.overlay:
// Com with PC
&uart0 {
status = "okay";
current-speed = <115200>;
// Com with Virtial sensor
&uart1 {
status = "okay";
pinctrl-0 = <&uart1_tx>;
pinctrl-1 = <&uart1_rx>;
pinctrl-names = "default", "alternate";
// Define RX and TX
&pinctrl {
uart1_tx: uart1_tx {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 7)>,
<NRF_PSEL(UART_RX, 0, 6)>;
/*group2 {
psels = <NRF_PSEL(UART_RX, 0, 6)>;
uart1_rx: uart1_rx {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 6)>,
<NRF_PSEL(UART_RX, 0, 7)>;
bias-pull-up;
/*group2 {
psels = <NRF_PSEL(UART_TX, 0, 6)>;
main:
#include <zephyr/kernel.h>
#include <zephyr/drivers/uart.h>
#include <zephyr/device.h>
#include <zephyr/pm/device.h>
#include <zephyr/drivers/pinctrl.h>
// Retrieving nodes
#define UART1_NL DT_NODELABEL(uart1)
// Macros
#define MAX_DATA_LENGTH 512
// Commands
#define get_address "0!"
#define start_measure "0M!"
#define get_measure "0D0!"
// Init LOG
LOG_MODULE_REGISTER(main, LOG_LEVEL_DBG);
// Defining devices
static const struct device *dev_uart1 = DEVICE_DT_GET(UART1_NL);
// Parameters for data storage
uint8_t buffer[MAX_DATA_LENGTH];
size_t i = 0;
// Baudrate manipulation function and parameters
struct uart_config cfg;
// Switch between tx and rx
static const struct pinctrl_dev_config *pinctrl_config;
void init_pinctrl_config(void)
pinctrl_config = pinctrl_lookup_config(dev_uart1);
if (!pinctrl_config) {
LOG_ERR("Failed to get pinctrl config");
void switch_to_tx(void) {
pinctrl_apply_state(pinctrl_config, 0);
LOG_DBG("Switched to transmit pin state");
void switch_to_rx(void) {
pinctrl_apply_state(pinctrl_config, 1);
LOG_DBG("Switched to receive pin state");
// Callback uart1
static void cb_uart1(const struct device *d, void *user_data) {
uint8_t byte;
while (uart_irq_update(d) && uart_irq_rx_ready(d)) {
while (uart_fifo_read(d, &byte, 1)) {
if (byte == '\0') {
buffer[i] = '\0';
LOG_INF("Message: %s", buffer);
LOG_HEXDUMP_DBG(buffer, MAX_DATA_LENGTH, "Hexdump: ");
i = 0;
memset(buffer, 0, MAX_DATA_LENGTH);
// Data contains bad bytes randomly placed in the message, these have to filtered out
} else if ((i < MAX_DATA_LENGTH - 1) && (byte != '\r') && (byte != '\0') && (byte !='\n')) {
buffer[i++] = byte;
} else if (i >= MAX_DATA_LENGTH - 1) {
LOG_WRN("Buffer overflow for data buffer");
i = 0;
// Send command
void send_command(const char *buf) {
uart_irq_rx_disable(dev_uart1);
switch_to_tx();
uart_tx_enable(dev_uart1);
while (*buf) {
uart_poll_out(dev_uart1, *buf++);
uart_tx_disable(dev_uart1);
switch_to_rx();
uart_irq_rx_enable(dev_uart1);
// Main
if (uart_config_get(dev_uart1, &cfg) != 0) {
LOG_ERR("Failed to retrieve config for uart1");
return 1;
cfg.baudrate = 1200;
cfg.parity = UART_CFG_PARITY_EVEN;
cfg.stop_bits = UART_CFG_STOP_BITS_1;
cfg.data_bits = UART_CFG_DATA_BITS_7;
cfg.flow_ctrl = UART_CFG_FLOW_CTRL_NONE;
if (uart_configure(dev_uart1, &cfg) != 0) {
LOG_ERR("Failed to configure initial baudrate for uart1");
return 1;
LOG_DBG("Uart1 baudrate set to 1200");
// Check if uart1 is ready
if(!device_is_ready(dev_uart1)) {
LOG_WRN("Uart1 is not ready");
return 1;
LOG_DBG("Uart1 is ready");
// Link callback and enable interrupt request for uart1
if (uart_irq_callback_user_data_set(dev_uart1, cb_uart1, NULL) != 0) {
LOG_ERR("Failed to set UART1 callback");
} else {
LOG_DBG("Callback for UART1 set");
// init pinctrl
init_pinctrl_config();
// Let sensor initialize
switch_to_rx();
k_sleep(K_MSEC(1000));
// Check address
send_command(get_address);
// Start measurement
send_command(start_measure);
k_sleep(K_MSEC(2000));
// Get measurement
send_command(get_measure);
// Run forever
while (1) {
k_sleep(K_FOREVER);
return 0;
