queries on qspi flash
Hello forum ,
                  here i m using nrf52840 customized board ;my flash is w25q64 i need to set my flash for deep power mode (sleep mode ) ;as well i need to set my supply gpio pins 5v and 3v3 ,backlight led gpio ,led gpio into sleep mode ; den i need to set pwm,adc,spi all into sleep mode ...pls sugest me for sleep mode because i need to measure current consumption during sleep mode for my board ...if possible pls send me sample code for sleep mode in overlay ...
    Most examples should already be powered optimized if you add CONFIG_SERIAL=n. But you can find this useful:
    https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/test_and_optimize/optimizing/power.html
    Kenneth
  • Hello kenneth,
                        pls help me sleep mode (power down ) using zephyr nrf52840 customised board  for PWM ,windbond qspi flash , adc ....i need to check current consumption during powerdown mode where i m using sdk 2.7.0
  • here i will upload my main.c where i tried to sleep mode for adc and pwm with terminal output
     * Copyright (c) 2018 Jan Van Winkel <[email protected]>
    #include <inttypes.h>
    #include <stddef.h>
    #include <stdint.h>
    #include <zephyr/device.h>
    #include <zephyr/drivers/display.h>
    #include <zephyr/drivers/flash.h>
    #include <lvgl.h>
    #include <stdio.h>
    #include <string.h>
    #include <nrfx_qspi.h>
    #include <hal/nrf_qspi.h>
    #include <zephyr/kernel.h>
    #include <lvgl_input_device.h>
    #include <stdio.h>
    #include <zephyr/drivers/pwm.h>
    #include <zephyr/pm/device.h>
    // #include "Vtlogo565.h"
    // #include"Billirubino.h"
    // #include "Billirubin.h"
    #include <zephyr/drivers/adc.h>
    #include <zephyr/sys/util.h>
    #include <stdlib.h>
    #include <math.h>
    #include <zephyr/sys/poweroff.h>
    #include <zephyr/sys/reboot.h>
    #include "ui.h"
    #include "vars.h"
    #include "actions.h"
    #include "structs.h"
    #include "screens.h"
    using namespace eez;
    using namespace eez::flow;
    #define LOG_LEVEL CONFIG_LOG_DEFAULT_LEVEL
    LOG_MODULE_REGISTER(app);
    static uint8_t sleepCount = 0;
    #define LED1_NODE DT_NODELABEL(led1)
    #define LED0_NODE DT_NODELABEL(led0)
    #define LED2_NODE DT_NODELABEL(led2)
    int16_t buf0, buf2, buf3;
    char *variable;
    lv_obj_t *main_screen;
    lv_obj_t *count_Value;
    uint16_t bilirubinValue = 0;
    char bilirubinValue_str[16];
    char PD1_str[16];
    char PD2_str[16];
    char pd_ratio_str[16];
    char battery_str[5];
    static bool offFlag = false;
    volatile bool adc_timeout = false;
    bool conversion_complete = false;
    bool display_timeout = false;
    #define PWM_FREQUENCY_HZ 4000U                          // Set frequency to 4 kHz
    #define PWM_PERIOD_NS (NSEC_PER_SEC / PWM_FREQUENCY_HZ) // 250,000 ns (250 µs)
    #define DUTY_CYCLE_PERCENT 70                           // Set duty cycle to 50%
    uint32_t pulse_width_ns = (PWM_PERIOD_NS * DUTY_CYCLE_PERCENT) / 100;
    #define FLASH_NODE DT_NODELABEL(w25q64)
    const struct device *flash_dev = DEVICE_DT_GET(FLASH_NODE);
    int32_t photodiode_one_mv = 0;
    int32_t photodiode_two_mv = 0;
    int32_t sum_photodiode_one = 0;
    int32_t sum_photodiode_two = 0;
    int32_t avg_photodiode_one = 0;
    int32_t avg_photodiode_two = 0;
    float phd1 = 0.0f;
    float phd2 = 0.0f;
    float value = 0.0f;
    // int32_t pd1_mv;
    int32_t pd2_mv;
    int32_t avg_pd1 = 0;
    int32_t avg_pd2 = 0;
    int battery_level = 0;
    float ratio = 0.0f;
    // char adc_ratio_str[32] = {0};
    static uint32_t battery_counter = 0;
    // #define CMD_READ_JEDEC_ID 0x9F
    #define CMD_POWER_DOWN    0xB9
    #if !DT_NODE_EXISTS(DT_PATH(zephyr_user)) || \
        !DT_NODE_HAS_PROP(DT_PATH(zephyr_user), io_channels)
    #error "No suitable devicetree overlay specified"
    #define DT_SPEC_AND_COMMA(node_id, prop, idx) \
        ADC_DT_SPEC_GET_BY_IDX(node_id, idx),
    /* ADC channel configurations */
    static const struct adc_dt_spec adc_channels[] = {
        DT_FOREACH_PROP_ELEM(DT_PATH(zephyr_user), io_channels, DT_SPEC_AND_COMMA)};
    struct adc_sequence sequence0 = {
        .buffer = &buf0,
        .buffer_size = sizeof(buf0),
    struct adc_sequence sequence2 = {
        .buffer = &buf2,
        .buffer_size = sizeof(buf2),
    struct adc_sequence sequence3 = {
        .buffer = &buf3,
        .buffer_size = sizeof(buf3),
    bool stopFlag = false;
    int32_t volt = 0;
    volatile bool led2_on = false; // Flag to track if LED2 is on
    void EnterPowerdown();
    #ifdef CONFIG_GPIO
    static struct gpio_dt_spec button_gpio = GPIO_DT_SPEC_GET_OR(
        DT_ALIAS(sw1), gpios, {0}); // Button 1
    static struct gpio_callback button_callback;
    static struct gpio_dt_spec button_onoff = GPIO_DT_SPEC_GET_OR(DT_ALIAS(sw0), gpios, {0}); // Button 0 (e.g., ON/OFF)
    static struct gpio_callback button_onoff_callback;
    static uint64_t last_activity_time = 0;
    static const uint32_t IDLE_TIMEOUT_MS = 40000; // 32 seconds
    #define LED_ON_DURATION_MS 200
    void led_timer_handler(struct k_timer *timer_id); // forward declaration
    K_TIMER_DEFINE(led_timer, led_timer_handler, NULL);
    #define ADC_DURATION_MS 10
    void adc_timer_handler(struct k_timer *timer_id); // forward declaration
    K_TIMER_DEFINE(adc_timer, adc_timer_handler, NULL);
    #define PWM_ON_DURATION_MS 200
    void pwm_timer_handler(struct k_timer *timer_id); // forward declaration
    K_TIMER_DEFINE(pwm_timer, pwm_timer_handler, NULL);
    #define DISPLAY_DURATION_MS 20000
    void display_timer_handler(struct k_timer *timer_id); // forward declaration
    K_TIMER_DEFINE(display_timer, display_timer_handler, NULL);
    uint64_t led2_on_timestamp = 0;
    uint64_t led2_off_timestamp = 0;
    // int32_t pd1_sum = 0, pd2_sum = 0;
    uint32_t sample_count = 0;
    static uint32_t count = 0;
    static uint32_t countbutton = 0;
    static bool led2_ever_used = false;
    static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(DT_NODELABEL(ledbacklight), gpios);
    static const struct gpio_dt_spec led1 = GPIO_DT_SPEC_GET(LED1_NODE, gpios);
    static const struct gpio_dt_spec led0 = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
    static const struct gpio_dt_spec led2 = GPIO_DT_SPEC_GET(LED2_NODE, gpios);
    static const struct pwm_dt_spec pwm_led0 = PWM_DT_SPEC_GET(DT_ALIAS(pwm_led0));
    void updateGUI()
        setGlobalVariable(FLOW_GLOBAL_VARIABLE_BILIRUBIN_VALUE_STR, bilirubinValue_str);
        setGlobalVariable(FLOW_GLOBAL_VARIABLE_BILIRUBIN_LABEL, bilirubinValue_str);
        setGlobalVariable(FLOW_GLOBAL_VARIABLE_PD1, PD1_str);
        setGlobalVariable(FLOW_GLOBAL_VARIABLE_PD2, PD2_str);
        setGlobalVariable(FLOW_GLOBAL_VARIABLE_RATIO, pd_ratio_str);
        setGlobalVariable(FLOW_GLOBAL_VARIABLE_BATTERY_PERCENTAGE, battery_str);
    void flash_power_down(void)
        nrf_qspi_cinstr_conf_t cinstr_cfg = {
            .opcode    = CMD_POWER_DOWN,
            .length    = NRF_QSPI_CINSTR_LEN_1B, // Only 1 byte command
            .io2_level = true,
            .io3_level = true,
            .wipwait   = false,
            .wren      = false
        nrfx_err_t err = nrfx_qspi_cinstr_xfer(&cinstr_cfg, NULL, NULL);
        if (err != NRFX_SUCCESS) {
            printk("Failed to send POWER-DOWN (B9h): %d\n", err);
        } else {
            printk("Flash entered deep power-down mode.\n");
    static void button_isr_callback(const struct device *port,
                                    struct gpio_callback *cb,
                                    uint32_t pins)
        last_activity_time = k_uptime_get();
        int button_state = gpio_pin_get_dt(&button_gpio);
        if (button_state == 1)
        { // Button pressed
            gpio_pin_set_dt(&led2, 1);
            led2_on = true;
            // pd1_sum = 0;
            // pd2_sum = 0;
            k_timer_stop(&display_timer);
            sample_count = 0;
            led2_on_timestamp = k_uptime_get();
            k_timer_start(&led_timer, K_MSEC(LED_ON_DURATION_MS), K_NO_WAIT);
            k_timer_start(&adc_timer, K_MSEC(ADC_DURATION_MS), K_NO_WAIT);
            k_timer_start(&pwm_timer, K_MSEC(PWM_ON_DURATION_MS), K_NO_WAIT);
            printk("LED2 turned ON at %llu ms\n", led2_on_timestamp);
            int ret = pwm_set_dt(&pwm_led0, PWM_PERIOD_NS, pulse_width_ns);
            if (ret < 0)
                printk("Failed to start PWM: %d\n", ret);
                printk("PWM started with duty cycle %d ns\n", pulse_width_ns);
        else if (button_state == 0)
        { // Button released
            printk("Button released - stopping sampling\n");
            pwm_set_dt(&pwm_led0, 0, 0);
    static void button_onoff_handler(const struct device *dev,
                                     uint32_t pins)
        // LOG_INF("Wake-up button pressed");
        // last_activity_time = k_uptime_get();
        // EnterPowerdown();
        offFlag = true;
        sleepCount = 0;
        countbutton = 0;
    #ifdef CONFIG_LV_Z_ENCODER_INPUT
    static const struct device *lvgl_encoder =
        DEVICE_DT_GET(DT_COMPAT_GET_ANY_STATUS_OKAY(zephyr_lvgl_encoder_input));
    #endif /* CONFIG_LV_Z_ENCODER_INPUT */
    #ifdef CONFIG_LV_Z_KEYPAD_INPUT
    static const struct device *lvgl_keypad =
        DEVICE_DT_GET(DT_COMPAT_GET_ANY_STATUS_OKAY(zephyr_lvgl_keypad_input));
    #endif /* CONFIG_LV_Z_KEYPAD_INPUT */
    static void lv_btn_click_callback(lv_event_t *e)
        ARG_UNUSED(e);
        count = 0;
        adc_timeout = true;
        display_timeout = true;
        conversion_complete = true;
        int ret = pwm_set_dt(&pwm_led0, 0, 0); // Stop PWM
        if (ret < 0)
            printk("Failed to stop PWM in timer: %d\n", ret);
            printk("PWM stopped by timer\n");
    void PWMInit()
        printk("pwminit");
        if (!pwm_is_ready_dt(&pwm_led0))
            printk("Error: PWM device %s is not ready\n", pwm_led0.dev->name);
    void AdcInit()
        printk("adcinit");
        for (size_t i = 0U; i < ARRAY_SIZE(adc_channels); i++)
            if (!device_is_ready(adc_channels[i].dev))
                printk("ADC controller device not ready\n");
            int err = adc_channel_setup_dt(&adc_channels[i]);
            if (err < 0)
                printk("Could not setup channel #%d (%d)\n", i, err);
    int calculate_battery_percentage(int32_t val_mv)
        const int32_t FULL_CHARGE_MV = 2965; // Adjust based on your battery specs
        const int32_t EMPTY_CHARGE_MV = 1976;
        if (val_mv >= FULL_CHARGE_MV)
            return 100;
        if (val_mv <= EMPTY_CHARGE_MV)
            return 0;
        return (int)((val_mv - EMPTY_CHARGE_MV) * 100 / (FULL_CHARGE_MV - EMPTY_CHARGE_MV));
    int32_t battery_adc()
        int err;
        // Initialize ADC sequence for battery channel (channel 2)
        err = adc_sequence_init_dt(&adc_channels[2], &sequence3);
        if (err < 0)
            printk("Failed to initialize ADC channel 2 sequence\n");
            return err;
        err = adc_read(adc_channels[2].dev, &sequence3);
        if (err < 0)
            printk("ADC read error on channel 2: %d\n", err);
            return err;
        int32_t val_mv = buf3;
        err = adc_raw_to_millivolts_dt(&adc_channels[2], &val_mv);
        if (err < 0)
            printk("Conversion error for channel 2\n");
            return err;
        battery_level = calculate_battery_percentage(val_mv);
        printk("Battery: %" PRId32 " mV (%d%%)\n", val_mv, battery_level);
        snprintf(battery_str, sizeof(battery_str), "%d", battery_level);
        updateGUI();
        return val_mv; // If you want to return mV for display
    int32_t adcRead()
        int err;
        // Initialize ADC sequences for PD1 (channel 0) and PD2 (channel 1)
        err = adc_sequence_init_dt(&adc_channels[0], &sequence0);
        if (err < 0)
            printk("Failed to initialize ADC channel 0 sequence\n");
            return err;
        err = adc_sequence_init_dt(&adc_channels[1], &sequence2);
        if (err < 0)
            printk("Failed to initialize ADC channel 1 sequence\n");
            return err;
        // Read ADC values
        err = adc_read(adc_channels[0].dev, &sequence0);
        if (err < 0)
            printk("ADC read error on channel 0: %d\n", err);
            return err;
        err = adc_read(adc_channels[1].dev, &sequence2);
        if (err < 0)
            printk("ADC read error on channel 1: %d\n", err);
            return err;
        printk("Raw ADC: Channel 0 = %" PRId16 ", Channel 1 = %" PRId16 "\n", buf0, buf2);
        // Convert raw ADC to millivolts
        int32_t val_mv0 = buf0;
        int32_t val_mv1 = buf2;
        adc_raw_to_millivolts_dt(&adc_channels[0], &val_mv0);
        adc_raw_to_millivolts_dt(&adc_channels[1], &val_mv1);
        // Treat negative values as zero
        photodiode_one_mv = (val_mv0 < 0) ? 0 : val_mv0;
        photodiode_two_mv = (val_mv1 < 0) ? 0 : val_mv1;
        sum_photodiode_one += photodiode_one_mv;
        sum_photodiode_two += photodiode_two_mv;
        printk("Converted: photodiode_one_mv = %d mV, photodiode_two_mv = %d mV\n", photodiode_one_mv, photodiode_two_mv);
        printk("sum_photodiode_one: %d\n", sum_photodiode_one);
        printk("sum_photodiode_two: %d\n", sum_photodiode_two);
        return photodiode_two_mv;
    void calculateBilirubin()
        // Check for division by zero
        if (sample_count == 0)
            printk("Error: No samples collected!\n");
            return;
        avg_photodiode_one = sum_photodiode_one / sample_count;
        avg_photodiode_two = sum_photodiode_two / sample_count;
        printk("avg_photodiode_one: %d\n", avg_photodiode_one);
        printk("avg_photodiode_two: %d\n", avg_photodiode_two);
        printk("sample_count: %d\n", sample_count);
        int int_part_1 = avg_photodiode_one / 1000;
        int frac_part_1 = avg_photodiode_one % 1000;
        printk("PD1 = %d.%03d V\n", int_part_1, frac_part_1);
        snprintf(PD1_str, sizeof(PD1_str), "%d.%03d V", int_part_1, frac_part_1);
        int int_part_2 = avg_photodiode_two / 1000;
        int frac_part_2 = avg_photodiode_two % 1000;
        printk("PD2 = %d.%03d V\n", int_part_2, frac_part_2);
        snprintf(PD2_str, sizeof(PD2_str), "%d.%03d V", int_part_2, frac_part_2);
        if (avg_photodiode_one <= 0)
            bilirubinValue = 0xFFFF;
            snprintf(bilirubinValue_str, sizeof(bilirubinValue_str), "E01");
            printk("bilirubinValue: E01 (PD1 is zero or negative)\n");
            updateGUI();
            return;
        float pd_ratio = (float)avg_photodiode_two / (float)avg_photodiode_one;
        printk("pd_ratio: %.3f\n", (double)pd_ratio);
        snprintf(pd_ratio_str, sizeof(pd_ratio_str), "%.3f", (double)pd_ratio);
        updateGUI();
        if (pd_ratio <= 0.0f)
            pd_ratio = 0.001f;
            // snprintf(pd_ratio_str, sizeof(pd_ratio_str), "0.001");
        float log_pd = log10f(pd_ratio);
        float bilirubin_temp = 2.005f * log_pd * log_pd + 13.417f * log_pd - 2.4092f;
        printk("log_pd: %.6f\n", log_pd);
        printk("bilirubin_temp: %.3f\n", bilirubin_temp);
        if (bilirubin_temp < 0.00f || bilirubin_temp > 25.00f)
            printk("bilirubinValue: E01 (out of range: %.3f)\n", bilirubin_temp);
            updateGUI();
            return;
        bilirubinValue = (uint16_t)(bilirubin_temp * 100); // Example: 11.16 → 1116
        int int_part = bilirubinValue / 100;
        int frac_part = bilirubinValue % 100;
        printk("bilirubinValue: %d.%02d\n", int_part, frac_part);
        snprintf(bilirubinValue_str, sizeof(bilirubinValue_str), "%d.%02d", int_part, frac_part);
        // Update GUI with all new values
        updateGUI();
    void resetAll()
        k_timer_stop(&adc_timer);
        sample_count = 0;
        bilirubinValue = 0;
    void adc_suspend_all(void)
        for (size_t i = 0U; i < ARRAY_SIZE(adc_channels); i++) {
            int err = pm_device_action_run(adc_channels[i].dev,
                                           PM_DEVICE_ACTION_SUSPEND);
            if (err < 0) {
                printk("Unable to suspend ADC device %s (err %d)\n",
                       adc_channels[i].dev->name, err);
            } else {
                printk("ADC device %s suspended\n", adc_channels[i].dev->name);
    void EnterPowerdown(void)
        printk("=== ENTERING POWERDOWN SEQUENCE ===\n");
        // Turn off all LEDs
        printk("Turning off LEDs...\n");
        int ret = gpio_pin_set_dt(&led0, 0);
        printk("LED0 off: %s\n", ret == 0 ? "OK" : "FAILED");
        ret = gpio_pin_set_dt(&led1, 0);
        printk("LED1 off: %s\n", ret == 0 ? "OK" : "FAILED");
        ret = gpio_pin_set_dt(&led, 0);
        printk("Backlight off: %s\n", ret == 0 ? "OK" : "FAILED");
        ret = gpio_pin_set_dt(&led2, 0);
        printk("LED2 off: %s\n", ret == 0 ? "OK" : "FAILED");
        // Stop and suspend PWM
        printk("Stopping PWM...\n");
        ret = pm_device_action_run(pwm_led0.dev, PM_DEVICE_ACTION_SUSPEND);
        printk("PWM suspend: %s (ret=%d)\n", ret == 0 ? "OK" : "FAILED", ret);
        // Put QSPI Flash into deep power-down
        printk("Putting flash into deep power-down...\n");
        // flash_power_down();
        // Stop all timers
        printk("Stopping all timers...\n");
        k_timer_stop(&led_timer);
        k_timer_stop(&pwm_timer);
        printk("Timers stopped\n");
         adc_suspend_all();
        // Add a small delay to ensure all operations complete
        printk("Final delay before powerdown...\n");
        k_sleep(K_MSEC(100));
        printk("=== CALLING sys_poweroff() NOW ===\n");
        printk("If you see this message again after reset, powerdown worked!\n");
        // Force flush any remaining log messages
        k_sleep(K_MSEC(10));
        sys_poweroff();
        // This should NEVER be reached if powerdown works
        printk("ERROR: sys_poweroff() returned! Powerdown failed!\n");
        printk("Entering infinite loop instead...\n");
        while (1) {
            k_sleep(K_SECONDS(1));
            printk("Still running... powerdown didn't work\n");
        printk("\n=== SYSTEM STARTUP ===\n");
        printk("Boot time: %llu ms\n", k_uptime_get());
        k_sleep(K_MSEC(100));  // Let debugger / clocks stabilize
        printk("QSPI JEDEC ID Read & Flash Byte Test\n");
        if (!device_is_ready(flash_dev)) {
            printk("Flash device not ready!\n");
        } else {
            printk("Flash device ready\n");
        // Try to read JEDEC ID via custom instruction
        // read_qspi_jedec_id();
        printk("Proceeding to powerdown test...\n");
        k_sleep(K_MSEC(500));
        EnterPowerdown();
        // uart_suspend();
        while (1) {
            k_sleep(K_FOREVER);
    where  i got in terminal as
     *** Using Zephyr OS v3.6.99-100befc70c74 ***
    00>
    00> === SYSTEM STARTUP ===
    00> Boot time: 154 ms
    00> QSPI JEDEC ID Read & Flash Byte Test
    00> Flash device ready
    00> Proceeding to powerdown test...
    00> === ENTERING POWERDOWN SEQUENCE ===
    00> Turning off LEDs...
    00> LED0 off: OK
    00> LED1 off: OK
    00> Backlight off: OK
    00> LED2 off: OK
    00> Stopping PWM...
    00> [00:00:00.756,042] <dbg> pwm_nrf_sw: pwm_nrf_sw_set_cycles: channel 0, period 0, pulse 0
    00> PWM suspend: FAILED (ret=-88)
    00> Putting flash into deep power-down...
    00> Stopping all timers...
    00> Timers stopped
    00> Unable to suspend ADC device adc@40007000 (err -88)
    00> Final delay before powerdown...
    00> === CALLING sys_poweroff() NOW ===
    00> If you see this message again after reset, powerdown worked!
    pls help me to power down PWM,ADC and FLASH where flash used windbond
  • pls help me forum here struggled in lot of days with powerdown for pwm,flash,spi ,adc ...pls pls
  • Some tips:
    - Simplify your application to ensure you get low idle current and then add functionality and ensure you still have low idle current.
    - Devicetree try to add zephyr,pm-device-runtime-auto; to the various peripheral nodes.
    - Kconfig try to add CONFIG_PM_DEVICE=y, CONFIG_PM_DEVICE_RUNTIME=y
    and double check here for tips:
    - https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/test_and_optimize/optimizing/power.html
    Kenneth
