nRF54L15 DK COMP false NRF_COMP_EVENT_UP when going down
I am trying to configure COMP peripheral on my NRF54L15 DK.
I am using P1.11 pin (AIN4) as single ended input for this purpose. For now I am trying only to evaluate this peripheral so I connected a potentiometer to this pin. Other two potentiometer terminals are connected to GND and VDDIO - so I am able to set a voltage in range 0.0V - 1.8V on P1.11.
I managed to get the COMP working using default configuration (that means down threshold = 0.5V and up threshold = 1.0V). It triggers nicely when going UP. However when going down I always get both NRF_COMP_EVENT_DOWN and NRF_COMP_EVENT_UP.
Below is all my code from main.c
 * Copyright (c) 2024 Nordic Semiconductor ASA
#include <zephyr/kernel.h>
#include <nrfx_comp.h>
#define NRF_COMP_INPUT_AIN4 NRF_PIN_PORT_TO_PIN_NUMBER(11U, 1)
#define COMP_INPUT_PIN NRF_COMP_INPUT_AIN4
static nrfx_comp_config_t comp_config = NRFX_COMP_DEFAULT_CONFIG(COMP_INPUT_PIN);
static void comparator_handler(nrf_comp_event_t event);
static nrfx_comp_event_handler_t comp_event_config = comparator_handler;
    switch (event)
    case NRF_COMP_EVENT_READY:
        printk("NRF_COMP_EVENT_READY\n");
    case NRF_COMP_EVENT_UP:
        printk("NRF_COMP_EVENT_UP\n");
    case NRF_COMP_EVENT_DOWN:
        printk("NRF_COMP_EVENT_DOWN\n");
    case NRF_COMP_EVENT_CROSS:
        printk("NRF_COMP_EVENT_CROSS\n");
static void configure_comp(void)
        //INTERRUPT
        IRQ_CONNECT(DT_IRQN(DT_NODELABEL(comp)),
                DT_IRQ(DT_NODELABEL(comp), priority),
                nrfx_isr, nrfx_comp_irq_handler, 0);
        // initialize comp driver
        nrfx_err_t err = nrfx_comp_init(&comp_config, comp_event_config);
        if (err != NRFX_SUCCESS)
                printk("Error COMP init: %08x", err);
                return;
        nrfx_comp_start(NRFX_COMP_EVT_EN_CROSS_MASK |
                NRFX_COMP_EVT_EN_UP_MASK |
                NRFX_COMP_EVT_EN_DOWN_MASK |
                NRFX_COMP_EVT_EN_READY_MASK, 0);
        configure_comp();
        k_sleep(K_FOREVER);
        return 0;
And below is the output from serial terminal I get when I rotate my potentiometer. I added my comments to elaborate that every time there is proper DOWN event there is also false UP triggered.
*** Using Zephyr OS v4.0.99-77f865b8f8d0 ***
NRF_COMP_EVENT_UP       // proper UP event
NRF_COMP_EVENT_CROSS    // proper CROSS event
NRF_COMP_EVENT_DOWN     // DOWN event
NRF_COMP_EVENT_UP       // false UP event generated - i don't know why
NRF_COMP_EVENT_DOWN     // proper DOWN event
NRF_COMP_EVENT_UP       // again: false UP
What I tried:
  • change speed of the COMP to the slowest
  • change voltage reference of the COMP to VDD
  • change threshold voltages to 0.9 down and 1.0 up
  • add 40mV hysteresis (besides the different up and down thresholds)
I thought that maybe there is some signal integrity problems. I measured the voltage on P1.11 during the experiment using my saleae pro with 5MHz BW. It shows little to no noise at all (i don't have any better equipment). Anyway if that would be the case then i think i would be getting also false DOWN events and the effect would be more random... So at this moment I think there is some code bug.
If anyone needs any additional information I will give it to You.
If anyone would try to test my code on DK please mind that You also need to add dts overlay to Your project:
&comp {
    compatible = "nordic,nrf-comp";
    status = "okay";
  • Hi Lukasz,
    You should use our SDK-provided comparator input enumerator and should not redefine NRF_COMP_INPUT_AIN4 as a raw GPIO number.. The nrfx/hal code expects the COMP input enum (nrf_comp_input_t).
    You should remove this
    -#define NRF_COMP_INPUT_AIN4 NRF_PIN_PORT_TO_PIN_NUMBER(11U, 1)
    -#define COMP_INPUT_PIN NRF_COMP_INPUT_AIN4
    -static nrfx_comp_config_t comp_config = NRFX_COMP_DEFAULT_CONFIG(COMP_INPUT_PIN);
    and just add
    +static nrfx_comp_config_t comp_config = NRFX_COMP_DEFAULT_CONFIG(NRF_COMP_INPUT_AIN4);
    I am not an expert in this API but looking at the code and the API documentation for nrfx_comp_start, it looks like the input you pass to NRFX/COMP is not the enum the driver expects. I would suggest that you just start with DOWN-only and READY event and then enable more events as you are debugging this
    nrfx_comp_start(NRFX_COMP_EVT_EN_DOWN_MASK | NRFX_COMP_EVT_EN_READY_MASK, 0);
