I need to add DEVICE_API in my code. How can I do that? Currently, I’m using NCS v2.6.1.
Hi Chirag,
Could you clarify what you are trying to achieve here? I need more information.
Benjamin
I want to use the flash driver.
Initially, I defined the API like this:
static const struct flash_driver_api micron_spi_nand_api = {
.read = micron_spi_nand_read,
.write = micron_spi_nand_write,
.erase = micron_spi_nand_erase,
.get_parameters = flash_nand_get_parameters,
.read_jedec_id = micron_spi_nand_read_jedec_id,
#if defined(CONFIG_FLASH_PAGE_LAYOUT)
.page_layout = micron_spi_nand_pages_layout,
When I tried to change this to use the DEVICE_API() macro:
// static DEVICE_API(flash, micron_spi_nand_api) = {
the build failed with an error. I also noticed that DEVICE_API is not defined in zephyr/include/zephyr/device.h in NCS v2.6.1.
So my question is: how can I correctly use the device API mechanism in NCS v2.6.1?
The DEVICE_API macro doesn’t exist in your NCS version. Could you explain what you’re trying to achieve by using it? That way I can suggest the right approach.
We have two products: one uses the old NVS version (already launched) and the other uses the latest version. To maintain consistency, we need to implement the same API for both firmware versions. For this purpose, we are using the device API as shown below.
Hi Chriaq,
The already launched version is the one that uses NCS v2.6.1 or is NCS v2.6.1 what you mean by newest version?
Benjamin
newest version is the 3.0.2
Yes, in v3.0.2 you can use the DEVICE_API macro. You cannot use it in v2.6.1, because it does not exist in Zephyr.
