MCUBoot+sysbuild+ns-variant: E: Protect mcuboot flash failed, cancel startup.
Hi.
Goal
I am creating a new application for the nRF54l15 and want to follow the latest recommendations for project configuration. I need to do DFU over BLE, so I'm trying to add MCUBoot in the chain-of-trust regime, using sysbuild. To get there, I used the zephyr/samples/sysbuild/with_mcuboot as a starting point.
Problem
The sample in question does not explicitly support any of the nordic boards with secure/non-secure regime, and I haven't found any samples that combine all these criteria. So I have tried to build the zephyr/sysbuild/with_mcuboot sample for nrf54l15dk/nrf54l15/ns. After erase+flash to my nRF54l15-PDK, I get the following error:
*** Booting MCUboot v2.1.0-dev-2b69d93e75bc ***
*** Using nRF Connect SDK v3.1.0-6c6e5b32496e ***
*** Using Zephyr OS v4.1.99-1612683d4010 ***
How to recreate
Open zephyr/sysbuild/with_mcuboot and build for zephyr/sysbuild/with_mcuboot sample for nrf54l15dk/nrf54l15/ns. My first build failed, but after doing a pristine build it built successfully and I was able to flash (VSCode build output is attached). Finally, flash to the DK and it should produce the error message shown above.
My setup
Support information is attached. I'm using SDK and toolchain version 3.1.0 with VSCode for windows 10, and nRF54L15-PDK (0.8.1, 2024.38).
Solutions?
I don't have to be able to run this exact sample, but what is causing this error and how do I best resolve it?
vscode_build_log.txt
// IMPORTANT: The following data can contain sensitive or confidential information about your environment.
// If you do not want others to see this information, make sure to remove it before sharing the data.
// For help and support, visit Nordic Semiconductor's DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Pro",
    "osKernel": "10.0.19045",
    "vscode": "1.103.0",
    "electron": "37.2.3",
    "node": "v22.17.0"
  "system": {
    "date": "2025-08-18T09:15:11.091Z",
    "vscodeRoot": "c:\\Program Files\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:47:59",
    "osUptime": "129:28:11",
    "cpu": "Intel(R) Core(TM) i7-10700T CPU @ 2.00GHz"
  "workspace": {
    "name": "with_mcuboot",
    "workspaceFile": null,
    "folders": [
      "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot"
  "sdks": [
      "version": "v3.1.0",
      "path": "c:\\ncs\\v3.1.0"
      "version": "v3.0.0",
      "path": "c:\\ncs\\v3.0.0"
      "version": "v2.9.0",
      "path": "c:\\ncs\\v2.9.0"
      "version": "v2.7.0",
      "path": "c:\\ncs\\v2.7.0"
      "version": "v2.6.1",
      "path": "c:\\ncs\\v2.6.1"
      "version": "v2.5.1",
      "path": "c:\\ncs\\v2.5.1"
      "version": "v2.4.2",
      "path": "c:\\project\\saferoad"
      "version": "v2.4.0",
      "path": "c:\\ncs\\v2.4.0"
      "version": "v2.3.0",
      "path": "c:\\ncs\\v2.3.0"
      "version": "v2.2.0",
      "path": "c:\\ncs\\v2.2.0"
      "version": "v1.9.1",
      "path": "c:\\ncs\\v1.9.1"
      "version": "v1.5.1",
      "path": "c:\\ncs\\v1.5.1"
  "activeBuild": "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot\\build_1",
  "apps": [
      "workspace": "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot",
      "uri": "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot",
      "buildConfigurations": [
          "id": "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot\\build",
          "name": "build",
          "boardId": "nrf54l15dk/nrf54l15/cpuapp/ns",
          "type": "Sysbuild",
          "isChild": false,
          "isStale": false,
          "taskBindings": {
            "build": [],
            "pristineBuild": [],
            "flash": [],
            "eraseAndFlash": []
          "sdk": "c:\\ncs\\v3.1.0",
          "toolchain": "nRF Connect SDK Toolchain v3.1.0"
          "id": "c:\\ncs\\v3.1.0\\zephyr\\samples\\sysbuild\\with_mcuboot\\build_1",
          "name": "build_1",
          "type": "Zephyr",
          "isChild": false,
          "isStale": false,
          "taskBindings": {
            "build": [],
            "flash": [],
            "eraseAndFlash": []
  "toolchains": [
      "version": "3.1.0",
      "path": "c:\\ncs\\toolchains\\b8b84efebd"
      "version": "3.0.0",
      "path": "c:\\ncs\\toolchains\\0b393f9e1b"
      "version": "2.9.0",
      "path": "c:\\ncs\\toolchains\\b620d30767"
      "version": "2.7.0",
      "path": "c:\\ncs\\toolchains\\ce3b5ff664"
      "version": "2.6.1",
      "path": "c:\\ncs\\toolchains\\cf2149caf2"
      "version": "2.5.1",
      "path": "c:\\ncs\\toolchains\\c57af46cb7"
      "version": "2.4.0",
      "path": "c:\\ncs\\toolchains\\31f4403e35"
      "version": "2.3.0",
      "path": "c:\\ncs\\toolchains\\v2.3.0"
      "version": "2.2.0",
      "path": "c:\\ncs\\toolchains\\v2.2.0"
      "version": "2.0.0",
      "path": "c:\\ncs\\toolchains\\v2.0.0"
      "version": "1.9.1",
      "path": "c:\\ncs\\v1.9.1\\toolchain"
      "version": "1.9.1",
      "path": "c:\\ncs\\toolchains\\v1.9.1"
      "version": "1.5.1",
      "path": "c:\\ncs\\v1.5.1\\toolchain"
  "connectedDevices": [
      "serialNumber": "000203200665"
      "serialNumber": "001057760695"
  "tools": {
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.17.0",
    "C:\\Program Files\\SEGGER\\JLink_V818\\JLink.exe": "8.18",
    "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.24.2",
    "C:\\ncs\\toolchains\\b8b84efebd\\nrfutil": "8.1.0",
    "C:\\ncs\\toolchains\\b8b84efebd\\cmake": "3.21.0",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\Scripts\\west.exe": "1.4.0",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\python.exe": "3.12.4",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\ninja.exe": "1.10.2",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\gperf.exe": "3.1",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\dtc.exe": "1.4.7",
    "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\gn.exe": "2223",
    "C:\\ncs\\toolchains\\b8b84efebd\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    "arm-gdbPath": "c:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe",
    "riscv-gdbPath": "C:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin\\riscv64-zephyr-elf-gdb.exe"
  "nrfutil": {
    "nrfutil-device": {
      "version": "2.7.2",
      "binPath": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device",
      "jlinkInfo": {
        "description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
        "expectedVersion": {
          "version": "JLink_V7.94i",
          "versionFormat": "string"
        "name": "JlinkARM",
        "version": "JLink_V8.18 ",
    "nrfutil-toolchain-manager": {
      "version": "0.14.4",
      "binPath": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
  "environment": {
    "westEnv": {
      "HOME": "C:\\SPB_Data",
      "HOMEDRIVE": "C:",
      "HOMEPATH": "\\Users\\ErlendEliasIsachsen",
      "PATH": "C:\\ncs\\toolchains\\b8b84efebd;C:\\ncs\\toolchains\\b8b84efebd\\mingw64\\bin;C:\\ncs\\toolchains\\b8b84efebd\\bin;C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin;C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\Scripts;c:/ncs/toolchains/b8b84efebd\\opt/nanopb/generator-bin;C:\\ncs\\toolchains\\b8b84efebd\\nrfutil\\bin;C:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;C:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin;c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Microchip\\xc8\\v2.31\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\WinMerge;C:\\Program Files\\dotnet\\;C:\\Program Files\\Wolfram Research\\WolframScript\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Program Files\\LLVM\\bin;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\otii;C:\\Program Files\\doxygen\\bin;C:\\Program Files\\Graphviz\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\ncs\\nrfutil;C:\\gnuarmemb\\9_2019-q4-major\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ErlendEliasIsachsen\\.dotnet\\tools;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Programs\\MiKTeX\\miktex\\bin\\x64\\;",
      "ZEPHYR_BASE": "c:\\ncs\\v3.1.0\\zephyr",
      "ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\b8b84efebd\\opt\\zephyr-sdk",
      "PYTHONPATH": "C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin;C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\Lib;C:\\ncs\\toolchains\\b8b84efebd\\opt\\bin\\Lib\\site-packages"
    "inherited": {
      "HOMEDRIVE": "C:",
      "Path": "C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Microchip\\xc8\\v2.31\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\WinMerge;C:\\Program Files\\dotnet\\;C:\\Program Files\\Wolfram Research\\WolframScript\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Program Files\\LLVM\\bin;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\otii;C:\\Program Files\\doxygen\\bin;C:\\Program Files\\Graphviz\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\ncs\\nrfutil;C:\\gnuarmemb\\9_2019-q4-major\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ErlendEliasIsachsen\\.dotnet\\tools;C:\\Program Files\\TortoiseSVN\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Programs\\MiKTeX\\miktex\\bin\\x64\\;",
      "PATH": "C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Microchip\\xc8\\v2.31\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\WinMerge;C:\\Program Files\\dotnet\\;C:\\Program Files\\Wolfram Research\\WolframScript\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Program Files\\LLVM\\bin;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\otii;C:\\Program Files\\doxygen\\bin;C:\\Program Files\\Graphviz\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\ncs\\nrfutil;C:\\gnuarmemb\\9_2019-q4-major\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ErlendEliasIsachsen\\.dotnet\\tools;C:\\Program Files\\TortoiseSVN\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\ErlendEliasIsachsen\\AppData\\Local\\Programs\\MiKTeX\\miktex\\bin\\x64\\;"
  "terminal": {
    "defaultProfile": null
  "config": {
      "topdir": "",
      "toolchain": {
        "path": ""
      "ozonePath": "",
      "applications": [],
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig"
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "taskBindings": {},
      "buildTerminal": {
        "condensedProgress": true
      "debugging": {
        "flash": true,
        "bindings": {},
        "justMyCode": false
      "flash": {
        "softreset": false,
        "erase": false,
        "recover": false
      "enableTelemetry": true,
      "thirdpartyIntegration": {},
      "toolchainManager": {
        "indexURL": null,
        "installDirectory": null
      "nrfutil": {
        "home": null
      "defaultOpenAction": "ask",
      "terminalProfile": {
        "shell": null
      "terminalMode": "character"
    "marus25.cortex-debug": {
      "variableUseNaturalFormat": true,
      "liveWatchRefreshRate": "300",
      "armToolchainPath": null,
      "armToolchainPrefix": "arm-none-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": null,
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "dbgServerLogfile": null
  "extensions": {
    "internal": {
        "version": "2024.12.55",
        "path": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64",
        "isActive": true
        "version": "2024.9.14",
        "path": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.9.14",
        "isActive": true
        "version": "2025.4.22",
        "path": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2025.4.22",
        "isActive": true
        "version": "2025.4.26",
        "path": "c:\\Users\\ErlendEliasIsachsen\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2025.4.26",
        "isActive": true
    "external": {
      "marus25.cortex-debug": "1.12.1",
      "ms-vscode.cpptools": "1.27.0",
      "ms-vscode.js-debug": "1.102.0",
      "bbenoist.Doxygen": "1.0.0",
      "cschlosser.doxdocgen": "1.4.0",
      "GitHub.copilot": "1.350.0",
      "GitHub.copilot-chat": "0.30.1",
      "josetr.cmake-language-support-vscode": "0.0.9",
      "mcu-debug.debug-tracker-vscode": "0.0.15",
      "mcu-debug.memory-view": "0.0.25",
      "mcu-debug.peripheral-viewer": "1.4.6",
      "mcu-debug.rtos-views": "0.0.7",
      "ms-dotnettools.vscode-dotnet-runtime": "2.3.7",
      "ms-python.vscode-python-envs": "1.2.0",
      "ms-vscode-remote.remote-containers": "0.422.1",
      "ms-vscode.cpptools-extension-pack": "1.3.1",
      "tomoki1207.pdf": "1.2.2",
      "xaver.clang-format": "1.9.0"
    (I'm taking this case from Abhijith, so if I'm missing some context, feel free to make me aware of it.)
    I would recommend you to follow this guide (link) on migrating from partition manager to devicetree partitioning.
    For the KMU we have extensive documentation on this (link). You should be able to find all the information you need about it there.
    Then, for the NSIB, we have a sample (link) that has some documentation on it, also shows how to use it. And here are proper guides to use NSIB with MCUBoot (link).
    I believe that with all of this you should already be able to go quite far.
    If you have any more questions, feel free to ask them.
    Simon
  • Hi, thank you for the suggestions.
    Some context:
    The original ticket: Enabling TFM with MCUboot on the nRF54L15 ran into problems with FPROTECT, making the image un-bootable due to FPROTECT size limitations. This was patched in the PR Abhijith linked, and I was happy to see that it was resolved when testing the newer SDKs. However, when I tried to migrate to dts-style partitions following the guide you linked, I ran into the same problem with FPROTECT again. This makes me believe the bug was only patched with the partition manager.
    Can you verify if this is the case?
    From what I can see, it looks like the fix has either been forgotten or been judge not relevant when updating MCUBoot while deprecating Partition Manager.
    Can you please try to patch your SDK with by adding back the fix in your SDK?
    In the meantime, I will also investigate internally to see the reason behind the removal of the fix.
    Simon
    This was indeed forgotten during the deprecation of Partition Manager. Here is the PR for the new fix: https://github.com/nrfconnect/sdk-mcuboot/pull/697
    Can you please try the new fix?
    Simon
  • So before marking this problem as resolved, it would be nice to be able to build my applications or even a sample application with the latest/current recommended configuration for the nRF54L15:
    MCUboot+sysbuild+ns-variant+dts-style partitioning.
    Please could someone make a sample application as a starting point for MCUBOOT+sysbuild+ns-variant+dts-style partitioning.  I've got a new project, so don't want to try and use Partition Manager and migrate from that. I too am getting similar Image size exceeds requested size. I can't see where it's getting boot_partition as it seemed to still try and compile with it removed from all my overlays.
    Thanks for the links to the KMU and NSIB but if someone at Nordic who is familiar with these things can make a demo that would really help, given it looks like the tooling is still being worked on, so it's hard to know where the problems are coming from!
