What is the default value of CONFIG_MPSL_HFCLK_LATENCY in nRF Connect SDK v3.1.0?
Hello.
I'm trying out nRF Connect SDK v3.1.0 with nRF54L15-DK.
docs.nordicsemi.com/.../release-notes-3.1.0.html
The release notes say:
Updated by increasing the default value of the CONFIG_MPSL_HFCLK_LATENCY Kconfig option to support slower crystals. See the Kconfig description for a detailed description on how to select the correct value for a given application.
However, it seems that CONFIG_MPSL_HFCLK_LATENCY in autoconf.h remains unchanged at 854.
Is there something I've overlooked?
Best regards.
  • Hi again
    This is not a bug. The Development Kit uses a lower MPSL values as we have measured the crystal used on the DK to have a lower startup time. If you build for custom boards the default CONFIG_MPSL_HFCLK_LATENCY will be 1400.
    Simon
  • Hi Simonr.
    OK. I understand.
    When building on a custom nRF54L15 SoC board,
    the hfxo: startup-time-us in ncs/v3.1.0/zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi was applied, resulting in a value of 1650.
    With the nRF54H20-DK and nRF52-DK, the value was 1400.
    This information can be used to report the issue to our team.
    Thank you for your cooperation.
    It’s okay to close this ticket.
    Best regards.
    - Kenta.
