bt_gatt: Unable to import the key for AES CMAC -141
I am using a dynamic BAS service. I have noticed that after a few bt_gatt_service_unregister() and bt_gatt_service_register() calls, the following error occurs:
bt_gatt: Unable to import the key for AES CMAC -141.
It appears that the problem is caused by bt_gatt_service_register() calling psa_import_key() without freeing the allocated memory during bt_gatt_service_unregister()
I have added some logs to psa_crypto.c:
*** Booting My Application v2.0.99-b2bc05116228 ***
*** Using nRF Connect SDK v3.0.2-89ba1294ac9b ***
*** Using Zephyr OS v4.0.99-f791c49f492c ***
<inf> main_app: Application started
<inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                            89 9a 50 8a 95 01 9c 58  fc 39 d2 c1 10 04 ee 02 |..P....X .9......
                                            64 ce 25 be                                      |d.%.
<inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
<inf> bt_hci_core: HW Variant: nRF52x (0x0002)
<inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 137.20634 Build 2617349514
<inf> bt_hci_core: No ID address. App must call settings_load()
<inf> bt_hci_core: Identity: E2:09:BC:9E:13:5E (random)
<inf> bt_hci_core: HCI: version 6.0 (0x0e) revision 0x10f3, manufacturer 0x0059
<inf> bt_hci_core: LMP: version 6.0 (0x0e) subver 0x10f3
<err> psa_crypto_srvc: === IMPORT KEY ===
<err> psa_crypto_srvc: === PSA KEYS: tracked_cur=0 peak=0
<err> psa_crypto_srvc: === PSA KEYS: tracked_cur=16 peak=16
<err> bas: SVC REGISTER
<err> psa_crypto_srvc: === REMOVE KEY DATA ===
<err> psa_crypto_srvc: === PSA KEYS: tracked_cur=16 peak=48
<err> bas: SVC UNREGISTER
<err> psa_crypto_srvc: === PSA KEYS: tracked_cur=32 peak=48
<err> psa_crypto_srvc: === PSA KEYS: tracked_cur=48 peak=48
<err> psa_crypto_srvc: === PSA KEYS: tracked_cur=64 peak=64
<err> psa_crypto_srvc: === PSA KEYS: tracked_cur=144 peak=144
<err> psa_crypto_srvc: ==== IMPORT KEY ====
<err> psa_crypto_srvc: === PSA KEYS: tracked_cur=160 peak=160
<err> psa_crypto_srvc: === mbedtls_calloc failed ===
<err> psa_crypto_srvc: === PSA allocate buffer failed ===
<err> bt_gatt: Unable to import the key for AES CMAC -141
Code snippet:
static void register_bas(void)
	for (size_t i = 0; i < ARRAY_SIZE(batteries); i++) {
		struct battery *battery = &batteries[i];
		if (!battery->registered) {
			LOG_ERR("SVC REGISTER");
			const int ret = bt_gatt_service_register(battery->svc);
			if (ret) {
				LOG_ERR("Can't register bas: %d", ret);
				continue;
		battery->registered = true;
static void unregister_bas(void)
		if (batteries[i].registered) {
			LOG_ERR("SVC UNREGISTER");
			const int ret = bt_gatt_service_unregister(batteries[i].svc);
			if (ret) {
				LOG_ERR("Can't unregister bas: %d", ret);
			} else {
				batteries[i].registered = false;
  • psa_crypto.c modifications:
    diff --git a/library/psa_crypto.c b/library/psa_crypto.c
    index 301eed0..d9421c1 100644
    --- a/library/psa_crypto.c
    +++ b/library/psa_crypto.c
    @@ -37,6 +37,8 @@
     #include "mbedtls/constant_time.h"
     #include "mbedtls/cipher.h"  // mbedtls_operation_t
    +#include <zephyr/logging/log.h>
    +LOG_MODULE_REGISTER(psa_crypto_srvc);
     #if defined(PSA_CRYPTO_DRIVER_TFM_BUILTIN_KEY_LOADER)
     #include "tfm_builtin_key_loader.h"
    @@ -283,9 +285,37 @@ MBEDTLS_STATIC_TESTABLE psa_status_t psa_mac_key_can_do(
         return PSA_ERROR_INVALID_ARGUMENT;
    +// ...existing code...
    +static atomic_t g_psa_key_bytes_current;
    +static atomic_t g_psa_key_bytes_peak;
    +static void psa_debug_acc_add(size_t sz)
    +    atomic_add(&g_psa_key_bytes_current, sz);
    +    size_t cur = atomic_get(&g_psa_key_bytes_current);
    +    size_t peak = atomic_get(&g_psa_key_bytes_peak);
    +    if (cur > peak) {
    +        atomic_set(&g_psa_key_bytes_peak, cur);
    +static void psa_debug_acc_sub(size_t sz)
    +    atomic_sub(&g_psa_key_bytes_current, sz);
    +void psa_crypto_debug_dump(void)
    +    LOG_ERR("=== PSA KEYS: tracked_cur=%zu peak=%zu", cur, peak);
     psa_status_t psa_allocate_buffer_to_slot(psa_key_slot_t *slot,
                                              size_t buffer_length)
    +    psa_crypto_debug_dump();
     #if defined(MBEDTLS_PSA_STATIC_KEY_SLOTS)
         if (buffer_length > ((size_t) MBEDTLS_PSA_STATIC_KEY_SLOT_BUFFER_SIZE)) {
             return PSA_ERROR_NOT_SUPPORTED;
    @@ -297,8 +327,10 @@ psa_status_t psa_allocate_buffer_to_slot(psa_key_slot_t *slot,
         slot->key.data = mbedtls_calloc(1, buffer_length);
         if (slot->key.data == NULL) {
    +        LOG_ERR("=== mbedtls_calloc failed ===");
             return PSA_ERROR_INSUFFICIENT_MEMORY;
    +    psa_debug_acc_add(buffer_length);
         slot->key.bytes = buffer_length;
    @@ -729,12 +761,14 @@ static psa_status_t psa_get_and_lock_transparent_key_slot_with_policy(
     psa_status_t psa_remove_key_data_from_memory(psa_key_slot_t *slot)
    +    LOG_ERR("=== REMOVE KEY DATA ===");
         if (slot->key.bytes > 0) {
             mbedtls_platform_zeroize(slot->key.data, MBEDTLS_PSA_STATIC_KEY_SLOT_BUFFER_SIZE);
     #else
         if (slot->key.data != NULL) {
    +        psa_debug_acc_sub(slot->key.bytes);
             mbedtls_zeroize_and_free(slot->key.data, slot->key.bytes);
    @@ -1541,6 +1575,7 @@ psa_status_t psa_import_key(const psa_key_attributes_t *attributes,
                                 size_t data_length,
                                 mbedtls_svc_key_id_t *key)
    +    LOG_ERR("==== IMPORT KEY ====");
         psa_status_t status;
         psa_key_slot_t *slot = NULL;
         psa_se_drv_table_entry_t *driver = NULL;
    @@ -1598,6 +1633,7 @@ psa_status_t psa_import_key(const psa_key_attributes_t *attributes,
             status = psa_allocate_buffer_to_slot(slot, storage_size);
             if (status != PSA_SUCCESS) {
    +            LOG_ERR("=== PSA allocate buffer failed ===");
                 goto exit;
    I am working on your case, and will update next week.
    Amanda H.
  • I have changed it's value from 512 to 4096 and the difference is it reproduces now after more bt_gatt_service_register() and bt_gatt_service_unregister() calls. So for me it still looks like some memory leakage.
  • Thanks for the testing. I have reported to the internal team to investigate. I will update if we have any way to fix it.
