Greetings,
In the process of adding the RTC driver to the project I am encountering a build error when I try to setup a device pointer. The offending line is:
const struct device *rtc_ptr = DEVICE_DT_GET(DT_NODELABEL(rtc0));
In prj.conf I have added:
C:/ncs/v2.9.0/zephyr/include/zephyr/device.h:92:41: error: '__device_dts_ord_82' undeclared here (not in a function); did you mean '__device_dts_ord_2'?
92 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
It appears that the device driver is not being compiled based on this error message. I am using V2.9.0 of the Zephyr SDK and building on a Windows PC with VS Code.
The configuration board target is nrf52dk/nrf52832
Are additional Kconfig options required to be enabled?
I am able to compile calls to RTC functions that don't require the device pointer such as:
rtc_time_to_tm( struct rtc_time *);
Thanks for any help with this issue!,
Mark
