I am experiencing an issue when trying to flash any program using nRF Connect for VS Code. When I execute the flash command, my board disappears from the "Connected Devices" section, and the LED5 on the Dev Kit starts blinking rapidly. This continues until I disconnect and reconnect the USB cable.
I have attached the generated log and the terminal output for reference. I have also tried uninstalling all Nordic software and reinstalling it, but the issue persists.
Additional information:
nRF SDK v2.5.2
nRF toolchain v2.7.0
nRF Command Line Tools version: 10.24.2
Board: nRF52840 DK
OS: Windows 11 - V21H2
I have tried multiple USB cables and ports.
Could you please assist me in resolving this issue? It seems like the debugger cannot connect properly to the device, but the J-Link works normally for other operations.
Log file:
[2025-Aug-20 10:33:26] [debug] -------------------------------------------------------------------------------- [2025-Aug-20 10:33:26] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --log --program c:\Users\Techplus\Desktop\imachine-sensor-v3\build_1\zephyr\zephyr.hex --chiperase --verify -f NRF52 --snr 1050297570 [2025-Aug-20 10:33:26] [debug] nrfjprog version 10.24.2 external [2025-Aug-20 10:33:26] [debug] -------------------------------------------------------------------------------- [2025-Aug-20 10:33:26] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll. [2025-Aug-20 10:33:26] [ info] Library loaded, loading member functions. [2025-Aug-20 10:33:26] [ info] Member functions succesfully loaded. [2025-Aug-20 10:33:26] [debug] [ Client] - open [2025-Aug-20 10:33:26] [debug] [ Client] - start [2025-Aug-20 10:33:26] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 62fbb1ef-7819-464a-a879-060f56351e59. [2025-Aug-20 10:33:26] [trace] [ Client] - Command open executed for 71 milliseconds with result 0 [2025-Aug-20 10:33:26] [debug] [ Client] - config [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger [2025-Aug-20 10:33:26] [debug] [ JLink] - Logger sink registered in JLink logger [2025-Aug-20 10:33:26] [debug] [ nRF52] - open [2025-Aug-20 10:33:26] [debug] [ nRF52] - just_check_family [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - open_dll [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect. [2025-Aug-20 10:33:26] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V858\JLink_x64.dll. [2025-Aug-20 10:33:26] [ info] [SeggerBackend] - Library loaded, loading member functions. [2025-Aug-20 10:33:26] [ info] [SeggerBackend] - Member functions succesfully loaded. [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - Set batch mode [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - dll_version [2025-Aug-20 10:33:26] [ info] [SeggerBackend] - Segger dll version 8.58. loaded. [2025-Aug-20 10:33:26] [trace] [ Worker] - Command open executed for 7 milliseconds with result 0 [2025-Aug-20 10:33:26] [debug] [ nRF52] - config [2025-Aug-20 10:33:26] [trace] [ Client] - Command config executed for 33 milliseconds with result 0 [2025-Aug-20 10:33:26] [debug] [ Client] - enum_emu_snr [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - enum_emu_snr [2025-Aug-20 10:33:26] [trace] [ Worker] - Command config executed for 32 milliseconds with result 0 [2025-Aug-20 10:33:26] [debug] [ nRF52] - enum_emu_con_info [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - is_connected_to_emu [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - enum_emu_con_info [2025-Aug-20 10:33:26] [trace] [ Client] - Command enum_emu_con_info executed for 39 milliseconds with result 0 [2025-Aug-20 10:33:26] [debug] [ Client] - connect_to_emu_with_snr [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - is_connected_to_emu [2025-Aug-20 10:33:26] [trace] [ Worker] - Command enum_emu_con_info executed for 20 milliseconds with result 0 [2025-Aug-20 10:33:26] [debug] [ nRF52] - connect_to_emu_with_snr [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - is_connected_to_emu [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - connect_to_emu_with_snr [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - is_connected_to_emu [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - ---just_enum_emu_snr [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - ---just_get_num_emus [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr [2025-Aug-20 10:33:26] [debug] [SeggerBackend] - Segger logging enabled. [2025-Aug-20 10:33:26] [trace] [ JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Feb 11 2025 17:15:35 [2025-Aug-20 10:33:26] [trace] [ JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Feb 11 2025 17:15:35 [2025-Aug-20 10:33:26] [trace] [ JLink] - Updating firmware: J-Link OB-nRF5340-NordicSemi compiled Jul 8 2025 10:15:34 [2025-Aug-20 10:33:26] [trace] [ JLink] - Updating firmware: J-Link OB-nRF5340-NordicSemi compiled Jul 8 2025 10:15:34 [2025-Aug-20 10:33:26] [trace] [ JLink] - Replacing firmware: J-Link OB-nRF5340-NordicSemi compiled Feb 11 2025 17:15:35 [2025-Aug-20 10:33:26] [trace] [ JLink] - Replacing firmware: J-Link OB-nRF5340-NordicSemi compiled Feb 11 2025 17:15:35 [2025-Aug-20 10:34:00] [trace] [ JLink] - ***** Error: [2025-Aug-20 10:34:00] [trace] [ JLink] - Failed to activate bootloader (timeout) [2025-Aug-20 10:34:00] [error] [ Client] - Encountered error -105: Command connect_to_emu_with_snr executed for 33907 milliseconds with result -105 [2025-Aug-20 10:34:00] [trace] [ JLink] - ***** Error: [2025-Aug-20 10:34:00] [trace] [ JLink] - Communication timed out: Requested 4 bytes, received 0 bytes ! [2025-Aug-20 10:34:00] [trace] [ JLink] - ***** Error: [2025-Aug-20 10:34:00] [trace] [ JLink] - Cannot connect to J-Link [2025-Aug-20 10:34:00] [trace] [ JLink] - - 33766.804ms returns "Failed to activate bootloader (timeout) Communication timed out: Requested 4 bytes, received 0 bytes ! Cannot connect to J-Link" [2025-Aug-20 10:34:00] [trace] [ JLink] - JLINK_HasError() [2025-Aug-20 10:34:00] [trace] [ JLink] - JLINK_OpenEx(...) [2025-Aug-20 10:34:00] [trace] [ JLink] - ***** Error: [2025-Aug-20 10:34:00] [trace] [ JLink] - Cannot connect to J-Link. [2025-Aug-20 10:34:00] [trace] [ JLink] - - 21.079ms returns "Cannot connect to J-Link." [2025-Aug-20 10:34:00] [trace] [ JLink] - JLINK_HasError() [2025-Aug-20 10:34:00] [trace] [ JLink] - JLINK_OpenEx(...) [2025-Aug-20 10:34:00] [trace] [ JLink] - ***** Error: [2025-Aug-20 10:34:00] [trace] [ JLink] - Cannot connect to J-Link. [2025-Aug-20 10:34:00] [trace] [ JLink] - - 9.042ms returns "Cannot connect to J-Link." [2025-Aug-20 10:34:00] [trace] [ JLink] - JLINK_HasError() [2025-Aug-20 10:34:00] [debug] [SeggerBackend] - is_connected_to_emu [2025-Aug-20 10:34:00] [trace] [ JLink] - JLINK_IsOpen() [2025-Aug-20 10:34:00] [trace] [ JLink] - - 0.031ms returns 0x00 [2025-Aug-20 10:34:00] [trace] [ JLink] - JLINK_HasError() [2025-Aug-20 10:34:00] [error] [ Worker] - JLinkARM.dll Open returned error 'Cannot connect to J-Link.' [2025-Aug-20 10:34:00] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 33885 milliseconds with result -105 [2025-Aug-20 10:34:00] [debug] [ nRF52] - close [2025-Aug-20 10:34:00] [debug] [SeggerBackend] - is_connected_to_emu [2025-Aug-20 10:34:00] [trace] [ JLink] - JLINK_IsOpen() [2025-Aug-20 10:34:00] [trace] [ JLink] - - 0.021ms returns 0x00 [2025-Aug-20 10:34:00] [trace] [ JLink] - JLINK_HasError() [2025-Aug-20 10:34:00] [debug] [SeggerBackend] - close [2025-Aug-20 10:34:00] [debug] [SeggerBackend] - disconnect_from_emu [2025-Aug-20 10:34:00] [debug] [SeggerBackend] - is_connected_to_emu [2025-Aug-20 10:34:00] [trace] [ JLink] - JLINK_IsOpen() [2025-Aug-20 10:34:00] [trace] [ JLink] - - 0.010ms returns 0x00 [2025-Aug-20 10:34:00] [trace] [ JLink] - JLINK_HasError() [2025-Aug-20 10:34:00] [debug] [SeggerBackend] - Segger Backend closed. [2025-Aug-20 10:34:00] [debug] [ nRF52] - nRF family DLL closed [2025-Aug-20 10:34:00] [trace] [ Client] - Command close executed for 39 milliseconds with result 0 [2025-Aug-20 10:34:00] [debug] [ Client] - terminate [2025-Aug-20 10:34:00] [trace] [ Client] - Command terminate executed for 5 milliseconds with result 0 [2025-Aug-20 10:34:00] [trace] [ Worker] - Command close executed for 34 milliseconds with result 0 [2025-Aug-20 10:34:00] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0 [2025-Aug-20 10:34:00] [trace] [ Worker] - Executed 6 commands for 33978 milliseconds [2025-Aug-20 10:34:00] [debug] [ Client] - Worker process exited with code: 0 [2025-Aug-20 10:34:00] [debug] [ Client] - Worker process exited with code: 0 [2025-Aug-20 10:34:00] [debug] [ Client] - Child process terminated with result 0 [2025-Aug-20 10:34:00] [trace] [ Client] - Executed 6 commands for 34094 milliseconds [2025-Aug-20 10:34:00] [debug] [ Client] - terminate
Thank you,
