I am having an issue with matter device commissioning after updating from NCS v3.0.2 to v3.1.0. Prior to the update, the device was able to join a matter network running under Home Assistant and SmartThings. After updating from NCS v3.0.2 to v3.1.0, device commissioning into a Matter network running on Home Assistant fails consistently (have not yet tested SmartThings). The commissioning process begins normally, but the device ultimately fails to join the network.
Based on a quick look through the commissioning logs, the significant divergence occurs at:
- NCS v3.0.2: Line 273 - device continues normal communication with Matter server
- NCS v3.1.0: Line 280 - device appears to stop communicating with server
The v3.0.2 log shows continued server communication and ultimately successful network joining, while the v3.1.0 log shows the process hanging with no clear error.
Logs:
NCS v3.0.2 (Working) Commissioning Log
4812.matter commissioning - ncs 302.txt
NCS v3.1.0 (Failing) Commissioning Log
00> *** Booting nRF Connect SDK v3.1.0-6c6e5b32496e *** 00> *** Using Zephyr OS v4.1.99-1612683d4010 *** 00> I: 16 [DL]BLE address: CE:47:7F:36:97:2D 00> I: Initializing all sensor services. 00> I: 20 [DL]CHIP task running 00> I: Init CHIP stack 00> I: 20 [DL]OpenThread started: OK 00> I: 21 [DL]Setting OpenThread device type to SLEEPY END DEVICE 00> I: 23 [DL]Found DAC Private Key in factory data set. Copying to secure storage... 00> I: 27 [DL]The device does not support hardware protection against write. 00> D: Registered new test event: 0xffffffff00000000 00> D: Registered new test event: 0xffffffff10000000 00> I: Successfully registered ICDManager as test event trigger handler 00> I: 28 [SVR]Initializing subscription resumption storage... 00> I: 29 [SVR]Server initializing... 00> I: 29 [TS]Last Known Good Time: [unknown] 00> I: 29 [TS]Setting Last Known Good Time to firmware build time 2023-10-14T01:16:48 00> I: 31 [DMG]AccessControl: initializing 00> I: 31 [DMG]Examples::AccessControlDelegate::Init 00> I: 31 [DMG]AccessControl: setting 00> I: 31 [DMG]DefaultAclStorage: initializing 00> I: I: 23476 [DL]Current number of connections: 1/1 00> I: 23476 [DL]BLE connection established (ConnId: 0x00) 00> I: 23476 [DL]CHIPoBLE advertising stopped 00> D: 24298 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 24298 [BLE]local and remote recv window sizes = 5 00> I: 24299 [BLE]selected BTP version 4 00> I: 24299 [BLE]using BTP fragment sizes rx 182 / tx 182. 00> D: 24418 [DL]ConnId: 0x00, New CCCD value: 0x0002 00> D: 24418 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6) 00> D: 24419 [IN]BLE EndPoint 0x2000b9a0 Connection Complete 00> I: 24419 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 185) 00> D: 24478 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 24481 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 24482 [EM]>>> [E:4864r S:0 M:75511551] (U) Msg RX from 0:18B5C5E5EEBC0E08 [0000] to 0000000000000000 --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:98) 00> I: 24483 [EM]<<< [E:4864r S:0 M:165987213] (U) Msg TX from 0000000000000000 to 0:18B5C5E5EEBC0E08 [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) (B:153) 00> D: 24483 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 158) 00> I: 24484 [SVR]Commissioning session establishment step started 00> D: 24598 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 24601 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 24601 [EM]>>> [E:4864r S:0 M:75511552] (U) Msg RX from 0:18B5C5E5EEBC0E08 [0000] to 0000000000000000 --- Type 0000:22 (SecureChannel:PASE_Pake1) (B:92) 00> I: 24608 [EM]<<< [E:4864r S:0 M:165987214] (U) Msg TX from 0000000000000000 to 0:18B5C5E5EEBC0E08 [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2) (B:127) 00> D: 24609 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132) 00> D: 24658 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 24660 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 24660 [EM]>>> [E:4864r S:0 M:75511553] (U) Msg RX from 0:18B5C5E5EEBC0E08 [0000] to 0000000000000000 --- Type 0000:24 (SecureChannel:PASE_Pake3) (B:59) 00> I: 24661 [EM]<<< [E:4864r S:0 M:165987215] (U) Msg TX from 0000000000000000 to 0:18B5C5E5EEBC0E08 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport) (B:30) 00> D: 24662 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35) 00> I: 24663 [SC]SecureSession[0x2000c070, LSID:62051]: State change 'kEstablishing' --> 'kActive' 00> D: 24663 [IN]SecureSession[0x2000c070]: Activated - Type:1 LSID:62051 00> D: 24663 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:62051 PSID:52577! 00> I: 24664 [SVR]Commissioning completed session establishment step 00> I: 24664 [DIS]Updating services using commissioning mode 0 00> E: 24664 [DIS]Failed to remove advertised services: 3 00> E: 24664 [DIS]Failed to finalize service update: 3 00> D: 24664 [DL]CHIPoBLE advertising set to off 00> I: 24664 [SVR]Device completed Rendezvous process 00> D: 24718 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 24720 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 24721 [EM]>>> [E:4865r S:62051 M:266886722] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51) 00> D: 24721 [IM]Received Read request 00> I: 24723 [EM]<<< [E:4865r S:62051 M:89986249] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:68) 00> D: 24723 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 73) 00> D: 24838 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 24840 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 24841 [EM]>>> [E:4866r S:62051 M:266886723] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51) 00> D: 24841 [IM]Received Read request 00> I: 24843 [EM]<<< [E:4866r S:62051 M:89986250] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:90) 00> D: 24843 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 95) 00> D: 24958 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 24960 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 24961 [EM]>>> [E:4867r S:62051 M:266886724] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:52) 00> D: 24961 [IM]Received Read request 00> I: 24963 [EM]<<< [E:4867r S:62051 M:89986251] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:67) 00> D: 24963 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72) 00> D: 25078 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 25080 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 25081 [EM]>>> [E:4868r S:62051 M:266886725] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:51) 00> D: 25081 [IM]Received Read request 00> I: 25083 [EM]<<< [E:4868r S:62051 M:89986252] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:66) 00> D: 25083 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) 00> D: 25198 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 25200 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 25201 [EM]>>> [E:4869r S:62051 M:266886726] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:59) 00> D: 25203 [DL]OpenThread State Changed (Flags: 0x01009009) 00> D: 25203 [DL] Network Name: OpenThread 00> D: 25203 [DL] PAN Id: 0x66D5 00> D: 25203 [DL] Extended PAN Id: 0xDEAD00BEEF00CAFE 00> D: 25203 [DL] Channel: 11 00> D: 25203 [DL] Mesh Prefix: fdde:ad00:beef:0:0:0:0:0/64 00> D: 25203 [DL] Thread Unicast Addresses: 00> D: 25204 [DL] fe80:0:0:0:4c65:af11:a7ec:b451/64 valid preferred 00> I: 26427 [DL]Thread Network: ha-thread-5a53 Panid 0x5a53 Channel 15 RSSI -69 LQI 108 Version 4 00> I: 26532 [DL]Thread Network: NEST-PAN-2E03 Panid 0x2e03 Channel 15 RSSI -91 LQI 20 Version 4 00> I: 26540 [DL]Thread Network: NEST-PAN-2E03 Panid 0x2e03 Channel 15 RSSI -91 LQI 20 Version 4 00> I: 26564 [DL]Thread Network: ha-thread-5a53 Panid 0x5a53 Channel 15 RSSI -38 LQI 232 Version 4 00> I: 26591 [DL]Thread Network: NEST-PAN-2E03 Panid 0x2e03 Channel 15 RSSI -90 LQI 24 Version 4 00> I: 26601 [DL]Thread Network: NEST-PAN-2E03 Panid 0x2e03 Channel 15 RSSI -89 LQI 24 Version 4 00> D: 27700 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) 00> D: 27779 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> I: 29611 [DL]Thread Network: MyHome36 Panid 0xbc1c Channel 25 RSSI -88 LQI 32 Version 4 00> D: 30054 [DL]OpenThread State Changed (Flags: 0x00008000) 00> D: 30055 [DL] Network Name: OpenThread 00> D: 30055 [DL] PAN Id: 0xFFFF 00> D: 30055 [DL] Extended PAN Id: 0xDEAD00BEEF00CAFE 00> D: 30055 [DL] Channel: 11 00> D: 30055 [DL] Mesh Prefix: fdde:ad00:beef:0:0:0:0:0/64 00> I: 30057 [EM]<<< [E:4869r S:62051 M:89986253] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:227) 00> D: 30057 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 30058 [DL]OpenThread State Changed (Flags: 0x01002002) 00> D: 30058 [DL] Thread Unicast Addresses: 00> D: 30119 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 30119 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 51) 00> D: 30239 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 30239 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 30422 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 30423 [EM]>>> [E:4870r S:62051 M:266886727] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:134) 00> D: 30423 [IM]Received Read request 00> I: 30433 [EM]<<< [E:4870r S:62051 M:89986254] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:257) 00> D: 30434 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 30539 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 30539 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 82) 00> D: 30659 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 30662 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 30663 [EM]>>> [E:4871r S:62051 M:266886728] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:103) 00> D: 30663 [IM]Received Read request 00> E: 30665 [DMG]Read request on unknown cluster - no data version available 00> E: 30665 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0002err = 5c3 00> E: 30666 [DMG]Read request on unknown cluster - no data version available 00> E: 30666 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0001err = 5c3 00> E: 30666 [DMG]Read request on unknown cluster - no data version available 00> E: 30667 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0000err = 5c3 00> E: 30667 [DMG]Read request on unknown cluster - no data version available 00> E: 30668 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0007err = 5c3 00> E: 30668 [DMG]Read request on unknown cluster - no data version available 00> E: 30668 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0006err = 5c3 00> I: 30670 [EM]<<< [E:4871r S:62051 M:89986255] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:181) 00> D: 30670 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 30839 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 30839 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6) 00> D: 30959 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 30961 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 30961 [EM]>>> [E:4872r S:62051 M:266886729] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65) 00> I: 30962 [FS]GeneralCommissioning: Received ArmFailSafe (60s) 00> I: 30963 [EM]<<< [E:4872r S:62051 M:89986256] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66) 00> D: 30963 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) 00> D: 31079 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 31081 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 31082 [EM]>>> [E:4873r S:62051 M:266886730] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:70) 00> I: 31086 [EM]<<< [E:4873r S:62051 M:89986257] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66) 00> D: 31086 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) 00> D: 31319 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 31321 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 31321 [EM]>>> [E:4874r S:62051 M:266886731] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62) 00> I: 31322 [ZCL]OpCreds: Certificate Chain request received for PAI 00> I: 31323 [EM]<<< [E:4874r S:62051 M:89986258] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:527) 00> D: 31324 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 31499 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 31499 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 31619 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 31619 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 172) 00> D: 31739 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 31799 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 31800 [EM]>>> [E:4875r S:62051 M:266886732] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62) 00> I: 31801 [ZCL]OpCreds: Certificate Chain request received for DAC 00> I: 31802 [EM]<<< [E:4875r S:62051 M:89986259] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:555) 00> D: 31802 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 31979 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 31979 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 32099 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 32099 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 32219 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 32219 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 20) 00> D: 32339 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 32340 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 32519 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 32520 [EM]>>> [E:4876r S:62051 M:266886733] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:94) 00> I: 32521 [ZCL]OpCreds: Received an AttestationRequest command 00> I: 32522 [ZCL]OpCreds: AttestationRequest successful. 00> I: 32523 [EM]<<< [E:4876r S:62051 M:89986260] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:716) 00> D: 32523 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 32699 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 32699 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 32819 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 32819 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 32939 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 32939 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 181) 00> D: 33059 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 33060 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 33241 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 33241 [EM]>>> [E:4877r S:62051 M:266886734] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65) 00> I: 33242 [FS]GeneralCommissioning: Received ArmFailSafe (60s) 00> I: 33243 [EM]<<< [E:4877r S:62051 M:89986261] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66) 00> D: 33243 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) 00> D: 33359 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 35160 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 35160 [EM]>>> [E:4878r S:62051 M:266886735] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:94) 00> I: 35161 [ZCL]OpCreds: Received a CSRRequest command 00> I: 35169 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded 00> I: 35170 [ZCL]OpCreds: CSRRequest successful. 00> I: 35171 [EM]<<< [E:4878r S:62051 M:89986262] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:391) 00> D: 35171 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 35279 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 35280 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 182) 00> D: 35459 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 35460 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 36) 00> D: 35579 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 35584 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 35703 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 35703 [EM]>>> [E:4879r S:62051 M:266886736] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:316) 00> I: 35704 [ZCL]OpCreds: Received an AddTrustedRootCertificate command 00> I: 35706 [ZCL]OpCreds: AddTrustedRootCertificate successful. 00> I: 35707 [EM]<<< [E:4879r S:62051 M:89986263] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:63) 00> D: 35707 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68) 00> D: 35819 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 35882 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 36062 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 36062 [EM]>>> [E:4880r S:62051 M:266886737] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:352) 00> I: 36063 [ZCL]OpCreds: Received an AddNOC command 00> I: 36064 [FP]Validating NOC chain 00> I: 36067 [FP]NOC chain validation successful 00> I: 36067 [FP]Added new fabric at index: 0x1 00> I: 36067 [FP]Assigned compressed fabric ID: 0xEBF1D717072701DF, node ID: 0x00000000311B32F6 00> I: 36068 [TS]Last Known Good Time: 2023-10-14T01:16:48 00> I: 36068 [TS]New proposed Last Known Good Time: 2025-08-21T00:40:40 00> I: 36068 [TS]Updating pending Last Known Good Time to 2025-08-21T00:40:40 00> I: 36078 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x0000000042461682 00> D: 36078 [DL]Using Thread extended MAC for hostname. 00> I: 36078 [DIS]Advertise operational node EBF1D717072701DF-00000000311B32F6 00> E: 36078 [SVR]Operational advertising failed: 3 00> I: 36079 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC 00> I: 36079 [EM]<<< [E:4880r S:62051 M:89986264] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [01DF] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66) 00> D: 36080 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) 00> D: 36239 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 36244 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 36245 [EM]>>> [E:4881r S:62051 M:266886738] (S) Msg RX from 1:FFFFFFFB00000000 [01DF] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:175) 00> I: 36248 [EM]<<< [E:4881r S:62051 M:89986265] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [01DF] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66) 00> D: 36248 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) 00> D: 36359 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 36420 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 36420 [EM]>>> [E:4882r S:62051 M:266886739] (S) Msg RX from 1:FFFFFFFB00000000 [01DF] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65) 00> I: 36421 [FS]GeneralCommissioning: Received ArmFailSafe (129s) 00> I: 36422 [EM]<<< [E:4882r S:62051 M:89986266] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [01DF] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66) 00> D: 36422 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) 00> D: 36539 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 36542 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 36543 [EM]>>> [E:4883r S:62051 M:266886740] (S) Msg RX from 1:FFFFFFFB00000000 [01DF] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:73) 00> D: 36573 [DL]OpenThread State Changed (Flags: 0x1017c110) 00> D: 36574 [DL] Network Name: ha-thread-5a53 00> D: 36574 [DL] PAN Id: 0x5A53 00> D: 36574 [DL] Extended PAN Id: 0x8383B9C50F008897 00> D: 36574 [DL] Channel: 15 00> D: 36574 [DL] Mesh Prefix: fd66:bf80:8221:1f54:0:0:0:0/64 00> D: 36579 [DL]OpenThread State Changed (Flags: 0x1100100d) 00> D: 36579 [DL] Device Role: DETACHED 00> D: 36579 [DL] Thread Unicast Addresses: 00> D: 36579 [DL] fd66:bf80:8221:1f54:7c7d:b926:4dd5:5b4/64 valid preferred 00> D: 36579 [DL] fe80:0:0:0:4c65:af11:a7ec:b451/64 valid preferred 00> I: 37782 [DL]SRP Client was started, detected server: fd66:bf80:8221:1f54:5a91:ed03:c4ba:51ed 00> D: 37783 [DL]OpenThread State Changed (Flags: 0x200002a4) 00> D: 37783 [DL] Device Role: CHILD 00> D: 37783 [DL] Partition Id: 0x17A5AE38 00> D: 37787 [DL]Thread Attached updating Multicast address 00> I: 37787 [SVR]Joining Multicast groups 00> I: 37788 [EM]<<< [E:4883r S:62051 M:89986267] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [01DF] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:65) 00> D: 37788 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70) 00> D: 37788 [DL]Using Thread extended MAC for hostname. 00> I: 37789 [DIS]Advertise operational node EBF1D717072701DF-00000000311B32F6 00> E: 37789 [SVR]Operational advertising failed: 3 00> D: 37860 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 38477 [DL]SRP update succeeded 00> I: 38477 [SVR]Server initialization complete 00> I: 38477 [DIS]Updating services using commissioning mode 0 00> D: 38477 [DL]Using Thread extended MAC for hostname. 00> I: 38477 [DIS]Advertise operational node EBF1D717072701DF-00000000311B32F6 00> I: 38478 [DL]advertising srp service: EBF1D717072701DF-00000000311B32F6._matter._tcp 00> I: 38481 [IM]No subscriptions to resume 00> I: 38481 [SWU]Stopping the watchdog timer 00> I: 38481 [SWU]Starting the periodic query timer, timeout: 86400 seconds 00> D: 39422 [DL]SRP update succeeded 00> D: 40320 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 42820 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) 00> D: 42900 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 45361 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 47861 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) 00> D: 47941 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 50401 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 52901 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) 00> D: 52981 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 55442 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 57942 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) 00> D: 58022 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 60482 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 62983 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) 00> D: 63062 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 65523 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 68023 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) 00> D: 68103 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 70563 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 73064 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) 00> D: 73143 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 75604 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 78104 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) 00> D: 78184 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 80644 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 82866 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> I: 82867 [EM]>>> [E:4884r S:62051 M:266886741] (S) Msg RX from 1:FFFFFFFB00000000 [01DF] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65) 00> I: 82868 [FS]GeneralCommissioning: Received ArmFailSafe (120s) 00> I: 82868 [EM]<<< [E:4884r S:62051 M:89986268] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [01DF] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66) 00> D: 82869 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) 00> D: 82984 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 00> D: 85445 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 00> D: 87945 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) 00> D: 88025 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
Questions:
- Does the Matter server (Home Assistant) need to match the specific Matter version in the NCS v3.1.0 SDK? Matter 1.4 is currently supported.
- What debugging steps would you recommend to identify why communication stops at line 280 in the v3.1.0 log?
Thanks in advance,
Patrick
