nRF52833 + nRF21540 Custom Board
Hello Team,
    We are using custom nRF52833 with nRF21540 (PCB). we manually controlling the nRF21540 FEM using GPIO and SPI (not using the FEM driver) for testing purpose. After configuring the gain to 20 dBm, I expected significantly increased BLE advertising range. However, I can only scan my device up to 40 meters—beyond that, it's no longer detected.
  We suspect this could be a timing or configuration issue that prevents the range extender from stabilizing correctly before TX.
 Here is my main.c
my main.c
#include <zephyr/kernel.h>
#include <zephyr/drivers/spi.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/uuid.h>
#define DEVICE_NAME " RANGE_2 "
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
static const struct bt_data ad[] = {
    BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
    BT_DATA_BYTES(BT_DATA_UUID128_ALL,
        BT_UUID_128_ENCODE(0x6E400001, 0xB5A3, 0xF393, 0xE0A9, 0xE50E24DCCA9E),
#define ZEPHYR_USER_NODE DT_PATH(zephyr_user)
static const struct gpio_dt_spec xtal_1 = GPIO_DT_SPEC_GET(ZEPHYR_USER_NODE, xtal_1_gpios);
static const struct gpio_dt_spec xtal_2 = GPIO_DT_SPEC_GET(ZEPHYR_USER_NODE, xtal_2_gpios);
LOG_MODULE_REGISTER(main, LOG_LEVEL_INF);
#define SPI_NODE DT_NODELABEL(spi3)
#define CS_GPIO_PORT DT_NODELABEL(gpio0)
#define CS_PIN 4  // Change to your actual CS pin number
static const struct device *spi_dev = DEVICE_DT_GET(SPI_NODE);
static const struct device *cs_gpio_dev = DEVICE_DT_GET(CS_GPIO_PORT);
#define TX_EN_NODE   DT_NODELABEL(nrf21540_tx_en)
#define RX_EN_NODE   DT_NODELABEL(nrf21540_rx_en)
#define PDN_NODE     DT_NODELABEL(nrf21540_pdn)
#define ANT_SEL_NODE DT_NODELABEL(nrf21540_ant_sel)
#define MODE_NODE    DT_NODELABEL(nrf21540_mode)
static const struct gpio_dt_spec tx_en_gpio   = GPIO_DT_SPEC_GET(TX_EN_NODE, gpios);
static const struct gpio_dt_spec rx_en_gpio   = GPIO_DT_SPEC_GET(RX_EN_NODE, gpios);
static const struct gpio_dt_spec pdn_gpio     = GPIO_DT_SPEC_GET(PDN_NODE, gpios);
static const struct gpio_dt_spec ant_sel_gpio = GPIO_DT_SPEC_GET(ANT_SEL_NODE, gpios);
static const struct gpio_dt_spec mode_gpio    = GPIO_DT_SPEC_GET(MODE_NODE, gpios);
static struct spi_config spi_cfg = {
    .operation = SPI_WORD_SET(8) | SPI_OP_MODE_MASTER | SPI_TRANSFER_MSB,
    .frequency = 4000000,
    .slave = 0,
    .cs = NULL, // Manual CS control
static uint8_t nrf21540_read_reg(uint8_t reg_addr)
    uint8_t tx_buffer[2] = {0x80 | (reg_addr << 1), 0x00};
  //  uint8_t tx_buffer[2] = {0x80 /*| (reg_addr << 1)*/, 0x00};  // 0x80: READ command, reg_addr shifted
    uint8_t rx_buffer[2] = {0};
    struct spi_buf tx_buf = {
        .buf = tx_buffer,
        .len = sizeof(tx_buffer),
    struct spi_buf rx_buf = {
        .buf = rx_buffer,
        .len = sizeof(rx_buffer),
    struct spi_buf_set tx_bufs = {
        .buffers = &tx_buf,
        .count = 1,
    struct spi_buf_set rx_bufs = {
        .buffers = &rx_buf,
        .count = 1,
    gpio_pin_set(cs_gpio_dev, CS_PIN, 0); // CS low
    int err = spi_transceive(spi_dev, &spi_cfg, &tx_bufs, &rx_bufs);
    gpio_pin_set(cs_gpio_dev, CS_PIN, 1); // CS high
    if (err) {
        LOG_INF("SPI read error: %d", err);
        return 0xFF;
    LOG_INF("Read reg 0x%02X: 0x%02X", reg_addr, rx_buffer[1]);
    return rx_buffer[1];
static void nrf21540_write_reg(uint8_t reg_addr, uint8_t value)
    uint8_t tx_buffer[2] = {0xC0 | (reg_addr << 1), value};
    struct spi_buf tx_buf = {.buf = tx_buffer, .len = sizeof(tx_buffer)};
    struct spi_buf_set tx_bufs = {.buffers = &tx_buf, .count = 1};
    int err = spi_write(spi_dev, &spi_cfg, &tx_bufs);
    if (err) {
        LOG_INF("SPI write error: %d", err);
    } else {
        LOG_INF("Wrote 0x%02X to reg 0x%02X", value, reg_addr);
    LOG_INF("nRF21540 Manual GPIO/SPI Example");
    // Configure all FEM control pins as outputs
    gpio_pin_configure_dt(&pdn_gpio, GPIO_OUTPUT_LOW);
    gpio_pin_configure_dt(&tx_en_gpio, GPIO_OUTPUT_LOW);
    gpio_pin_configure_dt(&rx_en_gpio, GPIO_OUTPUT_LOW);
    gpio_pin_configure_dt(&ant_sel_gpio, GPIO_OUTPUT_LOW);
    gpio_pin_configure_dt(&mode_gpio, GPIO_OUTPUT_LOW);
    gpio_pin_configure_dt(&xtal_1, GPIO_DISCONNECTED);
    gpio_pin_configure_dt(&xtal_2, GPIO_DISCONNECTED);
    // Power up FEM
    gpio_pin_set_dt(&pdn_gpio, 1);
    k_msleep(10);
    // Set gain and other controls before enabling TX
    gpio_pin_set_dt(&rx_en_gpio, 0);
    gpio_pin_set_dt(&ant_sel_gpio, 0);
    gpio_pin_set_dt(&mode_gpio, 0);
    // Configure CS pin
    gpio_pin_configure(cs_gpio_dev, CS_PIN, GPIO_OUTPUT_HIGH);
    // Set gain for 20 dBm
    nrf21540_write_reg(0x00, 0x9B);
    k_msleep(100);
    uint8_t reg_value = nrf21540_read_reg(0x00);
    LOG_INF("Current CONFREG0 value: 0x%02X", reg_value);
    k_msleep(2000);
    nrf21540_write_reg(0x00, 0xC7);
    k_msleep(100);
    // Enable TX after gain is set
    gpio_pin_set_dt(&tx_en_gpio, 1);
    k_msleep(10);
    // Bluetooth advertising
    int err = bt_enable(NULL);
    if (err) {
        LOG_INF("Bluetooth init failed (err %d)", err);
        return 0;
    LOG_INF("Bluetooth initialized");
    err = bt_le_adv_start(
        BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE, 8000, 8000, NULL),
        ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd)
    if (err) {
        LOG_INF("Advertising failed to start (err %d)", err);
        return 0;
    LOG_INF("Advertising successfully started");
    while (1) {
        k_msleep(1000);
    return 0;
my prj..conf as:
# Bluetooth configuration
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_EXT_ADV=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_ADV_PROV=y
CONFIG_BT_CTLR_ADV_EXT=y
CONFIG_BT_DEVICE_APPEARANCE=0
CONFIG_BT_LL_SOFTDEVICE=y
# Logging
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_GPIO=y
CONFIG_SPI=y
CONFIG_BT_CTLR_TX_PWR_ANTENNA=20
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=n
And RTT logs:
[00:00:00.000,366] <inf> main: nRF21540 Manual GPIO/SPI Example
[00:00:02.110,931] <inf> main: Wrote 0x9B to reg 0x00
[00:00:02.211,090] <inf> main: Read reg 0x00: 0x9B
[00:00:02.211,120] <inf> main: Current CONFREG0 value: 0x9B
[00:00:02.221,252] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
2d 79 a1 c8 6a 40 b7 3c f6 74 f9 0b 22 d3 c4 80 |-y..j@.< .t.."...
74 72 82 ba |tr..
[00:00:02.223,968] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:02.223,999] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:02.224,029] <inf> bt_hci_core: Firmware: Standard Bluetooth controller
     Despite writing the correct gain values and enabling TX_EN, BLE scan range is only about 40m in an open outdoor environment.
  • Is my power-on and register-write sequence sufficient for the nRF21540 to operate at full gain?
  • Is there a known stabilization delay between enabling PDN or TX_EN and starting BLE advertising?
  • Do I need to toggle RX_EN in a specific way for TX mode?
  • Would using the FEM driver provide better timing control than manual GPIO/SPI?
  • Hello Ashwini,
    based on your numbers alone it looks like the gain from the FEM is there and the numbers don't look too bad. Suspect that there might be two things worth checking here:
    Q1: What does the layout and schematic look like on your board? Are you able to share this information with us if you set this ticket to be private?
    Q2: RX timing, what clock source do you have available on your board. LFXO (32k crystal) or are you using LFRC (internal 32k)? It looks like you are using LFRC based on this: CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y, but what are you using for the clock source accuracy? https://docs.nordicsemi.com/bundle/ncs-1.7.0/page/kconfig/choice_483.html#choice-483 Can you set it to https://docs.nordicsemi.com/bundle/ncs-1.7.0/page/kconfig/CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM.html#std-kconfig-CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM and give it a try? I fear that if you haven't set this correct, your RX windows are out of sync with the phones.
    Best regards
    Asbjørn
  •      Yes, we are using LFRC. as per schematic no external crystal is mounted on it. Also documentation 500 ppm value reflects the expected accuracy after calibration for the internal RC oscillator. we cannot set it externally.
         Also, tried with setting up configuration as:
        CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
      but not getting drastic change in observations.
       Is there need to set accuracy at different value for internal RC?
  • Hello Ashwini,
    What schematic? I've asked about the schematic and layout for this board and the implementation, but haven't seen any. Would it be possible to share as this might also be related to the issues you're observing.
    Best regards
    Asbjørn
  • Hello Asbjorn,
           Due to certain limitations, the schematic cannot be shared.
          I would like to request confirmation on the following points regarding the control and configuration of the nRF21540 FEM for our testing setup:
    1. TX Gain Enable Sequence (Using GPIO and SPI):
      After enabling the nRF21540, the initial state of the control pins — MODE, TX_EN, and RX_EN — is LOW (logic 0).
      My current procedure is as follows:
      • First, I write to CONFREG0 to set the TX gain (e.g., writing 0x1C for +10 dBm gain or 0x6C for +20 dBm gain).
      • Once the write is successful, I set the TX_EN GPIO to HIGH (logic 1) to enable TX gain.
      Could you please confirm if this is the correct sequence for enabling TX gain using a combination of SPI and GPIO control and values written to CONFREG0 for the corresponding gain?
    2. TX Gain Control Using Only SPI (No GPIO Control):
      In the case where we want to set and enable TX gain using only CONFREG0 (Only SPI control without using FEM control GPIOs),
      • What is the correct sequence of SPI commands to set and activate the TX gain?
      • What should be the expected or required states of the TX_EN, RX_EN, and MODE pins in this SPI-only control scenario?
         Your guidance on these points will be greatly appreciated to ensure correct operation during our testing phase.
  • Hi, Ashwini.
    Asbjørn is currently out of office, so I'll try to help you out while he's away.
    Have you had a look at this section in the documentation, describing how to enable GPIO+SPI mode support for nRF21540?
    Are you sure you're not able to share a PDF containing your board's schematic and a zip folder containing the Gerber and drill files for the layout? Even not if the case is made private? This could possibly be very helpful for figuring out what may be the issue.
    Mathias
