm
    CONFIG_PSA_WANT_ALG_CTR_DRBG=y
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    CONFIG_PSA_USE_CTR_DRBG_DRIVER=y
    # end of Choose DRBG algorithm
    # CryptoCell PSA Driver Configuration
    # end of CryptoCell PSA Driver Configuration
    # CRACEN PSA Driver Configuration
    CONFIG_PSA_USE_CRACEN_CIPHER_DRIVER=y
    CONFIG_PSA_USE_CRACEN_AEAD_DRIVER=y
    CONFIG_PSA_USE_CRACEN_HASH_DRIVER=y
    CONFIG_PSA_USE_CRACEN_MAC_DRIVER=y
    CONFIG_PSA_USE_CRACEN_KEY_AGREEMENT_DRIVER=y
    CONFIG_PSA_USE_CRACEN_ASYMMETRIC_DRIVER=y
    CONFIG_PSA_USE_CRACEN_KEY_MANAGEMENT_DRIVER=y
    CONFIG_PSA_USE_CRACEN_KEY_DERIVATION_DRIVER=y
    CONFIG_PSA_USE_CRACEN_PAKE_DRIVER=y
    CONFIG_PSA_USE_CRACEN_ASYMMETRIC_SIGNATURE_DRIVER=y
    CONFIG_PSA_USE_CRACEN_CTR_DRBG_DRIVER=y
    # end of CRACEN PSA Driver Configuration
    # AES key size configuration
    CONFIG_PSA_WANT_AES_KEY_SIZE_128=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_192=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_256=y
    # end of AES key size configuration
    # RSA key size configuration
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_2048 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set
    CONFIG_PSA_MAX_RSA_KEY_BITS=0
    # end of RSA key size configuration
    CONFIG_PSA_ACCEL_CCM_AES_128=y
    CONFIG_PSA_ACCEL_CCM_AES_192=y
    CONFIG_PSA_ACCEL_CCM_AES_256=y
    CONFIG_PSA_ACCEL_CHACHA20_POLY1305=y
    CONFIG_PSA_ACCEL_CMAC_AES_128=y
    CONFIG_PSA_ACCEL_CMAC_AES_192=y
    CONFIG_PSA_ACCEL_CMAC_AES_256=y
    CONFIG_PSA_ACCEL_ECB_NO_PADDING_AES_128=y
    CONFIG_PSA_ACCEL_ECB_NO_PADDING_AES_192=y
    CONFIG_PSA_ACCEL_ECB_NO_PADDING_AES_256=y
    CONFIG_PSA_ACCEL_ECDH_SECP_R1_256=y
    CONFIG_PSA_ACCEL_ECDSA_SECP_R1_256_SHA_224=y
    CONFIG_PSA_ACCEL_ECDSA_SECP_R1_256_SHA_256=y
    CONFIG_PSA_ACCEL_GCM_AES_128=y
    CONFIG_PSA_ACCEL_GCM_AES_192=y
    CONFIG_PSA_ACCEL_GCM_AES_256=y
    CONFIG_PSA_ACCEL_GENERATE_RANDOM=y
    CONFIG_PSA_ACCEL_HKDF_SHA_224=y
    CONFIG_PSA_ACCEL_HKDF_SHA_256=y
    CONFIG_PSA_ACCEL_HMAC_SHA_224=y
    CONFIG_PSA_ACCEL_HMAC_SHA_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_DERIVE_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_EXPORT_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_GENERATE_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR_IMPORT_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_ECC_PUBLIC_KEY_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT_SECP_R1_256=y
    CONFIG_PSA_ACCEL_KEY_TYPE_SPAKE2P_PUBLIC_KEY_SECP_R1_256=y
    CONFIG_PSA_ACCEL_SHA_224=y
    CONFIG_PSA_ACCEL_SHA_256=y
    CONFIG_PSA_ACCEL_SPAKE2P_CMAC_SECP_R1_256_SHA_256=y
    CONFIG_PSA_ACCEL_SPAKE2P_HMAC_SECP_R1_256_SHA_256=y
    CONFIG_PSA_ACCEL_SPAKE2P_MATTER=y
    CONFIG_CRACEN_HW_PRESENT=y
    CONFIG_CRACEN_HW_VERSION_BASE=y
    # CONFIG_CRACEN_LOG_LEVEL_OFF is not set
    # CONFIG_CRACEN_LOG_LEVEL_ERR is not set
    # CONFIG_CRACEN_LOG_LEVEL_WRN is not set
    # CONFIG_CRACEN_LOG_LEVEL_INF is not set
    # CONFIG_CRACEN_LOG_LEVEL_DBG is not set
    CONFIG_CRACEN_LOG_LEVEL_DEFAULT=y
    CONFIG_CRACEN_LOG_LEVEL=1
    CONFIG_CRACEN_LOAD_MICROCODE=y
    CONFIG_CRACEN_LIB_KMU=y
    CONFIG_CRACEN_IKG_SEED_LOAD=y
    CONFIG_CRACEN_IKG_SEED_KMU_SLOT=183
    CONFIG_PSA_NEED_CRACEN_CCM_AES=y
    CONFIG_PSA_NEED_CRACEN_GCM_AES=y
    CONFIG_PSA_NEED_CRACEN_CHACHA20_POLY1305=y
    CONFIG_PSA_NEED_CRACEN_AEAD_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_ECB_NO_PADDING_AES=y
    CONFIG_PSA_NEED_CRACEN_CIPHER_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_ECDH_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_ECDH_SECP_R1=y
    CONFIG_PSA_NEED_CRACEN_KEY_AGREEMENT_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_ECDSA_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_ECDSA_SECP_R1=y
    CONFIG_PSA_NEED_CRACEN_ASYMMETRIC_SIGNATURE_ANY_ECC=y
    CONFIG_PSA_NEED_CRACEN_ASYMMETRIC_SIGNATURE_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_SHA_224=y
    CONFIG_PSA_NEED_CRACEN_SHA_256=y
    CONFIG_PSA_NEED_CRACEN_HASH_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_PUBLIC_KEY_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_KEY_PAIR_IMPORT_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_KEY_PAIR_EXPORT_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_KEY_PAIR_GENERATE_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_KEY_PAIR_DERIVE_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_SECP_R1=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_PUBLIC_KEY=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_ECC_KEY_PAIR_DERIVE=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_SPAKE2P_PUBLIC_KEY_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_KEY_TYPE_SPAKE2P_SECP_R1_256=y
    CONFIG_PSA_NEED_CRACEN_KEY_MANAGEMENT_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_HMAC=y
    CONFIG_PSA_NEED_CRACEN_CMAC=y
    CONFIG_PSA_NEED_CRACEN_MAC_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_CTR_DRBG_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_SPAKE2P=y
    CONFIG_PSA_NEED_CRACEN_PAKE_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_HKDF=y
    CONFIG_PSA_NEED_CRACEN_SP800_108_COUNTER_CMAC=y
    CONFIG_PSA_NEED_CRACEN_KEY_DERIVATION_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_KMU_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_KMU_ENCRYPTED_KEYS=y
    # PSA API support
    CONFIG_MBEDTLS_USE_PSA_CRYPTO=y
    # CONFIG_MBEDTLS_PSA_STATIC_KEY_SLOTS is not set
    # end of PSA API support
    CONFIG_MBEDTLS_PLATFORM_MEMORY=y
    CONFIG_MBEDTLS_PLATFORM_C=y
    CONFIG_MBEDTLS_MEMORY_C=y
    CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y
    CONFIG_MBEDTLS_THREADING_C=y
    CONFIG_MBEDTLS_BASE64_C=y
    CONFIG_MBEDTLS_OID_C=y
    CONFIG_MBEDTLS_ASN1_WRITE_C=y
    CONFIG_MBEDTLS_ASN1_PARSE_C=y
    CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y
    CONFIG_MBEDTLS_THREADING_ALT=y
    CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y
    CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1
    CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y
    # Legacy mbed TLS crypto APIs
    CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6
    CONFIG_MBEDTLS_MPI_MAX_SIZE=256
    # CONFIG_MBEDTLS_CIPHER_C is not set
    # CONFIG_MBEDTLS_PEM_PARSE_C is not set
    # CONFIG_MBEDTLS_PEM_WRITE_C is not set
    # end of Legacy mbed TLS crypto APIs
    # Zephyr legacy configurations
    # CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_MD5_ENABLED is not set
    # CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER is not set
    # CONFIG_MBEDTLS_MD is not set
    # CONFIG_MBEDTLS_ENTROPY_ENABLED is not set
    # CONFIG_MBEDTLS_GENPRIME_ENABLED is not set
    # end of Zephyr legacy configurations
    CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
    # end of nRF Security
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEST is not set
    # Log levels
    # end of Log levels
    # end of Audio Modules
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEMPLATE is not set
    # CONFIG_UART_ASYNC_ADAPTER is not set
    CONFIG_TRUSTED_STORAGE=y
    # CONFIG_TRUSTED_STORAGE_LOG_LEVEL_OFF is not set
    # CONFIG_TRUSTED_STORAGE_LOG_LEVEL_ERR is not set
    # CONFIG_TRUSTED_STORAGE_LOG_LEVEL_WRN is not set
    # CONFIG_TRUSTED_STORAGE_LOG_LEVEL_INF is not set
    # CONFIG_TRUSTED_STORAGE_LOG_LEVEL_DBG is not set
    CONFIG_TRUSTED_STORAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_TRUSTED_STORAGE_LOG_LEVEL=1
    CONFIG_PSA_PROTECTED_STORAGE=y
    CONFIG_PSA_PROTECTED_STORAGE_PREFIX="ps"
    CONFIG_PSA_INTERNAL_TRUSTED_STORAGE=y
    CONFIG_PSA_INTERNAL_TRUSTED_STORAGE_PREFIX="its"
    CONFIG_TRUSTED_STORAGE_BACKEND_AEAD=y
    CONFIG_TRUSTED_STORAGE_BACKEND_AEAD_CRYPTO_PSA_CHACHAPOLY=y
    CONFIG_TRUSTED_STORAGE_BACKEND_AEAD_NONCE_PSA_SEED_COUNTER=y
    # CONFIG_TRUSTED_STORAGE_BACKEND_AEAD_NONCE_CUSTOM is not set
    # CONFIG_TRUSTED_STORAGE_BACKEND_AEAD_KEY_HASH_UID is not set
    CONFIG_TRUSTED_STORAGE_BACKEND_AEAD_KEY_DERIVE_FROM_HUK=y
    # CONFIG_TRUSTED_STORAGE_BACKEND_AEAD_KEY_CUSTOM is not set
    CONFIG_TRUSTED_STORAGE_STORAGE_BACKEND_SETTINGS=y
    # CONFIG_TRUSTED_STORAGE_STORAGE_BACKEND_CUSTOM is not set
    # Logging over RPC
    # CONFIG_LOG_FORWARDER_RPC is not set
    # end of Logging over RPC
    # CONFIG_SUIT is not set
    # CONFIG_DULT is not set
    # CONFIG_NRF_COMPRESS is not set
    # MCUboot IDs (informative only, do not change)
    CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0
    CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
    # end of MCUboot IDs (informative only, do not change)
    # CONFIG_SETTINGS_ZMS_LEGACY is not set
    CONFIG_SETTINGS_ZMS_SECTOR_SIZE_MULT=1
    # end of Subsystems
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=1
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # CONFIG_APP_JWT is not set
    # Binary libraries
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_FPROTECT_BLOCK_SIZE=0x1000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_AT_PARSER is not set
    CONFIG_MULTITHREADING_LOCK=y
    CONFIG_RESET_ON_FATAL_ERROR=y
    # CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_INF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
    CONFIG_FATAL_ERROR_LOG_LEVEL_DEFAULT=y
    CONFIG_FATAL_ERROR_LOG_LEVEL=1
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_SRC=y
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    CONFIG_HW_UNIQUE_KEY=y
    CONFIG_HW_UNIQUE_KEY_WRITE_ON_CRYPTO_INIT=y
    CONFIG_HW_UNIQUE_KEY_RANDOM=y
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_MODEM_SLM is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    CONFIG_NCS_BOOT_BANNER=y
    CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="My Application"
    CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
    CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    # CONFIG_FLASH_RPC is not set
    CONFIG_CLOCK_CONTROL_MPSL=y
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_RPC is not set
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL=y
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_RPC_CONTROLLER is not set
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=1
    CONFIG_TEMP_NRF5_MPSL=y
    # CONFIG_ETH_RTT is not set
    CONFIG_SENSOR=y
    # CONFIG_BH1749 is not set
    # CONFIG_SENSOR_SIM is not set
    # CONFIG_SENSOR_STUB is not set
    # CONFIG_PMW3360 is not set
    # CONFIG_PAW3212 is not set
    # CONFIG_BME68X_IAQ is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # CONFIG_MOCK_NRF_RPC is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/opt/nordic/ncs/v3.0.2/nrf)
    # hostap (/opt/nordic/ncs/v3.0.2/modules/lib/hostap)
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    CONFIG_ZEPHYR_HOSTAP_MODULE=y
    # end of hostap (/opt/nordic/ncs/v3.0.2/modules/lib/hostap)
    # mcuboot (/opt/nordic/ncs/v3.0.2/bootloader/mcuboot)
    # MCUboot
    CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=16
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=16
    # CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (/opt/nordic/ncs/v3.0.2/bootloader/mcuboot)
    # mbedtls (/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_PSA_CRYPTO_CLIENT=y
    # CONFIG_PSA_CRYPTO_ENABLE_ALL is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    CONFIG_PSA_WANT_ALG_CCM=y
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    CONFIG_PSA_WANT_ALG_CMAC=y
    CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305=y
    # CONFIG_PSA_WANT_ALG_CTR is not set
    CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA=y
    CONFIG_PSA_WANT_ALG_ECDH=y
    CONFIG_PSA_WANT_ALG_ECDSA=y
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    CONFIG_PSA_WANT_ALG_GCM=y
    CONFIG_PSA_WANT_ALG_HKDF=y
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    CONFIG_PSA_WANT_ALG_HMAC=y
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_PBKDF2_HMAC is not set
    CONFIG_PSA_WANT_ALG_PBKDF2_AES_CMAC_PRF_128=y
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    CONFIG_PSA_WANT_ALG_SHA_256=y
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # CONFIG_PSA_WANT_ALG_TLS12_PRF is not set
    # CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS is not set
    # CONFIG_PSA_WANT_ALG_TLS12_ECJPAKE_TO_PMS is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    CONFIG_PSA_WANT_ECC_SECP_R1_256=y
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    CONFIG_PSA_WANT_KEY_TYPE_AES=y
    # CONFIG_PSA_WANT_KEY_TYPE_CHACHA20 is not set
    CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY=y
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE=y
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_DERIVE is not set
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_BASIC=y
    # CONFIG_MBEDTLS_LIBRARY is not set
    CONFIG_DISABLE_MBEDTLS_BUILTIN=y
    # CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_OFF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_ERR is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_WRN is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_INF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_DBG is not set
    CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT=y
    CONFIG_MBEDTLS_LOG_LEVEL=1
    # CONFIG_MBEDTLS_DEBUG is not set
    # CONFIG_MBEDTLS_HEAP_CUSTOM_SECTION is not set
    CONFIG_MBEDTLS_INIT=y
    # CONFIG_MBEDTLS_SHELL is not set
    # CONFIG_MBEDTLS_ZEROIZE_ALT is not set
    CONFIG_APP_LINK_WITH_MBEDTLS=y
    # end of mbedtls (/opt/nordic/ncs/v3.0.2/modules/crypto/mbedtls)
    # oberon-psa-crypto (/opt/nordic/ncs/v3.0.2/modules/crypto/oberon-psa-crypto)
    CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    # end of oberon-psa-crypto (/opt/nordic/ncs/v3.0.2/modules/crypto/oberon-psa-crypto)
    # trusted-firmware-m (/opt/nordic/ncs/v3.0.2/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (/opt/nordic/ncs/v3.0.2/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    # cjson (/opt/nordic/ncs/v3.0.2/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (/opt/nordic/ncs/v3.0.2/modules/lib/cjson)
    # azure-sdk-for-c (/opt/nordic/ncs/v3.0.2/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (/opt/nordic/ncs/v3.0.2/modules/lib/azure-sdk-for-c)
    # cirrus-logic (/opt/nordic/ncs/v3.0.2/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (/opt/nordic/ncs/v3.0.2/modules/hal/cirrus-logic)
    # openthread (/opt/nordic/ncs/v3.0.2/modules/lib/openthread)
    CONFIG_OPENTHREAD=y
    # OpenThread stack features
    # CONFIG_OPENTHREAD_THREAD_VERSION_1_1 is not set
    # CONFIG_OPENTHREAD_THREAD_VERSION_1_2 is not set
    # CONFIG_OPENTHREAD_THREAD_VERSION_1_3 is not set
    # CONFIG_OPENTHREAD_THREAD_VERSION_1_3_1 is not set
    CONFIG_OPENTHREAD_THREAD_VERSION_1_4=y
    CONFIG_OPENTHREAD_THREAD_VERSION="1.4"
    # CONFIG_OPENTHREAD_ANYCAST_LOCATOR is not set
    # CONFIG_OPENTHREAD_BACKBONE_ROUTER is not set
    # CONFIG_OPENTHREAD_BACKBONE_ROUTER_DUA_NDPROXYING is not set
    # CONFIG_OPENTHREAD_BACKBONE_ROUTER_MULTICAST_ROUTING is not set
    # CONFIG_OPENTHREAD_BLE_TCAT is not set
    # CONFIG_OPENTHREAD_BORDER_AGENT is not set
    # CONFIG_OPENTHREAD_BORDER_AGENT_EPHEMERAL_KEY_ENABLE is not set
    # CONFIG_OPENTHREAD_BORDER_AGENT_ID is not set
    # CONFIG_OPENTHREAD_BORDER_ROUTER is not set
    # CONFIG_OPENTHREAD_BORDER_ROUTING is not set
    # CONFIG_OPENTHREAD_BORDER_ROUTING_COUNTERS is not set
    # CONFIG_OPENTHREAD_BORDER_ROUTING_DHCP6_PD is not set
    # CONFIG_OPENTHREAD_CHANNEL_MONITOR is not set
    # CONFIG_OPENTHREAD_CHANNEL_MANAGER_CSL is not set
    CONFIG_OPENTHREAD_COAP=y
    # CONFIG_OPENTHREAD_COAP_BLOCK is not set
    # CONFIG_OPENTHREAD_COAP_OBSERVE is not set
    # CONFIG_OPENTHREAD_COAPS is not set
    # CONFIG_OPENTHREAD_COMMISSIONER is not set
    # CONFIG_OPENTHREAD_CSL_DEBUG is not set
    CONFIG_OPENTHREAD_CSL_RECEIVER=y
    # CONFIG_OPENTHREAD_CSL_RECEIVER_LOCAL_TIME_SYNC is not set
    CONFIG_OPENTHREAD_DEVICE_PROP_LEADER_WEIGHT=y
    # CONFIG_OPENTHREAD_DATASET_UPDATER is not set
    # CONFIG_OPENTHREAD_WAKEUP_COORDINATOR is not set
    # CONFIG_OPENTHREAD_WAKEUP_END_DEVICE is not set
    # CONFIG_OPENTHREAD_DHCP6_CLIENT is not set
    # CONFIG_OPENTHREAD_DHCP6_SERVER is not set
    # CONFIG_OPENTHREAD_DIAG is not set
    CONFIG_OPENTHREAD_DNS_CLIENT=y
    # CONFIG_OPENTHREAD_DNS_CLIENT_OVER_TCP is not set
    # CONFIG_OPENTHREAD_DNS_DSO is not set
    # CONFIG_OPENTHREAD_DNS_UPSTREAM_QUERY is not set
    # CONFIG_OPENTHREAD_DNSSD_DISCOVERY_PROXY is not set
    # CONFIG_OPENTHREAD_DNSSD_SERVER is not set
    CONFIG_OPENTHREAD_DUA=y
    CONFIG_OPENTHREAD_DYNAMIC_STORE_FRAME_AHEAD_COUNTER=y
    CONFIG_OPENTHREAD_ECDSA=y
    # CONFIG_OPENTHREAD_ENABLE_SERVICE is not set
    CONFIG_OPENTHREAD_EXTERNAL_HEAP=y
    # CONFIG_OPENTHREAD_FIREWALL is not set
    # CONFIG_OPENTHREAD_FULL_LOGS is not set
    CONFIG_OPENTHREAD_IP6_FRAGM=y
    # CONFIG_OPENTHREAD_JAM_DETECTION is not set
    # CONFIG_OPENTHREAD_JOINER is not set
    # CONFIG_OPENTHREAD_LEGACY is not set
    # CONFIG_OPENTHREAD_LINK_METRICS_INITIATOR is not set
    # CONFIG_OPENTHREAD_LINK_METRICS_MANAGER is not set
    # CONFIG_OPENTHREAD_LINK_METRICS_SUBJECT is not set
    # CONFIG_OPENTHREAD_PLATFORM_LOG_CRASH_DUMP is not set
    # CONFIG_OPENTHREAD_LOG_LEVEL_DYNAMIC is not set
    # CONFIG_OPENTHREAD_MAC_FILTER is not set
    # CONFIG_OPENTHREAD_MULTICAST_DNS is not set
    # CONFIG_OPENTHREAD_MESSAGE_USE_HEAP is not set
    # CONFIG_OPENTHREAD_MLE_LONG_ROUTES is not set
    CONFIG_OPENTHREAD_MLR=y
    # CONFIG_OPENTHREAD_MULTIPAN_RCP is not set
    # CONFIG_OPENTHREAD_MULTIPLE_INSTANCE is not set
    # CONFIG_OPENTHREAD_NAT64_BORDER_ROUTING is not set
    # CONFIG_OPENTHREAD_NAT64_TRANSLATOR is not set
    CONFIG_OPENTHREAD_NETDIAG_CLIENT=y
    CONFIG_OPENTHREAD_NETDIAG_VENDOR_INFO=y
    # CONFIG_OPENTHREAD_NEIGHBOR_DISCOVERY_AGENT is not set
    # CONFIG_OPENTHREAD_NETDATA_PUBLISHER is not set
    CONFIG_OPENTHREAD_OPERATIONAL_DATASET_AUTO_INIT=y
    # CONFIG_OPENTHREAD_OTNS is not set
    CONFIG_OPENTHREAD_PING_SENDER=y
    CONFIG_OPENTHREAD_PLATFORM_KEY_REF=y
    # CONFIG_OPENTHREAD_PLATFORM_NETIF is not set
    # CONFIG_OPENTHREAD_PLATFORM_UDP is not set
    # CONFIG_OPENTHREAD_POWER_SUPPLY_BATTERY is not set
    CONFIG_OPENTHREAD_POWER_SUPPLY_EXTERNAL=y
    # CONFIG_OPENTHREAD_POWER_SUPPLY_EXTERNAL_STABLE is not set
    # CONFIG_OPENTHREAD_POWER_SUPPLY_EXTERNAL_UNSTABLE is not set
    CONFIG_OPENTHREAD_POWER_SUPPLY="EXTERNAL"
    # CONFIG_OPENTHREAD_RADIO_STATS is not set
    # CONFIG_OPENTHREAD_RAW is not set
    # CONFIG_OPENTHREAD_REFERENCE_DEVICE is not set
    # CONFIG_OPENTHREAD_SETTINGS_RAM is not set
    CONFIG_OPENTHREAD_SLAAC=y
    # CONFIG_OPENTHREAD_SNTP_CLIENT is not set
    CONFIG_OPENTHREAD_SRP_CLIENT=y
    # CONFIG_OPENTHREAD_SRP_SERVER is not set
    # CONFIG_OPENTHREAD_TREL is not set
    # CONFIG_OPENTHREAD_TX_BEACON_PAYLOAD is not set
    # CONFIG_OPENTHREAD_TX_QUEUE_STATISTICS is not set
    # CONFIG_OPENTHREAD_UDP_FORWARD is not set
    CONFIG_OPENTHREAD_UPTIME=y
    # CONFIG_OPENTHREAD_VERHOEFF_CHECKSUM is not set
    CONFIG_OPENTHREAD_CLI_VENDOR_EXTENSION=""
    # end of OpenThread stack features
    # Thread Network configuration
    CONFIG_OPENTHREAD_PANID=43981
    CONFIG_OPENTHREAD_CHANNEL=11
    CONFIG_OPENTHREAD_NETWORK_NAME="ot_zephyr"
    CONFIG_OPENTHREAD_XPANID="de:ad:00:be:ef:00:ca:fe"
    CONFIG_OPENTHREAD_NETWORKKEY=""
    # CONFIG_OPENTHREAD_FTD is not set
    CONFIG_OPENTHREAD_MTD=y
    CONFIG_OPENTHREAD_MTD_SED=y
    CONFIG_OPENTHREAD_POLL_PERIOD=236000
    CONFIG_OPENTHREAD_MAX_CHILDREN=32
    CONFIG_OPENTHREAD_MAX_IP_ADDR_PER_CHILD=6
    CONFIG_OPENTHREAD_CONFIG_PLATFORM_INFO="Zephyr"
    CONFIG_OPENTHREAD_RADIO_LINK_IEEE_802_15_4_ENABLE=y
    CONFIG_OPENTHREAD_CSL_AUTO_SYNC=y
    CONFIG_OPENTHREAD_CSL_REQUEST_TIME_AHEAD=2000
    CONFIG_OPENTHREAD_CSL_RECEIVE_TIME_AHEAD=5000
    CONFIG_OPENTHREAD_MIN_RECEIVE_ON_AHEAD=104
    CONFIG_OPENTHREAD_MIN_RECEIVE_ON_AFTER=0
    CONFIG_OPENTHREAD_PLATFORM_CSL_UNCERT=30
    CONFIG_OPENTHREAD_CSL_TIMEOUT=20
    CONFIG_OPENTHREAD_MAC_SOFTWARE_TX_SECURITY_ENABLE=y
    # CONFIG_OPENTHREAD_MLE_INFORM_PREVIOUS_PARENT_ON_REATTACH is not set
    # CONFIG_OPENTHREAD_PARENT_SEARCH is not set
    CONFIG_OPENTHREAD_CLI_MAX_LINE_LENGTH=384
    CONFIG_OPENTHREAD_IP6_MAX_EXT_UCAST_ADDRS=4
    CONFIG_OPENTHREAD_IP6_MAX_EXT_MCAST_ADDRS=2
    # CONFIG_OPENTHREAD_TCP_ENABLE is not set
    # CONFIG_OPENTHREAD_HISTORY_TRACKER is not set
    # CONFIG_OPENTHREAD_MAC_STAY_AWAKE_BETWEEN_FRAGMENTS is not set
    CONFIG_OPENTHREAD_DEFAULT_RX_SENSITIVITY=-100
    # CONFIG_OPENTHREAD_TCAT_MULTIRADIO_CAPABILITIES is not set
    CONFIG_OPENTHREAD_BLE_TCAT_RING_BUF_SIZE=512
    CONFIG_OPENTHREAD_STORE_FRAME_COUNTER_AHEAD=100000
    CONFIG_OPENTHREAD_CHILD_SUPERVISION_CHECK_TIMEOUT=190
    CONFIG_OPENTHREAD_CHILD_SUPERVISION_INTERVAL=129
    CONFIG_OPENTHREAD_MLE_CHILD_TIMEOUT=240
    CONFIG_OPENTHREAD_PSA_NVM_BACKEND_ITS=y
    # CONFIG_OPENTHREAD_PSA_NVM_BACKEND_KMU is not set
    CONFIG_OPENTHREAD_PSA_ITS_NVM_OFFSET=0x20000
    CONFIG_OPENTHREAD_PSA_ITS_NVM_MAX_KEYS=20
    # end of Thread Network configuration
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (/opt/nordic/ncs/v3.0.2/modules/lib/openthread)
    # suit-generator (/opt/nordic/ncs/v3.0.2/modules/lib/suit-generator)
    CONFIG_SUIT_ENVELOPE_TEMPLATE_FILENAME=""
    CONFIG_SUIT_ENVELOPE_TARGET=""
    CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
    # CONFIG_SUIT_RECOVERY is not set
    # CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
    # CONFIG_SUIT_DFU_CACHE_EXTRACT_IMAGE is not set
    # CONFIG_SUIT_ENVELOPE_TARGET_ENCRYPT is not set
    # CONFIG_SUIT_ENVELOPE_TARGET_SIGN is not set
    CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
    # end of suit-generator (/opt/nordic/ncs/v3.0.2/modules/lib/suit-generator)
    # suit-processor (/opt/nordic/ncs/v3.0.2/modules/lib/suit-processor)
    # CONFIG_SUIT_PROCESSOR is not set
    CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
    CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
    # end of suit-processor (/opt/nordic/ncs/v3.0.2/modules/lib/suit-processor)
    # memfault-firmware-sdk (/opt/nordic/ncs/v3.0.2/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (/opt/nordic/ncs/v3.0.2/modules/lib/memfault-firmware-sdk)
    # coremark (/opt/nordic/ncs/v3.0.2/modules/benchmark/coremark)
    # CONFIG_COREMARK is not set
    CONFIG_ZEPHYR_COREMARK_MODULE=y
    # end of coremark (/opt/nordic/ncs/v3.0.2/modules/benchmark/coremark)
    # canopennode (/opt/nordic/ncs/v3.0.2/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (/opt/nordic/ncs/v3.0.2/modules/lib/canopennode)
    # chre (/opt/nordic/ncs/v3.0.2/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (/opt/nordic/ncs/v3.0.2/modules/lib/chre)
    # lz4 (/opt/nordic/ncs/v3.0.2/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (/opt/nordic/ncs/v3.0.2/modules/lib/lz4)
    # nanopb (/opt/nordic/ncs/v3.0.2/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (/opt/nordic/ncs/v3.0.2/modules/lib/nanopb)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (/opt/nordic/ncs/v3.0.2/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (/opt/nordic/ncs/v3.0.2/modules/lib/zscilib)
    # cmsis (/opt/nordic/ncs/v3.0.2/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis (/opt/nordic/ncs/v3.0.2/modules/hal/cmsis)
    # cmsis-dsp (/opt/nordic/ncs/v3.0.2/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (/opt/nordic/ncs/v3.0.2/modules/lib/cmsis-dsp)
    # cmsis-nn (/opt/nordic/ncs/v3.0.2/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (/opt/nordic/ncs/v3.0.2/modules/lib/cmsis-nn)
    # fatfs (/opt/nordic/ncs/v3.0.2/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (/opt/nordic/ncs/v3.0.2/modules/fs/fatfs)
    # hal_nordic (/opt/nordic/ncs/v3.0.2/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    CONFIG_NRF_802154_RADIO_DRIVER=y
    CONFIG_NRF_802154_MULTIPROTOCOL_SUPPORT=y
    # CONFIG_NRF_802154_SL_OPENSOURCE is not set
    CONFIG_NRF_802154_TEMPERATURE_UPDATE=y
    CONFIG_NRF_802154_TEMPERATURE_UPDATE_INIT_PRIO=91
    CONFIG_NRF_802154_TEMPERATURE_UPDATE_PERIOD=60000
    CONFIG_NRF_802154_CCA_MODE_ED=y
    # CONFIG_NRF_802154_CCA_MODE_CARRIER is not set
    # CONFIG_NRF_802154_CCA_MODE_CARRIER_AND_ED is not set
    # CONFIG_NRF_802154_CCA_MODE_CARRIER_OR_ED is not set
    CONFIG_NRF_802154_CCA_ED_THRESHOLD=45
    CONFIG_NRF_802154_CCA_CORR_THRESHOLD=45
    CONFIG_NRF_802154_CCA_CORR_LIMIT=2
    CONFIG_NRF_802154_RX_BUFFERS=16
    CONFIG_NRF_802154_PENDING_SHORT_ADDRESSES=16
    CONFIG_NRF_802154_PENDING_EXTENDED_ADDRESSES=16
    CONFIG_NRF_802154_SECURITY_KEY_STORAGE_SIZE=3
    # CONFIG_NRF_802154_CARRIER_FUNCTIONS is not set
    CONFIG_NRF_802154_ASSERT_ZEPHYR_MINIMAL=y
    # CONFIG_NRF_802154_ASSERT_ZEPHYR is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_DPPI_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_GRTC_LOG is not set
    # CONFIG_NRFX_NFCT_LOG is not set
    # CONFIG_NRFX_PPIB_LOG is not set
    # CONFIG_NRFX_PWM_LOG is not set
    # CONFIG_NRFX_SAADC_LOG is not set
    # CONFIG_NRFX_SPIM_LOG is not set
    # CONFIG_NRFX_TIMER_LOG is not set
    # CONFIG_NRFX_TWIM_LOG is not set
    # end of nrfx drivers logging
    # CONFIG_NRFX_CLOCK is not set
    # CONFIG_NRFX_COMP is not set
    CONFIG_NRFX_DPPI=y
    CONFIG_NRFX_DPPI00=y
    CONFIG_NRFX_DPPI10=y
    CONFIG_NRFX_DPPI20=y
    CONFIG_NRFX_DPPI30=y
    # CONFIG_NRFX_EGU10 is not set
    # CONFIG_NRFX_EGU20 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE20=y
    CONFIG_NRFX_GPIOTE30=y
    CONFIG_NRFX_GPPI=y
    CONFIG_NRFX_GRTC=y
    # CONFIG_NRFX_I2S20 is not set
    # CONFIG_NRFX_LPCOMP is not set
    CONFIG_NRFX_NFCT=y
    # CONFIG_NRFX_PDM20 is not set
    # CONFIG_NRFX_PDM21 is not set
    # CONFIG_NRFX_POWER is not set
    CONFIG_NRFX_PPIB=y
    CONFIG_NRFX_PPIB00=y
    CONFIG_NRFX_PPIB01=y
    CONFIG_NRFX_PPIB10=y
    CONFIG_NRFX_PPIB11=y
    CONFIG_NRFX_PPIB20=y
    CONFIG_NRFX_PPIB21=y
    CONFIG_NRFX_PPIB22=y
    CONFIG_NRFX_PPIB30=y
    CONFIG_NRFX_PWM=y
    CONFIG_NRFX_PWM20=y
    # CONFIG_NRFX_PWM21 is not set
    # CONFIG_NRFX_PWM22 is not set
    # CONFIG_NRFX_QDEC20 is not set
    # CONFIG_NRFX_QDEC21 is not set
    CONFIG_NRFX_RRAMC=y
    CONFIG_NRFX_SAADC=y
    CONFIG_NRFX_SPIM=y
    CONFIG_NRFX_SPIM00=y
    # CONFIG_NRFX_SPIM20 is not set
    # CONFIG_NRFX_SPIM21 is not set
    # CONFIG_NRFX_SPIM22 is not set
    # CONFIG_NRFX_SPIM30 is not set
    # CONFIG_NRFX_SPIS00 is not set
    # CONFIG_NRFX_SPIS20 is not set
    # CONFIG_NRFX_SPIS21 is not set
    # CONFIG_NRFX_SPIS22 is not set
    # CONFIG_NRFX_SPIS30 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TEMP is not set
    CONFIG_NRFX_TIMER=y
    # CONFIG_NRFX_TIMER00 is not set
    # CONFIG_NRFX_TIMER10 is not set
    CONFIG_NRFX_TIMER20=y
    # CONFIG_NRFX_TIMER21 is not set
    # CONFIG_NRFX_TIMER22 is not set
    # CONFIG_NRFX_TIMER23 is not set
    # CONFIG_NRFX_TIMER24 is not set
    CONFIG_NRFX_TWIM=y
    # CONFIG_NRFX_TWIM20 is not set
    CONFIG_NRFX_TWIM21=y
    # CONFIG_NRFX_TWIM22 is not set
    # CONFIG_NRFX_TWIM30 is not set
    # CONFIG_NRFX_TWIS20 is not set
    # CONFIG_NRFX_TWIS21 is not set
    # CONFIG_NRFX_TWIS22 is not set
    # CONFIG_NRFX_TWIS30 is not set
    # CONFIG_NRFX_UARTE00 is not set
    # CONFIG_NRFX_UARTE20 is not set
    # CONFIG_NRFX_UARTE21 is not set
    # CONFIG_NRFX_UARTE22 is not set
    # CONFIG_NRFX_UARTE30 is not set
    # CONFIG_NRFX_WDT30 is not set
    # CONFIG_NRFX_WDT31 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_config_reserved_resources_ncs.h"
    # end of hal_nordic (/opt/nordic/ncs/v3.0.2/modules/hal/nordic)
    # hal_st (/opt/nordic/ncs/v3.0.2/modules/hal/st)
    CONFIG_ZEPHYR_HAL_ST_MODULE=y
    # end of hal_st (/opt/nordic/ncs/v3.0.2/modules/hal/st)
    # hal_tdk (/opt/nordic/ncs/v3.0.2/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_TDK_MODULE=y
    # TDK drivers
    # CONFIG_TDK_HAL is not set
    # end of TDK drivers
    # end of hal_tdk (/opt/nordic/ncs/v3.0.2/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    # liblc3 (/opt/nordic/ncs/v3.0.2/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # CONFIG_LIBLC3 is not set
    # end of liblc3 (/opt/nordic/ncs/v3.0.2/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # littlefs (/opt/nordic/ncs/v3.0.2/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (/opt/nordic/ncs/v3.0.2/modules/fs/littlefs)
    # loramac-node (/opt/nordic/ncs/v3.0.2/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (/opt/nordic/ncs/v3.0.2/modules/lib/loramac-node)
    # lvgl (/opt/nordic/ncs/v3.0.2/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (/opt/nordic/ncs/v3.0.2/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    # nrf_wifi (/opt/nordic/ncs/v3.0.2/modules/lib/nrf_wifi)
    CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
    # CONFIG_NRF70_BUSLIB is not set
    # end of nrf_wifi (/opt/nordic/ncs/v3.0.2/modules/lib/nrf_wifi)
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # percepio (/opt/nordic/ncs/v3.0.2/modules/debug/percepio)
    # Percepio Tracealyzer support can be enabled from the tracing subsystem
    # CONFIG_PERCEPIO_DFM is not set
    CONFIG_ZEPHYR_PERCEPIO_MODULE=y
    # end of percepio (/opt/nordic/ncs/v3.0.2/modules/debug/percepio)
    # picolibc (/opt/nordic/ncs/v3.0.2/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (/opt/nordic/ncs/v3.0.2/modules/lib/picolibc)
    # segger (/opt/nordic/ncs/v3.0.2/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    # end of segger (/opt/nordic/ncs/v3.0.2/modules/debug/segger)
    CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    # uoscore-uedhoc (/opt/nordic/ncs/v3.0.2/modules/lib/uoscore-uedhoc)
    # CONFIG_UOSCORE is not set
    # CONFIG_UEDHOC is not set
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (/opt/nordic/ncs/v3.0.2/modules/lib/uoscore-uedhoc)
    # zcbor (/opt/nordic/ncs/v3.0.2/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    CONFIG_ZCBOR=y
    CONFIG_ZCBOR_CANONICAL=y
    # CONFIG_ZCBOR_STOP_ON_ERROR is not set
    # CONFIG_ZCBOR_VERBOSE is not set
    CONFIG_ZCBOR_ASSERT=y
    CONFIG_ZCBOR_MAX_STR_LEN=256
    # end of zcbor (/opt/nordic/ncs/v3.0.2/modules/lib/zcbor)
    # nrfxlib (/opt/nordic/ncs/v3.0.2/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # end of nrf_modem (Modem library)
    CONFIG_NFC_T2T_NRFXLIB=y
    # CONFIG_NFC_T4T_NRFXLIB is not set
    CONFIG_MPSL=y
    CONFIG_MPSL_BUILD_TYPE_LIB=y
    CONFIG_MPSL_LIB_DIR="nrf54l"
    CONFIG_MPSL_LIB_FLOAT_ABI_DIR="hard-float"
    # Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    # OpenThread
    CONFIG_OPENTHREAD_LIBRARY=y
    CONFIG_OPENTHREAD_NORDIC_LIBRARY=y
    CONFIG_OPENTHREAD_NORDIC_LIBRARY_COMMON=y
    # CONFIG_OPENTHREAD_NORDIC_LIBRARY_MASTER is not set
    # CONFIG_OPENTHREAD_NORDIC_LIBRARY_FTD is not set
    CONFIG_OPENTHREAD_NORDIC_LIBRARY_MTD=y
    # CONFIG_OPENTHREAD_NORDIC_LIBRARY_RCP is not set
    # CONFIG_OPENTHREAD_USER_CUSTOM_LIBRARY is not set
    # CONFIG_OPENTHREAD_BUILD_OUTPUT_STRIPPED is not set
    CONFIG_OPENTHREAD_NRFXLIB_RELEASE_TAG="Not specified"
    # end of OpenThread
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    CONFIG_NRF_802154_SL=y
    CONFIG_NRF_802154_CCAIDLE_TO_TXEN_EXTRA_TIME_US=0
    # CONFIG_NRF_DM is not set
    # CONFIG_SW_CODEC_LC3_T2_SOFTWARE is not set
    CONFIG_NRF_FUEL_GAUGE=y
    CONFIG_NRF_FUEL_GAUGE_VARIANT_PRIMARY_CELL=y
    # CONFIG_NRF_FUEL_GAUGE_VARIANT_SECONDARY_CELL is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (/opt/nordic/ncs/v3.0.2/nrfxlib)
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    # connectedhomeip (/opt/nordic/ncs/v3.0.2/modules/lib/matter)
    CONFIG_CHIP=y
    CONFIG_CHIP_DEVICE_VENDOR_ID=65521
    CONFIG_CHIP_DEVICE_VENDOR_NAME="Mobile Tech Inc"
    CONFIG_CHIP_DEVICE_PRODUCT_ID=32774
    CONFIG_CHIP_DEVICE_PRODUCT_NAME="MTI Padlock"
    CONFIG_CHIP_DEVICE_HARDWARE_VERSION=1
    CONFIG_CHIP_DEVICE_HARDWARE_VERSION_STRING="Pre-Production"
    CONFIG_CHIP_DEVICE_MANUFACTURING_DATE="2025-08-01"
    CONFIG_CHIP_DEVICE_SERIAL_NUMBER="11223344556677889900"
    CONFIG_CHIP_DEVICE_ROTATING_DEVICE_UID="91a9c12a7c80700a31ddcfa7fce63e44"
    CONFIG_CHIP_DEVICE_TYPE=65535
    CONFIG_CHIP_DEVICE_DISCRIMINATOR=0xF00
    CONFIG_CHIP_DEVICE_SPAKE2_PASSCODE=20202021
    CONFIG_CHIP_DEVICE_SPAKE2_IT=1000
    CONFIG_CHIP_DEVICE_SPAKE2_SALT="U1BBS0UyUCBLZXkgU2FsdA=="
    CONFIG_CHIP_DEVICE_SPAKE2_TEST_VERIFIER="uWFwqugDNGiEck/po7KHwwMwwqZgN10XuyBajPGuyzUEV/iree4lOrao5GuwnlQ65CJzbeUB49s31EH+NEkg0JVI5MGCQGMMT/SRPFNRODm3wH/MBiehuFc6FJ/NH6Rmzw=="
    CONFIG_CHIP_DEVICE_ENABLE_KEY="00112233445566778899AABBCCDDEEFF"
    CONFIG_CHIP_DEVICE_PRODUCT_FINISH="matte"
    CONFIG_CHIP_DEVICE_PRODUCT_COLOR="black"
    # CONFIG_CHIP_ENABLE_PAIRING_AUTOSTART is not set
    # CONFIG_CHIP_ROTATING_DEVICE_ID is not set
    # CONFIG_CHIP_COMMISSIONABLE_DEVICE_TYPE is not set
    # CONFIG_CHIP_EXTENDED_DISCOVERY is not set
    CONFIG_CHIP_OPERATIONAL_TIME_SAVE_INTERVAL=10
    CONFIG_CHIP_PERSISTENT_SUBSCRIPTIONS=y
    # CONFIG_CHIP_STATISTICS is not set
    # CONFIG_CHIP_LIB_SHELL is not set
    CONFIG_CHIP_PROJECT_CONFIG="src/chip_project_config.h"
    CONFIG_CHIP_ENABLE_DNSSD_SRP=y
    CONFIG_CHIP_ENABLE_DNS_CLIENT=y
    CONFIG_CHIP_ICD_SLOW_POLL_INTERVAL=5000
    CONFIG_CHIP_ICD_SIT_SLOW_POLL_LIMIT=15000
    CONFIG_CHIP_ICD_FAST_POLLING_INTERVAL=200
    CONFIG_CHIP_ICD_IDLE_MODE_DURATION=120
    CONFIG_CHIP_ICD_ACTIVE_MODE_DURATION=300
    CONFIG_CHIP_ICD_ACTIVE_MODE_THRESHOLD=300
    # CONFIG_CHIP_ICD_LIT_SUPPORT is not set
    # CONFIG_CHIP_ICD_CHECK_IN_SUPPORT is not set
    # CONFIG_CHIP_ICD_UAT_SUPPORT is not set
    # CONFIG_CHIP_ICD_REPORT_ON_ACTIVE_MODE is not set
    # CONFIG_CHIP_THREAD_SSED is not set
    CONFIG_CHIP_OPENTHREAD_CONFIG=""
    # CONFIG_CHIP_CERTIFICATION_DECLARATION_STORAGE is not set
    CONFIG_CHIP_FACTORY_RESET_ERASE_SETTINGS=y
    CONFIG_CHIP_MALLOC_SYS_HEAP=y
    CONFIG_CHIP_MALLOC_SYS_HEAP_OVERRIDE=y
    # CONFIG_CHIP_MALLOC_SYS_HEAP_WATERMARKS_SUPPORT is not set
    # CONFIG_CHIP_MALLOC_SYS_HEAP_DEBUG is not set
    # CONFIG_MATTER_LOG_LEVEL_OFF is not set
    # CONFIG_MATTER_LOG_LEVEL_ERR is not set
    # CONFIG_MATTER_LOG_LEVEL_WRN is not set
    CONFIG_MATTER_LOG_LEVEL_INF=y
    # CONFIG_MATTER_LOG_LEVEL_DBG is not set
    # CONFIG_MATTER_LOG_LEVEL_DEFAULT is not set
    CONFIG_MATTER_LOG_LEVEL=3
    CONFIG_APP_LINK_WITH_CHIP=y
    # CONFIG_CHIP_PW_RPC is not set
    # CONFIG_CHIP_BUILD_TESTS is not set
    CONFIG_CHIP_OTA_IMAGE_BUILD=y
    CONFIG_CHIP_OTA_IMAGE_FILE_NAME="matter.ota"
    CONFIG_CHIP_OTA_IMAGE_EXTRA_ARGS=""
    # CONFIG_CHIP_BLE_EXT_ADVERTISING is not set
    CONFIG_CHIP_BLE_ADVERTISING_DURATION=5
    # CONFIG_USE_CHIP_DATA_MODEL_INTERFACE is not set
    CONFIG_CHIP_NRF_PLATFORM=y
    CONFIG_CHIP_BOOTLOADER_MCUBOOT=y
    # CONFIG_CHIP_BOOTLOADER_NONE is not set
    CONFIG_CHIP_DFU_LIBRARY_MCUMGR=y
    CONFIG_CHIP_DFU_LIBRARY_DFU_TARGET=y
    CONFIG_CHIP_OTA_REQUESTOR_BUFFER_SIZE=1024
    CONFIG_CHIP_OTA_REQUESTOR_REBOOT_ON_APPLY=y
    CONFIG_CHIP_EXAMPLE_DEVICE_INFO_PROVIDER=y
    CONFIG_CHIP_DEBUG_SYMBOLS=y
    # CONFIG_CHIP_LOG_VERIFY_OR_DIE is not set
    CONFIG_CHIP_LOG_FILE_NAME=y
    CONFIG_CHIP_FACTORY_DATA=y
    CONFIG_CHIP_FACTORY_DATA_BUILD=y
    CONFIG_CHIP_FACTORY_DATA_VERSION=1
    CONFIG_CHIP_FACTORY_DATA_ROTATING_DEVICE_UID_MAX_LEN=16
    CONFIG_CHIP_FACTORY_DATA_MERGE_WITH_FIRMWARE=y
    CONFIG_CHIP_FACTORY_DATA_GENERATE_ONBOARDING_CODES=y
    CONFIG_CHIP_FACTORY_DATA_USE_DEFAULT_CERTS=y
    # CONFIG_CHIP_FACTORY_DATA_CERT_SOURCE_GENERATED is not set
    # CONFIG_CHIP_FACTORY_DATA_CERT_SOURCE_USER is not set
    # CONFIG_CHIP_FACTORY_DATA_GENERATE_CD is not set
    CONFIG_CHIP_FACTORY_DATA_GENERATE_SPAKE2_VERIFIER=y
    CONFIG_CHIP_DEVICE_GENERATE_ROTATING_DEVICE_UID=y
    CONFIG_CHIP_ENABLE_READ_CLIENT=y
    CONFIG_CHIP_CRYPTO_PSA_MIGRATE_DAC_PRIV_KEY=y
    # CONFIG_CHIP_CRYPTO_PSA_DAC_PRIV_KEY_ITS is not set
    CONFIG_CHIP_CRYPTO_PSA_DAC_PRIV_KEY_KMU=y
    CONFIG_CHIP_CRYPTO_PSA_DAC_PRIV_KEY_KMU_SLOT_ID=176
    CONFIG_CHIP_CRYPTO_PSA_DAC_PRIV_KEY_KMU_ENCRYPTED=y
    # CONFIG_CHIP_STORE_KEYS_IN_KMU is not set
    CONFIG_CHIP_MAX_FABRICS=5
    CONFIG_CHIP_MAX_ACTIVE_CASE_CLIENTS=5
    CONFIG_CHIP_MAX_ACTIVE_DEVICES=5
    CONFIG_CHIP_SUBSCRIPTION_RESUMPTION_MIN_RETRY_INTERVAL=20
    CONFIG_CHIP_SUBSCRIPTION_RESUMPTION_RETRY_MULTIPLIER=40
    # CONFIG_CHIP_ENABLE_BDX_LOG_TRANSFER is not set
    CONFIG_CHIP_SYSTEM_PACKETBUFFER_POOL_SIZE=15
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (/opt/nordic/ncs/v3.0.2/modules/lib/matter)
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_HAS_MEC5_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_TINYCRYPT is not set
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="/Users/subumuthu/Nordic/fw-Gen2_Locks/image_signing/mti_gen2_image_signing_priv.pem"
    CONFIG_MCUBOOT_ENCRYPTION_KEY_FILE=""
    CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="0.0.1+0"
    # CONFIG_MCUBOOT_IMGTOOL_OVERWRITE_ONLY is not set
    CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
    # On board MCUboot operation mode
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_RAM_LOAD is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_FIRMWARE_UPDATER is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y
    # CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set
    # CONFIG_MCUBOOT_BOOTLOADER_USES_SHA512 is not set
    # end of On board MCUboot operation mode
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL=1
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD="nrf54l15dk"
    CONFIG_BOARD_REVISION=""
    CONFIG_BOARD_TARGET="nrf54l15dk/nrf54l15/cpuapp"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF54L15DK=y
    CONFIG_BOARD_NRF54L15DK_NRF54L15_CPUAPP=y
    CONFIG_BOARD_QUALIFIERS="nrf54l15/cpuapp"
    # Board Options
    # end of Board Options
    # Hardware Configuration
    CONFIG_SOC="nrf54l15"
    CONFIG_SOC_SERIES="nrf54l"
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NORDIC_NRF=y
    CONFIG_SOC_SERIES_NRF54LX=y
    CONFIG_SOC_NRF54L15=y
    CONFIG_SOC_NRF54L15_CPUAPP=y
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIO2=y
    CONFIG_HAS_HW_NRF_GPIOTE20=y
    CONFIG_HAS_HW_NRF_GPIOTE30=y
    CONFIG_HAS_HW_NRF_GRTC=y
    CONFIG_HAS_HW_NRF_PWM20=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
    CONFIG_HAS_HW_NRF_RADIO_CS=y
    CONFIG_HAS_HW_NRF_RADIO_DFE=y
    CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM00=y
    CONFIG_HAS_HW_NRF_TEMP=y
    CONFIG_HAS_HW_NRF_TWIM21=y
    CONFIG_HAS_HW_NRF_UARTE30=y
    CONFIG_HAS_HW_NRF_WDT31=y
    CONFIG_HAS_NORDIC_RAM_CTRL=y
    # CONFIG_NRF_FORCE_RAM_ON_REBOOT is not set
    # CONFIG_NRF_SYS_EVENT is not set
    # CONFIG_SOC_NRF54H20_GPD is not set
    CONFIG_SOC_NRF54L_CPUAPP_COMMON=y
    # CONFIG_SOC_NRF54LX_DISABLE_FICR_TRIMCNF is not set
    # CONFIG_SOC_NRF54LX_SKIP_GLITCHDETECTOR_DISABLE is not set
    # CONFIG_SOC_NRF_FORCE_CONSTLAT is not set
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_DISABLE=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_DISABLE=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    CONFIG_GPIO_INIT_PRIORITY=40
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=1
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF54LX=y
    CONFIG_ARCH="arm"
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_CPU_CORTEX=y
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # ARM Options
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    # CONFIG_PLATFORM_SPECIFIC_INIT is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_ARM_STORE_EXC_RETURN=y
    CONFIG_FP_HARDABI=y
    # CONFIG_FP_SOFTABI is not set
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_ZERO_LATENCY_IRQS=y
    CONFIG_ZERO_LATENCY_LEVELS=1
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    # CONFIG_ARM_TRUSTZONE_M is not set
    CONFIG_MPU_STACK_GUARD=y
    CONFIG_MPU_STACK_GUARD_MIN_SIZE_FLOAT=128
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    CONFIG_CPU_HAS_ARM_SAU=y
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ISR_TABLE_SHELL is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=1
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # CONFIG_FRAME_POINTER is not set
    # Interrupt Configuration
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_EXCEPTION_DEBUG=y
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_CPU_HAS_ICACHE=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=1
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # DSP Options
    # end of DSP Options
    # Floating Point Options
    CONFIG_FPU_SHARING=y
    # end of Floating Point Options
    # Cache Options
    CONFIG_ICACHE=y
    # CONFIG_ICACHE_LINE_SIZE_DETECT is not set
    # CONFIG_ARCH_CACHE is not set
    CONFIG_EXTERNAL_CACHE=y
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=1
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    # CONFIG_SCHED_DUMB is not set
    CONFIG_SCHED_SIMPLE=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_DUMB is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_SIMPLE=y
    # Misc Kernel related options
    CONFIG_ERRNO=y
    # end of Misc Kernel related options
    # Kernel Debugging and Metrics
    CONFIG_BOOT_DELAY=0
    # CONFIG_BOOT_CLEAR_SCREEN is not set
    # CONFIG_THREAD_MONITOR is not set
    CONFIG_THREAD_NAME=y
    CONFIG_THREAD_MAX_NAME_LEN=32
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # System Work Queue Options
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of System Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # end of Timer API Options
    # Other Kernel Object Options
    CONFIG_POLL=y
    CONFIG_MEM_SLAB_POINTER_VALIDATE=y
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    CONFIG_EVENTS=y
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # end of Other Kernel Object Options
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    # Security Options
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # Memory Domains
    CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
    CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
    # end of Memory Domains
    # SMP Options
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # CONFIG_THREAD_LOCAL_STORAGE is not set
    CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
    CONFIG_STATIC_INIT_GNU=y
    # CONFIG_BOOTARGS is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # CONFIG_DEVICE_MUTABLE is not set
    # CONFIG_DEVICE_DT_METADATA is not set
    # end of Device Options
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Virtual Memory Support
    # end of Virtual Memory Support
    # SoC and Board Hooks
    # CONFIG_SOC_PREP_HOOK is not set
    # CONFIG_SOC_EARLY_INIT_HOOK is not set
    # CONFIG_SOC_LATE_INIT_HOOK is not set
    # CONFIG_SOC_PER_CORE_INIT_HOOK is not set
    # CONFIG_BOARD_EARLY_INIT_HOOK is not set
    # CONFIG_BOARD_LATE_INIT_HOOK is not set
    # end of SoC and Board Hooks
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    CONFIG_BT_DRIVERS=y
    # Bluetooth HCI Driver Options
    CONFIG_BT_HCI_INIT_PRIORITY=50
    # CONFIG_HCI_NXP_SET_CAL_DATA_ANNEX100 is not set
    CONFIG_FLASH=y
    CONFIG_BT_DRV_TX_STACK_SIZE=256
    CONFIG_BT_DRV_RX_STACK_SIZE=256
    CONFIG_CACHE_HAS_DRIVER=y
    # CONFIG_CACHE_LOG_LEVEL_OFF is not set
    # CONFIG_CACHE_LOG_LEVEL_ERR is not set
    # CONFIG_CACHE_LOG_LEVEL_WRN is not set
    # CONFIG_CACHE_LOG_LEVEL_INF is not set
    # CONFIG_CACHE_LOG_LEVEL_DBG is not set
    CONFIG_CACHE_LOG_LEVEL_DEFAULT=y
    CONFIG_CACHE_LOG_LEVEL=1
    # Device Drivers
    # CONFIG_CACHE_NRF_PATCH_LINEADDR is not set
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=1
    CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
    CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_LF_ALWAYS_ON=y
    CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_PERIOD=4000
    CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_MAX_SKIP=1
    CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_TEMP_DIFF=2
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=500
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    # CONFIG_CLOCK_CONTROL_RTS5912_SCCON is not set
    # CONFIG_COMPARATOR is not set
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=1
    # CONFIG_EFI_CONSOLE is not set
    CONFIG_WINSTREAM_CONSOLE_STATIC=y
    CONFIG_WINSTREAM_CONSOLE_STATIC_SIZE=32768
    # CONFIG_COREDUMP_DEVICE is not set
    CONFIG_COUNTER_INIT_PRIORITY=60
    # CONFIG_COUNTER_SHELL is not set
    # CONFIG_COUNTER_LOG_LEVEL_OFF is not set
    # CONFIG_COUNTER_LOG_LEVEL_ERR is not set
    # CONFIG_COUNTER_LOG_LEVEL_WRN is not set
    # CONFIG_COUNTER_LOG_LEVEL_INF is not set
    # CONFIG_COUNTER_LOG_LEVEL_DBG is not set
    CONFIG_COUNTER_LOG_LEVEL_DEFAULT=y
    CONFIG_COUNTER_LOG_LEVEL=1
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_DP_DRIVER is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    CONFIG_ENTROPY_GENERATOR=y
    # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
    # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
    # CONFIG_ENTROPY_LOG_LEVEL_INF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
    CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y
    CONFIG_ENTROPY_LOG_LEVEL=1
    CONFIG_ENTROPY_BT_HCI=y
    CONFIG_ENTROPY_PSA_CRYPTO_RNG=y
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_ESPI is not set
    # CONFIG_ETH_DRIVER is not set
    # Firmware drivers
    # CONFIG_ARM_SCMI is not set
    # end of Firmware drivers
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_EX_OP=y
    CONFIG_FLASH_HAS_EXPLICIT_ERASE=y
    CONFIG_FLASH_HAS_NO_EXPLICIT_ERASE=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH_JESD216=y
    # CONFIG_FLASH_JESD216_API is not set
    CONFIG_FLASH_PAGE_LAYOUT=y
    # CONFIG_FLASH_EX_OP_ENABLED is not set
    # MSPI flash device driver
    # end of MSPI flash device driver
    CONFIG_SPI_NOR_SFDP_MINIMAL=y
    # CONFIG_SPI_NOR_SFDP_DEVICETREE is not set
    # CONFIG_SPI_NOR_SFDP_RUNTIME is not set
    CONFIG_SPI_NOR_INIT_PRIORITY=80
    CONFIG_SPI_NOR_CS_WAIT_DELAY=0
    CONFIG_SPI_NOR_SLEEP_WHILE_WAITING_UNTIL_READY=y
    CONFIG_SPI_NOR_ACTIVE_DWELL_MS=10
    CONFIG_FLASH_NRF_FORCE_ALT=y
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE is not set
    CONFIG_SOC_FLASH_NRF_TIMEOUT_MULTIPLIER=15
    CONFIG_SOC_FLASH_NRF_RRAM=y
    CONFIG_NRF_RRAM_WRITE_BUFFER_SIZE=32
    CONFIG_NRF_RRAM_READYNEXT_TIMEOUT_VALUE=128
    CONFIG_NRF_RRAM_REGION_ADDRESS_RESOLUTION=0x1000
    CONFIG_NRF_RRAM_REGION_SIZE_UNIT=0x1000
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_FLASH_LOG_LEVEL=1
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=1
    # CONFIG_GPIO_SHELL is not set
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NPM2100=y
    CONFIG_GPIO_NPM2100_INIT_PRIORITY=80
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_GPIO_RTS5912 is not set
    # CONFIG_HAPTICS is not set
    # CONFIG_HDLC_RCP_IF is not set
    CONFIG_HWINFO=y
    # CONFIG_HWINFO_LOG_LEVEL_OFF is not set
    # CONFIG_HWINFO_LOG_LEVEL_ERR is not set
    # CONFIG_HWINFO_LOG_LEVEL_WRN is not set
    # CONFIG_HWINFO_LOG_LEVEL_INF is not set
    # CONFIG_HWINFO_LOG_LEVEL_DBG is not set
    CONFIG_HWINFO_LOG_LEVEL_DEFAULT=y
    CONFIG_HWINFO_LOG_LEVEL=1
    CONFIG_HWINFO_HAS_DRIVER=y
    CONFIG_HWINFO_NRF=y
    # CONFIG_HWSPINLOCK is not set
    CONFIG_I2C=y
    CONFIG_I2C_SHELL=y
    # CONFIG_I2C_CALLBACK is not set
    # CONFIG_I2C_RTIO is not set
    # CONFIG_I2C_TARGET is not set
    CONFIG_I2C_NRFX=y
    CONFIG_I2C_NRFX_TWIM=y
    CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
    CONFIG_I2C_SAM0_TRANSFER_TIMEOUT=500
    CONFIG_I2C_INIT_PRIORITY=50
    # CONFIG_I2C_LOG_LEVEL_OFF is not set
    # CONFIG_I2C_LOG_LEVEL_ERR is not set
    # CONFIG_I2C_LOG_LEVEL_WRN is not set
    # CONFIG_I2C_LOG_LEVEL_INF is not set
    # CONFIG_I2C_LOG_LEVEL_DBG is not set
    CONFIG_I2C_LOG_LEVEL_DEFAULT=y
    CONFIG_I2C_LOG_LEVEL=1
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    CONFIG_IEEE802154=y
    # CONFIG_IEEE802154_NET_IF_NO_AUTO_START is not set
    # CONFIG_IEEE802154_VENDOR_OUI_ENABLE is not set
    CONFIG_IEEE802154_L2_PKT_INCL_FCS=y
    CONFIG_IEEE802154_NRF5_INIT_PRIO=80
    CONFIG_IEEE802154_NRF5_EXT_IRQ_MGMT=y
    # CONFIG_IEEE802154_NRF5_LOG_RX_FAILURES is not set
    # CONFIG_IEEE802154_NRF5_MULTIPLE_CCA is not set
    # CONFIG_IEEE802154_NRF5_CST_ENDPOINT is not set
    # CONFIG_IEEE802154_CSL_DEBUG is not set
    # CONFIG_IEEE802154_SELECTIVE_TXCHANNEL is not set
    # CONFIG_IEEE802154_CARRIER_FUNCTIONS is not set
    # CONFIG_IEEE802154_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_IEEE802154_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_IEEE802154_DRIVER_LOG_LEVEL_WRN is not set
    # CONFIG_IEEE802154_DRIVER_LOG_LEVEL_INF is not set
    # CONFIG_IEEE802154_DRIVER_LOG_LEVEL_DBG is not set
    CONFIG_IEEE802154_DRIVER_LOG_LEVEL_DEFAULT=y
    CONFIG_IEEE802154_DRIVER_LOG_LEVEL=1
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=1
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    CONFIG_LED=y
    # CONFIG_LED_LOG_LEVEL_OFF is not set
    # CONFIG_LED_LOG_LEVEL_ERR is not set
    # CONFIG_LED_LOG_LEVEL_WRN is not set
    # CONFIG_LED_LOG_LEVEL_INF is not set
    # CONFIG_LED_LOG_LEVEL_DBG is not set
    CONFIG_LED_LOG_LEVEL_DEFAULT=y
    CONFIG_LED_LOG_LEVEL=1
    CONFIG_LED_INIT_PRIORITY=90
    # CONFIG_LED_SHELL is not set
    CONFIG_LED_GPIO=y
    CONFIG_LED_PWM=y
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MBOX is not set
    # CONFIG_MDIO is not set
    # CONFIG_MFD_LOG_LEVEL_OFF is not set
    # CONFIG_MFD_LOG_LEVEL_ERR is not set
    # CONFIG_MFD_LOG_LEVEL_WRN is not set
    # CONFIG_MFD_LOG_LEVEL_INF is not set
    # CONFIG_MFD_LOG_LEVEL_DBG is not set
    CONFIG_MFD_LOG_LEVEL_DEFAULT=y
    CONFIG_MFD_LOG_LEVEL=1
    CONFIG_MFD_INIT_PRIORITY=80
    CONFIG_MFD_NPM2100=y
    # CONFIG_MIPI_DBI is not set
    # Miscellaneous Drivers
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_MSPI is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    CONFIG_PINCTRL=y
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=1
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PINCTRL_REALTEK_RTS5912 is not set
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    CONFIG_PWM=y
    # CONFIG_PWM_LOG_LEVEL_OFF is not set
    # CONFIG_PWM_LOG_LEVEL_ERR is not set
    # CONFIG_PWM_LOG_LEVEL_WRN is not set
    # CONFIG_PWM_LOG_LEVEL_INF is not set
    # CONFIG_PWM_LOG_LEVEL_DBG is not set
    CONFIG_PWM_LOG_LEVEL_DEFAULT=y
    CONFIG_PWM_LOG_LEVEL=1
    CONFIG_PWM_INIT_PRIORITY=50
    # CONFIG_PWM_SHELL is not set
    # CONFIG_PWM_CAPTURE is not set
    CONFIG_PWM_NRFX=y
    CONFIG_PWM_TC_INIT_PRIORITY=50
    CONFIG_REGULATOR_THREAD_SAFE_REFCNT=y
    # CONFIG_REGULATOR_SHELL is not set
    # CONFIG_REGULATOR_LOG_LEVEL_OFF is not set
    # CONFIG_REGULATOR_LOG_LEVEL_ERR is not set
    # CONFIG_REGULATOR_LOG_LEVEL_WRN is not set
    # CONFIG_REGULATOR_LOG_LEVEL_INF is not set
    # CONFIG_REGULATOR_LOG_LEVEL_DBG is not set
    CONFIG_REGULATOR_LOG_LEVEL_DEFAULT=y
    CONFIG_REGULATOR_LOG_LEVEL=1
    CONFIG_REGULATOR_NPM2100=y
    CONFIG_REGULATOR_NPM2100_COMMON_INIT_PRIORITY=85
    CONFIG_REGULATOR_NPM2100_INIT_PRIORITY=86
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # CONFIG_SENSOR_LOG_LEVEL_OFF is not set
    # CONFIG_SENSOR_LOG_LEVEL_ERR is not set
    # CONFIG_SENSOR_LOG_LEVEL_WRN is not set
    # CONFIG_SENSOR_LOG_LEVEL_INF is not set
    # CONFIG_SENSOR_LOG_LEVEL_DBG is not set
    CONFIG_SENSOR_LOG_LEVEL_DEFAULT=y
    CONFIG_SENSOR_LOG_LEVEL=1
    CONFIG_SENSOR_INIT_PRIORITY=90
    # CONFIG_SENSOR_ASYNC_API is not set
    # CONFIG_SENSOR_SHELL_BATTERY is not set
    # CONFIG_SENSOR_INFO is not set
    # Device Drivers
    CONFIG_ADXL345_TRIGGER_NONE=y
    # CONFIG_ADXL345_TRIGGER_GLOBAL_THREAD is not set
    # CONFIG_ADXL345_TRIGGER_OWN_THREAD is not set
    CONFIG_SENSOR_DS3231_INIT_PRIORITY=86
    CONFIG_NPM2100_VBAT=y
    CONFIG_TEMP_NRF5_FORCE_ALT=y
    CONFIG_TEMP_NRF5=y
    # CONFIG_TDK_APEX is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=1
    CONFIG_UART_ASYNC_API=y
    CONFIG_UART_EXCLUSIVE_API_CALLBACKS=y
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # CONFIG_UART_SHELL is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    CONFIG_UART_NRFX_UARTE_ENHANCED_RX=y
    CONFIG_UART_ASYNC_TX_CACHE_SIZE=8
    # CONFIG_UART_30_INTERRUPT_DRIVEN is not set
    CONFIG_UART_30_ASYNC=y
    # CONFIG_UART_30_NRF_PARITY_BIT is not set
    CONFIG_UART_30_NRF_TX_BUFFER_SIZE=32
    # CONFIG_UART_30_NRF_ASYNC_LOW_POWER is not set
    # CONFIG_UART_RTS5912 is not set
    # CONFIG_SMBUS is not set
    # CONFIG_SPI_SHELL is not set
    # CONFIG_SPI_ASYNC is not set
    # CONFIG_SPI_RTIO is not set
    # CONFIG_SPI_SLAVE is not set
    # CONFIG_SPI_EXTENDED_MODES is not set
    CONFIG_SPI_INIT_PRIORITY=50
    CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    # CONFIG_SPI_LOG_LEVEL_OFF is not set
    # CONFIG_SPI_LOG_LEVEL_ERR is not set
    # CONFIG_SPI_LOG_LEVEL_WRN is not set
    # CONFIG_SPI_LOG_LEVEL_INF is not set
    # CONFIG_SPI_LOG_LEVEL_DBG is not set
    CONFIG_SPI_LOG_LEVEL_DEFAULT=y
    CONFIG_SPI_LOG_LEVEL=1
    CONFIG_SPI_NRFX=y
    CONFIG_SPI_NRFX_SPIM=y
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
    CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200
    # CONFIG_STEPPER is not set
    # Timer drivers
    CONFIG_TIMER_HAS_64BIT_CYCLE_COUNTER=y
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_NRF_GRTC_TIMER=y
    # CONFIG_NRF_GRTC_TIMER_APP_DEFINED_INIT is not set
    CONFIG_NRF_GRTC_START_SYSCOUNTER=y
    CONFIG_NRF_GRTC_TIMER_CLOCK_MANAGEMENT=y
    CONFIG_NRF_GRTC_SYSCOUNTER_SLEEP_MINIMUM_LATENCY=1000
    CONFIG_NRF_GRTC_TIMER_AUTO_KEEP_ALIVE=y
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # CONFIG_REALTEK_RTS5912_RTMR is not set
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=1
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=1
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_USBC_PPC_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    CONFIG_NET_TC_TX_COUNT=0
    CONFIG_NET_INTERFACE_NAME_LEN=8
    # CONFIG_TEE is not set
    CONFIG_REQUIRES_FULL_LIBC=y
    CONFIG_REQUIRES_FLOAT_PRINTF=y
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    # CONFIG_PICOLIBC is not set
    CONFIG_NEWLIB_LIBC=y
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_ASCTIME_R is not set
    # CONFIG_COMMON_LIBC_CTIME_R is not set
    # CONFIG_COMMON_LIBC_MALLOC is not set
    # CONFIG_COMMON_LIBC_REMOVE is not set
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
    # CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
    # CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
    # CONFIG_NEWLIB_LIBC_CUSTOM_SBRK is not set
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    CONFIG_CPP=y
    # CONFIG_STD_CPP98 is not set
    # CONFIG_STD_CPP11 is not set
    # CONFIG_STD_CPP14 is not set
    CONFIG_STD_CPP17=y
    # CONFIG_STD_CPP2A is not set
    # CONFIG_STD_CPP20 is not set
    # CONFIG_STD_CPP2B is not set
    CONFIG_REQUIRES_FULL_LIBCPP=y
    CONFIG_FULL_LIBCPP_SUPPORTED=y
    CONFIG_GLIBCXX_LIBCPP=y
    # CONFIG_EXTERNAL_LIBCPP is not set
    # CONFIG_EXTERNAL_MODULE_LIBCPP is not set
    # CONFIG_CPP_RTTI is not set
    # end of C++ Language Support
    CONFIG_CRC=y
    # CONFIG_CRC_SHELL is not set
    # Additional libraries
    # Hash Function Support
    CONFIG_SYS_HASH_FUNC32=y
    # CONFIG_SYS_HASH_FUNC32_DJB2 is not set
    CONFIG_SYS_HASH_FUNC32_MURMUR3=y
    # CONFIG_SYS_HASH_FUNC32_CHOICE_DJB2 is not set
    CONFIG_SYS_HASH_FUNC32_CHOICE_MURMUR3=y
    # CONFIG_SYS_HASH_FUNC32_CHOICE_IDENTITY is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    # CONFIG_SYS_HEAP_STRESS is not set
    # CONFIG_SYS_HEAP_INFO is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    CONFIG_SYS_HEAP_RUNTIME_STATS=y
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_MULTI_HEAP is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # end of Heap and Memory Allocation
    # Memory Blocks
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Memory Blocks
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_BUF_LOG_LEVEL_INF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_BUF_LOG_LEVEL=1
    # CONFIG_NET_BUF_POOL_USAGE is not set
    CONFIG_NET_BUF_ALIGNMENT=0
    # OS Support Library
    CONFIG_FDTABLE=y
    CONFIG_ZVFS_OPEN_MAX=4
    # CONFIG_MPSC_PBUF is not set
    # CONFIG_SPSC_PBUF is not set
    CONFIG_HAS_POWEROFF=y
    CONFIG_POWEROFF=y
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    CONFIG_CBPRINTF_FP_SUPPORT=y
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_N_SPECIFIER=y
    CONFIG_CBPRINTF_LIBC_SUBSTS=y
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=1
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    CONFIG_ZVFS=y
    CONFIG_ZVFS_EVENTFD=y
    CONFIG_ZVFS_EVENTFD_MAX=1
    CONFIG_ZVFS_POLL=y
    CONFIG_ZVFS_POLL_MAX=3
    CONFIG_ZVFS_SELECT=y
    # end of OS Support Library
    # POSIX API Support
    # POSIX Options
    # CONFIG_POSIX_API is not set
    CONFIG_POSIX_AEP_CHOICE_NONE=y
    # CONFIG_POSIX_AEP_CHOICE_BASE is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
    # CONFIG_POSIX_ASYNCHRONOUS_IO is not set
    # CONFIG_POSIX_BARRIERS is not set
    # CONFIG_POSIX_C_LANG_SUPPORT_R is not set
    # CONFIG_POSIX_C_LIB_EXT is not set
    # POSIX device I/O
    # CONFIG_POSIX_DEVICE_IO is not set
    CONFIG_POSIX_OPEN_MAX=4
    # end of POSIX device I/O
    # CONFIG_POSIX_FD_MGMT is not set
    # CONFIG_POSIX_FILE_SYSTEM_R is not set
    # CONFIG_POSIX_FILE_SYSTEM is not set
    # POSIX memory
    CONFIG_POSIX_PAGE_SIZE=0x40
    # CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
    # CONFIG_POSIX_MAPPED_FILES is not set
    # CONFIG_POSIX_MEMORY_PROTECTION is not set
    # end of POSIX memory
    # CONFIG_POSIX_MESSAGE_PASSING is not set
    # CONFIG_POSIX_NETWORKING is not set
    # CONFIG_POSIX_SINGLE_PROCESS is not set
    # CONFIG_POSIX_MULTI_PROCESS is not set
    # CONFIG_POSIX_THREADS is not set
    # CONFIG_POSIX_READER_WRITER_LOCKS is not set
    # POSIX scheduler options
    # CONFIG_POSIX_PRIORITY_SCHEDULING is not set
    # end of POSIX scheduler options
    # CONFIG_POSIX_SEMAPHORES is not set
    # POSIX signals
    # CONFIG_POSIX_REALTIME_SIGNALS is not set
    # CONFIG_POSIX_SIGNALS is not set
    # end of POSIX signals
    # CONFIG_POSIX_SPIN_LOCKS is not set
    # POSIX synchronized I/O
    # CONFIG_POSIX_FSYNC is not set
    # CONFIG_POSIX_SYNCHRONIZED_IO is not set
    # end of POSIX synchronized I/O
    # CONFIG_POSIX_TIMERS is not set
    # X/Open system interfaces
    # CONFIG_XOPEN_STREAMS is not set
    # CONFIG_XSI_SYSTEM_LOGGING is not set
    # CONFIG_XSI_THREADS_EXT is not set
    # end of X/Open system interfaces
    # Miscellaneous POSIX-related options
    CONFIG_EVENTFD=y
    # end of Miscellaneous POSIX-related options
    # Deprecated POSIX options
    CONFIG_EVENTFD_MAX=1
    # CONFIG_FNMATCH is not set
    CONFIG_MAX_PTHREAD_COUNT=0
    CONFIG_MAX_PTHREAD_KEY_COUNT=0
    CONFIG_MAX_TIMER_COUNT=0
    CONFIG_MSG_COUNT_MAX=0
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_POSIX_FS is not set
    CONFIG_POSIX_LIMITS_RTSIG_MAX=0
    CONFIG_POSIX_MAX_OPEN_FILES=4
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_POSIX_PUTMSG is not set
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_POSIX_SYSCONF is not set
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_PTHREAD is not set
    # CONFIG_PTHREAD_BARRIER is not set
    # CONFIG_PTHREAD_COND is not set
    # CONFIG_PTHREAD_IPC is not set
    # CONFIG_PTHREAD_KEY is not set
    # CONFIG_PTHREAD_MUTEX is not set
    # CONFIG_PTHREAD_RWLOCK is not set
    # CONFIG_PTHREAD_SPINLOCK is not set
    # CONFIG_TIMER is not set
    CONFIG_TIMER_DELAYTIMER_MAX=0
    CONFIG_SEM_NAMELEN_MAX=0
    CONFIG_SEM_VALUE_MAX=0
    # end of Deprecated POSIX options
    CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
    # end of POSIX Options
    # POSIX Shell Utilities
    # CONFIG_POSIX_ENV_SHELL is not set
    # end of POSIX Shell Utilities
    # end of POSIX API Support
    # CONFIG_OPENAMP_RSC_TABLE is not set
    CONFIG_SMF=y
    CONFIG_SMF_ANCESTOR_SUPPORT=y
    CONFIG_SMF_INITIAL_TRANSITION=y
    CONFIG_LIBGCC_RTLIB=y
    # Utility Library
    # CONFIG_JSON_LIBRARY is not set
    CONFIG_RING_BUFFER=y
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    CONFIG_ONOFF=y
    # CONFIG_UTF8 is not set
    # end of Utility Library
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_SCA_UPDATE is not set
    # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
    # CONFIG_BT_PATH_LOSS_MONITORING is not set
    # CONFIG_BT_SUBRATING is not set
    # CONFIG_BT_CHANNEL_SOUNDING is not set
    # CONFIG_BT_ISO_PERIPHERAL is not set
    # CONFIG_BT_ISO_BROADCASTER is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # Bluetooth Classic Options
    # end of Bluetooth Classic Options
    # end of Bluetooth Host
    CONFIG_BT_CTLR_ENTROPY_SUPPORT=y
    CONFIG_BT_CTLR_CRYPTO_SUPPORT=y
    CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
    CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
    CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
    CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
    CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
    CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_CODING_SELECTION_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
    CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
    CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
    CONFIG_BT_CTLR_LE_POWER_CONTROL_SUPPORT=y
    CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING_SUPPORT=y
    CONFIG_BT_CTLR_SUBRATING_SUPPORT=y
    CONFIG_BT_CTLR_CHANNEL_SOUNDING_SUPPORT=y
    CONFIG_HAS_BT_CTLR=y
    CONFIG_BT_CTLR_HCI=y
    # Bluetooth Controller configuration
    CONFIG_BT_CTLR_ENTROPY=y
    CONFIG_BT_CTLR_CRYPTO=y
    CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
    # CONFIG_BT_CTLR_TX_PWR_PLUS_8 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_7 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_6 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_5 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_1 is not set
    CONFIG_BT_CTLR_TX_PWR_0=y
    # CONFIG_BT_CTLR_TX_PWR_MINUS_1 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_2 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_3 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_5 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_6 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_7 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_9 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_10 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_14 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_26 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_46 is not set
    CONFIG_BT_CTLR_TX_PWR_DBM=0
    CONFIG_BT_CTLR_TX_PWR_ANTENNA=0
    # CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
    # Bluetooth Controller features
    CONFIG_BT_CTLR_EXT_REJ_IND=y
    CONFIG_BT_CTLR_DATA_LENGTH=y
    CONFIG_BT_CTLR_PHY=y
    # CONFIG_BT_CTLR_CONN_RSSI is not set
    # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
    # CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING is not set
    # CONFIG_BT_CTLR_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_CTLR_PRIVACY=y
    CONFIG_BT_CTLR_RL_SIZE=8
    # CONFIG_BT_CTLR_PHY_CODED is not set
    CONFIG_BT_CTLR_CHAN_SEL_2=y
    CONFIG_BT_CTLR_ADV_EXT=y
    CONFIG_BT_CTLR_ADV_SET=1
    CONFIG_BT_CTLR_ADV_INTERVAL_MAX=0xFFFFFF
    CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=31
    # CONFIG_BT_CTLR_ADV_PERIODIC is not set
    # CONFIG_BT_CTLR_ADV_PERIODIC_RSP is not set
    # CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER is not set
    # CONFIG_BT_CTLR_ADV_ISO is not set
    # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
    # CONFIG_BT_CTLR_PERIPHERAL_ISO is not set
    # CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
    # CONFIG_BT_CTLR_SUBRATING is not set
    CONFIG_BT_CTLR_DF_CTE_TX_SUPPORT=y
    # CONFIG_BT_CTLR_ASSERT_HANDLER is not set
    # CONFIG_BT_EAD is not set
    # Bluetooth logging
    # Common
    # end of Common
    # Libraries
    # end of Libraries
    # Host
    # end of Host
    # Services
    # end of Services
    # end of Bluetooth logging
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_DAP is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    CONFIG_ASSERT_LEVEL=2
    CONFIG_SPIN_VALIDATE=y
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    CONFIG_DEBUG_COREDUMP=y
    CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
    # CONFIG_DEBUG_COREDUMP_BACKEND_FLASH_PARTITION is not set
    # CONFIG_DEBUG_COREDUMP_BACKEND_OTHER is not set
    # CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN is not set
    # CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_THREADS is not set
    CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_LINKER_RAM=y
    # CONFIG_DEBUG_COREDUMP_SHELL is not set
    # CONFIG_DEBUG_COREDUMP_THREADS_METADATA is not set
    # CONFIG_SYMTAB is not set
    # end of Debugging Options
    # CONFIG_MIPI_STP_DECODER is not set
    # CONFIG_CS_TRACE_DEFMT is not set
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
    CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE=0x8000
    CONFIG_IMG_BLOCK_BUF_SIZE=512
    # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
    CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y
    CONFIG_IMG_MANAGER_LOG_LEVEL=1
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM_LIB_LINK is not set
    # CONFIG_FILE_SYSTEM is not set
    # CONFIG_FCB is not set
    CONFIG_ZMS_LOOKUP_CACHE=y
    # CONFIG_ZMS_DATA_CRC is not set
    # CONFIG_ZMS_CUSTOMIZE_BLOCK_SIZE is not set
    CONFIG_ZMS_LOOKUP_CACHE_FOR_SETTINGS=y
    # CONFIG_ZMS_NO_DOUBLE_WRITE is not set
    # CONFIG_ZMS_LOG_LEVEL_OFF is not set
    # CONFIG_ZMS_LOG_LEVEL_ERR is not set
    # CONFIG_ZMS_LOG_LEVEL_WRN is not set
    # CONFIG_ZMS_LOG_LEVEL_INF is not set
    # CONFIG_ZMS_LOG_LEVEL_DBG is not set
    CONFIG_ZMS_LOG_LEVEL_DEFAULT=y
    CONFIG_ZMS_LOG_LEVEL=1
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # Linkable loadable Extension Development Kit (EDK)
    CONFIG_LLEXT_EDK_NAME="llext-edk"
    # CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
    # end of Linkable loadable Extension Development Kit (EDK)
    # Logging
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    # CONFIG_LOG_MODE_DEFERRED is not set
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    CONFIG_LOG_MODE_MINIMAL=y
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    # end of Processing
    # Misc
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_FMT_STRING_VALIDATE is not set
    # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
    # end of Misc
    # CONFIG_LOG_OUTPUT is not set
    # end of Logging
    CONFIG_MEM_ATTR=y
    # CONFIG_MEM_ATTR_HEAP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    CONFIG_MCUMGR=y
    # CONFIG_MCUMGR_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_LOG_LEVEL=1
    # CONFIG_MCUMGR_MGMT_HANDLER_USER_DATA is not set
    # CONFIG_MCUMGR_MGMT_CUSTOM_PAYLOAD is not set
    CONFIG_MCUMGR_SMP_CBOR_MAX_MAIN_MAP_ENTRIES=15
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVELS=2
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_2=y
    CONFIG_MCUMGR_SMP_CBOR_MAX_DECODING_LEVELS=2
    CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVELS=3
    CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVEL_3=y
    CONFIG_MCUMGR_SMP_CBOR_MAX_ENCODING_LEVELS=3
    CONFIG_MCUMGR_SMP_SUPPORT_ORIGINAL_PROTOCOL=y
    # CONFIG_MCUMGR_SMP_VERBOSE_ERR_RESPONSE is not set
    # CONFIG_MCUMGR_SMP_LEGACY_RC_BEHAVIOUR is not set
    # SMP Client
    # CONFIG_SMP_CLIENT is not set
    # end of SMP Client
    # Command Handlers
    CONFIG_MCUMGR_GRP_IMG=y
    CONFIG_MCUMGR_GRP_IMG_UPDATABLE_IMAGE_NUMBER=1
    # CONFIG_MCUMGR_GRP_IMG_VERBOSE_ERR is not set
    CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_SECONDARY=y
    # CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_ANY is not set
    CONFIG_MCUMGR_GRP_IMG_ALLOW_ERASE_PENDING=y
    # CONFIG_MCUMGR_GRP_IMG_DIRECT_UPLOAD is not set
    # CONFIG_MCUMGR_GRP_IMG_REJECT_DIRECT_XIP_MISMATCHED_SLOT is not set
    # CONFIG_MCUMGR_GRP_IMG_FRUGAL_LIST is not set
    # CONFIG_MCUMGR_GRP_IMG_VERSION_CMP_USE_BUILD_NUMBER is not set
    CONFIG_MCUMGR_GRP_IMG_STATUS_HOOKS=y
    # CONFIG_MCUMGR_GRP_IMG_MUTEX is not set
    CONFIG_MCUMGR_GRP_IMG_TOO_LARGE_DISABLED=y
    # CONFIG_MCUMGR_GRP_IMG_TOO_LARGE_SYSBUILD is not set
    # CONFIG_MCUMGR_GRP_IMG_IMAGE_SLOT_STATE_HOOK is not set
    CONFIG_MCUMGR_GRP_IMG_IMAGE_SLOT_STATE_STATES=15
    # CONFIG_MCUMGR_GRP_IMG_SLOT_INFO is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL=1
    CONFIG_MCUMGR_GRP_OS=y
    CONFIG_MCUMGR_GRP_OS_RESET_MS=250
    # CONFIG_MCUMGR_GRP_OS_RESET_HOOK is not set
    CONFIG_MCUMGR_GRP_OS_ECHO=y
    # CONFIG_MCUMGR_GRP_OS_INFO is not set
    CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO=y
    # CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO_HOOK is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_OS_LOG_LEVEL=1
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL=1
    # CONFIG_MCUMGR_GRP_SETTINGS is not set
    # CONFIG_MCUMGR_GRP_ENUM is not set
    # end of Command Handlers
    # Transports and Transport Related Configuration Options
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE=2048
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_THREAD_PRIO=3
    CONFIG_MCUMGR_TRANSPORT_REASSEMBLY=y
    CONFIG_MCUMGR_TRANSPORT_NETBUF_MIN_USER_DATA_SIZE=8
    CONFIG_MCUMGR_TRANSPORT_NETBUF_USER_DATA_SIZE=8
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL=1
    CONFIG_MCUMGR_TRANSPORT_BT=y
    CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y
    CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW=y
    # CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW_ENCRYPT is not set
    # CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW_AUTHEN is not set
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MIN_INT=6
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MAX_INT=9
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_LATENCY=0
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_TIMEOUT=42
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RESTORE_TIME=5000
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RETRY_TIME=1000
    CONFIG_MCUMGR_TRANSPORT_BT_DYNAMIC_SVC_REGISTRATION=y
    # CONFIG_MCUMGR_TRANSPORT_UDP is not set
    # end of Transports and Transport Related Configuration Options
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    CONFIG_NETWORKING=y
    # CONFIG_NET_HOSTNAME_ENABLE is not set
    # Link layer options
    # CONFIG_NET_L2_DUMMY is not set
    # CONFIG_NET_L2_VIRTUAL is not set
    # CONFIG_NET_L2_PPP is not set
    CONFIG_NET_L2_PHY_IEEE802154=y
    # CONFIG_OPENTHREAD_SOURCES is not set
    # Logging
    # CONFIG_OPENTHREAD_DEBUG is not set
    CONFIG_OPENTHREAD_LOG_LEVEL=0
    CONFIG_OPENTHREAD_PLATFORM_LOG_LEVEL=0
    # CONFIG_OPENTHREAD_L2_DEBUG is not set
    CONFIG_OPENTHREAD_L2_LOG_LEVEL=0
    # end of Logging
    # Zephyr optimizations
    # CONFIG_OPENTHREAD_THREAD_PREEMPTIVE is not set
    CONFIG_OPENTHREAD_THREAD_PRIORITY=8
    CONFIG_OPENTHREAD_PKT_LIST_SIZE=10
    # end of Zephyr optimizations
    # CONFIG_CUSTOM_OPENTHREAD_SECURITY is not set
    # CONFIG_OPENTHREAD_MBEDTLS_CHOICE is not set
    # CONFIG_OPENTHREAD_COPROCESSOR is not set
    CONFIG_OPENTHREAD_PLATFORM_INFO="ZEPHYR"
    CONFIG_OPENTHREAD_CUSTOM_PARAMETERS=""
    CONFIG_OPENTHREAD_MESSAGE_BUFFER_SIZE=128
    # CONFIG_OPENTHREAD_PLATFORM_MESSAGE_MANAGEMENT is not set
    CONFIG_OPENTHREAD_MAX_STATECHANGE_HANDLERS=2
    CONFIG_OPENTHREAD_TMF_ADDRESS_CACHE_ENTRIES=20
    CONFIG_OPENTHREAD_TMF_ADDRESS_CACHE_MAX_SNOOP_ENTRIES=2
    # CONFIG_OPENTHREAD_LOG_PREPEND_LEVEL_ENABLE is not set
    CONFIG_OPENTHREAD_MAC_SOFTWARE_ACK_TIMEOUT_ENABLE=y
    CONFIG_OPENTHREAD_MAC_SOFTWARE_RETRANSMIT_ENABLE=y
    CONFIG_OPENTHREAD_MAC_SOFTWARE_CSMA_BACKOFF_ENABLE=y
    CONFIG_OPENTHREAD_CRYPTO_PSA=y
    CONFIG_OPENTHREAD_PLATFORM_KEYS_EXPORTABLE_ENABLE=y
    # CONFIG_NET_L2_CUSTOM_IEEE802154 is not set
    # CONFIG_NET_L2_CANBUS_RAW is not set
    # CONFIG_NET_L2_WIFI_MGMT is not set
    # CONFIG_NET_L2_WIFI_SHELL is not set
    # CONFIG_NET_L2_PTP is not set
    # end of Link layer options
    # IP stack
    CONFIG_NET_IP=y
    CONFIG_NET_NATIVE=y
    CONFIG_NET_NATIVE_IP=y
    CONFIG_NET_NATIVE_IPV6=y
    CONFIG_NET_NATIVE_UDP=y
    # CONFIG_NET_OFFLOAD is not set
    CONFIG_NET_INIT_PRIO=90
    CONFIG_NET_IP_DSCP_ECN=y
    CONFIG_NET_IF_MAX_IPV6_COUNT=1
    CONFIG_NET_IPV6_MTU=1280
    # CONFIG_NET_IPV6_PMTU is not set
    CONFIG_NET_INITIAL_HOP_LIMIT=64
    CONFIG_NET_INITIAL_MCAST_HOP_LIMIT=1
    CONFIG_NET_IPV6_MAX_NEIGHBORS=8
    # CONFIG_NET_IPV6_FRAGMENT is not set
    CONFIG_NET_IPV6_IID_EUI_64=y
    # CONFIG_NET_IPV6_IID_STABLE is not set
    # CONFIG_NET_IPV6_PE is not set
    # CONFIG_NET_6LO is not set
    CONFIG_NET_IPV6_LOG_LEVEL=0
    CONFIG_NET_IPV6_ND_LOG_LEVEL=0
    CONFIG_NET_IPV6_PE_LOG_LEVEL=0
    CONFIG_NET_ICMPV6_LOG_LEVEL=0
    CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL=0
    # CONFIG_NET_IPV4 is not set
    # CONFIG_NET_IPV4_MAPPING_TO_IPV6 is not set
    # CONFIG_NET_SHELL is not set
    CONFIG_NET_TC_RX_COUNT=1
    # CONFIG_NET_TC_SKIP_FOR_HIGH_PRIO is not set
    CONFIG_NET_TC_THREAD_COOPERATIVE=y
    # CONFIG_NET_TC_THREAD_PREEMPTIVE is not set
    CONFIG_NET_TC_NUM_PRIORITIES=16
    # CONFIG_NET_TC_THREAD_PRIO_CUSTOM is not set
    CONFIG_NET_TC_MAPPING_STRICT=y
    CONFIG_NET_TX_DEFAULT_PRIORITY=1
    CONFIG_NET_RX_DEFAULT_PRIORITY=0
    # CONFIG_NET_ALLOW_ANY_PRIORITY is not set
    CONFIG_NET_IP_ADDR_CHECK=y
    CONFIG_NET_MAX_ROUTERS=1
    # CONFIG_NET_TCP is not set
    # CONFIG_NET_TEST_PROTOCOL is not set
    CONFIG_NET_UDP=y
    CONFIG_NET_UDP_LOG_LEVEL=0
    CONFIG_NET_MAX_CONN=4
    CONFIG_NET_MAX_CONTEXTS=6
    # CONFIG_NET_CONTEXT_NET_PKT_POOL is not set
    CONFIG_NET_CONTEXT_SYNC_RECV=y
    CONFIG_NET_CONTEXT_CHECK=y
    # CONFIG_NET_CONTEXT_PRIORITY is not set
    # CONFIG_NET_CONTEXT_TXTIME is not set
    # CONFIG_NET_CONTEXT_RCVTIMEO is not set
    # CONFIG_NET_CONTEXT_SNDTIMEO is not set
    # CONFIG_NET_CONTEXT_RCVBUF is not set
    # CONFIG_NET_CONTEXT_SNDBUF is not set
    CONFIG_NET_CONTEXT_DSCP_ECN=y
    CONFIG_NET_CONTEXT_REUSEADDR=y
    CONFIG_NET_CONTEXT_REUSEPORT=y
    # CONFIG_NET_CONTEXT_RECV_PKTINFO is not set
    CONFIG_NET_CONTEXT_TIMESTAMPING=y
    # CONFIG_NET_CONTEXT_CLAMP_PORT_RANGE is not set
    # CONFIG_NET_TEST is not set
    CONFIG_NET_BUF_FIXED_DATA_SIZE=y
    # CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set
    CONFIG_NET_BUF_DATA_SIZE=128
    CONFIG_NET_PKT_BUF_USER_DATA_SIZE=4
    CONFIG_NET_DEFAULT_IF_FIRST=y
    # CONFIG_NET_DEFAULT_IF_UP is not set
    CONFIG_NET_INTERFACE_NAME=y
    # CONFIG_NET_PKT_TIMESTAMP_THREAD is not set
    # CONFIG_NET_PKT_RXTIME_STATS is not set
    # CONFIG_NET_PKT_TXTIME_STATS is not set
    # CONFIG_NET_PKT_ALLOC_STATS is not set
    # CONFIG_NET_PROMISCUOUS_MODE is not set
    # CONFIG_NET_DISABLE_ICMP_DESTINATION_UNREACHABLE is not set
    # Stack usage
    # end of Stack usage
    # CONFIG_NET_MGMT is not set
    # CONFIG_NET_STATISTICS is not set
    # CONFIG_NET_LOG is not set
    CONFIG_NET_PKT_LOG_LEVEL=0
    # CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set
    CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0
    # CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set
    CONFIG_NET_CORE_LOG_LEVEL=0
    CONFIG_NET_IF_LOG_LEVEL=0
    CONFIG_NET_TC_LOG_LEVEL=0
    CONFIG_NET_UTILS_LOG_LEVEL=0
    CONFIG_NET_CONTEXT_LOG_LEVEL=0
    CONFIG_NET_CONN_LOG_LEVEL=0
    CONFIG_NET_ROUTE_LOG_LEVEL=0
    # end of IP stack
    # Network Packet Filtering
    # CONFIG_NET_PKT_FILTER is not set
    # end of Network Packet Filtering
    # Network Protocols
    # CONFIG_COAP is not set
    # CONFIG_DNS_RESOLVER is not set
    # CONFIG_DNS_SD is not set
    # CONFIG_MQTT_LIB is not set
    # CONFIG_MQTT_SN_LIB is not set
    # CONFIG_TFTP_LIB is not set
    # CONFIG_HTTP_PARSER is not set
    # CONFIG_HTTP_PARSER_URL is not set
    # CONFIG_HTTP_CLIENT is not set
    # CONFIG_HTTP_SERVER is not set
    CONFIG_NET_HTTP_LOG_LEVEL=0
    CONFIG_NET_HTTP_SERVER_LOG_LEVEL=0
    # CONFIG_WEBSOCKET_CLIENT is not set
    # CONFIG_LWM2M is not set
    # CONFIG_SOCKS is not set
    # CONFIG_SNTP is not set
    # end of Network Protocols
    # Network Libraries
    CONFIG_NET_CONFIG_LOG_LEVEL=0
    # CONFIG_NET_CONFIG_SETTINGS is not set
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_PRIORITY_DEFAULT=50
    CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000
    CONFIG_NET_SOCKET_MAX_SEND_WAIT=10000
    # CONFIG_NET_SOCKETS_SERVICE is not set
    # CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set
    CONFIG_NET_SOCKETS_TLS_PRIORITY=45
    CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y
    # CONFIG_NET_SOCKETS_OFFLOAD is not set
    CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY=40
    # CONFIG_NET_SOCKETS_PACKET is not set
    # CONFIG_NET_SOCKETS_CAN is not set
    # CONFIG_NET_SOCKETPAIR is not set
    CONFIG_NET_SOCKETS_LOG_LEVEL=0
    # CONFIG_TLS_CREDENTIALS is not set
    # end of Network Libraries
    # Network additional services
    # CONFIG_NET_CAPTURE is not set
    # CONFIG_NET_DHCPV6 is not set
    CONFIG_NET_DHCPV6_DUID_MAX_LEN=22
    # CONFIG_NET_TRICKLE is not set
    # CONFIG_NET_ZPERF is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # end of Network additional services
    # CONFIG_NET_CONNECTION_MANAGER is not set
    # end of Networking
    # Power Management
    # CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_OFF is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_ERR is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_WRN is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_INF is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_DBG is not set
    CONFIG_PM_DEVICE_LOG_LEVEL_DEFAULT=y
    CONFIG_PM_DEVICE_LOG_LEVEL=1
    # CONFIG_PM_DEVICE_RUNTIME_EXCLUSIVE is not set
    # CONFIG_PM_DEVICE_SHELL is not set
    # end of Power Management
    # Portability
    # end of Portability
    # CONFIG_PROFILING is not set
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    # CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set
    CONFIG_XOSHIRO_RANDOM_GENERATOR=y
    CONFIG_CSPRNG_AVAILABLE=y
    CONFIG_CSPRNG_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SECURE_STORAGE is not set
    CONFIG_SETTINGS=y
    # CONFIG_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_SETTINGS_LOG_LEVEL_DBG is not set
    CONFIG_SETTINGS_LOG_LEVEL_DEFAULT=y
    CONFIG_SETTINGS_LOG_LEVEL=1
    CONFIG_SETTINGS_RUNTIME=y
    CONFIG_SETTINGS_DYNAMIC_HANDLERS=y
    CONFIG_SETTINGS_ZMS=y
    # CONFIG_SETTINGS_ZMS_LL_CACHE is not set
    # CONFIG_SETTINGS_CUSTOM is not set
    # CONFIG_SETTINGS_NONE is not set
    # CONFIG_SETTINGS_ZMS_CUSTOM_SECTOR_COUNT is not set
    CONFIG_SETTINGS_ZMS_MAX_COLLISIONS_BITS=4
    # CONFIG_SETTINGS_ZMS_NO_LL_DELETE is not set
    # CONFIG_SETTINGS_ZMS_LOAD_SUBTREE_PATH is not set
    # CONFIG_SETTINGS_SHELL is not set
    # CONFIG_SHELL_LOG_LEVEL_OFF is not set
    # CONFIG_SHELL_LOG_LEVEL_ERR is not set
    # CONFIG_SHELL_LOG_LEVEL_WRN is not set
    # CONFIG_SHELL_LOG_LEVEL_INF is not set
    # CONFIG_SHELL_LOG_LEVEL_DBG is not set
    CONFIG_SHELL_LOG_LEVEL_DEFAULT=y
    CONFIG_SHELL_LOG_LEVEL=1
    CONFIG_SHELL_BACKENDS=y
    CONFIG_SHELL_BACKEND_SERIAL_INIT_PRIORITY=90
    CONFIG_SHELL_PROMPT_UART="uart:~$ "
    CONFIG_SHELL_BACKEND_SERIAL_INTERRUPT_DRIVEN=y
    # CONFIG_SHELL_ASYNC_API is not set
    # CONFIG_SHELL_BACKEND_SERIAL_API_POLLING is not set
    CONFIG_SHELL_BACKEND_SERIAL_API_INTERRUPT_DRIVEN=y
    # CONFIG_SHELL_BACKEND_SERIAL_API_ASYNC is not set
    # CONFIG_SHELL_BACKEND_SERIAL_FORCE_TX_BLOCKING_MODE is not set
    CONFIG_SHELL_BACKEND_SERIAL_TX_RING_BUFFER_SIZE=8
    CONFIG_SHELL_BACKEND_SERIAL_RX_RING_BUFFER_SIZE=64
    CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_TIMEOUT=100
    CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_SIZE=512
    CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DEFAULT=y
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DBG is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_INF is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_WRN is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_ERR is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_NONE is not set
    CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL=5
    # CONFIG_SHELL_BACKEND_DUMMY is not set
    # CONFIG_SHELL_DEVICE_HELPERS is not set
    # CONFIG_SHELL_THREAD_PRIORITY_OVERRIDE is not set
    CONFIG_SHELL_BACKSPACE_MODE_DELETE=y
    # CONFIG_SHELL_PROMPT_CHANGE is not set
    CONFIG_SHELL_PRINTF_BUFF_SIZE=30
    CONFIG_SHELL_DEFAULT_TERMINAL_WIDTH=80
    CONFIG_SHELL_DEFAULT_TERMINAL_HEIGHT=24
    CONFIG_SHELL_ARGC_MAX=20
    # CONFIG_SHELL_TAB is not set
    CONFIG_SHELL_ASCII_FILTER=y
    CONFIG_SHELL_MSG_CMD_NOT_FOUND=y
    CONFIG_SHELL_MSG_SPECIFY_SUBCOMMAND=y
    CONFIG_SHELL_ECHO_STATUS=y
    # CONFIG_SHELL_START_OBSCURED is not set
    CONFIG_SHELL_VT100_COMMANDS=y
    # CONFIG_SHELL_VT100_COLORS is not set
    # CONFIG_SHELL_GETOPT is not set
    # CONFIG_SHELL_METAKEYS is not set
    # CONFIG_SHELL_HELP is not set
    # CONFIG_SHELL_HISTORY is not set
    # CONFIG_SHELL_STATS is not set
    # CONFIG_SHELL_CMDS is not set
    CONFIG_SHELL_CMD_ROOT=""
    # CONFIG_SHELL_LOG_BACKEND_CUSTOM is not set
    CONFIG_SHELL_AUTOSTART=y
    # CONFIG_SHELL_CUSTOM_HEADER is not set
    # CONFIG_STATS is not set
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_MAP_SHELL is not set
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_FLASH_MAP_LABELS is not set
    CONFIG_STREAM_FLASH=y
    CONFIG_STREAM_FLASH_INSPECT=y
    CONFIG_STREAM_FLASH_POST_WRITE_CALLBACK=y
    CONFIG_STREAM_FLASH_ERASE=y
    # CONFIG_STREAM_FLASH_PROGRESS is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_STREAM_FLASH_LOG_LEVEL=1
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # CONFIG_MODULES is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_FLASH_LOAD_SIZE=0x51000
    CONFIG_ROM_END_OFFSET=0x8000
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_ITERABLE_SUBALIGN=4
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_STD_C90 is not set
    CONFIG_STD_C99=y
    # CONFIG_STD_C11 is not set
    # CONFIG_STD_C17 is not set
    # CONFIG_STD_C23 is not set
    CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
    # CONFIG_GNU_C_EXTENSIONS is not set
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    CONFIG_BUILD_GAP_FILL_PATTERN=0xFF
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_DEPRECATED=y
    CONFIG_WARN_DEPRECATED=y
    CONFIG_EXPERIMENTAL=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
    # end of Compatibility
    # CONFIG_PLANET_FITNESS is not set
    # CONFIG_PLANET_FITNESS_RFID is not set
    CONFIG_MATTER_LOCK=y
    # CONFIG_GEN2_LOCK_NFC is not set
    CONFIG_MAX_LOGS_RECORDS=190
    CONFIG_MTI_BLE_SERVICE=y
    # CONFIG_MTI_BLE_NO_SECURITY is not set
    CONFIG_MTI_BLE_ENCRYPT_UNAUTHENTICATED_PAIRING=y
    # CONFIG_MTI_BLE_ENCRYPT_AUTHENTICATED_PAIRING is not set
    # CONFIG_MTI_BLE_ENCRYPT_LE_SECURE is not set
    CONFIG_MTI_BLE_MAX_COMMANDS=2
    CONFIG_MTI_BLE_MAX_COMMAND_LEN=10
    CONFIG_MTI_BLE_TX_MAX_BYTES=240
    CONFIG_DEVELOPMENT_TESTING=y
    # CONFIG_USE_DK is not set
    # CONFIG_USE_NPM1300 is not set
    CONFIG_USE_NPM2100=y
