Fast data transfer through USB
Hello
Im trying to send data[3000] using USB, problem is I need to finish transfer within 13ms because after that period new data is ready to be sent.
ISR_DIRECT_DECLARE(trig_cnt_irq_handler)
	// Half way point
	if(SPI_TRIG_COUNTER->EVENTS_COMPARE[0]) {
		SPI_TRIG_COUNTER->EVENTS_COMPARE[0] = 0;
		m_item_num = LIST_ITEMS / 2;
		m_item_index = 0;
		k_sem_give(&m_sem_samples_available);
		size_t send_target = m_item_num * 3;
	    printf("Zeljeno %u bajtova\n", (unsigned)send_target);
	// End of buffer (not including margin)
	if(SPI_TRIG_COUNTER->EVENTS_COMPARE[1]) {
		SPI_TRIG_COUNTER->EVENTS_COMPARE[1] = 0;
		// If there is a risk that this interrupt gets delayed we need to handle the case where more items have been sampled than expected
		// trigger a capture on the counter to check how far the count has reached
		// TODO: Possibly we would also need to check the state of the timer to check if is just about to trigger another sample, which could lead to a race condition
		SPI_TRIG_COUNTER->TASKS_CAPTURE[3] = 1;
		m_item_num = SPI_TRIG_COUNTER->CC[3] - (LIST_ITEMS / 2);
		m_item_index = LIST_ITEMS / 2;
		SPI_MASTER->TXD.PTR = (uint32_t)m_tx_buffer[0];
		SPI_MASTER->RXD.PTR = (uint32_t)m_rx_buffer[0];
		SPI_TRIG_COUNTER->TASKS_CLEAR = 1;
	ISR_DIRECT_PM();
	return 1;
In this Interrupt Im using first or second half of baffer to be send in main faction
main () {
    while (1) {
    		// Wait for the samples available semaphore to be set
    		k_sem_take(&m_sem_samples_available, K_FOREVER);
    		communication_send_adc_data((uint8_t *)&m_rx_buffer[m_item_index][0], m_item_num*3);
This is communication_send_adc_data()
int communication_send_adc_data(uint8_t *adc_value, size_t length )
    // Pošalji 3 bajta u ring buffer
    ring_buf_put(&ringbuf_tx, adc_value, length);
    sent_counter = 0;
    uart_irq_tx_enable(usb_uart_device);
And communication_interrupt_handler for TX
static void communication_interrupt_handler(const struct device *dev, void *user_data)
    ARG_UNUSED(user_data);
    while (uart_irq_update(dev) && uart_irq_is_pending(dev)) {
        if (uart_irq_tx_ready(dev)) {
            int rb_len, send_len;
            uint8_t *blk;
            // "Zahvati" kontinualni blok iz ring-bufa bez kopiranja
            rb_len = ring_buf_get_claim(&ringbuf_tx, &blk, 64);
            if (rb_len == 0) {
                uart_irq_tx_disable(dev);
                printf("Sent bytes: %u\n", (unsigned int)sent_counter);
                return; // ili continue;
            // Pokušaj da pošalješ sve što si claim-ovao
            send_len = uart_fifo_fill(dev, blk, rb_len);
            // Javi ring-bufu tačno koliko je stvarno poslato
            ring_buf_get_finish(&ringbuf_tx, send_len);
            sent_counter += send_len;
            // Ako nije sve stalo u FIFO, ostalo ostaje claim-ovano za sledeći IRQ,
            // pa odmah prekini (driver će te opet pozvati kad FIFO oslobodi mesto)
            if (send_len < rb_len) {
                return;
My otput is not synchronized, I should be getting Zeljeno 3000 bajtova/n Sent bytes: 3000/n, but instead Im getting this:
Zeljeno 300Zeljeno 3000 bajtova
Zeljeno 3006 bajtova
Sent bytes: 3166
Sent bytes: 3006
Sent bytes: 3000
Sent bytes: 3000
Sent bytes:Zeljeno 3000 bajtova
 3000
Sent bytes: 3000
Sent bytes: 3000
Sent bytes: 3000
Zeljeno 3003 bajtova
Sent bytes: 3031
Sent bytes: 3000
Sent bytes: 3000
Sent bytesZeljeno 3000 bajtova
: 3000
Sent bytes: 3000
Sent bytes: 3000
Sent bytes: 3003
SZeljeno 3000 bajtova
ent bytes: 3000
Sent bytes: 3000
Sent bytZeljeno 3000 bajtova
es: 3000
Sent bytes: 3000
Sent bytes: 3000
Sent bytes: 3000
Sent bytes: 3003
Is there a faster way to do it, some examples and what Iam doing wrong here.
Thank you.
