Cannot get UART00 to function
SDK v3.0.2 Toolchain 3.01
I'm beating my head against the wall for what should be a trivial matter. I need to use P2 for uart: RX is P2.00 TX is P2.02. No RTS CTS in use.
Originally this was on a custom PCB, but to test I've switched to my 54L15DK. (I have cut/bridged the relevant DK jumpers to use the P2 pins for I/O.) For testing I'm using a slightly modified "Hello World" sample. I'm using a scope to monitor the pins, they just go high and stay high.
I'm sure this is a DTS problem and probably flow control related. But none of the DKs use UART00 so I can't cross reference...
Here is my DTS
/dts-v1/;
#include <nordic/nrf54l15_cpuapp.dtsi>
#include "test-pinctrl.dtsi"
	model = "UART test";
	compatible = "MyCo,test-cpuapp";
	chosen {
		zephyr,console = &uart00;
		zephyr,code-partition = &slot0_partition;
		zephyr,sram = &cpuapp_sram;
		zephyr,flash-controller = &rram_controller;
		zephyr,flash = &cpuapp_rram;
		zephyr,ieee802154 = &ieee802154;
	reserved-memory {
		#address-cells = <1>;
		#size-cells = <1>;
		ranges;
&cpuapp_sram {
	status = "okay";
&grtc {
	owned-channels = <0 1 2 3 4 5 6 7 8 9 10 11>;
	/* Channels 7-11 reserved for Zero Latency IRQs, 3-4 for FLPR */
	child-owned-channels = <3 4 7 8 9 10 11>;
	status = "okay";
&cpuapp_rram {
	partitions {
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x0 DT_SIZE_K(64)>;
		slot0_partition: partition@10000 {
			label = "image-0";
			reg = <0x10000 DT_SIZE_K(324)>;
		slot0_ns_partition: partition@61000 {
			label = "image-0-nonsecure";
			reg = <0x61000 DT_SIZE_K(324)>;
		slot1_partition: partition@b2000 {
			label = "image-1";
			reg = <0xb2000 DT_SIZE_K(324)>;
		slot1_ns_partition: partition@103000 {
			label = "image-1-nonsecure";
			reg = <0x103000 DT_SIZE_K(324)>;
		/* 32k from 0x154000 to 0x15bfff reserved for TF-M partitions */
		storage_partition: partition@15c000 {
			label = "storage";
			reg = <0x15c000 DT_SIZE_K(36)>;
&clock {
	status = "okay";
&i2c20{
	status = "okay";
  compatible="nordic,nrf-twim";
	pinctrl-0 = <&i2c20_default>;
  pinctrl-1 = <&i2c20_sleep>;
	wakeup-source;
&i2c30{
	status = "okay";
	pinctrl-0 = <&i2c30_default>;
  pinctrl-1 = <&i2c30_sleep>;
	wakeup-source;
&gpio1 {
	status = "okay";
&gpio2 {
	status = "okay";
&gpiote20 {
    status = "okay";
&regulators {
	status = "okay";
&vregmain {
	status = "okay";
	regulator-initial-mode = <NRF5X_REG_MODE_DCDC>;
&uart00 {
	status = "okay";
  current-speed = <115200>;
  pinctrl-0 = <&uart00_default>;
  pinctrl-1 = <&uart00_sleep>;
&spi00 {
  status = "disabled";
&uicr {
	nfct-pins-as-gpios;
and DTSI
&pinctrl {
	uart00_default: uart00_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 2, 2)>;
		group2 {
			psels = <NRF_PSEL(UART_RX, 2, 0)>;
			bias-pull-up;
	uart00_sleep: uart00_sleep {
		group1 {
			low-power-enable;
	/omit-if-no-ref/ uart30_default: uart30_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 0)>,
				<NRF_PSEL(UART_RTS, 0, 2)>;
		group2 {
			psels = <NRF_PSEL(UART_RX, 0, 1)>,
				<NRF_PSEL(UART_CTS, 0, 3)>;
			bias-pull-up;
	/omit-if-no-ref/ uart30_sleep: uart30_sleep {
		group1 {
				<NRF_PSEL(UART_RTS, 0, 2)>,
			low-power-enable;
	/omit-if-no-ref/ pwm20_default: pwm20_default {
		group1 {
			psels = <NRF_PSEL(PWM_OUT0, 1, 10)>;
	/omit-if-no-ref/ pwm20_sleep: pwm20_sleep {
		group1 {
			low-power-enable;
	/omit-if-no-ref/ grtc_default: grtc_default {
		group1 {
			psels = <NRF_PSEL(GRTC_CLKOUT_FAST, 1, 8)>,
				<NRF_PSEL(GRTC_CLKOUT_32K, 0, 4)>;
	/omit-if-no-ref/ grtc_sleep: grtc_sleep {
		group1 {
			low-power-enable;
	i2c20_default: i2c20_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SCL, 1, 12)>, <NRF_PSEL(TWIM_SDA, 1, 13)>;
	i2c20_sleep: i2c20_sleep {
		group1 {
      low-power-enable;
	i2c30_default: i2c30_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SCL, 1, 12)>, <NRF_PSEL(TWIM_SDA, 0, 2)>;
	i2c30_sleep: i2c30_sleep {
		group1 {
			psels = <NRF_PSEL(TWIM_SCL, 1, 12)>, <NRF_PSEL(TWIM_SDA, 0, 3)>;
      low-power-enable;
&lfxo {
	load-capacitors = "internal";
	load-capacitance-femtofarad = <15500>;
&hfxo {
	load-capacitance-femtofarad = <15000>;
prj.conf
CONFIG_CONSOLE=y
CONFIG_SERIAL=y
and finally the code
#include <stdio.h>
#include <zephyr/kernel.h>
int main()
	while(true)
		printf("Hello World! %s\n", CONFIG_BOARD_TARGET);
		k_sleep(K_MSEC(500));
	return 0;
