Peripheral not advertising after adding custom service (nRF52832, SDK 17.1.0)
I am working with nRF52832 (PCA10040 DK) on nRF5 SDK v17.1.0 with SoftDevice S132 v7.2.0.
I started with the ble_app_uart example and added a custom BLE service.
After adding the custom service, my peripheral is not visible in nRF Connect when scanning.
The firmware compiles and runs without errors.
What I Expect
  • #include <stdint.h>
    #include <string.h>
    #include "app_timer.h"
    #include "app_uart.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_hci.h"
    #include "ble_nus.h"
    #include "ble_srv_common.h"
    #include "bsp_btn_ble.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #if defined(UART_PRESENT)
    #include "nrf_uart.h"
    #if defined(UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG      1                                        /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME            "Connect_Satabdika "                        /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN                 /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO     3                                        /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL         64                                        /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION        18000                                      /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL       MSEC_TO_UNITS(20,UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL       MSEC_TO_UNITS(75,UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY             0                                        /**< Slave latency. */
    #define CONN_SUP_TIMEOUT        MSEC_TO_UNITS(4000,UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)            /**< Time from initiating event (connect or start of notification) to first time \
        sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(30000)             /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                /**< Number of attempts before giving up the connection parameter negotiation. \
    #define DEAD_BEEF                    0xDEADBEEF                         /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE 256                                      /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256                                      /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                 /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                         /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                           /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                               /**< Advertising module instance. */
    static uint16_t m_conn_handle          = BLE_CONN_HANDLE_INVALID;              /**< Handle of the current connection. */
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    #define CUSTOM_SERVICE_UUID_BASE \
      {0x23, 0x15, 0xBC, 0xED, 0x45, 0x11, 0xE7, 0xB8, 0x31, 0x08, 0x00, 0x00, 0xE7, 0x7A, 0x12, 0x12}
    #define CUSTOM_SERVICE_UUID 0x1400
    #define CUSTOM_CHAR_UUID 0x1401
    static uint16_t m_cus_service_handle;
    static ble_gatts_char_handles_t m_cus_char_handles;
    static uint8_t m_cus_char_value[20] = {0};
    static uint8_t m_cus_uuid_type;           // store returned UUID type
    static ble_uuid_t m_adv_uuids[] =
        {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE},
        {CUSTOM_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN}   // <-- your custom service UUID
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name) {
    /**@brief Function for initializing the timer module.
    static void timers_init(void) {
     *          the device. It also sets the permissions and appearance.
    static void gap_params_init(void) {
      ret_code_t err_code;
      ble_gap_conn_params_t gap_conn_params;
      err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME));
    static void nrf_qwr_error_handler(uint32_t nrf_error) {
      APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
    static void nus_data_handler(ble_nus_evt_t *p_evt) {
      if (p_evt->type == BLE_NUS_EVT_RX_DATA) {
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++) {
          do {
            err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
            if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY)) {
              NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
          } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r') {
          while (app_uart_put('\n') == NRF_ERROR_BUSY)
    static void custom_service_init(void) {
      uint32_t err_code;
      ble_uuid_t service_uuid;
      ble_uuid128_t base_uuid = CUSTOM_SERVICE_UUID_BASE;
      // Add custom base UUID
      err_code = sd_ble_uuid_vs_add(&base_uuid, &m_cus_uuid_type);
      service_uuid.type = m_cus_uuid_type;
      service_uuid.uuid = CUSTOM_SERVICE_UUID;
      // Add service
      err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &service_uuid, &m_cus_service_handle);
    static void custom_value_char_add(void)
        uint32_t              err_code;
        ble_gatts_char_md_t   char_md;
        ble_gatts_attr_md_t   attr_md;
        ble_gatts_attr_t      attr_char_value;
        ble_uuid_t            char_uuid;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.read  = 1;
        char_md.char_props.write = 1;
        char_uuid.type = m_cus_uuid_type;
        char_uuid.uuid = CUSTOM_CHAR_UUID;
        memset(&attr_md, 0, sizeof(attr_md));
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
        attr_md.vloc = BLE_GATTS_VLOC_STACK;
        uint8_t initial_value = 0;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid    = &char_uuid;
        attr_char_value.p_attr_md = &attr_md;
        attr_char_value.init_len  = sizeof(uint8_t);
        attr_char_value.max_len   = sizeof(uint8_t);
        attr_char_value.p_value   = &initial_value;
        err_code = sd_ble_gatts_characteristic_add(m_cus_service_handle,
                                                   &char_md,
                                                   &attr_char_value,
                                                   &m_cus_char_handles);
    static void services_init(void) {
      ble_nus_init_t nus_init;
      // Initialize NUS.
      custom_service_init();
      custom_value_char_add();
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
    static void on_conn_params_evt(ble_conn_params_evt_t *p_evt) {
      if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
    /**@brief Function for handling errors from the Connection Parameters module.
    static void conn_params_error_handler(uint32_t nrf_error) {
    static void conn_params_init(void) {
    static void sleep_mode_enter(void) {
      ret_code_t err_code = bsp_indication_set(BSP_INDICATE_IDLE);
      // Prepare wakeup buttons.
    static void on_adv_evt(ble_adv_evt_t ble_adv_evt) {
      switch (ble_adv_evt) {
      case BLE_ADV_EVT_FAST:
        NRF_LOG_INFO("Fast advertising.");
      case BLE_ADV_EVT_IDLE:
        sleep_mode_enter();
    static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context) {
      switch (p_ble_evt->header.evt_id) {
      case BLE_GAP_EVT_CONNECTED:
        NRF_LOG_INFO("Connected");
        err_code      = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle);
        NRF_LOG_INFO("Disconnected");
      case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
        ble_gap_phys_t const phys = {
            .rx_phys = BLE_GAP_PHY_AUTO,
            .tx_phys = BLE_GAP_PHY_AUTO,
      } break;
        // Pairing not supported
      case BLE_GATTC_EVT_TIMEOUT:
        err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
      case BLE_GATTS_EVT_TIMEOUT:
        err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
    static void ble_stack_init(void) {
      uint32_t ram_start = 0;
      err_code           = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
      // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t *p_gatt, nrf_ble_gatt_evt_t const *p_evt) {
      if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)) {
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
      NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                    p_gatt->att_mtu_desired_central,
                    p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void) {
      err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
      err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
    void bsp_event_handler(bsp_event_t event) {
      switch (event) {
      case BSP_EVENT_SLEEP:
        sleep_mode_enter();
      case BSP_EVENT_DISCONNECT:
        err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        if (err_code != NRF_ERROR_INVALID_STATE) {
      case BSP_EVENT_WHITELIST_OFF:
        if (m_conn_handle == BLE_CONN_HANDLE_INVALID) {
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
    void uart_event_handle(app_uart_evt_t *p_event) {
      static uint8_t index = 0;
      uint32_t err_code;
      switch (p_event->evt_type) {
      case APP_UART_DATA_READY:
        index++;
        if ((data_array[index - 1] == '\n') || (data_array[index - 1] == '\r') || (index >= m_ble_nus_max_data_len)) {
          if (index > 1) {
            do {
              err_code        = ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle);
              if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_RESOURCES) &&
                  (err_code != NRF_ERROR_NOT_FOUND)) {
            } while (err_code == NRF_ERROR_RESOURCES);
          index = 0;
      case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void) {
      uint32_t err_code;
      app_uart_comm_params_t const comm_params = {.rx_pin_no    = RX_PIN_NUMBER,
                                                  .tx_pin_no    = TX_PIN_NUMBER,
                                                  .use_parity   = false,
                                                  .baud_rate = NRF_UART_BAUDRATE_115200
    #else
                                                  .baud_rate = NRF_UARTE_BAUDRATE_115200
      APP_UART_FIFO_INIT(
          &comm_params, UART_RX_BUF_SIZE, UART_TX_BUF_SIZE, uart_event_handle, APP_IRQ_PRIORITY_LOWEST, err_code);
    static void advertising_init(void) {
      ble_advertising_init_t init;
      // Build UUID list using runtime types
      ble_uuid_t adv_uuids[2];
      adv_uuids[0].uuid = BLE_UUID_NUS_SERVICE;
      adv_uuids[0].type = m_nus.uuid_type;    // <-- use NUS runtime type
      adv_uuids[1].uuid = CUSTOM_SERVICE_UUID;
      adv_uuids[1].type = m_cus_uuid_type;    // <-- use your custom runtime type
      init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
      init.advdata.include_appearance = true;
      init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
      init.srdata.uuids_complete.uuid_cnt =  sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
      init.srdata.uuids_complete.p_uuids  = adv_uuids;
      init.evt_handler                  = on_adv_evt;
    static void buttons_leds_init(bool *p_erase_bonds) {
      bsp_event_t startup_event;
      ret_code_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void) {
    static void power_management_init(void) {
      if (NRF_LOG_PROCESS() == false) {
        nrf_pwr_mgmt_run();
    static void advertising_start(void) {
            err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /**@brief Application main function.
    int main(void) {
      bool erase_bonds;
      // Initialize.
      uart_init();
      log_init();
      timers_init();
      power_management_init();
      ble_stack_init();
      gap_params_init();
      gatt_init();
      advertising_init();
      services_init();
      conn_params_init();
      // Start execution.
      advertising_start();
      // Enter main loop.
      for (;;) {
        idle_state_handle();
    The device should advertise with the custom service UUID and appear in nRF Connect (mobile).
