Help with Ring Buffer Implementation
Hello Nordic Support Team,
I am trying to implement a ring buffer of structs.
Even though my consumer runs much more frequently than my producer, the buffer becomes full just a few moments after starting my code.
I suspect the issue might be related to data alignment, but I am unable to identify the problem.
Could someone please help me with this issue?
Thank you in advance.
typedef struct
    uint16_t addr;
    uint8_t valid_addr;
    filterSrvSensorType_t analyzing_type;
    emaFilterContext_t ema_context;
    temaFilterContext_t tema_context;
    kalmanFilterContext_t kalman_context;
    filterSrvSensorContext_t ble_sensor_context;
    filterSrvSensorContext_t lora_sensor_context;
} filterSrvContext_t;
#define FILTER_SRV_REFRESH_INTERVAL 50
#define FILTER_SRV_RING_BUFFER_AMOUNT 64 // Number of filterSrvContext_t
#define FILTER_SRV_BUFFER_SIZE_BYTES (FILTER_SRV_RING_BUFFER_AMOUNT * ((sizeof(filterSrvContext_t) + 3) / 4))
struct ring_buf filterSrvRingBuffer;
static uint8_t filterSrvBufferStorage[FILTER_SRV_BUFFER_SIZE_BYTES];
filterSrvContext_t filterSrvContext[FILTER_SRV_MAX_CONTEXTS];
uint8_t filterSrvMsg[I2C_SRV_TX_BUF_LEN - 5] = {0};
uint8_t filterSrvMsgSize = 0;
uint8_t filterSrvProducerItem(filterSrvContext_t *filter_context)
    __aligned(4) static uint32_t tmp_buf_static[(sizeof(filterSrvContext_t) + 3) / 4];
    memcpy(tmp_buf_static, filter_context, sizeof(filterSrvContext_t));
    int ret = ring_buf_item_put(&filterSrvRingBuffer,
                                filter_context->analyzing_type,
                                0,
                                tmp_buf_static,
                                (sizeof(filterSrvContext_t) + 3) / 4);
     LOG_INF("Producing %s Distance: %.2f",
             (filter_context->analyzing_type == FILTER_SRV_SENSOR_TYPE_BLE) ? "BLE " : "LORA",
             (filter_context->analyzing_type == FILTER_SRV_SENSOR_TYPE_BLE) ? filter_context->ble_sensor_context.distance_value
        : filter_context->lora_sensor_context.distance_value);
    if (ret != 0)
        LOG_ERR("Ring buffer is full");
        return FILTER_SRV_RING_IS_FULL;
        return FILTER_SRV_RING_IS_NOT_FULL;
uint8_t filterSrvConsumerItem(filterSrvContext_t *filter_context)
    uint16_t type;
    uint8_t value;
    uint8_t size32 = (sizeof(filterSrvContext_t) + 3) / 4;
    uint32_t tmp_buf[size32];
    int ret = ring_buf_item_get(&filterSrvRingBuffer,
                                &type,
                                &value,
                                tmp_buf,
                                &size32);
    if (ret == 0)
        memcpy(filter_context, tmp_buf, sizeof(filterSrvContext_t));
         LOG_INF("Consuming %s Distance: %.2f",
        return FILTER_SRV_RING_IS_NOT_EMPTY;
        return FILTER_SRV_RING_IS_EMPTY;
void filterSrvThread(void)
    while (1)
        filterSrvContext_t aux = {0};
        while (filterSrvConsumerItem(&aux) != FILTER_SRV_RING_IS_EMPTY)
            filterSrvAddSensorData(&aux);
        k_sleep(K_MSEC(FILTER_SRV_REFRESH_INTERVAL));
