Matter Test Harness failed in TC-IDM-10.2
Hello, Nordic Team!
I am conducting Matter Test Harness testing and have successfully built the test environment. However, I am encountering some issues during test execution.
1452.UI_Test_Run_2025_08_25_20_21_38-43.json
3036.UI_Test_Run_2025_08_25_20_21_38.log
And here is the log:
PICS_USER_PROMPT=1' > /var/tmp/pics"
INFO       | 2025-08-25 12:21:48.624347 | ================================================================================
INFO       | 2025-08-25 12:21:48.629021 | Executing Test Case: TC-IDM-10.2
INFO       | 2025-08-25 12:21:48.630436 | Test Setup
INFO       | 2025-08-25 12:21:48.631706 | User prompt: "Should the DUT be commissioned to run this test case?"
INFO       | 2025-08-25 12:21:58.128668 | User prompt: "Do you want to reuse the previous commissioning information?
If you select NO, a new commissioning will be performed"
INFO       | 2025-08-25 12:22:09.758025 | User chose prompt option DONE
INFO       | 2025-08-25 12:22:09.760647 | Copying file /app/admin_storage.json to container
INFO       | 2025-08-25 12:22:09.809352 | --------------------------------------------------------------------------------
INFO       | 2025-08-25 12:22:09.811613 | Executing Test Step: Start Python test
INFO       | 2025-08-25 12:22:09.813581 | Running Python Test: TC_IDM_10_2
INFO       | 2025-08-25 12:22:10.000145 | Sending command to SDK container: python3 /root/python_testing/scripts/sdk/matter_testing_infrastructure/chip/testing/test_harness_client.py sdk/TC_DeviceConformance TC_DeviceConformance --tests test_TC_IDM_10_2 --trace-to json:log --in-test-commissioning-method ble-thread --qr-code MT:Y.K90CEK01HBTF25X10  --PICS /var/tmp/pics
INFO       | 2025-08-25 12:22:52.088293 | Test Step Completed [PASSED]: Start Python test
INFO       | 2025-08-25 12:22:52.089935 | --------------------------------------------------------------------------------
INFO       | 2025-08-25 12:22:52.106976 | --------------------------------------------------------------------------------
INFO       | 2025-08-25 12:22:52.108564 | Executing Test Step: Run entire test
WARNING    | 2025-08-25 12:22:52.125711 | Test Failure: Python test step failure
INFO       | 2025-08-25 12:22:52.133347 | --------------------------------------------------------------------------------
INFO       | 2025-08-25 12:22:52.135055 | Executing Test Step: Show test logs
INFO       | 2025-08-25 12:22:52.181456 | ---- Start of Python test logs ----
PYTHON_TEST | 2025-08-25 12:22:52.191025 | [MatterTest] 08-25 12:22:20.644 INFO ==========> TC_DeviceConformance <==========
And here is my UART output information:
I: 24861888 [DL]Device Configuration:
I: 24861891 [DL]  Serial Number: 1145141919813
I: 24861895 [DL]  Vendor Id: 65521 (0xFFF1)
I: 24861899 [DL]  Product Id: 32768 (0x8000)
I: 24861903 [DL]  Product Name: Test Product
I: 24861907 [DL]  Hardware Version: 1
I: 24861911 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 88581739
I: 24861916 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 1145 (0x479)
I: 24861923 [DL]  Manufacturing Date: 2025-08-01
I: 24861928 [DL]  Device Type: 65535 (0xFFFF)
I: 24861932 [SVR]SetupQRCode: [MT:Y.K90CEK01HBTF25X10]
I: 24861937 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 24861943 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3AY.K90CEK01HBTF25X10
I: 24861953 [SVR]Manual pairing code: [10983554067]
I: Initialize binding Handler
I: 24861960 [SVR]Cannot load binding table: a0
I: Binding Table size: [0]:
I: 24861967 [ZCL]Emit DSTTableEmpty event [ep=0]
D: Global watchdog started with timeout 600000 ms
E: 24861975 [DL]Long dispatch time: 636 ms, for event type 2
I: NO DEVICE BOUND
D: [DeviceWorkerHandler] LINE: 233 Release unique id 1
I: 24861988 [DL]CHIPoBLE advertising started
I: 24861992 [DL]NFC Tag emulation started
I: 24891992 [DL]CHIPoBLE advertising mode changed to slow
I: 24891998 [DL]CHIPoBLE advertising started
I: 25761992 [DL]CHIPoBLE advertising mode changed to extended
I: 25761998 [DL]CHIPoBLE advertising started
There are also some useful logs.
ubuntu@ubuntu:~/ScriptRunner$ ./OTBRStart.sh
Using BR Interface: wlan0
Using BR Variant: 37
otbr_start.sh: Starting...
otbr_start.sh: Removing 'otbr-chip' container
nrfconnect/otbr                                        9185bda                                    083c8472bc52   2 years ago     1.21GB
otbr image nrfconnect/otbr:9185bda already installed
otbr_start.sh: Starting 'otbr-chip' container
a195577e2a7e0ac850ca65bdaab0eb10e53d5c2304f1adca3f7e34441202a314
otbr_start.sh: Waiting 10 seconds to give the the docker container enough time to start up...
otbr_start.sh: Setting up Thread Network
Param: 'dataset init new'Done
Param: 'dataset channel 25'Done
Param: 'dataset panid 0x5b37'Done
Param: 'dataset extpanid 5b37dead5b37beef'Done
Param: 'dataset networkname 5b37'Done
Param: 'dataset networkkey 00112233445566778899aabbccddeeff'Done
Param: 'dataset commit active'Done
Param: 'prefix add fd11:37::/64 pasor'Done
Param: 'ifconfig up'Done
Param: 'thread start'Done
Param: 'netdata register'Done
Param: 'dataset active -x'0e08000000000001000035060004001fffe00708fd5e18d459de590904109e90c98379c9a88e1ce94b613a1405890c0402a0f7f8000300001901025b3702085b37dead5b37beef030435623337051000112233445566778899aabbccddeeff
Done
Simple Dataset: 000300001902085b37dead5b37beef051000112233445566778899aabbccddeeff01025b37
otbr_start.sh: Restarting the Raspi avahi to have it in a clean state
otbr_start.sh: Finishing...
ubuntu@ubuntu:~/ScriptRunner$ docker ps
CONTAINER ID   IMAGE        COMMAND                  CREATED              STATUS              PORTS        NAMES
5f10d282fd8e   connectedhomeip/chip-cert-bins:1b2b3fd571feaca7328db35798b99ab7ba4e6212   "tail -f /dev/null"      53 seconds ago       Up 53 seconds        th-sdk
a195577e2a7e   nrfconnect/otbr:9185bda                                                   "/app/etc/docker/doc…"   About a minute ago   Up About a minute        otbr-chip
de5a6e52f066   ghcr.io/project-chip/csa-certification-tool-frontend:e3af91a              "docker-entrypoint.s…"   3 days ago           Up 3 days           4200/tcp        certification-tool-frontend-1
01ebe05ec272   ghcr.io/project-chip/csa-certification-tool-backend:9bf5d9f               "bash -c './prestart…"   3 days ago           Up 3 days           0.0.0.0:8888->8888/tcp, [::]:8888->8888/tcp, 0.0.0.0:50000->50000/tcp, [::]:50000->50000/tcp   certification-tool-backend-1
817e087de054   postgres:12                                                               "docker-entrypoint.s…"   3 days ago           Up 3 days           0.0.0.0:5432->5432/tcp, [::]:5432->5432/tcp                                                    certification-tool-db-1
879a52b318c8   traefik:v2.2                                                              "/entrypoint.sh --pr…"   3 days ago           Up 3 days           0.0.0.0:80->80/tcp, [::]:80->80/tcp, 0.0.0.0:8090->8080/tcp, [::]:8090->8080/tcp               certification-tool-proxy-1
ubuntu@ubuntu:~/ScriptRunner$ docker ps | grep otbr
And I create such a test
  "config": {
    "test_parameters": {
      "qr-code": "MT:Y.K90CEK01HBTF25X10"
    "network": {
      "wifi": {
        "ssid": "testharness",
        "password": "wifi-password"
      "thread": {
        "rcp_serial_path": "/dev/ttyACM0",
        "rcp_baudrate": 115200,
        "on_mesh_prefix": "fd11:37::/64",
        "network_interface": "wlan0",
        "dataset": {
          "channel": "25",
          "panid": "0x5b37",
          "extpanid": "5b37dead5b37beef",
          "networkkey": "00112233445566778899aabbccddeeff",
          "networkname": "5b37"
        "otbr_docker_image": null
    "dut_config": {
      "discriminator": "1145",
      "setup_code": "88581739",
      "pairing_mode": "ble-thread",
      "chip_timeout": null,
      "chip_use_paa_certs": true,
      "trace_log": true,
      "enhanced_setup_flow": null
  "pics": {
    "clusters": {
      "Base": {
        "name": "Base",
        "items": {
          "MCORE.DT_SW_COMP": {
            "number": "MCORE.DT_SW_COMP",
            "enabled": false
          "MCORE.COM.BLE": {
            "number": "MCORE.COM.BLE",
            "enabled": true
          "MCORE.COM.WIFI_2P4GHZ": {
            "number": "MCORE.COM.WIFI_2P4GHZ",
            "enabled": false
          "MCORE.COM.WIFI_5GHZ": {
            "number": "MCORE.COM.WIFI_5GHZ",
            "enabled": false
          "MCORE.COM.WIFI": {
            "number": "MCORE.COM.WIFI",
            "enabled": false
          "MCORE.COM.ETH": {
            "number": "MCORE.COM.ETH",
            "enabled": false
          "MCORE.COM.THR": {
            "number": "MCORE.COM.THR",
            "enabled": true
          "MCORE.COM.WIRELESS": {
            "number": "MCORE.COM.WIRELESS",
            "enabled": true
          "MCORE.ROLE.COMMISSIONER": {
            "number": "MCORE.ROLE.COMMISSIONER",
            "enabled": false
          "MCORE.ROLE.COMMISSIONEE": {
            "number": "MCORE.ROLE.COMMISSIONEE",
            "enabled": true
          "MCORE.ROLE.CONTROLLER": {
            "number": "MCORE.ROLE.CONTROLLER",
            "enabled": false
          "MCORE.DLOG.S.UTCTIMESTAMP": {
            "number": "MCORE.DLOG.S.UTCTIMESTAMP",
            "enabled": false
          "MCORE.DLOG.S.TIMESINCEBOOT": {
            "number": "MCORE.DLOG.S.TIMESINCEBOOT",
            "enabled": false
          "MCORE.DD.CHIP_DEV": {
            "number": "MCORE.DD.CHIP_DEV",
            "enabled": true
          "MCORE.DD.DEV_LOCK": {
            "number": "MCORE.DD.DEV_LOCK",
            "enabled": false
          "MCORE.DD.DEV_BARRIER": {
            "number": "MCORE.DD.DEV_BARRIER",
            "enabled": false
          "MCORE.DD.IE": {
            "number": "MCORE.DD.IE",
            "enabled": false
          "MCORE.DD.QR": {
            "number": "MCORE.DD.QR",
            "enabled": false
          "MCORE.DD.MANUAL_PC": {
            "number": "MCORE.DD.MANUAL_PC",
            "enabled": true
          "MCORE.DD.NFC": {
            "number": "MCORE.DD.NFC",
            "enabled": false
          "MCORE.DD.UI": {
            "number": "MCORE.DD.UI",
            "enabled": true
          "MCORE.DD.COMM_DISCOVERY": {
            "number": "MCORE.DD.COMM_DISCOVERY",
            "enabled": true
          "MCORE.DD.CONCATENATED_QR_CODE": {
            "number": "MCORE.DD.CONCATENATED_QR_CODE",
            "enabled": false
          "MCORE.DD.CTRL_CONCATENATED_QR_CODE_1": {
            "number": "MCORE.DD.CTRL_CONCATENATED_QR_CODE_1",
            "enabled": false
          "MCORE.DD.CTRL_CONCATENATED_QR_CODE_1_INORDER": {
            "number": "MCORE.DD.CTRL_CONCATENATED_QR_CODE_1_INORDER",
            "enabled": false
          "MCORE.DD.CTRL_CONCATENATED_QR_CODE_2": {
            "number": "MCORE.DD.CTRL_CONCATENATED_QR_CODE_2",
            "enabled": false
          "MCORE.DD.DISCOVERY_BLE": {
            "number": "MCORE.DD.DISCOVERY_BLE",
            "enabled": false
          "MCORE.DD.DISCOVERY_PAF": {
            "number": "MCORE.DD.DISCOVERY_PAF",
            "enabled": false
          "MCORE.DD.DISCOVERY_IP": {
            "number": "MCORE.DD.DISCOVERY_IP",
            "enabled": false
          "MCORE.DD.DISCOVERY_SOFTAP": {
            "number": "MCORE.DD.DISCOVERY_SOFTAP",
            "enabled": false
          "MCORE.DD.STANDARD_COMM_FLOW": {
            "number": "MCORE.DD.STANDARD_COMM_FLOW",
            "enabled": true
          "MCORE.DD.NON_CONCURRENT_CONNECTION": {
            "number": "MCORE.DD.NON_CONCURRENT_CONNECTION",
            "enabled": false
          "MCORE.DD.USER_INTENT_COMM_FLOW": {
            "number": "MCORE.DD.USER_INTENT_COMM_FLOW",
            "enabled": false
          "MCORE.DD.CUSTOM_COMM_FLOW": {
            "number": "MCORE.DD.CUSTOM_COMM_FLOW",
            "enabled": false
          "MCORE.DD.MANUAL_PC_COMMISSIONING": {
            "number": "MCORE.DD.MANUAL_PC_COMMISSIONING",
            "enabled": true
          "MCORE.DD.11_MANUAL_PC": {
            "number": "MCORE.DD.11_MANUAL_PC",
            "enabled": true
          "MCORE.DD.21_MANUAL_PC": {
            "number": "MCORE.DD.21_MANUAL_PC",
            "enabled": false
          "MCORE.DD.PHYSICAL_TAMPERING": {
            "number": "MCORE.DD.PHYSICAL_TAMPERING",
            "enabled": false
          "MCORE.DD.SCAN_NFC": {
            "number": "MCORE.DD.SCAN_NFC",
            "enabled": false
          "MCORE.DD.QR_COMMISSIONING": {
            "number": "MCORE.DD.QR_COMMISSIONING",
            "enabled": false
          "MCORE.DD.SCAN_QR_CODE": {
            "number": "MCORE.DD.SCAN_QR_CODE",
            "enabled": false
          "MCORE.DD.EXTENDED_DISCOVERY": {
            "number": "MCORE.DD.EXTENDED_DISCOVERY",
            "enabled": false
          "MCORE.DD.COMMISSIONING_SUBTYPE_V": {
            "number": "MCORE.DD.COMMISSIONING_SUBTYPE_V",
            "enabled": false
          "MCORE.DD.COMMISSIONING_SUBTYPE_T": {
            "number": "MCORE.DD.COMMISSIONING_SUBTYPE_T",
            "enabled": false
          "MCORE.DD.TXT_KEY_VP": {
            "number": "MCORE.DD.TXT_KEY_VP",
            "enabled": true
          "MCORE.DD.TXT_KEY_DT": {
            "number": "MCORE.DD.TXT_KEY_DT",
            "enabled": true
          "MCORE.DD.TXT_KEY_DN": {
            "number": "MCORE.DD.TXT_KEY_DN",
            "enabled": false
          "MCORE.DD.TXT_KEY_RI": {
            "number": "MCORE.DD.TXT_KEY_RI",
            "enabled": false
          "MCORE.DD.TXT_KEY_PH": {
            "number": "MCORE.DD.TXT_KEY_PH",
            "enabled": false
          "MCORE.DD.TXT_KEY_PI": {
            "number": "MCORE.DD.TXT_KEY_PI",
            "enabled": false
          "MCORE.COM.PAF": {
            "number": "MCORE.COM.PAF",
            "enabled": false
          "MCORE.DD.ESF_TC_COMMISSIONER": {
            "number": "MCORE.DD.ESF_TC_COMMISSIONER",
            "enabled": false
          "MCORE.SC.VENDOR_SUBTYPE": {
            "number": "MCORE.SC.VENDOR_SUBTYPE",
            "enabled": false
          "MCORE.SC.DEVTYPE_SUBTYPE": {
            "number": "MCORE.SC.DEVTYPE_SUBTYPE",
            "enabled": false
          "MCORE.SC.VP_KEY": {
            "number": "MCORE.SC.VP_KEY",
            "enabled": false
          "MCORE.SC.DT_KEY": {
            "number": "MCORE.SC.DT_KEY",
            "enabled": false
          "MCORE.SC.DN_KEY": {
            "number": "MCORE.SC.DN_KEY",
            "enabled": false
          "MCORE.SC.RI_KEY": {
            "number": "MCORE.SC.RI_KEY",
            "enabled": false
          "MCORE.SC.PH_KEY": {
            "number": "MCORE.SC.PH_KEY",
            "enabled": false
          "MCORE.SC.PI_KEY": {
            "number": "MCORE.SC.PI_KEY",
            "enabled": false
          "MCORE.SC.SII_OP_DISCOVERY_KEY": {
            "number": "MCORE.SC.SII_OP_DISCOVERY_KEY",
            "enabled": false
          "MCORE.SC.SAI_OP_DISCOVERY_KEY": {
            "number": "MCORE.SC.SAI_OP_DISCOVERY_KEY",
            "enabled": false
          "MCORE.SC.SAT_OP_DISCOVERY_KEY": {
            "number": "MCORE.SC.SAT_OP_DISCOVERY_KEY",
            "enabled": false
          "MCORE.SC.T_KEY": {
            "number": "MCORE.SC.T_KEY",
            "enabled": false
          "MCORE.SC.SII_COMM_DISCOVERY_KEY": {
            "number": "MCORE.SC.SII_COMM_DISCOVERY_KEY",
            "enabled": false
          "MCORE.SC.SAI_COMM_DISCOVERY_KEY": {
            "number": "MCORE.SC.SAI_COMM_DISCOVERY_KEY",
            "enabled": false
          "MCORE.SC.EXTENDED_DISCOVERY": {
            "number": "MCORE.SC.EXTENDED_DISCOVERY",
            "enabled": false
          "MCORE.SC.SIT_ICD": {
            "number": "MCORE.SC.SIT_ICD",
            "enabled": false
          "MCORE.SC.TCP": {
            "number": "MCORE.SC.TCP",
            "enabled": false
          "MCORE.IDM.S": {
            "number": "MCORE.IDM.S",
            "enabled": true
          "MCORE.IDM.C": {
            "number": "MCORE.IDM.C",
            "enabled": false
          "MCORE.IDM.C.InvokeRequest": {
            "number": "MCORE.IDM.C.InvokeRequest",
            "enabled": false
          "MCORE.IDM.C.ReadRequest": {
            "number": "MCORE.IDM.C.ReadRequest",
            "enabled": false
          "MCORE.IDM.C.WriteRequest": {
            "number": "MCORE.IDM.C.WriteRequest",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest": {
            "number": "MCORE.IDM.C.SubscribeRequest",
            "enabled": false
          "MCORE.IDM.C.InvokeRequest.BatchCommands": {
            "number": "MCORE.IDM.C.InvokeRequest.BatchCommands",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_Bool": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_Bool",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_String": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_String",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_UnsignedInteger": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_UnsignedInteger",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_SignedInteger": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_SignedInteger",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_Struct": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_Struct",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_FloatingPoint": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_FloatingPoint",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_List": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_List",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_OctetString": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_OctetString",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_Enum": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_Enum",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_Bitmap": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_Bitmap",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_Bool": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_Bool",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_String": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_String",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_UnsignedInteger": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_UnsignedInteger",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_SignedInteger": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_SignedInteger",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_Struct": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_Struct",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_FloatingPoint": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_FloatingPoint",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_List": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_List",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_OctetString": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_OctetString",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_Enum": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_Enum",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_Bitmap": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_Bitmap",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_Bool": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_Bool",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_String": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_String",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_UnsignedInteger": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_UnsignedInteger",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_SignedInteger": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_SignedInteger",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_Struct": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_Struct",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_FloatingPoint": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_FloatingPoint",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_List": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_List",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_OctetString": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_OctetString",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_Enum": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_Enum",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_Bitmap": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_Bitmap",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_Bool": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_Bool",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_String": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_String",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_UnsignedInteger": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_UnsignedInteger",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_Integer": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_Integer",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_FloatingPoint": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_FloatingPoint",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_List": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_List",
            "enabled": false
          "MCORE.IDM.S.LargeData": {
            "number": "MCORE.IDM.S.LargeData",
            "enabled": false
          "MCORE.IDM.C.SubscribeEvent": {
            "number": "MCORE.IDM.C.SubscribeEvent",
            "enabled": false
          "MCORE.IDM.C.ReadEvent": {
            "number": "MCORE.IDM.C.ReadEvent",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.MultipleAttributes": {
            "number": "MCORE.IDM.C.SubscribeRequest.MultipleAttributes",
            "enabled": false
          "MCORE.IDM.S.PersistentSubscription": {
            "number": "MCORE.IDM.S.PersistentSubscription",
            "enabled": true
          "MCORE.BRIDGE": {
            "number": "MCORE.BRIDGE",
            "enabled": false
          "MCORE.BRIDGE.BatInfo": {
            "number": "MCORE.BRIDGE.BatInfo",
            "enabled": false
          "MCORE.BRIDGE.OtherControl": {
            "number": "MCORE.BRIDGE.OtherControl",
            "enabled": false
          "MCORE.BRIDGE.AllowDeviceRename": {
            "number": "MCORE.BRIDGE.AllowDeviceRename",
            "enabled": false
          "MCORE.BRIDGECLIENT": {
            "number": "MCORE.BRIDGECLIENT",
            "enabled": false
          "MCORE.DEVLIST.UseDevices": {
            "number": "MCORE.DEVLIST.UseDevices",
            "enabled": false
          "MCORE.DEVLIST.UseDeviceName": {
            "number": "MCORE.DEVLIST.UseDeviceName",
            "enabled": false
          "MCORE.DEVLIST.UseDeviceState": {
            "number": "MCORE.DEVLIST.UseDeviceState",
            "enabled": false
          "MCORE.DEVLIST.UseBatInfo": {
            "number": "MCORE.DEVLIST.UseBatInfo",
            "enabled": false
          "MCORE.BDX.Sender": {
            "number": "MCORE.BDX.Sender",
            "enabled": false
          "MCORE.BDX.Receiver": {
            "number": "MCORE.BDX.Receiver",
            "enabled": false
          "MCORE.BDX.SynchronousSender": {
            "number": "MCORE.BDX.SynchronousSender",
            "enabled": false
          "MCORE.BDX.SynchronousReceiver": {
            "number": "MCORE.BDX.SynchronousReceiver",
            "enabled": false
          "MCORE.BDX.AsynchronousSender": {
            "number": "MCORE.BDX.AsynchronousSender",
            "enabled": false
          "MCORE.BDX.AsynchronousReceiver": {
            "number": "MCORE.BDX.AsynchronousReceiver",
            "enabled": false
          "MCORE.BDX.Driver": {
            "number": "MCORE.BDX.Driver",
            "enabled": false
          "MCORE.BDX.Initiator": {
            "number": "MCORE.BDX.Initiator",
            "enabled": false
          "MCORE.BDX.Responder": {
            "number": "MCORE.BDX.Responder",
            "enabled": false
          "MCORE.BDX.BlockQueryWithSkip": {
            "number": "MCORE.BDX.BlockQueryWithSkip",
            "enabled": false
          "MCORE.OTA.Requestor": {
            "number": "MCORE.OTA.Requestor",
            "enabled": true
          "MCORE.OTA.Provider": {
            "number": "MCORE.OTA.Provider",
            "enabled": false
          "MCORE.OTA.HTTPS": {
            "number": "MCORE.OTA.HTTPS",
            "enabled": false
          "MCORE.OTA.RequestorConsent": {
            "number": "MCORE.OTA.RequestorConsent",
            "enabled": true
          "MCORE.OTA.Resume": {
            "number": "MCORE.OTA.Resume",
            "enabled": false
          "MCORE.OTA.VendorSpecific": {
            "number": "MCORE.OTA.VendorSpecific",
            "enabled": false
          "MCORE.ACL.Administrator": {
            "number": "MCORE.ACL.Administrator",
            "enabled": false
          "MCORE.OTA.Retry": {
            "number": "MCORE.OTA.Retry",
            "enabled": false
          "MCORE.FS": {
            "number": "MCORE.FS",
            "enabled": false
          "MCORE.SM.S": {
            "number": "MCORE.SM.S",
            "enabled": true
          "MCORE.DT.S": {
            "number": "MCORE.DT.S",
            "enabled": true
          "MCORE.G.MULTIENDPOINT": {
            "number": "MCORE.G.MULTIENDPOINT",
            "enabled": false
      "On/Off Cluster Test Plan": {
        "name": "On/Off Cluster Test Plan",
        "items": {
          "OO.S": {
            "number": "OO.S",
            "enabled": true
          "OO.C": {
            "number": "OO.C",
            "enabled": false
          "OO.S.A0000": {
            "number": "OO.S.A0000",
            "enabled": true
          "OO.S.A4000": {
            "number": "OO.S.A4000",
            "enabled": false
          "OO.S.A4001": {
            "number": "OO.S.A4001",
            "enabled": false
          "OO.S.A4002": {
            "number": "OO.S.A4002",
            "enabled": false
          "OO.S.A4003": {
            "number": "OO.S.A4003",
            "enabled": false
          "OO.S.C00.Rsp": {
            "number": "OO.S.C00.Rsp",
            "enabled": true
          "OO.S.C01.Rsp": {
            "number": "OO.S.C01.Rsp",
            "enabled": true
          "OO.S.C02.Rsp": {
            "number": "OO.S.C02.Rsp",
            "enabled": true
          "OO.S.C40.Rsp": {
            "number": "OO.S.C40.Rsp",
            "enabled": false
          "OO.S.C41.Rsp": {
            "number": "OO.S.C41.Rsp",
            "enabled": false
          "OO.S.C42.Rsp": {
            "number": "OO.S.C42.Rsp",
            "enabled": false
          "OO.S.F00": {
            "number": "OO.S.F00",
            "enabled": false
          "OO.S.F01": {
            "number": "OO.S.F01",
            "enabled": false
          "OO.S.F02": {
            "number": "OO.S.F02",
            "enabled": false
          "OO.M.ManuallyControlled": {
            "number": "OO.M.ManuallyControlled",
            "enabled": false
          "OO.C.C00.Tx": {
            "number": "OO.C.C00.Tx",
            "enabled": false
          "OO.C.C01.Tx": {
            "number": "OO.C.C01.Tx",
            "enabled": false
          "OO.C.C02.Tx": {
            "number": "OO.C.C02.Tx",
            "enabled": false
          "OO.C.C40.Tx": {
            "number": "OO.C.C40.Tx",
            "enabled": false
          "OO.C.C41.Tx": {
            "number": "OO.C.C41.Tx",
            "enabled": false
          "OO.C.C42.Tx": {
            "number": "OO.C.C42.Tx",
            "enabled": false
Here are my pics files
6254.PICS.zip
And I want to what happen, and how to solve it. My otbr seems fine, because I can run the following command:
ubuntu@ubuntu:~/ScriptRunner$ sudo docker exec -ti otbr-chip ot-ctl state
leader
Done
4606.MatterTH.zip
NCS vesion is v3.0.2. NRF54L15 DK
Thanks!
Xiongwei.Wang
    I misunderstood how the TH tool and OTBR work together. I actually don't need to start OTBR manually before running the test in the TH web interface. When I paste the JSON config into the TH tool, it automatically creates a Thread network and runs the test. What I didn't realize is that it first kills any existing OTBR container before doing so.
    Xiongwei.Wang
