SERIAL_HAS_DRIVER error in DevAcademy Intermediate Lesson 9
I am trying to build the Lesson 9 Exercise 1 in the DevAcademy Intermediate course, related to DFU. I get the following error:
error: SERIAL_HAS_DRIVER (defined at drivers/serial/Kconfig:15) is assigned in a configuration file,
but is not directly user-configurable (has no prompt). It gets its value indirectly from other
symbols. See docs.zephyrproject.org/.../kconfig.html and/or look
up SERIAL_HAS_DRIVER in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
This happens when trying to build in step 2, that is, having added the following lines to sysbuild.conf:
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_MCUBOOT_MODE_SINGLE_APP=y
And these to sysbuild/mcuboot.conf:
CONFIG_LOG=y
CONFIG_MCUBOOT_LOG_LEVEL_INF=y
The same error is reported when building the solution. It is also independent of the selected board target (it happens with both nrf5340dk/nrf5340/cpuapp and cpuapp/ns). Since this fails when trying to run the first build, I am not able to use the Kconfig tool to see the configuration.
Regarding my build configuration, I am using nRF Connect SDK v2.9.1 with Toolchain v2.9.0. The board target is chosen to be a Nordic SoC (selecting "Nordic Kits" does not make any difference). File prj.conf is selected as the base configuration file. All other settings are left empty as per default.
Since this is happening with the solution to an exercise, I assume somebody else has been already able to build it. Do you have any clue on what could be running wrong on my system?
Thank you very much in advance.
 *  Executing task: nRF Connect: Generate config nrf5340dk/nrf5340/cpuapp/ns for c:\mahle_ecp\nrftraining\ncs-inter\l9_e1_sol
Building l9_e1_sol
C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/build c:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol --pristine --board nrf5340dk/nrf5340/cpuapp/ns -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=prj.conf"
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.9.1/zephyr/.cache
-- Board: nrf5340dk, qualifiers: nrf5340/cpuapp/ns
Parsing C:/ncs/v2.9.1/zephyr/share/sysbuild/Kconfig
Loaded configuration 'C:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/build/_sysbuild/empty.conf'
Merged configuration 'c:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/sysbuild.conf'
Configuration saved to 'C:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/build/zephyr/.config'
Kconfig header saved to 'C:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/build/_sysbuild/autoconf.h'
   * Running CMake for mcuboot *
-- Application: C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr
-- CMake version: 3.21.0
-- Zephyr version: 3.7.99 (C:/ncs/v2.9.1/zephyr)
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.9.1/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: C:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/sysbuild/mcuboot.overlay
-- Generated zephyr.dts: C:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: C:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/build/mcuboot/zephyr/dts.cmake
symbols. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_SERIAL_HAS_DRIVER and/or look
helpful too.
Parsing C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.9.1/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/sysbuild/mcuboot.conf'
Merged configuration 'C:/ncs/v2.9.1/nrf/modules/mcuboot/tfm.conf'
Merged configuration 'C:/ncs/v2.9.1/nrf/modules/mcuboot/fih_low_enable.conf'
Merged configuration 'C:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/build/mcuboot/zephyr/.config.sysbuild'
CMake Error at C:/ncs/v2.9.1/zephyr/cmake/modules/kconfig.cmake:396 (message):
  command failed with return code: 1
  C:/ncs/v2.9.1/nrf/cmake/modules/kconfig.cmake:29 (include)
  C:/ncs/v2.9.1/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
  C:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  C:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:12 (find_package)
CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
  CMake configure failed for Zephyr project: mcuboot
  Location: C:/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/
  cmake/modules/sysbuild_images.cmake:20 (ExternalZephyrProject_Cmake)
  cmake/modules/sysbuild_default.cmake:20 (include)
  C:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  C:/ncs/v2.9.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
See also "C:/mahle_ecp/nrftraining/ncs-inter/l9_e1_sol/build/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/b620d30767/opt/bin/python.exe '-Bc:\mahle_ecp\nrftraining\ncs-inter\l9_e1_sol\build' -GNinja -DBOARD=nrf5340dk/nrf5340/cpuapp/ns -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=prj.conf '-SC:\ncs\v2.9.1\zephyr\share\sysbuild' '-DAPP_DIR:PATH=c:\mahle_ecp\nrftraining\ncs-inter\l9_e1_sol'
 *  The terminal process terminated with exit code: 1.
  • Alejandro Navarro said:
    Just to make sure, could you please check on your side that the mentioned line effectively does not belong to the _defconfig file? If so, then we can close the issue.
    Looking through misc. commits in the repo, I can't see that CONFIG_SERIAL_HAS_DRIVER=y has ever been a part of the nrf5340dk_nrf5340_cpuapp_defconfig.
    E.g. here is a comparison to tag v3.6.99-ncs2
    I'm glad you were able to find the culprit.
    Øyvind
