MCUBoot+sysbuild+ns-variant: E: Protect mcuboot flash failed, cancel startup.
Hi.
Goal
I am creating a new application for the nRF54l15 and want to follow the latest recommendations for project configuration. I need to do DFU over BLE, so I'm trying to add MCUBoot in the chain-of-trust regime, using sysbuild. To get there, I used the zephyr/samples/sysbuild/with_mcuboot as a starting point.
Problem
The sample in question does not explicitly support any of the nordic boards with secure/non-secure regime, and I haven't found any samples that combine all these criteria. So I have tried to build the zephyr/sysbuild/with_mcuboot sample for nrf54l15dk/nrf54l15/ns. After erase+flash to my nRF54l15-PDK, I get the following error:
*** Booting MCUboot v2.1.0-dev-2b69d93e75bc ***
*** Using nRF Connect SDK v3.1.0-6c6e5b32496e ***
*** Using Zephyr OS v4.1.99-1612683d4010 ***
How to recreate
Open zephyr/sysbuild/with_mcuboot and build for zephyr/sysbuild/with_mcuboot sample for nrf54l15dk/nrf54l15/ns. My first build failed, but after doing a pristine build it built successfully and I was able to flash (VSCode build output is attached). Finally, flash to the DK and it should produce the error message shown above.
My setup
Support information is attached. I'm using SDK and toolchain version 3.1.0 with VSCode for windows 10, and nRF54L15-PDK (0.8.1, 2024.38).
Solutions?
I don't have to be able to run this exact sample, but what is causing this error and how do I best resolve it?
vscode_build_log.txt
// IMPORTANT: The following data can contain sensitive or confidential information about your environment.
// If you do not want others to see this information, make sure to remove it before sharing the data.
// For help and support, visit Nordic Semiconductor's DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Pro",
    "osKernel": "10.0.19045",
    "vscode": "1.103.0",
    "electron": "37.2.3",
    "node": "v22.17.0"
  "system": {
    "date": "2025-08-18T09:15:11.091Z",
    "vscodeRoot": "c:\\Program Files\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:47:59",
    "osUptime": "129:28:11",
    "cpu": "Intel(R) Core(TM) i7-10700T CPU @ 2.00GHz"
  "workspace": {
    "name": "with_mcuboot",
    "workspaceFile": null,
    "folders": [
      "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot"
  "sdks": [
      "version": "v3.1.0",
      "path": "c:\\ncs\\v3.1.0"
      "version": "v3.0.0",
      "path": "c:\\ncs\\v3.0.0"
      "version": "v2.9.0",
      "path": "c:\\ncs\\v2.9.0"
      "version": "v2.7.0",
      "path": "c:\\ncs\\v2.7.0"
      "version": "v2.6.1",
      "path": "c:\\ncs\\v2.6.1"
      "version": "v2.5.1",
      "path": "c:\\ncs\\v2.5.1"
      "version": "v2.4.2",
      "path": "c:\\project\\saferoad"
      "version": "v2.4.0",
      "path": "c:\\ncs\\v2.4.0"
      "version": "v2.3.0",
      "path": "c:\\ncs\\v2.3.0"
      "version": "v2.2.0",
      "path": "c:\\ncs\\v2.2.0"
      "version": "v1.9.1",
      "path": "c:\\ncs\\v1.9.1"
      "version": "v1.5.1",
      "path": "c:\\ncs\\v1.5.1"
  "activeBuild": "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot\\build_1",
  "apps": [
      "workspace": "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot",
      "uri": "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot",
      "buildConfigurations": [
          "id": "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot\\build",
          "name": "build",
          "boardId": "nrf54l15dk/nrf54l15/cpuapp/ns",
          "type": "Sysbuild",
          "isChild": false,
          "isStale": false,
          "taskBindings": {
            "build": [],
            "pristineBuild": [],
            "flash": [],
            "eraseAndFlash": []
          "sdk": "c:\\ncs\\v3.1.0",
          "toolchain": "nRF Connect SDK Toolchain v3.1.0"
          "id": "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot\\build_1",
          "name": "build_1",
          "type": "Zephyr",
          "isChild": false,
          "isStale": false,
          "taskBindings": {
            "build": [],
            "flash": [],
            "eraseAndFlash": []
  "toolchains": [
      "version": "3.1.0",
      "path": "c:\\ncs\\toolchains\\b8b84efebd"
      "version": "3.0.0",
      "path": "c:\\ncs\\toolchains\\0b393f9e1b"
      "version": "2.9.0",
      "path": "c:\\ncs\\toolchains\\b620d30767"
      "version": "2.7.0",
      "path": "c:\\ncs\\toolchains\\ce3b5ff664"
      "version": "2.6.1",
      "path": "c:\\ncs\\toolchains\\cf2149caf2"
      "version": "2.5.1",
      "path": "c:\\ncs\\toolchains\\c57af46cb7"
      "version": "2.4.0",
      "path": "c:\\ncs\\toolchains\\31f4403e35"
      "version": "2.3.0",
      "path": "c:\\ncs\\toolchains\\v2.3.0"
      "version": "2.2.0",
      "path": "c:\\ncs\\toolchains\\v2.2.0"
      "version": "2.0.0",
      "path": "c:\\ncs\\toolchains\\v2.0.0"
      "version": "1.9.1",
      "path": "c:\\ncs\\v1.9.1\\toolchain"
      "version": "1.9.1",
      "path": "c:\\ncs\\toolchains\\v1.9.1"
      "version": "1.5.1",
      "path": "c:\\ncs\\v1.5.1\\toolchain"
  "connectedDevices": [
      "serialNumber": "000203200665"
      "serialNumber": "001057760695"
  "tools": {
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.17.0",
    "C:\\Program Files\\SEGGER\\JLink_V818\\JLink.exe": "8.18",
    "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.24.2",
    "C:\\ncs\\toolchains\\b8b84efebd\\nrfutil": "8.1.0",
    "C:\\ncs\\toolchains\\b8b84efebd\\cmake": "3.21.0",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\Scripts\\west.exe": "1.4.0",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\python.exe": "3.12.4",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\ninja.exe": "1.10.2",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\gperf.exe": "3.1",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\dtc.exe": "1.4.7",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\gn.exe": "2223",
    "C:\\ncs\\toolchains\\b8b84efebd\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    "arm-gdbPath": "c:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe",
    "riscv-gdbPath": "C:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin\\riscv64-zephyr-elf-gdb.exe"
  "nrfutil": {
    "nrfutil-device": {
      "version": "2.7.2",
      "binPath": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device",
      "jlinkInfo": {
        "description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
        "expectedVersion": {
          "version": "JLink_V7.94i",
          "versionFormat": "string"
        "name": "JlinkARM",
        "version": "JLink_V8.18 ",
    "nrfutil-toolchain-manager": {
      "version": "0.14.4",
      "binPath": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
  "environment": {
    "westEnv": {
      "HOME": "C:\\SPB_Data",
      "HOMEDRIVE": "C:",
      "HOMEPATH": "\\Users\\ErlendEliasIsachsen",
      "PATH": "C:\\ncs\\toolchains\\b8b84efebd;C:\\ncs\\toolchains\\b8b84efebd\\mingw64\\bin;C:\\ncs\\toolchains\\b8b84efebd\\bin;C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin;C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\Scripts;c:/ncs/toolchains/b8b84efebd\\opt/nanopb/generator-bin;C:\\ncs\\toolchains\\b8b84efebd\\nrfutil\\bin;C:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;C:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin;c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Microchip\\xc8\\v2.31\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\WinMerge;C:\\Program Files\\dotnet\\;C:\\Program Files\\Wolfram Research\\WolframScript\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Program Files\\LLVM\\bin;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\otii;C:\\Program Files\\doxygen\\bin;C:\\Program Files\\Graphviz\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\ncs\\nrfutil;C:\\gnuarmemb\\9_2019-q4-major\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ErlendEliasIsachsen\\.dotnet\\tools;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Programs\\MiKTeX\\miktex\\bin\\x64\\;",
      "ZEPHYR_BASE": "c:\\ncs\\v3.1.0\\zephyr",
      "ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk",
      "PYTHONPATH": "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin;C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\Lib;C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\Lib\\site-packages"
    "inherited": {
      "HOMEDRIVE": "C:",
      "Path": "C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Microchip\\xc8\\v2.31\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\WinMerge;C:\\Program Files\\dotnet\\;C:\\Program Files\\Wolfram Research\\WolframScript\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Program Files\\LLVM\\bin;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\otii;C:\\Program Files\\doxygen\\bin;C:\\Program Files\\Graphviz\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\ncs\\nrfutil;C:\\gnuarmemb\\9_2019-q4-major\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ErlendEliasIsachsen\\.dotnet\\tools;C:\\Program Files\\TortoiseSVN\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Programs\\MiKTeX\\miktex\\bin\\x64\\;",
      "PATH": "C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Microchip\\xc8\\v2.31\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\WinMerge;C:\\Program Files\\dotnet\\;C:\\Program Files\\Wolfram Research\\WolframScript\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Program Files\\LLVM\\bin;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\otii;C:\\Program Files\\doxygen\\bin;C:\\Program Files\\Graphviz\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\ncs\\nrfutil;C:\\gnuarmemb\\9_2019-q4-major\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ErlendEliasIsachsen\\.dotnet\\tools;C:\\Program Files\\TortoiseSVN\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Programs\\MiKTeX\\miktex\\bin\\x64\\;"
  "terminal": {
    "defaultProfile": null
  "config": {
      "topdir": "",
      "toolchain": {
        "path": ""
      "ozonePath": "",
      "applications": [],
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig"
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "taskBindings": {},
      "buildTerminal": {
        "condensedProgress": true
      "debugging": {
        "flash": true,
        "bindings": {},
        "justMyCode": false
      "flash": {
        "softreset": false,
        "erase": false,
        "recover": false
      "enableTelemetry": true,
      "thirdpartyIntegration": {},
      "toolchainManager": {
        "indexURL": null,
        "installDirectory": null
      "nrfutil": {
        "home": null
      "defaultOpenAction": "ask",
      "terminalProfile": {
        "shell": null
      "terminalMode": "character"
    "marus25.cortex-debug": {
      "variableUseNaturalFormat": true,
      "liveWatchRefreshRate": "300",
      "armToolchainPath": null,
      "armToolchainPrefix": "arm-none-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": null,
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "dbgServerLogfile": null
  "extensions": {
    "internal": {
        "version": "2024.12.55",
        "path": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64",
        "isActive": true
        "version": "2024.9.14",
        "path": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.9.14",
        "isActive": true
        "version": "2025.4.22",
        "path": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2025.4.22",
        "isActive": true
        "version": "2025.4.26",
        "path": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2025.4.26",
        "isActive": true
    "external": {
      "marus25.cortex-debug": "1.12.1",
      "ms-vscode.cpptools": "1.27.0",
      "ms-vscode.js-debug": "1.102.0",
      "bbenoist.Doxygen": "1.0.0",
      "cschlosser.doxdocgen": "1.4.0",
      "GitHub.copilot": "1.350.0",
      "GitHub.copilot-chat": "0.30.1",
      "josetr.cmake-language-support-vscode": "0.0.9",
      "mcu-debug.debug-tracker-vscode": "0.0.15",
      "mcu-debug.memory-view": "0.0.25",
      "mcu-debug.peripheral-viewer": "1.4.6",
      "mcu-debug.rtos-views": "0.0.7",
      "ms-dotnettools.vscode-dotnet-runtime": "2.3.7",
      "ms-python.vscode-python-envs": "1.2.0",
      "ms-vscode-remote.remote-containers": "0.422.1",
      "ms-vscode.cpptools-extension-pack": "1.3.1",
      "tomoki1207.pdf": "1.2.2",
      "xaver.clang-format": "1.9.0"
  • Hi.
    The size of MCUBoot alone is what causing the issue in your case, 96 kiB > 64 kiB. Are you using all that space, or can you reduce it?
    I usually find 0xc000 (48 kiB) to be sufficient for mcuboot, and leaves room for debug and logging. If that's sufficient for you, I would suggest editing pm_static.yml like so:
    mcuboot:
      address: 0x00000000
    Setting size to 0x10000 might work as well, although I'm not sure as it sits right at that 64 kiB limit.
    Since that is all you have in your pm_static.yml, the automatic partition manager should resolve the rest of the partitions as well.
    any update on this? Will it be fixed on NCS v3.2.0? I have the same problem on my own custom board using MCUBoot and TF-M. And I cannot remove the TF-M.
    It can also be reproduce following the NCS intermediate course, Lesson 9 Exercise 5, on the nRF54L15DK cpuapp/ns
    Sorry for the delay with this issue. Please check the PRs below for the FPROTECT issue:
    https://github.com/nrfconnect/sdk-mcuboot/pull/576
    https://github.com/nrfconnect/sdk-nrf/pull/25655
    Kind Regards,
    Abhijith
  • Thanks, I'll try to check it out. Does the sample work out of the box with this fix, or is additional configuration required?
    i.e. zephyr/sysbuild/with_mcuboot for nrf54l15dk/nrf54l15/ns.
  • After a while I was finally able to test the fix in some of the newer SDK versions, and I'm now able to build with sysbuild+MCUboot+TFM / non-secure variant with both nRF54l15 DK and our custom boards. However, I only managed to get it working with the partition manager, which since the creation of this thread has been marked as depreciated. As soon as I tried to switch to DTS-style partitioning (nRF Connect SDK 3.3.1) I encountered problems again, for example:
    In file included from C:/ncs/v3.3.1/zephyr/include/zephyr/toolchain.h:52,
                     from C:/ncs/v3.3.1/zephyr/include/zephyr/kernel_includes.h:23,
                     from C:/ncs/v3.3.1/zephyr/include/zephyr/kernel.h:17,
                     from C:/ncs/v3.3.1/bootloader/mcuboot/boot/zephyr/main.c:22:
    C:/ncs/v3.3.1/bootloader/mcuboot/boot/zephyr/main.c: In function 'main':
    C:/ncs/v3.3.1/zephyr/include/zephyr/toolchain/gcc.h:87:36: error: static assertion failed: "Can not FPROTECT region that big"
       87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert((EXPR), "" MSG)
    C:/ncs/v3.3.1/bootloader/mcuboot/boot/zephyr/main.c:951:5: note: in expansion of macro 'BUILD_ASSERT'
      951 |     BUILD_ASSERT(FPROTECT_REGION_SIZE <= (62 * 1024), "Can not FPROTECT region that big");
    Where again the 62KiB limitation appears (close to the 64KiB / 0x10000 limitation some have reported previously). This was for my custom board/application, but if I modify the "with_mcuboot" sample to use the dts partition manager with nRF54L15 DK ns I get another error:
    Generating files from C:/ncs/v3.3.1/zephyr/samples/sysbuild/with_mcuboot/build/with_mcuboot/zephyr/zephyr.elf for board: nrf54l15dk/nrf54l15/cpuapp/ns
    Usage: imgtool.py sign [OPTIONS] INFILE OUTFILE
    Try 'imgtool.py sign -h' for help.
    Error: Image size (0x91580) + trailer (0x20) exceeds requested size 0x80000
    image.py: sign the digest
    So before marking this problem as resolved, it would be nice to be able to build my applications or even a sample application with the latest/current recommended configuration for the nRF54L15:
    MCUboot+sysbuild+ns-variant+dts-style partitioning.
    Or, even better:
    NSIB+MCUboot+sysbuild+ns-variant+dts-style partitioning+KMU.
    Which seems to be the latest recommendation based on your previous answer and this guide.
    Any suggestions?
