Delete/overwrite old bond keys when a new pair happens
I am using nRF54L15, SDK & Toolchain as 3.0.2 version
This is for Hid Keyboard, the problem I'm facing is once connected to one device, manually disconnecting & connecting to a new device, not properly getting connected, facing automatic disconnection immediately, reason 0x05.
The solution I need is to delete/overwrite the old bond keys whenever device is pairing with a new one, so this will solve the issue, I'm implemented on my code, but still it's not properly working. Check my code what's the issue/what I need to add.
Below I have attached the main file & prj.config file, kindly check it & do the grateful
# Enable Bluetooth Low Energy stack
CONFIG_BT=y
# Maximum 1 simultaneous connection (HID keyboard)
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
# Device acts as peripheral (server)
CONFIG_BT_PERIPHERAL=y
# Device name shown in Bluetooth scans
CONFIG_BT_DEVICE_NAME="HID Keyboard"
# Device appears as keyboard (0x03C1 = 961)
CONFIG_BT_DEVICE_APPEARANCE=961
# Enable connection context (required by HID service)
CONFIG_BT_CONN_CTX=y
# Memory buffer alignment for connection context
CONFIG_BT_CONN_CTX_MEM_BUF_ALIGN=4
# Enable HID Service (Human Interface Device)
CONFIG_BT_HIDS=y
# Maximum 1 HID client (single host connection)
CONFIG_BT_HIDS_MAX_CLIENT_COUNT=1
# Enable Security Manager Protocol (pairing)
CONFIG_BT_SMP=y
# Allow device to be paired/bonded
CONFIG_BT_BONDABLE=y
# Allow overwriting unauthenticated bonds
CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y
CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
# Enable settings subsystem
CONFIG_SETTINGS=y
# Store Bluetooth settings in flash
CONFIG_BT_SETTINGS=y
# Enable flash memory support
CONFIG_FLASH=y
# Enable flash page layout
CONFIG_FLASH_PAGE_LAYOUT=y
# Enable flash memory mapping
CONFIG_FLASH_MAP=y
# Enable Non-Volatile Storage
CONFIG_NVS=y
# Use NVS for settings storage
CONFIG_SETTINGS_NVS=y
# Enable DK button/LED functions
CONFIG_DK_LIBRARY=y
# Set TX power to +8 dBm (maximum for nRF54L15)
CONFIG_BT_CTLR_TX_PWR_PLUS_8=y
# Below is the link to Nordic's documentation for TX power settings for maximum transmission power.
#https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/protocols/matter/getting_started/transmission_power.html
# Enable TX Power Service (advertising data)
CONFIG_BT_TPS=y
# Disable default HID encryption (use custom security)
CONFIG_BT_HIDS_DEFAULT_PERM_RW_ENCRYPT=n
# Use public Bluetooth addresses (simpler)
CONFIG_BT_PRIVACY=n
CONFIG_CONSOLE=y
CONFIG_SERIAL=y
CONFIG_UART_CONSOLE=y
# Disable Bluetooth debug messages
CONFIG_BT_LOG_LEVEL_OFF=y
# Disable NVS debug messages
CONFIG_NVS_LOG_LEVEL_OFF=y
//output
Starting advertising
Connected
Security level 1 requested
Going to sleep
Security (encryption) established, level 2
Pairing completed, bonded=1
Disconnected reason 0x13, waking up to restart advertising
Connected
Disconnected reason 0x05, waking up to restart advertising
Connected
Connected
Going to sleep
Connected
  • This is the main file, kindly look this also, I forgot to add this
    /* main.c - BLE HID Keyboard sample for nRF Connect SDK */
    #include <errno.h>                    /* Error number definitions for return codes */
    #include <stddef.h>                   /* Standard definitions (NULL, size_t, etc.) */
    #include <string.h>                   /* String manipulation functions (memcpy, memset) */
    #include <zephyr/kernel.h>            /* Zephyr kernel API (k_sleep, k_sem) */
    #include <zephyr/sys/printk.h>        /* Print functions for debug output */
    #include <zephyr/types.h>             /* Zephyr type definitions */
    #include <zephyr/settings/settings.h> /* Settings subsystem for persistent storage */
    #include <zephyr/bluetooth/bluetooth.h> /* Core Bluetooth API */
    #include <zephyr/bluetooth/conn.h>      /* Bluetooth connection management */
    #include <zephyr/bluetooth/gatt.h>      /* GATT (Generic Attribute Profile) */
    #include <zephyr/bluetooth/uuid.h>      /* Bluetooth UUID definitions */
    #include <zephyr/bluetooth/addr.h>      /* Bluetooth address utilities */
    #include <bluetooth/services/hids.h>    /* HID Service implementation */
    #include <dk_buttons_and_leds.h>        /* Nordic DK button and LED functions */
    #include <zephyr/device.h>              /* Device tree and device API */
    #include <zephyr/sys/util.h>            /* Utility macros (ARRAY_SIZE) */
    #include <zephyr/bluetooth/hci.h>        /* HCI (Host Controller Interface) */
    /* Device name & size (CONFIG_BT_DEVICE_NAME) - Used in advertising data */
    #define DEVICE_NAME CONFIG_BT_DEVICE_NAME
    #define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
    /* HID related definitions - Standard HID keyboard specifications */
    #define BASE_USB_HID_SPEC_VERSION    0x0101  /* HID Class Specification release version 1.1 */
    #define KEY_PRESS_MAX                4       /* Maximum number of simultaneous non-modifier keys (HID standard) */
    #define INPUT_REPORT_KEYS_MAX_LEN    1  /* Report format: 1 byte for single key */
    enum { INPUT_REP_KEYS_IDX = 0 };      /* Index for the keyboard input report */
    /* Lookup table for button to key mapping - Efficient button-to-key conversion */
    static const struct button_key_map {
        uint32_t button_mask;  /* Button bit mask for identification */
        uint8_t key_value;     /* Corresponding HID key code */
    } button_key_lookup[] = {
        {DK_BTN1_MSK, 0x04}, /* HID keycode 0x04 = 'a' - Button 1 maps to 'a' */
        {DK_BTN2_MSK, 0x05}, /* HID keycode 0x05 = 'b' - Button 2 maps to 'b' */
        {DK_BTN3_MSK, 0x06}, /* HID keycode 0x06 = 'c' - Button 3 maps to 'c' */
        {DK_BTN4_MSK, 0x07}, /* HID keycode 0x07 = 'd' - Button 4 maps to 'd' */
    #define BUTTON_KEY_COUNT ARRAY_SIZE(button_key_lookup)  /* Number of button mappings */
    /* HID service instance (HIDS) - Global instance for keyboard functionality */
    BT_HIDS_DEF(hids_obj, 0, INPUT_REPORT_KEYS_MAX_LEN);
    /* TX Power value for advertising - Set to 9 dBm */
    static int8_t adv_tx_power = 9;
    /* Advertising data: flags, appearance (Keyboard), service UUIDs (HIDS), and TX power - Optimized for efficiency */
    static const struct bt_data ad[] = {
        BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)), /* General discoverable, LE only */
        BT_DATA_BYTES(BT_DATA_GAP_APPEARANCE,    /* Device appearance as keyboard (0x03C1) */
                      (CONFIG_BT_DEVICE_APPEARANCE >> 0) & 0xFF,
                      (CONFIG_BT_DEVICE_APPEARANCE >> 8) & 0xFF),
        BT_DATA_BYTES(BT_DATA_UUID16_ALL,        /* Include HID Service UUID in advertising */
                       BT_UUID_16_ENCODE(BT_UUID_HIDS_VAL)),
        BT_DATA(BT_DATA_TX_POWER, &adv_tx_power, sizeof(adv_tx_power))  /* Include TX power in advertising */
    /* Scan response data: Complete device name - Sent when host requests additional info */
    static const struct bt_data sd[] = {
        BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    /* Bluetooth connection parameters for better low power consumption - Optimized for battery life */
    struct bt_le_conn_param param = {
        .interval_min = 40, // 50ms (40 * 1.25ms) - Minimum connection interval
        .interval_max = 80, // 100ms (80 * 1.25ms) - Maximum connection interval
        .latency = 4, // slave can skip 4 connection events - Reduces power consumption
        .timeout = 500 // 5 second supervision timeout - Connection lost detection
    /* Default values for connection parameters
        .interval_min = 30, // 37.5ms (30 * 1.25ms) - Minimum connection interval
        .interval_max = 40, // 50ms (40 * 1.25ms) - Maximum connection interval
        .latency = 0, // slave can skip 0 connection events
        .timeout = 400 // 4 second supervision timeout - Connection lost detection
    /* Semaphore used to pause the main loop until a wake-up event (e.g., button) occurs - Power management */
    K_SEM_DEFINE(wakeup_sem, 0, 1);
    /* Application state structure - Centralized state management */
    struct app_state {
        uint8_t is_adv;      /* Flag to indicate if advertising is ongoing - State tracking */
        uint8_t is_con;      /* Flag to indicate if a connection is active - State tracking */
        uint8_t is_dis;      /* Flag to indicate if system gets disconnected - State tracking */
        uint8_t is_sleep;    /* Flag to indicate if system is in sleep mode - Power management */
        struct bt_conn *current_conn;  /* Current connection reference - Tracks active connection for key reporting */
    /* Global application state instance - Centralized state management */
    static struct app_state app_state = {
        .is_adv = false,
        .is_con = false,
        .is_dis = false,
        .is_sleep = false,
        .current_conn = NULL
    /* Start Bluetooth advertising with TX power - Device discovery and connection setup */
     * Create advertising parameters:
     *  - Use connectable advertising (BT_LE_ADV_OPT_CONN) for device connections
     *  - Include TX power information (BT_LE_ADV_OPT_USE_TX_POWER) for better range estimation
     *  - Use fast advertising intervals (BT_GAP_ADV_FAST_INT_MIN_2/MAX_2) for quick discovery
     *  - Undirected advertising (NULL peer address) for general discoverability
     * BT_LE_ADV_PARAM macro creates a bt_le_adv_param structure with these settings
        const struct bt_le_adv_param *adv_param = BT_LE_ADV_PARAM(
            BT_LE_ADV_OPT_CONN | BT_LE_ADV_OPT_USE_TX_POWER,  /* Connectable advertising with TX power information */
            BT_GAP_ADV_FAST_INT_MIN_2,    /* Fast advertising interval minimum */
            BT_GAP_ADV_FAST_INT_MAX_2,    /* Fast advertising interval maximum */
            NULL);                        /* No specific peer address (undirected) */
        int err = bt_le_adv_start(adv_param, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
        if (err) {
            if (err == -EALREADY) {
                printk("Advertising continued\n");  /* Already advertising - normal case */
            } else {
                printk("Advertising failed to start (err %d)\n", err);  /* Error handling */
            return;
        app_state.is_adv = true;  /* Set advertising flag - Update state */
    /* Bluetooth connection callback: handles new connections - Called when a client connects */
    static void connected(struct bt_conn *conn, uint8_t err)
        char addr[BT_ADDR_LE_STR_LEN];  /* Buffer for storing peer address string */
        bt_addr_le_to_str(bt_conn_get_dst(conn), addr, sizeof(addr));  /* Get peer address for logging */
        if (err) {
            printk("Failed to connect (err %u)\n", err);  /* Connection failed */
            return;
        if(app_state.current_conn!=conn){
            if(app_state.current_conn){
                bt_unpair(BT_ID_DEFAULT, bt_conn_get_dst(app_state.current_conn));
            app_state.current_conn = conn;  /* Store connection reference - For key reporting */
        printk("Connected\n");  /* Successful connection */
        bt_le_adv_stop();  /* Stop advertising once connected - No longer need to be discoverable */
        app_state.is_adv = false;  /* Update advertising state */
        app_state.is_con = true;  /* Set connection flag - Update state */
        dk_set_led_on(DK_LED2);  /* CON_STATUS_LED on - Visual connection indicator */
        dk_set_led_off(DK_LED1);  /* Advertise led off - Visual state update */
        /* Update connection parameters for latency - Optimize power consumption */
        err = bt_conn_le_param_update(conn, &param);  /* Request connection parameter update */
        if (err) {
            printk("Failed to request connection parameter update (err %d)\n", err);  /* Parameter update failed */
        /* Inform the HID service of the new connection - Initialize HID for this connection */
        int hids_err = bt_hids_connected(&hids_obj, conn);
        if (hids_err) {
            printk("Failed to notify HID service about connection (err %d)\n", hids_err);  /* HID service error */
            return;
        /* Request security level 2 (encryption) for HID service - Security requirement */
        err = bt_conn_set_security(conn, BT_SECURITY_L1);
        if (err) {
            printk("Failed to set security level (err %d)\n", err);  /* Security setup failed */
        } else {
            printk("Security level 1 requested\n");  /* Security setup successful */
    /* Bluetooth disconnection callback: handle cleanup and wakeup main function from sleep once disconnected */
        const bt_addr_le_t *peer = bt_conn_get_dst(conn);  /* Get peer address for cleanup */
        char s[BT_ADDR_LE_STR_LEN];  /* Buffer for storing peer address string */
        bt_addr_le_to_str(peer, s, sizeof(s));  /* Convert address to string for logging */
        printk("Disconnected reason 0x%02X, waking up to restart advertising\n", reason);
        // app_state.current_conn = NULL;  /* Clear connection reference immediately */
        bt_hids_disconnected(&hids_obj, conn);  /* Inform the HID service of the disconnection - Clean up HID state */
        dk_set_led_off(DK_LED2);  /* turn off CON_STATUS_LED if no connections - Visual state update */
        dk_set_led_off(DK_LED1);  /* turn off ADV_STATUS_LED if no connections - Visual state update */
        app_state.is_con = false;  /* Reset connection flag - Update state */
        app_state.is_adv = false;  /* Reset advertising flag - Update state */
        app_state.is_dis = true;  /* Set disconnection flag - Trigger re-advertising */
        if(app_state.is_sleep){
            app_state.is_sleep = false;  /* Reset sleep flag - Wake up from sleep */
            k_sem_give(&wakeup_sem);  /* Wake up the main loop - Resume operation */
    /* Security level changed callback (e.g. after pairing completes) - Security status monitoring */
    static void security_changed(struct bt_conn *conn, bt_security_t level, enum bt_security_err err)
        if (!err) {
            printk("Security (encryption) established, level %u\n", level);  /* Security established */
        } else {
            printk("Security failed, level %u, err %d\n", level, err);  /* Security failed */
    /* Register the connection callbacks - Set up Bluetooth event handlers */
    BT_CONN_CB_DEFINE(conn_callbacks) = {
        .connected = connected,        /* Called when connection established */
        .disconnected = disconnected,  /* Called when connection lost */
        .security_changed = security_changed  /* Called when security level changes */
    /* Initialize the HID service and report map - Set up keyboard functionality */
    static void hid_init(void)
        /* Define the HID Report Map (descriptor) for a simple keyboard*/
        static const uint8_t report_map[] = {
            0x05, 0x01,       /* Usage Page (Generic Desktop) */
            0x09, 0x06,       /* Usage (Keyboard) */
            0xA1, 0x01,       /* Collection (Application) */
            /* Single key (1 byte) - Direct key code  */
            0x95, 0x01,       /* Report Count (1) - One key byte */
            0x75, 0x08,       /* Report Size (8) - 8 bits per key code */
            0x15, 0x00,       /* Logical Minimum (0) - For key release */
            0x25, 0x07,       /* Logical Maximum (7) - Max key code used (0x07 = 'd') */
            0x05, 0x07,       /* Usage Page (Key Codes) - Standard keyboard usage page */
            0x19, 0x00,       /* Usage Minimum (0) - Allow key release (0x00) */
            0x29, 0x07,       /* Usage Maximum (7) - Max key code used (0x07 = 'd') */
            0x81, 0x00,       /* Input (Data, Array) – single key (1 byte) */
            0xC0              /* End Collection */
        /* Initialize HID service configuration structure - Set up HID service parameters */
        struct bt_hids_init_param hids_init_obj = { 0 };  /* Initialize to zero */
        hids_init_obj.rep_map.data = report_map;  /* Set report map data */
        hids_init_obj.rep_map.size = sizeof(report_map);  /* Set report map size */
        /* HID information - Standard HID device information */
        hids_init_obj.info.bcd_hid = BASE_USB_HID_SPEC_VERSION;  /* HID specification version */
        hids_init_obj.info.b_country_code = 0x00;  /* Country code (0 = not specified) */
        hids_init_obj.info.flags = BT_HIDS_REMOTE_WAKE | BT_HIDS_NORMALLY_CONNECTABLE;  /* Device capabilities */
        /* Set security requirements for HID service - Encryption required for key data */
        hids_init_obj.inp_rep_group_init.reports[INPUT_REP_KEYS_IDX].perm = BT_GATT_PERM_READ_ENCRYPT;
         /* Initialize input report (keyboard keys) - Configure keyboard report */
        struct bt_hids_inp_rep *inp_rep = &hids_init_obj.inp_rep_group_init.reports[INPUT_REP_KEYS_IDX];
        inp_rep->size = INPUT_REPORT_KEYS_MAX_LEN;  /* Set report size */
        inp_rep->id   = 0;  /* Report ID (if using, else 0) - Single report */
        hids_init_obj.inp_rep_group_init.cnt++;  /* Increment report count */
        int err;  /* Error code for HID service initialization */
        err = bt_hids_init(&hids_obj, &hids_init_obj);  /* Register the HID service with the stack */
        __ASSERT(err == 0, "HIDS initialization failed (err %d)\n", err);  /* Assert on initialization failure */
    /* Called when pairing completes - Security pairing status */
    static void pairing_complete(struct bt_conn *conn, bool bonded)
        char addr_str[BT_ADDR_LE_STR_LEN];  /* Buffer for storing peer address string */
        const bt_addr_le_t *addr = bt_conn_get_dst(conn);  /* Get peer address for logging */
        bt_addr_le_to_str(addr, addr_str, sizeof(addr_str));  /* Convert address to string for logging */
        printk("Pairing completed, bonded=%d\n", bonded);  /* Log pairing result */
    // Called when pairing fails - Security pairing error handling
    static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason) {
      bt_addr_le_to_str(bt_conn_get_dst(conn), addr, sizeof(addr));  /* Convert address to string for logging */
      printk("Pairing failed, reason %d %s\n", reason,
             bt_security_err_to_str(reason));  /* Log pairing failure details */
      /* If pairing failed due to authentication issues, try to clean up any partial bonds */
      if (reason == BT_SECURITY_ERR_AUTH_FAIL ||
          reason == BT_SECURITY_ERR_PAIR_NOT_SUPPORTED ||
          reason == BT_SECURITY_ERR_PAIR_NOT_ALLOWED) {
        printk("Cleaning up bonds for failed pairing\n");  /* Clean up failed bonds */
        bt_unpair(BT_ID_DEFAULT, bt_conn_get_dst(conn)); //clean up stale/partial bonding info
    // Register the pairing-complete and pairing-failed callbacks - Security event handlers
    static struct bt_conn_auth_info_cb auth_info_cb = {
        .pairing_complete = pairing_complete,  /* Called when pairing succeeds */
        .pairing_failed   = pairing_failed     /* Called when pairing fails */
    /* Handle key press or release then send updated report directly - Optimized single key handling */
    static int hid_buttons_action(uint8_t key, bool is_press) {
      if (is_press) {
        dk_set_led_on(DK_LED3);  /* Turn on activity LED - Visual feedback */
      } else {
        dk_set_led_off(DK_LED3);  /* Turn off activity LED - Visual feedback */
        key = 0;  /* Key release = 0 */
    return bt_hids_inp_rep_send(&hids_obj, app_state.current_conn, INPUT_REP_KEYS_IDX, &key, 1, NULL);
    /* Application-specific handling of physical buttons: map to keyboard actions - Button event processing
    * Called by dk_buttons_init.
    * For each button (1..4), on press it sends the corresponding HID key (a/b/c/d),
     and on release clears it.
    * Only sends when a connection is active (is_con).
    static void handle_button_changed(uint32_t button_state, uint32_t has_changed)
        if(has_changed && !app_state.is_con){
                app_state.is_sleep = false;  /* Reset sleep flag - Wake up from sleep mode */
        return; // No connection - Don't send keys
        /* Process each button using lookup table - Efficient button processing */
        for (int i = 0; i < BUTTON_KEY_COUNT; i++) {
            if (has_changed & button_key_lookup[i].button_mask) {  /* Check if this button changed */
                bool pressed = button_state & button_key_lookup[i].button_mask;  /* Check if button is pressed */
                hid_buttons_action(button_key_lookup[i].key_value, pressed);  /* Send key press/release */
        printk("Starting Bluetooth LE HID Keyboard example\n");  /* Application startup message */
        int err;  /* Error code for initialization functions */
        /* Initialize buttons and LEDs on the DK - Hardware initialization */
        err = dk_buttons_init(handle_button_changed);  /* Set up button interrupt handler */
        if (err) {
            printk("Buttons init failed (err %d)\n", err);  /* Button initialization error */
        err = dk_leds_init();  /* Initialize LED hardware */
        if (err) {
            printk("LEDs init failed (err %d)\n", err);  /* LED initialization error */
        /* Register BLE pairing callback - Security event handling */
        bt_conn_auth_info_cb_register(&auth_info_cb);
        // Initializes the HID service - Set up keyboard functionality
        hid_init();
        // Initializes settings subsystem if enabled (for bond storage) - Persistent storage
        if (IS_ENABLED(CONFIG_SETTINGS)) {
            err = settings_subsys_init();  /* Initialize settings system */
            if (err) {
            printk("settings_subsys_init failed (err %d)\n", err);  /* Settings initialization error */
            return 0;
        /* Enable Bluetooth subsystem - Initialize BLE stack */
        err = bt_enable(NULL);  /* Start Bluetooth with default parameters */
        if (err) {
            printk("Bluetooth init failed (err %d)\n", err);  /* Bluetooth initialization error */
            return 0;
        printk("Bluetooth initialized\n");  /* Bluetooth startup successful */
        /* Load bond information (if CONFIG_SETTINGS enabled for storing bonds) - Restore pairings */
            settings_load();  /* Load previously stored bonds */
        while (1) {  /* Main application loop - Continuous operation */
            if(!app_state.is_con && !app_state.is_adv){  /* Not connected and not advertising - Start advertising */
                printk("Starting advertising\n");  /* Normal advertising with Public address - DA:F5:C0:BE:DB:AD*/
                advertising_start();  /* Start BLE advertising */
                dk_set_led_on(DK_LED1);  /* Turn on advertising LED - Visual indicator */
                /* Wait for connection or timeout, but check for events periodically */
                for (int i = 0; i < 30 && !app_state.is_con && !app_state.is_dis; i++) {
                    k_sleep(K_SECONDS(1));  /* Sleep for 1 second at a time */
                /* Only stop advertising if not connected and not disconnected */
                if(app_state.is_adv && !app_state.is_con && !app_state.is_dis){
                    bt_le_adv_stop();  /* Stop advertising to save power */
                    printk("Advertising stopped\n");
                    dk_set_led_off(DK_LED1);  /* Turn off advertising LED */
                if(app_state.is_dis){  /* Disconnection occurred - Re-advertise */
                    app_state.is_dis = false;  /* Clear disconnection flag */
                    continue;  // If disconnected, continue to re-advertise
            // Drain the semaphore before sleeping - Clear any pending wake events
            while (k_sem_count_get(&wakeup_sem)) {
                k_sem_take(&wakeup_sem, K_NO_WAIT);  /* Remove pending semaphore */
            app_state.is_sleep = true;  // Set sleep flag - Enter sleep mode
            printk("Going to sleep\n");
            k_sem_take(&wakeup_sem, K_FOREVER);  /* Wait for wake event - Power saving sleep */
                app_state.is_dis = false;  /* Clear disconnection flag if set during sleep */
  • Hi Harish,
    We will need to look into why  it couldn't reconnect after bond.
    Could you capture a sniffer trace ?
    If you test with the default HID keyboard sample in the SDK do you see the same issue ?
  • Hi Hung Bui,
    Thanks for your response.
    I noticed the problem & solved the issue.
    Thanks Hung Bui.
  • Actually, I’m overwriting the old bond whenever a new pairing occurs, so the nRF removes the old bonds and successfully pairs with the new one.
    Using this configuration, I'm overwriting old bonds.
