Following this link I integrated the extended power save mode in my code,
I put the nrf7002 in extended power save mode after successfully connecting to the AP.
Doing that I am getting below error.
- DTIM period is selected by the AP only, it can't be set by STA device. - faced error for setting power save mode. - I: wifi_set_ps_wakeup_mode: Set wakeup mode: Listen interval - E: wifi_set_ps_wakeup_mode: Setting wakeup mode failed. Reason Cannot set parameters while device connected
Attaching the code snippet I am using.
int nrf_wifi_ps_enabled = 0;
int nrf_wifi_ps_wakeup_mode = 0;
int wifi_set_ps_wakeup_mode();
int wifi_set_power_state()
struct net_if *iface = net_if_get_first_wifi();
/* STEP 2.1 - Define the Wi-Fi power save parameters structure */
struct wifi_ps_params ps_params = {0};
/* STEP 2.2 - Check if power saving is currently enabled */
if (!nrf_wifi_ps_enabled)
ps_params.enabled = WIFI_PS_ENABLED;
ps_params.enabled = WIFI_PS_DISABLED;
/* STEP 2.3 - Send the power save request */
if (net_mgmt(NET_REQUEST_WIFI_PS, iface, &ps_params, sizeof(ps_params)))
WB_ERR("Power save %s failed. Reason %s", ps_params.enabled ? "enable" : "disable",
wifi_ps_get_config_err_code_str(ps_params.fail_reason));
return -1;
WB_INF("Set power save: %s", ps_params.enabled ? "enable" : "disable");
/* STEP 2.4 - Toggle the power save status */
nrf_wifi_ps_enabled = nrf_wifi_ps_enabled ? 0 : 1;
return 0;
struct net_if *iface = net_if_get_default();
/* STEP 6.2 - Define the Wi-Fi power save parameters structure */
/* STEP 6.3 - Check and toggle the current wakeup mode */
if (nrf_wifi_ps_wakeup_mode)
ps_params.wakeup_mode = WIFI_PS_WAKEUP_MODE_DTIM;
ps_params.wakeup_mode = WIFI_PS_WAKEUP_MODE_LISTEN_INTERVAL;
/* STEP 6.4 - Set the request type to wakeup mode. */
ps_params.type = WIFI_PS_PARAM_WAKEUP_MODE;
/* STEP 6.5 - Send the wakeup mode request */
WB_ERR("Setting wakeup mode failed. Reason %s",
return -1;
WB_INF("Set wakeup mode: %s", ps_params.wakeup_mode ? "Listen interval" : "DTIM");
if (ps_params.wakeup_mode == WIFI_PS_WAKEUP_MODE_LISTEN_INTERVAL)
/* STEP 6.6 - Set the listen interval */
memset(&ps_params, 0x00, sizeof(ps_params));
ps_params.type = WIFI_PS_PARAM_LISTEN_INTERVAL;
ps_params.listen_interval = 10;
/* Assuming 100ms DTIM interval, the listen interval should be 10 * 100ms = 1000ms */
return -1;
/* STEP 6.6 - Toggle the wakeup mode status */
nrf_wifi_ps_wakeup_mode = nrf_wifi_ps_wakeup_mode ? 0 : 1;
return 0;
Can you point out what am doing wrong in this.
