NCS SDK and toolchain: nRF Connect SDK v3.0.2
Boards: nRF52DK-nRF52832, nRF54L15DK-nRF54L15
Issue:
After un-initializing and then re-initializing MPSL, MPSL no longer performs LFCLK calibration.
I have confirmed this behavior on the nRF52832 and the nRF54L15.
Details:
I have an application which needs to switch between having BLE enabled, and having a custom RF protocol with 100% control of the radio. Since the MPSL arbitrator is automatically included, I am using the recommended Kconfig options to un-initialize MPSL and connect my own interrupt to have 100% control of the radio.
My application also requires that the internal RC LFCLK be used, so I need clock calibration to occur regularly. MPSL handles this when it is running, and I understand I will need to trigger clock calibration on my own when MPSL is not running, but after re-initializing MPSL and Bluetooth, the LFCLK event is not triggered regularly.
I am confirming this by hooking up a PPI LED toggle task to the NRF_CLOCK "DONE" event. When it first boots, the dev kit flashes led1 every 8 seconds or so as expected, but the LED does not flash after un-initializing and re-initializing MPSL.
Bluetooth works as expected. After disabling bluetooth and re-enabling it, it functions normally.
Relevant Kconfig:
static const nrfx_gpiote_t led1_gpiote_inst = NRFX_GPIOTE_INSTANCE(NRF_DT_GPIOTE_INST(DT_ALIAS(led1), gpios));
static const uint32_t led1_pin = NRF_DT_GPIOS_TO_PSEL(DT_ALIAS(led1), gpios);
static void setup_clock_done_ppi_toggle(void)
nrfx_err_t err;
static uint8_t ppi_ch;
static uint8_t led1_gpiote_ch;
static bool first_run = true;
/* GPIOTE is assumed initialized by Zephyr via CONFIG_NRFX_GPIOTE */
if (first_run)
err = nrfx_gpiote_channel_alloc(&led1_gpiote_inst, &led1_gpiote_ch);
if (err != NRFX_SUCCESS)
LOG_ERR("Failed to allocate GPIOTE channel for pin %d (err=%d)", led1_pin, err);
return;
LOG_INF("Allocated GPIOTE channel %d for pin %d", led1_gpiote_ch, led1_pin);
// Configure output and task for the pin
nrfx_gpiote_output_config_t output_config = {
.drive = NRF_GPIO_PIN_S0S1,
.input_connect = NRF_GPIO_PIN_INPUT_DISCONNECT,
.pull = NRF_GPIO_PIN_NOPULL
nrfx_gpiote_task_config_t task_config = {
.task_ch = led1_gpiote_ch,
.polarity = NRF_GPIOTE_POLARITY_TOGGLE,
.init_val = NRF_GPIOTE_INITIAL_VALUE_HIGH
err = nrfx_gpiote_output_configure(&led1_gpiote_inst, led1_pin, &output_config, &task_config);
LOG_ERR("GPIOTE output configure failed: %d", err);
return;
nrfx_gpiote_out_task_enable(&led1_gpiote_inst, led1_pin);
if (first_run)
// Allocate a GPPI (PPI/DPPI) channel
err = nrfx_gppi_channel_alloc(&ppi_ch);
LOG_ERR("GPPI channel alloc failed: %d", err);
return;
LOG_INF("GPPI channel %d allocated", ppi_ch);
// Connect CLOCK DONE event to GPIOTE OUT task using GPPI
nrfx_gppi_channel_endpoints_setup(ppi_ch,
nrfx_clock_event_address_get(NRF_CLOCK_EVENT_DONE),//nrfx_gpiote_in_event_address_get(&gpiote_instance, button3.pin),
nrfx_gpiote_out_task_address_get(&led1_gpiote_inst, led1_pin));
nrfx_gppi_channels_enable(BIT(ppi_ch));
first_run = false;
Bluetooth and MPSL Init/Un-init code:
static void _RadioManagerThread(void *p1, void *p2, void *p3)
ARG_UNUSED(p1);
ARG_UNUSED(p2);
ARG_UNUSED(p3);
int err;
RadioManagerMsg_t msg;
uint8_t _currentMode = BLE_ONLY;
/* Initialize Bluetooth Advertiser work */
k_work_init(&_bleAdvertiserWork, _BLEAdvertiserWorkHandler);
/* Initialize Bluetooth */
err = bt_enable(NULL);
if (err < 0)
LOG_ERR("Bluetooth init failed (err %d)", err);
LOG_INF("Bluetooth initialized");
_BLEStartAdvertising();
_bleEnabled = true;
setup_clock_done_ppi_toggle();
for (;;)
/* Wait forever for a message */
err = k_msgq_get(&radio_manager_msgq, &msg, K_FOREVER);
if (err == 0u)
switch (msg.mode)
case CUSTOM_RF_ONLY:
err = bt_disable();
if (err < 0)
LOG_ERR("Bluetooth disable failed (err %d)", err);
_bleEnabled = false;
LOG_INF("Bluetooth disabled");
// TODO: Install interrupt
/** After successful execution of this method, user-supplied interrupt handlers
* can be attached to RADIO_IRQn, RTC0_IRQn, and TIMER0_IRQn using irq_connect_dynamic.
* Care must be taken when developing these handlers, as they will be executed as direct
* dynamic interrupts. See ARM_IRQ_DIRECT_DYNAMIC_CONNECT for additional documentation.
* These interrupts will trigger thread re-scheduling upon return. */
// TODO: Start clock calibration task
// TODO: Constant Latency Mode?? nrf_power_task_trigger(NRF_POWER, NRF_POWER_TASK_CONSTLAT);
case BLE_ONLY:
// TODO: Uninstall interrupt
// TODO: Stop clock calibration task
if (err < 0)
_bleEnabled = true;
LOG_ERR("Bad Radio Manager MsgQ message");
k_oops();
Full Kconfig .config file:
# CONFIG_INPUT is not set # CONFIG_WIFI is not set # CONFIG_MIPI_DSI is not set # CONFIG_MODEM is not set # CONFIG_UART_INTERRUPT_DRIVEN is not set # CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set CONFIG_BT_HCI_VS=y CONFIG_ROM_START_OFFSET=0 # CONFIG_BT_CTLR is not set CONFIG_NUM_IRQS=271 CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=1000000 CONFIG_FLASH_SIZE=1428 CONFIG_FLASH_BASE_ADDRESS=0x0 CONFIG_MP_MAX_NUM_CPUS=1 CONFIG_SOC_RESET_HOOK=y CONFIG_MAIN_STACK_SIZE=3584 CONFIG_IDLE_STACK_SIZE=320 CONFIG_ISR_STACK_SIZE=2048 CONFIG_CLOCK_CONTROL=y CONFIG_SYS_CLOCK_TICKS_PER_SEC=31250 CONFIG_KERNEL_ENTRY="__start" CONFIG_BUILD_OUTPUT_BIN=y CONFIG_XIP=y CONFIG_HAS_FLASH_LOAD_OFFSET=y # CONFIG_SRAM_VECTOR_TABLE is not set CONFIG_CPU_HAS_ARM_MPU=y # CONFIG_COUNTER is not set # CONFIG_SHARED_INTERRUPTS is not set # CONFIG_PM_DEVICE is not set CONFIG_TICKLESS_KERNEL=y CONFIG_BT_AUTO_PHY_UPDATE=y CONFIG_BT_AUTO_DATA_LEN_UPDATE=y # CONFIG_FPU is not set CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 # CONFIG_BT_USER_PHY_UPDATE is not set CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30 CONFIG_USE_DT_CODE_PARTITION=y # CONFIG_MULTI_LEVEL_INTERRUPTS is not set CONFIG_CACHE_MANAGEMENT=y CONFIG_GEN_IRQ_VECTOR_TABLE=y CONFIG_DYNAMIC_INTERRUPTS=y CONFIG_GEN_ISR_TABLES=y # CONFIG_INIT_STACKS is not set CONFIG_TIMESLICE_SIZE=0 CONFIG_FLASH_LOAD_OFFSET=0x10000 # CONFIG_REGULATOR is not set CONFIG_SYS_CLOCK_EXISTS=y CONFIG_INIT_ARCH_HW_AT_BOOT=y # CONFIG_BUILD_OUTPUT_S19 is not set CONFIG_FLASH_FILL_BUFFER_SIZE=32 CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y CONFIG_HW_STACK_PROTECTION=y # CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set # CONFIG_HCI_NXP_SET_CAL_DATA is not set # CONFIG_MFD is not set # CONFIG_HCI_NXP_RX_THREAD is not set CONFIG_GPIO=y CONFIG_SERIAL=y # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set CONFIG_SPI=y # CONFIG_CODE_DATA_RELOCATION_SRAM is not set # CONFIG_MEMC is not set CONFIG_CACHE=y CONFIG_LOG=y CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y # CONFIG_CODE_DATA_RELOCATION is not set # CONFIG_ROMSTART_RELOCATION_ROM is not set CONFIG_DCACHE_LINE_SIZE=32 # CONFIG_RESET is not set CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4 # CONFIG_NRF_RTC_TIMER is not set CONFIG_LOG_DOMAIN_NAME="" CONFIG_ASSERT=y CONFIG_CACHE_NRF_CACHE=y CONFIG_BUILD_OUTPUT_HEX=y # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set # CONFIG_SYSCON is not set CONFIG_SERIAL_INIT_PRIORITY=50 CONFIG_ENTROPY_INIT_PRIORITY=50 # CONFIG_INTC_MTK_ADSP is not set # CONFIG_MTK_ADSP_TIMER is not set CONFIG_CONSOLE=y # CONFIG_WINSTREAM is not set CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1 CONFIG_SOC_TOOLCHAIN_NAME="amd_acp_6_0_adsp" CONFIG_GEN_SW_ISR_TABLE=y CONFIG_REBOOT=y CONFIG_FLASH_INIT_PRIORITY=50 CONFIG_GEN_IRQ_START_VECTOR=0 CONFIG_SRAM_OFFSET=0 # CONFIG_POWER_DOMAIN is not set CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4 CONFIG_SPI_NOR=y # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set CONFIG_BOOTLOADER_MCUBOOT=y # CONFIG_SCHED_CPU_MASK is not set CONFIG_WATCHDOG=y CONFIG_ICACHE_LINE_SIZE=32 CONFIG_PRIVILEGED_STACK_SIZE=1024 CONFIG_BT_BUF_ACL_TX_COUNT=3 CONFIG_BT_BUF_CMD_TX_SIZE=65 CONFIG_BT_BUF_EVT_RX_SIZE=68 CONFIG_BT_BUF_ACL_TX_SIZE=251 CONFIG_BT_BUF_ACL_RX_SIZE=502 CONFIG_BT_L2CAP_TX_MTU=498 # # Devicetree Info # CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y CONFIG_DT_HAS_FIXED_CLOCK_ENABLED=y CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y CONFIG_DT_HAS_NORDIC_BT_HCI_SDC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GRTC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_HFXO_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_LFXO_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_PPIB_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF54L_REGULATORS_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y CONFIG_DT_HAS_NORDIC_RRAM_CONTROLLER_ENABLED=y CONFIG_DT_HAS_PWM_LEDS_ENABLED=y CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y CONFIG_DT_HAS_ZEPHYR_PSA_CRYPTO_RNG_ENABLED=y # end of Devicetree Info # # Modules # # CONFIG_BUILD_ONLY_NO_BLOBS is not set # # Available modules. # # # nrf (C:/ncs/v3.0.2/nrf) # CONFIG_NUM_METAIRQ_PRIORITIES=0 CONFIG_LOG_BUFFER_SIZE=4096 CONFIG_MBEDTLS_HEAP_SIZE=512 CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT=32 CONFIG_MPSL_WORK_STACK_SIZE=1024 # CONFIG_ZMS is not set # CONFIG_NVS is not set # CONFIG_MBEDTLS is not set # CONFIG_MBEDTLS_MD_C is not set # CONFIG_MBEDTLS_TLS_LIBRARY is not set # CONFIG_MBEDTLS_X509_LIBRARY is not set CONFIG_MBEDTLS_ENABLE_HEAP=y # CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C is not set # CONFIG_MBEDTLS_LEGACY_CRYPTO_C is not set # # Nordic nRF Connect # CONFIG_WARN_EXPERIMENTAL=y CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=2475 CONFIG_BT_BUF_CMD_TX_COUNT=2 CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 # CONFIG_GETOPT is not set CONFIG_NRF_SECURITY_ENABLER=y # CONFIG_NCS_SAMPLES_DEFAULTS is not set # # Image build variants # # CONFIG_NCS_MCUBOOT_IN_BUILD is not set # end of Image build variants # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU is not set CONFIG_IMG_ERASE_PROGRESSIVELY=y CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y # CONFIG_MCUMGR_GRP_ZBASIC is not set CONFIG_UPDATEABLE_IMAGE_NUMBER=1 # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set CONFIG_BT_CTLR_DATA_LENGTH_MAX=251 # # Subsystems # # # Bootloader # # CONFIG_SECURE_BOOT is not set CONFIG_PM_PARTITION_SIZE_PROVISION=0x460 # CONFIG_B0_MIN_PARTITION_SIZE is not set CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7800 # CONFIG_IS_SECURE_BOOTLOADER is not set # # Secure Boot firmware validation # CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483 CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1 CONFIG_SB_VALIDATION_INFO_VERSION=2 CONFIG_SB_VALIDATION_METADATA_OFFSET=0 CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y CONFIG_SB_VALIDATE_FW_SIGNATURE=y # end of Secure Boot firmware validation # CONFIG_SECURE_BOOT_STORAGE is not set # CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519=y # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set # end of Bootloader # # Bluetooth Low Energy # CONFIG_BT_COMPANY_ID_NORDIC=0x0059 CONFIG_BT_COMPANY_ID=0x0059 CONFIG_BT_MAX_CONN=1 CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y CONFIG_BT_LONG_WQ_STACK_SIZE=2100 CONFIG_BT_LL_SOFTDEVICE=y CONFIG_BT_CTLR_DF_SUPPORT=y # # SoftDevice Controller # CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y CONFIG_BT_HCI_TX_STACK_SIZE=1536 CONFIG_BT_RX_STACK_SIZE=1024 # CONFIG_BT_CTLR_SDC_LLPM is not set # CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1 # CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is not set CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500 CONFIG_BT_CTLR_SDC_CONN_EVENT_EXTEND_DEFAULT=y # CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3 CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2 CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3 CONFIG_BT_CTLR_SDC_RX_PRIO=6 # CONFIG_BT_CTLR_DF is not set # CONFIG_BT_LL_SOFTDEVICE_PERIPHERAL is not set CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y CONFIG_BT_CTLR_FAL_SIZE=8 # CONFIG_BT_CTLR_SDC_EVENT_TRIGGER is not set # CONFIG_BT_CTLR_SDC_CONN_ANCHOR_POINT_REPORT is not set CONFIG_BT_UNINIT_MPSL_ON_DISABLE=y # CONFIG_BT_CTLR_CHANNEL_SOUNDING is not set # CONFIG_BT_CTLR_SDC_LE_POWER_CLASS_1 is not set CONFIG_BT_LL_SOFTDEVICE_INIT_PRIORITY=40 # end of SoftDevice Controller # CONFIG_BT_RADIO_NOTIFICATION_CONN_CB is not set # # BLE Libraries # # CONFIG_BT_GATT_POOL is not set # CONFIG_BT_GATT_DM is not set # CONFIG_BT_ADV_PROV is not set # CONFIG_BT_CONN_CTX is not set # # Bluetooth Services # # CONFIG_BT_AMS_CLIENT is not set # CONFIG_BT_ANCS_CLIENT is not set # CONFIG_BT_BAS_CLIENT is not set # CONFIG_BT_BMS is not set # CONFIG_BT_CTS_CLIENT is not set # CONFIG_BT_DFU_SMP is not set # CONFIG_BT_GATTP is not set # CONFIG_BT_HIDS is not set # CONFIG_BT_HOGP is not set # CONFIG_BT_LBS is not set # CONFIG_BT_NSMS is not set # CONFIG_BT_NUS is not set # CONFIG_BT_NUS_CLIENT is not set # CONFIG_BT_RSCS is not set # CONFIG_BT_THROUGHPUT is not set # CONFIG_BT_LATENCY is not set # CONFIG_BT_LATENCY_CLIENT is not set # CONFIG_BT_HRS_CLIENT is not set # CONFIG_BT_DDFS is not set # CONFIG_BT_MDS is not set # CONFIG_BT_CGMS is not set # CONFIG_BT_FAST_PAIR is not set CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1 # end of Bluetooth Services # # BLE over nRF RPC # # CONFIG_BT_RPC is not set CONFIG_HEAP_MEM_POOL_SIZE=0 # CONFIG_BT_SHELL is not set # CONFIG_BT_RPC_STACK is not set # CONFIG_BT_CENTRAL is not set CONFIG_BT_PERIPHERAL=y # CONFIG_BT_OBSERVER is not set CONFIG_BT_BROADCASTER=y CONFIG_BT_CONN=y # CONFIG_BT_REMOTE_VERSION is not set CONFIG_BT_PHY_UPDATE=y CONFIG_BT_DATA_LEN_UPDATE=y # CONFIG_BT_EXT_ADV is not set CONFIG_BT_LOG=y # CONFIG_BT_LOG_LEVEL_OFF is not set # CONFIG_BT_LOG_LEVEL_ERR is not set # CONFIG_BT_LOG_LEVEL_WRN is not set # CONFIG_BT_LOG_LEVEL_INF is not set # CONFIG_BT_LOG_LEVEL_DBG is not set CONFIG_BT_LOG_LEVEL_DEFAULT=y CONFIG_BT_LOG_LEVEL=3 CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y CONFIG_BT_HCI_DRIVER_LOG_LEVEL=3 # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y CONFIG_BT_RPA_LOG_LEVEL=3 # CONFIG_BT_RPA_LOG_LEVEL_OFF is not set # CONFIG_BT_RPA_LOG_LEVEL_ERR is not set # CONFIG_BT_RPA_LOG_LEVEL_WRN is not set # CONFIG_BT_RPA_LOG_LEVEL_INF is not set # CONFIG_BT_RPA_LOG_LEVEL_DBG is not set # CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y CONFIG_BT_ATT_LOG_LEVEL=3 # CONFIG_BT_ATT_LOG_LEVEL_OFF is not set # CONFIG_BT_ATT_LOG_LEVEL_ERR is not set # CONFIG_BT_ATT_LOG_LEVEL_WRN is not set # CONFIG_BT_ATT_LOG_LEVEL_INF is not set # CONFIG_BT_ATT_LOG_LEVEL_DBG is not set # CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y CONFIG_BT_GATT_LOG_LEVEL=3 # CONFIG_BT_GATT_LOG_LEVEL_OFF is not set # CONFIG_BT_GATT_LOG_LEVEL_ERR is not set # CONFIG_BT_GATT_LOG_LEVEL_WRN is not set # CONFIG_BT_GATT_LOG_LEVEL_INF is not set # CONFIG_BT_GATT_LOG_LEVEL_DBG is not set # CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y CONFIG_BT_L2CAP_LOG_LEVEL=3 # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set # CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y CONFIG_BT_HCI_CORE_LOG_LEVEL=3 # CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set # CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set # CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set # CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set # CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set # CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y CONFIG_BT_CONN_LOG_LEVEL=3 # CONFIG_BT_CONN_LOG_LEVEL_OFF is not set # CONFIG_BT_CONN_LOG_LEVEL_ERR is not set # CONFIG_BT_CONN_LOG_LEVEL_WRN is not set # CONFIG_BT_CONN_LOG_LEVEL_INF is not set # CONFIG_BT_CONN_LOG_LEVEL_DBG is not set # CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y CONFIG_BT_KEYS_LOG_LEVEL=3 # CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set # CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set # CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set # CONFIG_BT_KEYS_LOG_LEVEL_INF is not set # CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set # CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y CONFIG_BT_SERVICE_LOG_LEVEL=3 # CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set # CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set # CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set # CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set # CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set # CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set # CONFIG_BT_DIS is not set # CONFIG_BT_CTS is not set # CONFIG_BT_HRS is not set # CONFIG_BT_TPS is not set # CONFIG_BT_ZEPHYR_NUS is not set # CONFIG_BT_IAS is not set # CONFIG_BT_IAS_CLIENT is not set # CONFIG_BT_OTS is not set # CONFIG_BT_OTS_CLIENT is not set # CONFIG_BT_BAS is not set # CONFIG_BT_BAS_BLS is not set CONFIG_BT_BUF_ACL_RX_COUNT_EXTRA=0 CONFIG_BT_BUF_ACL_RX_COUNT=0 CONFIG_BT_BUF_EVT_RX_COUNT=10 CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43 CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3 CONFIG_BT_HAS_HCI_VS=y # CONFIG_BT_HCI_VS_FATAL_ERROR is not set # CONFIG_BT_WAIT_NOP is not set CONFIG_BT_ASSERT=y CONFIG_BT_ASSERT_VERBOSE=y # CONFIG_BT_ASSERT_PANIC is not set # CONFIG_BT_HCI_ERR_TO_STR is not set CONFIG_BT_DEBUG_NONE=y # CONFIG_BT_DEBUG_MONITOR_UART is not set CONFIG_BT_LONG_WQ=y CONFIG_BT_LONG_WQ_PRIO=10 CONFIG_BT_LONG_WQ_INIT_PRIO=50 CONFIG_BT_HCI_HOST=y # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set CONFIG_BT_HCI_TX_PRIO=7 # CONFIG_BT_RECV_WORKQ_SYS is not set CONFIG_BT_RECV_WORKQ_BT=y CONFIG_BT_RX_PRIO=8 CONFIG_BT_DRIVER_RX_HIGH_PRIO=6 # CONFIG_BT_CONN_TX_NOTIFY_WQ is not set # CONFIG_BT_AUDIO is not set # CONFIG_BT_HOST_CRYPTO is not set # CONFIG_BT_FILTER_ACCEPT_LIST is not set CONFIG_BT_LIM_ADV_TIMEOUT=30 CONFIG_BT_CONN_TX_USER_DATA_SIZE=16 CONFIG_BT_CONN_FRAG_COUNT=1 CONFIG_BT_CONN_TX_MAX=3 # CONFIG_BT_CONN_PARAM_ANY is not set # CONFIG_BT_CONN_CHECK_NULL_BEFORE_CREATE is not set # CONFIG_BT_USER_DATA_LEN_UPDATE is not set # CONFIG_BT_REMOTE_INFO is not set # CONFIG_BT_SMP is not set CONFIG_BT_L2CAP_TX_BUF_COUNT=3 CONFIG_BT_L2CAP_TX_FRAG_COUNT=2 # CONFIG_BT_L2CAP_SEG_RECV is not set # CONFIG_BT_L2CAP_RECONFIGURE_EXPLICIT is not set # CONFIG_BT_ATT_ERR_TO_STR is not set CONFIG_BT_ATT_TX_COUNT=3 CONFIG_BT_ATT_PREPARE_COUNT=0 # CONFIG_BT_ATT_SENT_CB_AFTER_TX is not set CONFIG_BT_GATT_SERVICE_CHANGED=y # CONFIG_BT_GATT_DYNAMIC_DB is not set CONFIG_BT_GATT_CACHING=y # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y # CONFIG_BT_GATT_CLIENT is not set CONFIG_BT_GATT_READ_MULTIPLE=y CONFIG_BT_GATT_READ_MULT_VAR_LEN=y CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24 CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40 CONFIG_BT_PERIPHERAL_PREF_LATENCY=0 CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42 # CONFIG_BT_GATT_AUTHORIZATION_CUSTOM is not set CONFIG_BT_MAX_PAIRED=0 CONFIG_BT_CREATE_CONN_TIMEOUT=3 CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000 CONFIG_BT_CONN_PARAM_RETRY_COUNT=3 CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000 # CONFIG_BT_DEVICE_NAME_DYNAMIC is not set CONFIG_BT_DEVICE_NAME="CustomDevice" # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set CONFIG_BT_DEVICE_APPEARANCE=0 CONFIG_BT_ID_MAX=1 # CONFIG_BT_DF is not set # CONFIG_BT_HOST_CCM is not set # CONFIG_BT_LOG_SNIFFER_INFO is not set # CONFIG_BT_TESTING is not set # CONFIG_BT_CLASSIC is not set # CONFIG_BT_HCI_VS_EVT_USER is not set # end of BLE over nRF RPC # end of Bluetooth Low Energy # # DFU # # CONFIG_DFU_MULTI_IMAGE is not set # CONFIG_DFU_TARGET is not set # end of DFU # CONFIG_ESB is not set # CONFIG_EMDS is not set # # Peripheral CPU DFU (PCD) # # CONFIG_PCD is not set # CONFIG_PCD_APP is not set CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046 # CONFIG_PCD_NET is not set # end of Peripheral CPU DFU (PCD) # # Networking # # # Application protocols # # CONFIG_NRF_CLOUD is not set # CONFIG_REST_CLIENT is not set # CONFIG_DOWNLOAD_CLIENT is not set # CONFIG_DOWNLOADER is not set # CONFIG_AWS_IOT is not set # CONFIG_AWS_JOBS is not set # CONFIG_AZURE_IOT_HUB is not set # # Self-Registration (Zi ZHu Ce) # # end of Self-Registration (Zi ZHu Ce) # CONFIG_ICAL_PARSER is not set # CONFIG_FTP_CLIENT is not set # CONFIG_LWM2M_CLIENT_UTILS is not set # CONFIG_MQTT_HELPER is not set # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set # end of Application protocols # CONFIG_OPENTHREAD_RPC is not set # end of Networking # # NFC # # CONFIG_NFC_NDEF is not set # CONFIG_NFC_NDEF_PARSER is not set # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set # CONFIG_NFC_T2T_PARSER is not set # CONFIG_NFC_T4T_NDEF_FILE is not set # CONFIG_NFC_T4T_ISODEP is not set # CONFIG_NFC_T4T_APDU is not set # CONFIG_NFC_T4T_CC_FILE is not set # CONFIG_NFC_T4T_HL_PROCEDURE is not set # CONFIG_NFC_PLATFORM is not set # CONFIG_NFC_TNEP_TAG is not set # CONFIG_NFC_TNEP_POLLER is not set # CONFIG_NFC_TNEP_CH is not set # CONFIG_NFC_RPC is not set # end of NFC # CONFIG_APP_EVENT_MANAGER is not set # CONFIG_NRF_PROFILER is not set # CONFIG_FW_INFO is not set # # Debug # # CONFIG_CPU_LOAD is not set # CONFIG_PPI_TRACE is not set # end of Debug # CONFIG_SHELL_BT_NUS is not set # # Multiprotocol service layer (MPSL) # # CONFIG_MPSL_FEM_ONLY is not set CONFIG_MPSL_FEM_API_AVAILABLE=y # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y CONFIG_MPSL_FEM_LOG_LEVEL=3 CONFIG_MPSL_THREAD_COOP_PRIO=6 CONFIG_MPSL_TIMESLOT_SESSION_COUNT=1 # CONFIG_MPSL_ASSERT_HANDLER is not set CONFIG_MPSL_DYNAMIC_INTERRUPTS=y CONFIG_MPSL_LOW_PRIO_IRQN=28 CONFIG_MPSL_HFCLK_LATENCY=854 CONFIG_MPSL_CALIBRATION_PERIOD=4000 CONFIG_MPSL_INIT_PRIORITY=40 # CONFIG_MPSL_LOG_LEVEL_OFF is not set # CONFIG_MPSL_LOG_LEVEL_ERR is not set # CONFIG_MPSL_LOG_LEVEL_WRN is not set # CONFIG_MPSL_LOG_LEVEL_INF is not set CONFIG_MPSL_LOG_LEVEL_DBG=y # CONFIG_MPSL_LOG_LEVEL_DEFAULT is not set CONFIG_MPSL_LOG_LEVEL=4 # CONFIG_MPSL_PIN_DEBUG is not set # CONFIG_MPSL_USE_EXTERNAL_CLOCK_CONTROL is not set # end of Multiprotocol service layer (MPSL) # # Partition Manager # CONFIG_PARTITION_MANAGER_ENABLED=y CONFIG_FLASH_MAP_CUSTOM=y CONFIG_SRAM_SIZE=188 CONFIG_SRAM_BASE_ADDRESS=0x20000000 CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0 CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0 # # Zephyr subsystem configurations # # end of Zephyr subsystem configurations # # NCS subsystem configurations # CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y CONFIG_PM_EXTERNAL_FLASH_BASE=0 CONFIG_PM_EXTERNAL_FLASH_PATH="" CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0 # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set CONFIG_PM_SRAM_BASE=0x20000000 CONFIG_PM_SRAM_SIZE=0x2f000 # end of Partition Manager # # nRF RPC (Remote Procedure Call) library # # end of nRF RPC (Remote Procedure Call) library # # Full Modem Firmware Update Management(FMFU) # # end of Full Modem Firmware Update Management(FMFU) # # Additional MCUmgr configuration # # # Additional MCUmgr group configuration # # # Additional MCUmgr OS group management functionality # # end of Additional MCUmgr OS group management functionality # end of Additional MCUmgr group configuration # end of Additional MCUmgr configuration # CONFIG_CAF is not set # # Nordic IEEE 802.15.4 # # end of Nordic IEEE 802.15.4 # CONFIG_DM_MODULE is not set # # nRF Security # # CONFIG_NORDIC_SECURITY_BACKEND is not set CONFIG_NRF_SECURITY=y # # Nordic-added meta types # CONFIG_PSA_HAS_CIPHER_SUPPORT=y CONFIG_PSA_HAS_KEY_SUPPORT=y CONFIG_PSA_HAS_MAC_SUPPORT=y # # Nordic added alg types # # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set # CONFIG_PSA_WANT_ALG_ED25519PH is not set # CONFIG_PSA_WANT_ALG_ED448PH is not set # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_HMAC is not set # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_CMAC is not set # CONFIG_PSA_WANT_ALG_SRP_6 is not set # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set # CONFIG_PSA_WANT_ALG_XTS is not set CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y # CONFIG_PSA_WANT_ALG_CHACHA20 is not set # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set # CONFIG_PSA_WANT_ALG_AES_KW is not set # CONFIG_PSA_WANT_ALG_AES_KWP is not set # CONFIG_PSA_WANT_ALG_WPA3_SAE_PT is not set # CONFIG_PSA_WANT_ALG_WPA3_SAE is not set # # Nordic added ECC curve types # # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set # # Nordic addded RNG configuration # CONFIG_PSA_WANT_GENERATE_RANDOM=y # # Nordic added key types # # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set CONFIG_MBEDTLS_PSA_CRYPTO_BUILTIN_KEYS=y CONFIG_MBEDTLS_CFG_FILE="nrf-config.h" CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG=y CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-config.h" CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-user-config.h" CONFIG_MBEDTLS_ENTROPY_POLL=y CONFIG_MBEDTLS_PSA_CRYPTO_C=y CONFIG_PSA_CORE_OBERON=y # CONFIG_PSA_CORE_LITE is not set # # PSA Driver Support # CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y # CONFIG_PSA_CRYPTO_DRIVER_OBERON is not set CONFIG_PSA_CRYPTO_DRIVER_CRACEN=y # # Choose DRBG algorithm # CONFIG_PSA_WANT_ALG_CTR_DRBG=y # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set CONFIG_PSA_USE_CTR_DRBG_DRIVER=y # end of Choose DRBG algorithm # # CryptoCell PSA Driver Configuration # # end of CryptoCell PSA Driver Configuration # # CRACEN PSA Driver Configuration # CONFIG_PSA_USE_CRACEN_CIPHER_DRIVER=y CONFIG_PSA_USE_CRACEN_AEAD_DRIVER=y CONFIG_PSA_USE_CRACEN_HASH_DRIVER=y CONFIG_PSA_USE_CRACEN_MAC_DRIVER=y CONFIG_PSA_USE_CRACEN_KEY_AGREEMENT_DRIVER=y CONFIG_PSA_USE_CRACEN_ASYMMETRIC_DRIVER=y CONFIG_PSA_USE_CRACEN_KEY_MANAGEMENT_DRIVER=y CONFIG_PSA_USE_CRACEN_KEY_DERIVATION_DRIVER=y CONFIG_PSA_USE_CRACEN_PAKE_DRIVER=y CONFIG_PSA_USE_CRACEN_ASYMMETRIC_SIGNATURE_DRIVER=y CONFIG_PSA_USE_CRACEN_CTR_DRBG_DRIVER=y # end of CRACEN PSA Driver Configuration # # AES key size configuration # CONFIG_PSA_WANT_AES_KEY_SIZE_128=y CONFIG_PSA_WANT_AES_KEY_SIZE_192=y CONFIG_PSA_WANT_AES_KEY_SIZE_256=y # end of AES key size configuration # # RSA key size configuration # # CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_2048 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set CONFIG_PSA_MAX_RSA_KEY_BITS=0 # end of RSA key size configuration CONFIG_PSA_ACCEL_CMAC_AES_128=y CONFIG_PSA_ACCEL_CMAC_AES_192=y CONFIG_PSA_ACCEL_CMAC_AES_256=y CONFIG_PSA_ACCEL_ECB_NO_PADDING_AES_128=y CONFIG_PSA_ACCEL_ECB_NO_PADDING_AES_192=y CONFIG_PSA_ACCEL_ECB_NO_PADDING_AES_256=y CONFIG_PSA_ACCEL_GENERATE_RANDOM=y CONFIG_CRACEN_HW_PRESENT=y CONFIG_CRACEN_HW_VERSION_BASE=y # CONFIG_CRACEN_LOG_LEVEL_OFF is not set # CONFIG_CRACEN_LOG_LEVEL_ERR is not set # CONFIG_CRACEN_LOG_LEVEL_WRN is not set # CONFIG_CRACEN_LOG_LEVEL_INF is not set # CONFIG_CRACEN_LOG_LEVEL_DBG is not set CONFIG_CRACEN_LOG_LEVEL_DEFAULT=y CONFIG_CRACEN_LOG_LEVEL=3 # CONFIG_CRACEN_LOAD_MICROCODE is not set CONFIG_CRACEN_LIB_KMU=y CONFIG_CRACEN_IKG_SEED_LOAD=y CONFIG_CRACEN_IKG_SEED_KMU_SLOT=183 CONFIG_PSA_NEED_CRACEN_ECB_NO_PADDING_AES=y CONFIG_PSA_NEED_CRACEN_CIPHER_DRIVER=y CONFIG_PSA_NEED_CRACEN_CMAC=y CONFIG_PSA_NEED_CRACEN_MAC_DRIVER=y CONFIG_PSA_NEED_CRACEN_CTR_DRBG_DRIVER=y CONFIG_PSA_NEED_CRACEN_KMU_DRIVER=y # # PSA API support # CONFIG_MBEDTLS_USE_PSA_CRYPTO=y # CONFIG_MBEDTLS_PSA_STATIC_KEY_SLOTS is not set # end of PSA API support CONFIG_MBEDTLS_PLATFORM_MEMORY=y CONFIG_MBEDTLS_PLATFORM_C=y CONFIG_MBEDTLS_MEMORY_C=y CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y CONFIG_MBEDTLS_THREADING_C=y CONFIG_MBEDTLS_BASE64_C=y CONFIG_MBEDTLS_OID_C=y CONFIG_MBEDTLS_ASN1_WRITE_C=y CONFIG_MBEDTLS_ASN1_PARSE_C=y CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y CONFIG_MBEDTLS_THREADING_ALT=y CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1 CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y # CONFIG_NRF_SECURITY_ADVANCED is not set # # Legacy mbed TLS crypto APIs # CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6 CONFIG_MBEDTLS_MPI_MAX_SIZE=256 # CONFIG_MBEDTLS_CIPHER_C is not set # CONFIG_MBEDTLS_PK_C is not set # CONFIG_MBEDTLS_PEM_PARSE_C is not set # CONFIG_MBEDTLS_PEM_WRITE_C is not set # end of Legacy mbed TLS crypto APIs # end of nRF Security # # Audio Modules # # CONFIG_AUDIO_MODULE_TEST is not set # # Log levels # # end of Log levels # end of Audio Modules # # Audio Modules # # CONFIG_AUDIO_MODULE_TEMPLATE is not set # end of Audio Modules # CONFIG_UART_ASYNC_ADAPTER is not set # CONFIG_TRUSTED_STORAGE is not set # # Logging over RPC # # CONFIG_LOG_FORWARDER_RPC is not set # CONFIG_LOG_BACKEND_RPC is not set # end of Logging over RPC # CONFIG_SUIT is not set # CONFIG_DULT is not set # CONFIG_NRF_COMPRESS is not set # # MCUboot IDs (informative only, do not change) # CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0 CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1 CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1 CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1 CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1 # end of MCUboot IDs (informative only, do not change) # end of Subsystems # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set # CONFIG_WFA_QT_LOG_LEVEL_INF is not set # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y CONFIG_WFA_QT_LOG_LEVEL=3 # CONFIG_WFA_QT_CONTROL_APP is not set CONFIG_WFA_QT_THREAD_STACK_SIZE=5200 CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000 CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0" CONFIG_WPAS_READY_TIMEOUT_MS=10000 # # Libraries # # CONFIG_APP_JWT is not set # # Binary libraries # # end of Binary libraries # CONFIG_AT_MONITOR is not set # CONFIG_LTE_LINK_CONTROL is not set CONFIG_FPROTECT_BLOCK_SIZE=0x1000 # CONFIG_FPROTECT is not set # CONFIG_AT_CMD_CUSTOM is not set # CONFIG_DK_LIBRARY is not set # CONFIG_AT_CMD_PARSER is not set # CONFIG_AT_PARSER is not set CONFIG_MULTITHREADING_LOCK=y # CONFIG_RESET_ON_FATAL_ERROR is not set # CONFIG_SMS is not set # CONFIG_DATE_TIME is not set # CONFIG_HW_ID_LIBRARY is not set # CONFIG_RAM_POWER_DOWN_LIBRARY is not set # CONFIG_WAVE_GEN_LIB is not set CONFIG_HW_UNIQUE_KEY_SUPPORTED=y # CONFIG_HW_UNIQUE_KEY is not set CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0 # CONFIG_LOCATION is not set # CONFIG_QOS is not set # CONFIG_SFLOAT is not set # CONFIG_CONTIN_ARRAY is not set # CONFIG_PCM_MIX is not set # CONFIG_TONE is not set # CONFIG_PSCM is not set # CONFIG_DATA_FIFO is not set # CONFIG_FEM_AL_LIB is not set # CONFIG_SAMPLE_RATE_CONVERTER is not set CONFIG_NCS_BOOT_BANNER=y CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="My Application" CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK" CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS" # end of Libraries # # Device Drivers # # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set # CONFIG_FLASH_RPC is not set CONFIG_CLOCK_CONTROL_MPSL=y # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_RPC is not set CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL=y # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_RPC_CONTROLLER is not set CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=1 # CONFIG_ETH_RTT is not set # CONFIG_SENSOR is not set # CONFIG_NRF_SW_LPUART is not set CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1 # end of Device Drivers # # External libraries # # end of External libraries # # Test # # CONFIG_UNITY is not set # # Mocks # # CONFIG_MOCK_NRF_MODEM_AT is not set # CONFIG_MOCK_NRF_RPC is not set # end of Mocks # end of Test # end of Nordic nRF Connect CONFIG_ZEPHYR_NRF_MODULE=y # end of nrf (C:/ncs/v3.0.2/nrf) # # hostap (C:/ncs/v3.0.2/modules/lib/hostap) # # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set CONFIG_ZEPHYR_HOSTAP_MODULE=y # end of hostap (C:/ncs/v3.0.2/modules/lib/hostap) # # mcuboot (C:/ncs/v3.0.2/bootloader/mcuboot) # # # MCUboot # CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=16 CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=16 # CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set # end of MCUboot CONFIG_ZEPHYR_MCUBOOT_MODULE=y # end of mcuboot (C:/ncs/v3.0.2/bootloader/mcuboot) # # mbedtls (C:/ncs/v3.0.2/modules/crypto/mbedtls) # CONFIG_ZEPHYR_MBEDTLS_MODULE=y CONFIG_PSA_CRYPTO_CLIENT=y # CONFIG_PSA_CRYPTO_ENABLE_ALL is not set # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set # CONFIG_PSA_WANT_ALG_CCM is not set # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set CONFIG_PSA_WANT_ALG_CMAC=y # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set # CONFIG_PSA_WANT_ALG_CTR is not set # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set # CONFIG_PSA_WANT_ALG_ECDH is not set # CONFIG_PSA_WANT_ALG_ECDSA is not set # CONFIG_PSA_WANT_ALG_JPAKE is not set # CONFIG_PSA_WANT_ALG_GCM is not set # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set # CONFIG_PSA_WANT_ALG_HMAC is not set # CONFIG_PSA_WANT_ALG_MD5 is not set # CONFIG_PSA_WANT_ALG_PBKDF2_AES_CMAC_PRF_128 is not set # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set # CONFIG_PSA_WANT_ALG_RSA_PSS is not set # CONFIG_PSA_WANT_ALG_SHA_1 is not set # CONFIG_PSA_WANT_ALG_SHA_224 is not set # CONFIG_PSA_WANT_ALG_SHA_256 is not set # CONFIG_PSA_WANT_ALG_SHA_384 is not set # CONFIG_PSA_WANT_ALG_SHA_512 is not set # CONFIG_PSA_WANT_ALG_SHA3_224 is not set # CONFIG_PSA_WANT_ALG_SHA3_256 is not set # CONFIG_PSA_WANT_ALG_SHA3_384 is not set # CONFIG_PSA_WANT_ALG_SHA3_512 is not set # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set CONFIG_PSA_WANT_KEY_TYPE_AES=y # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_DERIVE is not set # end of mbedtls (C:/ncs/v3.0.2/modules/crypto/mbedtls) # # oberon-psa-crypto (C:/ncs/v3.0.2/modules/crypto/oberon-psa-crypto) # CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y # end of oberon-psa-crypto (C:/ncs/v3.0.2/modules/crypto/oberon-psa-crypto) # # trusted-firmware-m (C:/ncs/v3.0.2/modules/tee/tf-m/trusted-firmware-m) # CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y # end of trusted-firmware-m (C:/ncs/v3.0.2/modules/tee/tf-m/trusted-firmware-m) CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y # # cjson (C:/ncs/v3.0.2/modules/lib/cjson) # # CONFIG_CJSON_LIB is not set CONFIG_ZEPHYR_CJSON_MODULE=y # end of cjson (C:/ncs/v3.0.2/modules/lib/cjson) # # azure-sdk-for-c (C:/ncs/v3.0.2/modules/lib/azure-sdk-for-c) # # CONFIG_AZURE_SDK is not set CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y # end of azure-sdk-for-c (C:/ncs/v3.0.2/modules/lib/azure-sdk-for-c) # # cirrus-logic (C:/ncs/v3.0.2/modules/hal/cirrus-logic) # # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y # end of cirrus-logic (C:/ncs/v3.0.2/modules/hal/cirrus-logic) # # openthread (C:/ncs/v3.0.2/modules/lib/openthread) # # CONFIG_OPENTHREAD is not set CONFIG_ZEPHYR_OPENTHREAD_MODULE=y # end of openthread (C:/ncs/v3.0.2/modules/lib/openthread) # # suit-generator (C:/ncs/v3.0.2/modules/lib/suit-generator) # CONFIG_SUIT_ENVELOPE_TEMPLATE_FILENAME="" CONFIG_SUIT_ENVELOPE_TARGET="" CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex" # CONFIG_SUIT_RECOVERY is not set # CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set # CONFIG_SUIT_DFU_CACHE_EXTRACT_IMAGE is not set # CONFIG_SUIT_ENVELOPE_TARGET_ENCRYPT is not set # CONFIG_SUIT_ENVELOPE_TARGET_SIGN is not set CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y # end of suit-generator (C:/ncs/v3.0.2/modules/lib/suit-generator) # # suit-processor (C:/ncs/v3.0.2/modules/lib/suit-processor) # # CONFIG_SUIT_PROCESSOR is not set CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y # end of suit-processor (C:/ncs/v3.0.2/modules/lib/suit-processor) # # memfault-firmware-sdk (C:/ncs/v3.0.2/modules/lib/memfault-firmware-sdk) # # CONFIG_MEMFAULT is not set CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y # end of memfault-firmware-sdk (C:/ncs/v3.0.2/modules/lib/memfault-firmware-sdk) # # coremark (C:/ncs/v3.0.2/modules/benchmark/coremark) # # CONFIG_COREMARK is not set CONFIG_ZEPHYR_COREMARK_MODULE=y # end of coremark (C:/ncs/v3.0.2/modules/benchmark/coremark) # # canopennode (C:/ncs/v3.0.2/modules/lib/canopennode) # CONFIG_ZEPHYR_CANOPENNODE_MODULE=y # end of canopennode (C:/ncs/v3.0.2/modules/lib/canopennode) # # chre (C:/ncs/v3.0.2/modules/lib/chre) # CONFIG_ZEPHYR_CHRE_MODULE=y # CONFIG_CHRE is not set # end of chre (C:/ncs/v3.0.2/modules/lib/chre) # # lz4 (C:/ncs/v3.0.2/modules/lib/lz4) # CONFIG_ZEPHYR_LZ4_MODULE=y # CONFIG_LZ4 is not set # end of lz4 (C:/ncs/v3.0.2/modules/lib/lz4) # # nanopb (C:/ncs/v3.0.2/modules/lib/nanopb) # CONFIG_ZEPHYR_NANOPB_MODULE=y # CONFIG_NANOPB is not set # end of nanopb (C:/ncs/v3.0.2/modules/lib/nanopb) CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y # # zscilib (C:/ncs/v3.0.2/modules/lib/zscilib) # # CONFIG_ZSL is not set CONFIG_ZEPHYR_ZSCILIB_MODULE=y # end of zscilib (C:/ncs/v3.0.2/modules/lib/zscilib) # # cmsis (C:/ncs/v3.0.2/modules/hal/cmsis) # CONFIG_ZEPHYR_CMSIS_MODULE=y CONFIG_HAS_CMSIS_CORE=y CONFIG_HAS_CMSIS_CORE_M=y # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set # end of cmsis (C:/ncs/v3.0.2/modules/hal/cmsis) # # cmsis-dsp (C:/ncs/v3.0.2/modules/lib/cmsis-dsp) # CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y # CONFIG_CMSIS_DSP is not set # end of cmsis-dsp (C:/ncs/v3.0.2/modules/lib/cmsis-dsp) # # cmsis-nn (C:/ncs/v3.0.2/modules/lib/cmsis-nn) # CONFIG_ZEPHYR_CMSIS_NN_MODULE=y # CONFIG_CMSIS_NN is not set # end of cmsis-nn (C:/ncs/v3.0.2/modules/lib/cmsis-nn) # # fatfs (C:/ncs/v3.0.2/modules/fs/fatfs) # CONFIG_ZEPHYR_FATFS_MODULE=y # end of fatfs (C:/ncs/v3.0.2/modules/fs/fatfs) # # hal_nordic (C:/ncs/v3.0.2/modules/hal/nordic) # CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y CONFIG_HAS_NORDIC_DRIVERS=y # # Nordic drivers # # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set # CONFIG_NRF_802154_RADIO_DRIVER is not set # CONFIG_NRF_802154_SER_RADIO is not set # end of Nordic drivers CONFIG_HAS_NRFX=y # # nrfx drivers # # # nrfx drivers logging # # CONFIG_NRFX_DPPI_LOG is not set # CONFIG_NRFX_GPIOTE_LOG is not set # CONFIG_NRFX_GRTC_LOG is not set # CONFIG_NRFX_PPIB_LOG is not set # CONFIG_NRFX_SPIM_LOG is not set # CONFIG_NRFX_WDT_LOG is not set # end of nrfx drivers logging # CONFIG_NRFX_CLOCK is not set # CONFIG_NRFX_COMP is not set CONFIG_NRFX_DPPI=y CONFIG_NRFX_DPPI00=y CONFIG_NRFX_DPPI10=y CONFIG_NRFX_DPPI20=y CONFIG_NRFX_DPPI30=y # CONFIG_NRFX_EGU10 is not set # CONFIG_NRFX_EGU20 is not set CONFIG_NRFX_GPIOTE=y CONFIG_NRFX_GPIOTE20=y CONFIG_NRFX_GPIOTE30=y CONFIG_NRFX_GPPI=y CONFIG_NRFX_GRTC=y # CONFIG_NRFX_I2S20 is not set # CONFIG_NRFX_LPCOMP is not set # CONFIG_NRFX_NFCT is not set # CONFIG_NRFX_PDM20 is not set # CONFIG_NRFX_PDM21 is not set # CONFIG_NRFX_POWER is not set CONFIG_NRFX_PPIB=y CONFIG_NRFX_PPIB00=y CONFIG_NRFX_PPIB01=y CONFIG_NRFX_PPIB10=y CONFIG_NRFX_PPIB11=y CONFIG_NRFX_PPIB20=y CONFIG_NRFX_PPIB21=y CONFIG_NRFX_PPIB22=y CONFIG_NRFX_PPIB30=y # CONFIG_NRFX_PWM20 is not set # CONFIG_NRFX_PWM21 is not set # CONFIG_NRFX_PWM22 is not set # CONFIG_NRFX_QDEC20 is not set # CONFIG_NRFX_QDEC21 is not set CONFIG_NRFX_RRAMC=y # CONFIG_NRFX_SAADC is not set CONFIG_NRFX_SPIM=y CONFIG_NRFX_SPIM00=y # CONFIG_NRFX_SPIM20 is not set # CONFIG_NRFX_SPIM21 is not set # CONFIG_NRFX_SPIM22 is not set # CONFIG_NRFX_SPIM30 is not set # CONFIG_NRFX_SPIS00 is not set # CONFIG_NRFX_SPIS20 is not set # CONFIG_NRFX_SPIS21 is not set # CONFIG_NRFX_SPIS22 is not set # CONFIG_NRFX_SPIS30 is not set # CONFIG_NRFX_SYSTICK is not set # CONFIG_NRFX_TEMP is not set # CONFIG_NRFX_TIMER00 is not set # CONFIG_NRFX_TIMER10 is not set # CONFIG_NRFX_TIMER20 is not set # CONFIG_NRFX_TIMER21 is not set # CONFIG_NRFX_TIMER22 is not set # CONFIG_NRFX_TIMER23 is not set # CONFIG_NRFX_TIMER24 is not set # CONFIG_NRFX_TWIM20 is not set # CONFIG_NRFX_TWIM21 is not set # CONFIG_NRFX_TWIM22 is not set # CONFIG_NRFX_TWIM30 is not set # CONFIG_NRFX_TWIS20 is not set # CONFIG_NRFX_TWIS21 is not set # CONFIG_NRFX_TWIS22 is not set # CONFIG_NRFX_TWIS30 is not set # CONFIG_NRFX_UARTE00 is not set # CONFIG_NRFX_UARTE20 is not set # CONFIG_NRFX_UARTE21 is not set # CONFIG_NRFX_UARTE22 is not set # CONFIG_NRFX_UARTE30 is not set CONFIG_NRFX_WDT=y # CONFIG_NRFX_WDT30 is not set CONFIG_NRFX_WDT31=y # # Peripheral Resource Sharing module # # CONFIG_NRFX_PRS_BOX_0 is not set # CONFIG_NRFX_PRS_BOX_1 is not set # CONFIG_NRFX_PRS_BOX_2 is not set # CONFIG_NRFX_PRS_BOX_3 is not set # CONFIG_NRFX_PRS_BOX_4 is not set # end of Peripheral Resource Sharing module CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_config_reserved_resources_ncs.h" # end of nrfx drivers # end of hal_nordic (C:/ncs/v3.0.2/modules/hal/nordic) # # hal_st (C:/ncs/v3.0.2/modules/hal/st) # CONFIG_ZEPHYR_HAL_ST_MODULE=y # end of hal_st (C:/ncs/v3.0.2/modules/hal/st) # # hal_tdk (C:/ncs/v3.0.2/modules/hal/tdk) # CONFIG_ZEPHYR_HAL_TDK_MODULE=y # # TDK drivers # # CONFIG_TDK_HAL is not set # end of TDK drivers # end of hal_tdk (C:/ncs/v3.0.2/modules/hal/tdk) CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y # # liblc3 (C:/ncs/v3.0.2/modules/lib/liblc3) # CONFIG_ZEPHYR_LIBLC3_MODULE=y # end of liblc3 (C:/ncs/v3.0.2/modules/lib/liblc3) CONFIG_ZEPHYR_LIBMETAL_MODULE=y # # littlefs (C:/ncs/v3.0.2/modules/fs/littlefs) # CONFIG_ZEPHYR_LITTLEFS_MODULE=y # end of littlefs (C:/ncs/v3.0.2/modules/fs/littlefs) # # loramac-node (C:/ncs/v3.0.2/modules/lib/loramac-node) # CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set # end of loramac-node (C:/ncs/v3.0.2/modules/lib/loramac-node) # # lvgl (C:/ncs/v3.0.2/modules/lib/gui/lvgl) # CONFIG_ZEPHYR_LVGL_MODULE=y # end of lvgl (C:/ncs/v3.0.2/modules/lib/gui/lvgl) CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y # # nrf_wifi (C:/ncs/v3.0.2/modules/lib/nrf_wifi) # CONFIG_ZEPHYR_NRF_WIFI_MODULE=y # CONFIG_NRF70_BUSLIB is not set # end of nrf_wifi (C:/ncs/v3.0.2/modules/lib/nrf_wifi) CONFIG_ZEPHYR_OPEN_AMP_MODULE=y # # percepio (C:/ncs/v3.0.2/modules/debug/percepio) # # # Percepio Tracealyzer support can be enabled from the tracing subsystem # # CONFIG_PERCEPIO_DFM is not set CONFIG_ZEPHYR_PERCEPIO_MODULE=y # end of percepio (C:/ncs/v3.0.2/modules/debug/percepio) # # picolibc (C:/ncs/v3.0.2/modules/lib/picolibc) # # CONFIG_PICOLIBC_MODULE is not set CONFIG_ZEPHYR_PICOLIBC_MODULE=y # end of picolibc (C:/ncs/v3.0.2/modules/lib/picolibc) # # segger (C:/ncs/v3.0.2/modules/debug/segger) # CONFIG_ZEPHYR_SEGGER_MODULE=y CONFIG_HAS_SEGGER_RTT=y # CONFIG_USE_SEGGER_RTT is not set # end of segger (C:/ncs/v3.0.2/modules/debug/segger) CONFIG_ZEPHYR_TINYCRYPT_MODULE=y # # uoscore-uedhoc (C:/ncs/v3.0.2/modules/lib/uoscore-uedhoc) # CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y # end of uoscore-uedhoc (C:/ncs/v3.0.2/modules/lib/uoscore-uedhoc) # # zcbor (C:/ncs/v3.0.2/modules/lib/zcbor) # CONFIG_ZEPHYR_ZCBOR_MODULE=y CONFIG_ZCBOR=y # CONFIG_ZCBOR_CANONICAL is not set # CONFIG_ZCBOR_STOP_ON_ERROR is not set # CONFIG_ZCBOR_VERBOSE is not set CONFIG_ZCBOR_ASSERT=y CONFIG_ZCBOR_MAX_STR_LEN=256 # end of zcbor (C:/ncs/v3.0.2/modules/lib/zcbor) # # nrfxlib (C:/ncs/v3.0.2/nrfxlib) # # # Nordic nrfxlib # # # nrf_modem (Modem library) # CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8 # end of nrf_modem (Modem library) # CONFIG_NFC_T2T_NRFXLIB is not set # CONFIG_NFC_T4T_NRFXLIB is not set CONFIG_MPSL=y CONFIG_MPSL_BUILD_TYPE_LIB=y CONFIG_MPSL_LIB_DIR="nrf54l" CONFIG_MPSL_LIB_FLOAT_ABI_DIR="soft-float" # # Crypto libraries for nRF5x SOCs. # # CONFIG_NRF_OBERON is not set # CONFIG_NRF_CC310_BL is not set # end of Crypto libraries for nRF5x SOCs. # CONFIG_NRF_RPC is not set CONFIG_NRF_802154_SOURCE_NRFXLIB=y # CONFIG_NRF_DM is not set # CONFIG_NRF_FUEL_GAUGE is not set # end of Nordic nrfxlib CONFIG_ZEPHYR_NRFXLIB_MODULE=y # end of nrfxlib (C:/ncs/v3.0.2/nrfxlib) CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y # # connectedhomeip (C:/ncs/v3.0.2/modules/lib/matter) # # CONFIG_CHIP is not set CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y # end of connectedhomeip (C:/ncs/v3.0.2/modules/lib/matter) # CONFIG_LIBMETAL is not set # CONFIG_LVGL is not set # CONFIG_HAS_MEC_HAL is not set # CONFIG_HAS_MPFS_HAL is not set # CONFIG_HAS_MEC5_HAL is not set # CONFIG_OPENAMP is not set # CONFIG_MIPI_SYST_LIB is not set # CONFIG_HAS_TELINK_DRIVERS is not set # CONFIG_TINYCRYPT is not set CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="C:/ncs/v3.0.2/bootloader/mcuboot/root-ed25519.pem" CONFIG_MCUBOOT_ENCRYPTION_KEY_FILE="" CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="0.1.0+0" # CONFIG_MCUBOOT_IMGTOOL_OVERWRITE_ONLY is not set CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS="" # # On board MCUboot operation mode # # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_RAM_LOAD is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_FIRMWARE_UPDATER is not set CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y # CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set CONFIG_MCUBOOT_BOOTLOADER_USES_SHA512=y # end of On board MCUboot operation mode CONFIG_MCUBOOT_BOOTUTIL_LIB=y CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT=y CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3 # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set # # Unavailable modules, please install those via the project manifest. # # # hal_gigadevice module not available. # # # Trusted-firmware-a module not available. # # # THRIFT module not available. # # CONFIG_ACPI is not set # end of Modules CONFIG_BOARD="nrf54l15dk" CONFIG_BOARD_REVISION="" CONFIG_BOARD_TARGET="nrf54l15dk/nrf54l15/cpuapp" # CONFIG_NET_DRIVERS is not set CONFIG_BOARD_NRF54L15DK=y CONFIG_BOARD_NRF54L15DK_NRF54L15_CPUAPP=y CONFIG_BOARD_QUALIFIERS="nrf54l15/cpuapp" # # Board Options # # end of Board Options # # Hardware Configuration # CONFIG_SOC="nrf54l15" CONFIG_SOC_SERIES="nrf54l" CONFIG_SOC_FAMILY="nordic_nrf" CONFIG_SOC_FAMILY_NORDIC_NRF=y CONFIG_SOC_SERIES_NRF54LX=y CONFIG_SOC_NRF54L15=y CONFIG_SOC_NRF54L15_CPUAPP=y # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set CONFIG_HAS_HW_NRF_CLOCK=y CONFIG_HAS_HW_NRF_DPPIC=y CONFIG_HAS_HW_NRF_GPIO0=y CONFIG_HAS_HW_NRF_GPIO1=y CONFIG_HAS_HW_NRF_GPIO2=y CONFIG_HAS_HW_NRF_GPIOTE20=y CONFIG_HAS_HW_NRF_GPIOTE30=y CONFIG_HAS_HW_NRF_GRTC=y CONFIG_HAS_HW_NRF_PWM20=y CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y CONFIG_HAS_HW_NRF_RADIO_CS=y CONFIG_HAS_HW_NRF_RADIO_DFE=y CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y CONFIG_HAS_HW_NRF_SAADC=y CONFIG_HAS_HW_NRF_SPIM00=y CONFIG_HAS_HW_NRF_TEMP=y CONFIG_HAS_HW_NRF_UARTE20=y CONFIG_HAS_HW_NRF_WDT31=y CONFIG_HAS_NORDIC_RAM_CTRL=y # CONFIG_NRF_FORCE_RAM_ON_REBOOT is not set # CONFIG_NRF_SYS_EVENT is not set # CONFIG_SOC_NRF54H20_GPD is not set CONFIG_SOC_NRF54L_CPUAPP_COMMON=y # CONFIG_SOC_NRF54LX_DISABLE_FICR_TRIMCNF is not set # CONFIG_SOC_NRF54LX_SKIP_GLITCHDETECTOR_DISABLE is not set # CONFIG_SOC_NRF_FORCE_CONSTLAT is not set CONFIG_NRF_SOC_SECURE_SUPPORTED=y # CONFIG_NFCT_PINS_AS_GPIOS is not set CONFIG_NRF_APPROTECT_DISABLE=y # CONFIG_NRF_APPROTECT_LOCK is not set # CONFIG_NRF_APPROTECT_USER_HANDLING is not set CONFIG_NRF_SECURE_APPROTECT_DISABLE=y # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set # CONFIG_NRF_TRACE_PORT is not set CONFIG_GPIO_INIT_PRIORITY=40 # CONFIG_SOC_LOG_LEVEL_OFF is not set # CONFIG_SOC_LOG_LEVEL_ERR is not set # CONFIG_SOC_LOG_LEVEL_WRN is not set # CONFIG_SOC_LOG_LEVEL_INF is not set # CONFIG_SOC_LOG_LEVEL_DBG is not set CONFIG_SOC_LOG_LEVEL_DEFAULT=y CONFIG_SOC_LOG_LEVEL=3 # end of Hardware Configuration CONFIG_SOC_COMPATIBLE_NRF=y CONFIG_SOC_COMPATIBLE_NRF54LX=y CONFIG_ARCH="arm" # CONFIG_EXTRA_EXCEPTION_INFO is not set CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y CONFIG_CPU_CORTEX=y CONFIG_KOBJECT_TEXT_AREA=256 CONFIG_ARM_MPU=y CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32 CONFIG_MPU_ALLOW_FLASH_WRITE=y # # ARM Options # CONFIG_CPU_CORTEX_M=y # CONFIG_ARM_ZIMAGE_HEADER is not set CONFIG_ISA_THUMB2=y CONFIG_ASSEMBLER_ISA_THUMB2=y CONFIG_COMPILER_ISA_THUMB2=y CONFIG_STACK_ALIGN_DOUBLE_WORD=y # CONFIG_RUNTIME_NMI is not set # CONFIG_PLATFORM_SPECIFIC_INIT is not set CONFIG_FAULT_DUMP=2 CONFIG_BUILTIN_STACK_GUARD=y CONFIG_ARM_STACK_PROTECTION=y CONFIG_FP16=y CONFIG_FP16_IEEE=y # CONFIG_FP16_ALT is not set CONFIG_CPU_CORTEX_M33=y CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y CONFIG_CPU_CORTEX_M_HAS_VTOR=y CONFIG_CPU_CORTEX_M_HAS_SPLIM=y CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y CONFIG_CPU_CORTEX_M_HAS_CMSE=y CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_SE=y CONFIG_ARMV7_M_ARMV8_M_FP=y CONFIG_ARMV8_M_DSP=y # # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options # CONFIG_ZERO_LATENCY_IRQS=y CONFIG_ZERO_LATENCY_LEVELS=1 CONFIG_DYNAMIC_DIRECT_INTERRUPTS=y # CONFIG_SW_VECTOR_RELAY is not set # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set # CONFIG_TRAP_UNALIGNED_ACCESS is not set # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set # CONFIG_ARM_TRUSTZONE_M is not set # CONFIG_MPU_STACK_GUARD is not set # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set # CONFIG_CUSTOM_SECTION_ALIGN is not set CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32 CONFIG_CPU_HAS_ARM_SAU=y # end of ARM Options CONFIG_ARM=y CONFIG_ARCH_IS_SET=y # # General Architecture Options # # CONFIG_SEMIHOST is not set # CONFIG_ARCH_LOG_LEVEL_OFF is not set # CONFIG_ARCH_LOG_LEVEL_ERR is not set # CONFIG_ARCH_LOG_LEVEL_WRN is not set # CONFIG_ARCH_LOG_LEVEL_INF is not set # CONFIG_ARCH_LOG_LEVEL_DBG is not set CONFIG_ARCH_LOG_LEVEL_DEFAULT=y CONFIG_ARCH_LOG_LEVEL=3 CONFIG_LITTLE_ENDIAN=y # CONFIG_USERSPACE is not set CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100 CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16 CONFIG_GEN_PRIV_STACKS=y # CONFIG_STACK_GROWS_UP is not set # CONFIG_FRAME_POINTER is not set # # Interrupt Configuration # CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set CONFIG_EXCEPTION_DEBUG=y # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set # end of Interrupt Configuration # end of General Architecture Options CONFIG_ARCH_HAS_STACK_PROTECTION=y CONFIG_ARCH_HAS_USERSPACE=y CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y CONFIG_ARCH_SUPPORTS_COREDUMP=y CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y CONFIG_ARCH_SUPPORTS_ROM_START=y CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y CONFIG_ARCH_HAS_THREAD_ABORT=y CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y CONFIG_CPU_HAS_TEE=y CONFIG_CPU_HAS_FPU=y CONFIG_CPU_HAS_MPU=y CONFIG_CPU_HAS_ICACHE=y CONFIG_MPU=y # CONFIG_MPU_LOG_LEVEL_OFF is not set # CONFIG_MPU_LOG_LEVEL_ERR is not set # CONFIG_MPU_LOG_LEVEL_WRN is not set # CONFIG_MPU_LOG_LEVEL_INF is not set # CONFIG_MPU_LOG_LEVEL_DBG is not set CONFIG_MPU_LOG_LEVEL_DEFAULT=y CONFIG_MPU_LOG_LEVEL=3 CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y CONFIG_MPU_GAP_FILLING=y CONFIG_SRAM_REGION_PERMISSIONS=y # # DSP Options # # end of DSP Options # # Floating Point Options # # end of Floating Point Options # # Cache Options # CONFIG_ICACHE=y # CONFIG_ICACHE_LINE_SIZE_DETECT is not set # CONFIG_ARCH_CACHE is not set CONFIG_EXTERNAL_CACHE=y # end of Cache Options CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y # # General Kernel Options # # CONFIG_KERNEL_LOG_LEVEL_OFF is not set # CONFIG_KERNEL_LOG_LEVEL_ERR is not set # CONFIG_KERNEL_LOG_LEVEL_WRN is not set # CONFIG_KERNEL_LOG_LEVEL_INF is not set # CONFIG_KERNEL_LOG_LEVEL_DBG is not set CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y CONFIG_KERNEL_LOG_LEVEL=3 CONFIG_MULTITHREADING=y CONFIG_NUM_COOP_PRIORITIES=16 CONFIG_NUM_PREEMPT_PRIORITIES=15 CONFIG_MAIN_THREAD_PRIORITY=0 CONFIG_COOP_ENABLED=y CONFIG_PREEMPT_ENABLED=y CONFIG_PRIORITY_CEILING=-127 # CONFIG_SCHED_DEADLINE is not set CONFIG_THREAD_STACK_INFO=y # CONFIG_THREAD_CUSTOM_DATA is not set # CONFIG_DYNAMIC_THREAD is not set # CONFIG_SCHED_DUMB is not set CONFIG_SCHED_SIMPLE=y # CONFIG_SCHED_SCALABLE is not set # CONFIG_SCHED_MULTIQ is not set # CONFIG_WAITQ_DUMB is not set # CONFIG_WAITQ_SCALABLE is not set CONFIG_WAITQ_SIMPLE=y # # Misc Kernel related options # CONFIG_LIBC_ERRNO=y CONFIG_ERRNO=y CONFIG_CURRENT_THREAD_USE_TLS=y # end of Misc Kernel related options # # Kernel Debugging and Metrics # CONFIG_BOOT_DELAY=0 # CONFIG_BOOT_CLEAR_SCREEN is not set CONFIG_THREAD_MONITOR=y CONFIG_THREAD_NAME=y CONFIG_THREAD_MAX_NAME_LEN=32 CONFIG_INSTRUMENT_THREAD_SWITCHING=y CONFIG_THREAD_RUNTIME_STATS=y # CONFIG_THREAD_RUNTIME_STATS_USE_TIMING_FUNCTIONS is not set CONFIG_SCHED_THREAD_USAGE=y # CONFIG_SCHED_THREAD_USAGE_ANALYSIS is not set CONFIG_SCHED_THREAD_USAGE_ALL=y CONFIG_SCHED_THREAD_USAGE_AUTO_ENABLE=y # end of Kernel Debugging and Metrics # CONFIG_OBJ_CORE is not set # # System Work Queue Options # # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set # end of System Work Queue Options # # Barrier Operations # CONFIG_BARRIER_OPERATIONS_ARCH=y # end of Barrier Operations # # Atomic Operations # CONFIG_ATOMIC_OPERATIONS_BUILTIN=y # end of Atomic Operations # # Timer API Options # CONFIG_TIMESLICING=y CONFIG_TIMESLICE_PRIORITY=0 # CONFIG_TIMESLICE_PER_THREAD is not set # end of Timer API Options # # Other Kernel Object Options # CONFIG_POLL=y CONFIG_MEM_SLAB_POINTER_VALIDATE=y # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set CONFIG_NUM_MBOX_ASYNC_MSGS=10 CONFIG_EVENTS=y # CONFIG_PIPES is not set CONFIG_KERNEL_MEM_POOL=y # CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set # end of Other Kernel Object Options CONFIG_SWAP_NONATOMIC=y CONFIG_TIMEOUT_64BIT=y CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365 # # Security Options # CONFIG_STACK_POINTER_RANDOM=0 # end of Security Options # # Memory Domains # CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y # end of Memory Domains # # SMP Options # # CONFIG_TICKET_SPINLOCKS is not set # end of SMP Options CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y CONFIG_THREAD_LOCAL_STORAGE=y CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y # CONFIG_STATIC_INIT_GNU is not set # CONFIG_BOOTARGS is not set # end of General Kernel Options # # Device Options # # CONFIG_DEVICE_DEPS is not set # CONFIG_DEVICE_MUTABLE is not set # CONFIG_DEVICE_DT_METADATA is not set # end of Device Options # # Initialization Priorities # CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30 CONFIG_KERNEL_INIT_PRIORITY_LIBC=35 CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40 CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50 CONFIG_APPLICATION_INIT_PRIORITY=90 # end of Initialization Priorities # # Virtual Memory Support # # end of Virtual Memory Support # # SoC and Board Hooks # # CONFIG_SOC_PREP_HOOK is not set # CONFIG_SOC_EARLY_INIT_HOOK is not set # CONFIG_SOC_LATE_INIT_HOOK is not set # CONFIG_SOC_PER_CORE_INIT_HOOK is not set # CONFIG_BOARD_EARLY_INIT_HOOK is not set # CONFIG_BOARD_LATE_INIT_HOOK is not set # end of SoC and Board Hooks # # Device Drivers # # CONFIG_ADC is not set # CONFIG_AUDIO is not set # CONFIG_AUXDISPLAY is not set # CONFIG_BBRAM is not set CONFIG_BT_DRIVERS=y # # Bluetooth HCI Driver Options # CONFIG_BT_HCI_INIT_PRIORITY=50 # CONFIG_HCI_NXP_SET_CAL_DATA_ANNEX100 is not set CONFIG_FLASH=y CONFIG_BT_DRV_TX_STACK_SIZE=256 CONFIG_BT_DRV_RX_STACK_SIZE=256 CONFIG_CACHE_HAS_DRIVER=y # CONFIG_CACHE_LOG_LEVEL_OFF is not set # CONFIG_CACHE_LOG_LEVEL_ERR is not set # CONFIG_CACHE_LOG_LEVEL_WRN is not set # CONFIG_CACHE_LOG_LEVEL_INF is not set # CONFIG_CACHE_LOG_LEVEL_DBG is not set CONFIG_CACHE_LOG_LEVEL_DEFAULT=y CONFIG_CACHE_LOG_LEVEL=3 # # Device Drivers # # CONFIG_CACHE_NRF_PATCH_LINEADDR is not set # CONFIG_CAN is not set # CONFIG_CHARGER is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG=y # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT is not set CONFIG_CLOCK_CONTROL_LOG_LEVEL=4 CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y CONFIG_CLOCK_CONTROL_NRF=y CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y # CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_LF_ALWAYS_ON is not set CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_PERIOD=4000 CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_MAX_SKIP=1 CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_TEMP_DIFF=2 # CONFIG_CLOCK_CONTROL_NRF_HFINT_CALIBRATION is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set CONFIG_CLOCK_CONTROL_NRF_ACCURACY=250 # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set # CONFIG_CLOCK_CONTROL_RTS5912_SCCON is not set # CONFIG_COMPARATOR is not set CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128 CONFIG_CONSOLE_HAS_DRIVER=y # CONFIG_CONSOLE_HANDLER is not set CONFIG_CONSOLE_INIT_PRIORITY=60 CONFIG_UART_CONSOLE=y # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set # CONFIG_UART_CONSOLE_MCUMGR is not set # CONFIG_RAM_CONSOLE is not set # CONFIG_IPM_CONSOLE_SENDER is not set # CONFIG_IPM_CONSOLE_RECEIVER is not set # CONFIG_UART_MCUMGR is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y CONFIG_UART_CONSOLE_LOG_LEVEL=3 # CONFIG_EFI_CONSOLE is not set CONFIG_WINSTREAM_CONSOLE_STATIC=y CONFIG_WINSTREAM_CONSOLE_STATIC_SIZE=32768 # CONFIG_COREDUMP_DEVICE is not set # CONFIG_CRYPTO is not set # CONFIG_DAC is not set # CONFIG_DAI is not set # CONFIG_DISK_DRIVERS is not set # CONFIG_DISPLAY is not set # CONFIG_DMA is not set # CONFIG_DP_DRIVER is not set # CONFIG_EDAC is not set # CONFIG_EEPROM is not set CONFIG_ENTROPY_GENERATOR=y # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set # CONFIG_ENTROPY_LOG_LEVEL_INF is not set # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y CONFIG_ENTROPY_LOG_LEVEL=3 CONFIG_ENTROPY_BT_HCI=y CONFIG_ENTROPY_PSA_CRYPTO_RNG=y CONFIG_ENTROPY_HAS_DRIVER=y # CONFIG_ESPI is not set # # Firmware drivers # # CONFIG_ARM_SCMI is not set # end of Firmware drivers CONFIG_FLASH_HAS_DRIVER_ENABLED=y CONFIG_FLASH_HAS_EX_OP=y CONFIG_FLASH_HAS_EXPLICIT_ERASE=y CONFIG_FLASH_HAS_NO_EXPLICIT_ERASE=y CONFIG_FLASH_HAS_PAGE_LAYOUT=y CONFIG_FLASH_JESD216=y # CONFIG_FLASH_JESD216_API is not set CONFIG_FLASH_PAGE_LAYOUT=y # CONFIG_FLASH_EX_OP_ENABLED is not set # # MSPI flash device driver # # end of MSPI flash device driver CONFIG_SPI_NOR_SFDP_MINIMAL=y # CONFIG_SPI_NOR_SFDP_DEVICETREE is not set # CONFIG_SPI_NOR_SFDP_RUNTIME is not set CONFIG_SPI_NOR_INIT_PRIORITY=80 CONFIG_SPI_NOR_CS_WAIT_DELAY=0 CONFIG_SPI_NOR_SLEEP_WHILE_WAITING_UNTIL_READY=y CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=65536 CONFIG_FLASH_NRF_FORCE_ALT=y # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE is not set CONFIG_SOC_FLASH_NRF_TIMEOUT_MULTIPLIER=15 CONFIG_SOC_FLASH_NRF_RRAM=y CONFIG_NRF_RRAM_WRITE_BUFFER_SIZE=32 CONFIG_NRF_RRAM_READYNEXT_TIMEOUT_VALUE=128 CONFIG_NRF_RRAM_REGION_ADDRESS_RESOLUTION=0x1000 CONFIG_NRF_RRAM_REGION_SIZE_UNIT=0x1000 # CONFIG_FLASH_LOG_LEVEL_OFF is not set # CONFIG_FLASH_LOG_LEVEL_ERR is not set # CONFIG_FLASH_LOG_LEVEL_WRN is not set # CONFIG_FLASH_LOG_LEVEL_INF is not set # CONFIG_FLASH_LOG_LEVEL_DBG is not set CONFIG_FLASH_LOG_LEVEL_DEFAULT=y CONFIG_FLASH_LOG_LEVEL=3 # CONFIG_FPGA is not set # CONFIG_FUEL_GAUGE is not set # CONFIG_GNSS is not set # CONFIG_GPIO_LOG_LEVEL_OFF is not set # CONFIG_GPIO_LOG_LEVEL_ERR is not set # CONFIG_GPIO_LOG_LEVEL_WRN is not set # CONFIG_GPIO_LOG_LEVEL_INF is not set CONFIG_GPIO_LOG_LEVEL_DBG=y # CONFIG_GPIO_LOG_LEVEL_DEFAULT is not set CONFIG_GPIO_LOG_LEVEL=4 # CONFIG_GPIO_GET_DIRECTION is not set # CONFIG_GPIO_GET_CONFIG is not set # CONFIG_GPIO_HOGS is not set # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set CONFIG_GPIO_NRFX=y CONFIG_GPIO_NRFX_INTERRUPT=y # CONFIG_GPIO_RTS5912 is not set # CONFIG_HAPTICS is not set # CONFIG_HWINFO is not set # CONFIG_HWSPINLOCK is not set # CONFIG_I2C is not set # CONFIG_I2S is not set # CONFIG_I3C is not set # # Interrupt controller drivers # CONFIG_INTC_INIT_PRIORITY=40 # CONFIG_INTC_LOG_LEVEL_OFF is not set # CONFIG_INTC_LOG_LEVEL_ERR is not set # CONFIG_INTC_LOG_LEVEL_WRN is not set # CONFIG_INTC_LOG_LEVEL_INF is not set # CONFIG_INTC_LOG_LEVEL_DBG is not set CONFIG_INTC_LOG_LEVEL_DEFAULT=y CONFIG_INTC_LOG_LEVEL=3 # end of Interrupt controller drivers # CONFIG_IPM is not set # CONFIG_KSCAN is not set # CONFIG_LED is not set # CONFIG_LED_STRIP is not set # CONFIG_LORA is not set # CONFIG_MBOX is not set # CONFIG_MDIO is not set # CONFIG_MIPI_DBI is not set # # Miscellaneous Drivers # # CONFIG_TIMEAWARE_GPIO is not set # end of Miscellaneous Drivers # CONFIG_MM_DRV is not set # CONFIG_MSPI is not set # CONFIG_PCIE is not set # CONFIG_PCIE_ENDPOINT is not set # CONFIG_PECI is not set CONFIG_PINCTRL=y # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set # CONFIG_PINCTRL_LOG_LEVEL_INF is not set # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y CONFIG_PINCTRL_LOG_LEVEL=3 CONFIG_PINCTRL_STORE_REG=y # CONFIG_PINCTRL_DYNAMIC is not set CONFIG_PINCTRL_NRF=y # CONFIG_PINCTRL_REALTEK_RTS5912 is not set # CONFIG_PM_CPU_OPS is not set # CONFIG_PS2 is not set # CONFIG_PTP_CLOCK is not set # CONFIG_PWM is not set # CONFIG_RETAINED_MEM is not set # CONFIG_RTC is not set # CONFIG_SDHC is not set # # Capabilities # CONFIG_SERIAL_HAS_DRIVER=y CONFIG_SERIAL_SUPPORT_ASYNC=y CONFIG_SERIAL_SUPPORT_INTERRUPT=y # CONFIG_UART_LOG_LEVEL_OFF is not set # CONFIG_UART_LOG_LEVEL_ERR is not set # CONFIG_UART_LOG_LEVEL_WRN is not set # CONFIG_UART_LOG_LEVEL_INF is not set # CONFIG_UART_LOG_LEVEL_DBG is not set CONFIG_UART_LOG_LEVEL_DEFAULT=y CONFIG_UART_LOG_LEVEL=3 # CONFIG_UART_ASYNC_API is not set # CONFIG_UART_LINE_CTRL is not set # CONFIG_UART_DRV_CMD is not set # CONFIG_UART_WIDE_DATA is not set # CONFIG_UART_PIPE is not set # CONFIG_UART_ASYNC_RX_HELPER is not set # # Serial Drivers # CONFIG_UART_NRFX=y CONFIG_UART_NRFX_UARTE=y CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y # CONFIG_UART_20_NRF_PARITY_BIT is not set CONFIG_UART_20_NRF_TX_BUFFER_SIZE=32 # CONFIG_UART_RTS5912 is not set # CONFIG_SMBUS is not set # CONFIG_SPI_ASYNC is not set # CONFIG_SPI_RTIO is not set # CONFIG_SPI_SLAVE is not set # CONFIG_SPI_EXTENDED_MODES is not set CONFIG_SPI_INIT_PRIORITY=50 CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200 # CONFIG_SPI_LOG_LEVEL_OFF is not set # CONFIG_SPI_LOG_LEVEL_ERR is not set # CONFIG_SPI_LOG_LEVEL_WRN is not set # CONFIG_SPI_LOG_LEVEL_INF is not set # CONFIG_SPI_LOG_LEVEL_DBG is not set CONFIG_SPI_LOG_LEVEL_DEFAULT=y CONFIG_SPI_LOG_LEVEL=3 CONFIG_SPI_NRFX=y CONFIG_SPI_NRFX_SPIM=y CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8 CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200 # CONFIG_STEPPER is not set # # Timer drivers # CONFIG_TIMER_HAS_64BIT_CYCLE_COUNTER=y # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0 CONFIG_TICKLESS_CAPABLE=y CONFIG_NRF_GRTC_TIMER=y # CONFIG_NRF_GRTC_TIMER_APP_DEFINED_INIT is not set CONFIG_NRF_GRTC_START_SYSCOUNTER=y CONFIG_NRF_GRTC_TIMER_CLOCK_MANAGEMENT=y CONFIG_NRF_GRTC_TIMER_AUTO_KEEP_ALIVE=y # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y # CONFIG_REALTEK_RTS5912_RTMR is not set # end of Timer drivers # CONFIG_USB_BC12 is not set # CONFIG_UDC_DRIVER is not set # CONFIG_UHC_DRIVER is not set # CONFIG_UVB is not set # CONFIG_USB_DEVICE_DRIVER is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3 # CONFIG_USBC_TCPC_DRIVER is not set # CONFIG_USBC_LOG_LEVEL_OFF is not set # CONFIG_USBC_LOG_LEVEL_ERR is not set # CONFIG_USBC_LOG_LEVEL_WRN is not set # CONFIG_USBC_LOG_LEVEL_INF is not set # CONFIG_USBC_LOG_LEVEL_DBG is not set CONFIG_USBC_LOG_LEVEL_DEFAULT=y CONFIG_USBC_LOG_LEVEL=3 # CONFIG_USBC_VBUS_DRIVER is not set # CONFIG_USBC_PPC_DRIVER is not set # CONFIG_VIDEO is not set # CONFIG_VIRTUALIZATION is not set # CONFIG_W1 is not set # CONFIG_WDT_LOG_LEVEL_OFF is not set # CONFIG_WDT_LOG_LEVEL_ERR is not set # CONFIG_WDT_LOG_LEVEL_WRN is not set # CONFIG_WDT_LOG_LEVEL_INF is not set # CONFIG_WDT_LOG_LEVEL_DBG is not set CONFIG_WDT_LOG_LEVEL_DEFAULT=y CONFIG_WDT_LOG_LEVEL=3 CONFIG_WDT_NRFX=y CONFIG_WDT_NRFX_NO_IRQ=y # CONFIG_TEE is not set # end of Device Drivers # CONFIG_REQUIRES_FULL_LIBC is not set # CONFIG_REQUIRES_FLOAT_PRINTF is not set CONFIG_FULL_LIBC_SUPPORTED=y CONFIG_MINIMAL_LIBC_SUPPORTED=y CONFIG_NEWLIB_LIBC_SUPPORTED=y CONFIG_PICOLIBC_SUPPORTED=y # # C Library # # CONFIG_MINIMAL_LIBC is not set CONFIG_PICOLIBC=y # CONFIG_NEWLIB_LIBC is not set # CONFIG_EXTERNAL_LIBC is not set CONFIG_HAS_NEWLIB_LIBC_NANO=y CONFIG_COMMON_LIBC_ABORT=y # CONFIG_COMMON_LIBC_ASCTIME_R is not set # CONFIG_COMMON_LIBC_CTIME_R is not set CONFIG_COMMON_LIBC_MALLOC=y CONFIG_COMMON_LIBC_CALLOC=y CONFIG_COMMON_LIBC_REALLOCARRAY=y # CONFIG_COMMON_LIBC_REMOVE is not set # CONFIG_PICOLIBC_USE_MODULE is not set CONFIG_PICOLIBC_USE_TOOLCHAIN=y # CONFIG_PICOLIBC_IO_FLOAT is not set CONFIG_PICOLIBC_IO_LONG_LONG=y CONFIG_STDOUT_CONSOLE=y CONFIG_NEED_LIBC_MEM_PARTITION=y # end of C Library # # C++ Language Support # # CONFIG_CPP is not set # end of C++ Language Support CONFIG_CRC=y # # Additional libraries # # # Hash Function Support # # CONFIG_SYS_HASH_FUNC32 is not set # end of Hash Function Support # # Hashmap (Hash Table) Support # # CONFIG_SYS_HASH_MAP is not set # end of Hashmap (Hash Table) Support # # Heap and Memory Allocation # # CONFIG_SYS_HEAP_VALIDATE is not set # CONFIG_SYS_HEAP_STRESS is not set # CONFIG_SYS_HEAP_INFO is not set CONFIG_SYS_HEAP_ALLOC_LOOPS=3 # CONFIG_SYS_HEAP_RUNTIME_STATS is not set # CONFIG_SYS_HEAP_LISTENER is not set # CONFIG_SYS_HEAP_SMALL_ONLY is not set # CONFIG_SYS_HEAP_BIG_ONLY is not set CONFIG_SYS_HEAP_AUTO=y # CONFIG_MULTI_HEAP is not set # CONFIG_SHARED_MULTI_HEAP is not set # end of Heap and Memory Allocation # # Memory Blocks # # CONFIG_SYS_MEM_BLOCKS is not set # end of Memory Blocks CONFIG_NET_BUF=y # CONFIG_NET_BUF_LOG is not set # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set # CONFIG_NET_BUF_LOG_LEVEL_INF is not set # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y CONFIG_NET_BUF_LOG_LEVEL=3 # CONFIG_NET_BUF_POOL_USAGE is not set CONFIG_NET_BUF_ALIGNMENT=0 # # OS Support Library # # CONFIG_FDTABLE is not set CONFIG_ZVFS_OPEN_MAX=4 # CONFIG_PRINTK_SYNC is not set CONFIG_MPSC_PBUF=y # CONFIG_SPSC_PBUF is not set # CONFIG_MPSC_CLEAR_ALLOCATED is not set CONFIG_HAS_POWEROFF=y # CONFIG_POWEROFF is not set CONFIG_CBPRINTF_COMPLETE=y # CONFIG_CBPRINTF_NANO is not set CONFIG_CBPRINTF_FULL_INTEGRAL=y # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set # CONFIG_CBPRINTF_FP_SUPPORT is not set # CONFIG_CBPRINTF_FP_A_SUPPORT is not set # CONFIG_CBPRINTF_LIBC_SUBSTS is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3 # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y # CONFIG_ZVFS is not set # end of OS Support Library # # POSIX API Support # # # POSIX Options # # CONFIG_POSIX_API is not set CONFIG_POSIX_AEP_CHOICE_NONE=y # CONFIG_POSIX_AEP_CHOICE_BASE is not set # CONFIG_POSIX_AEP_CHOICE_PSE51 is not set # CONFIG_POSIX_AEP_CHOICE_PSE52 is not set # CONFIG_POSIX_AEP_CHOICE_PSE53 is not set # CONFIG_POSIX_ASYNCHRONOUS_IO is not set # CONFIG_POSIX_BARRIERS is not set # CONFIG_POSIX_C_LANG_SUPPORT_R is not set # CONFIG_POSIX_C_LIB_EXT is not set # # POSIX device I/O # # CONFIG_POSIX_DEVICE_IO is not set CONFIG_POSIX_OPEN_MAX=4 # end of POSIX device I/O # CONFIG_POSIX_FD_MGMT is not set # CONFIG_POSIX_FILE_SYSTEM_R is not set # CONFIG_POSIX_FILE_SYSTEM is not set # # POSIX memory # CONFIG_POSIX_PAGE_SIZE=0x40 # CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set # CONFIG_POSIX_MAPPED_FILES is not set # CONFIG_POSIX_MEMORY_PROTECTION is not set # end of POSIX memory # CONFIG_POSIX_MESSAGE_PASSING is not set # CONFIG_POSIX_SINGLE_PROCESS is not set # CONFIG_POSIX_MULTI_PROCESS is not set # CONFIG_POSIX_THREADS is not set # CONFIG_POSIX_READER_WRITER_LOCKS is not set # # POSIX scheduler options # # CONFIG_POSIX_PRIORITY_SCHEDULING is not set # end of POSIX scheduler options # CONFIG_POSIX_SEMAPHORES is not set # # POSIX signals # # CONFIG_POSIX_REALTIME_SIGNALS is not set # CONFIG_POSIX_SIGNALS is not set # end of POSIX signals # CONFIG_POSIX_SPIN_LOCKS is not set # # POSIX synchronized I/O # # CONFIG_POSIX_FSYNC is not set # CONFIG_POSIX_SYNCHRONIZED_IO is not set # end of POSIX synchronized I/O # CONFIG_POSIX_TIMERS is not set # # X/Open system interfaces # # CONFIG_XOPEN_STREAMS is not set # CONFIG_XSI_SYSTEM_LOGGING is not set # CONFIG_XSI_THREADS_EXT is not set # end of X/Open system interfaces # # Miscellaneous POSIX-related options # # CONFIG_EVENTFD is not set # end of Miscellaneous POSIX-related options # # Deprecated POSIX options # CONFIG_EVENTFD_MAX=0 # CONFIG_FNMATCH is not set CONFIG_MAX_PTHREAD_COUNT=0 CONFIG_MAX_PTHREAD_KEY_COUNT=0 CONFIG_MAX_TIMER_COUNT=0 CONFIG_MSG_COUNT_MAX=0 # CONFIG_POSIX_CLOCK is not set # CONFIG_POSIX_FS is not set CONFIG_POSIX_LIMITS_RTSIG_MAX=0 CONFIG_POSIX_MAX_FDS=4 CONFIG_POSIX_MAX_OPEN_FILES=4 # CONFIG_POSIX_MQUEUE is not set # CONFIG_POSIX_PUTMSG is not set # CONFIG_POSIX_SIGNAL is not set # CONFIG_POSIX_SYSCONF is not set # CONFIG_POSIX_UNAME is not set # CONFIG_PTHREAD is not set # CONFIG_PTHREAD_BARRIER is not set # CONFIG_PTHREAD_COND is not set # CONFIG_PTHREAD_IPC is not set # CONFIG_PTHREAD_KEY is not set # CONFIG_PTHREAD_MUTEX is not set # CONFIG_PTHREAD_RWLOCK is not set # CONFIG_PTHREAD_SPINLOCK is not set # CONFIG_TIMER is not set CONFIG_TIMER_DELAYTIMER_MAX=0 CONFIG_SEM_NAMELEN_MAX=0 CONFIG_SEM_VALUE_MAX=0 # end of Deprecated POSIX options CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y # end of POSIX Options # # POSIX Shell Utilities # # end of POSIX Shell Utilities # end of POSIX API Support # CONFIG_OPENAMP_RSC_TABLE is not set # CONFIG_SMF is not set CONFIG_LIBGCC_RTLIB=y # # Utility Library # # CONFIG_JSON_LIBRARY is not set # CONFIG_RING_BUFFER is not set CONFIG_NOTIFY=y # CONFIG_BASE64 is not set CONFIG_ONOFF=y # CONFIG_UTF8 is not set # end of Utility Library # end of Additional libraries # # Subsystems and OS Services # # CONFIG_BINDESC is not set CONFIG_BT=y CONFIG_BT_HCI=y # CONFIG_BT_CUSTOM is not set # CONFIG_BT_HCI_RAW is not set # CONFIG_BT_HCI_RAW_H4 is not set # CONFIG_BT_HCI_RAW_CMD_EXT is not set CONFIG_BT_CONN_TX=y # CONFIG_BT_SCA_UPDATE is not set # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set # CONFIG_BT_PATH_LOSS_MONITORING is not set # CONFIG_BT_SUBRATING is not set # CONFIG_BT_CHANNEL_SOUNDING is not set # CONFIG_BT_ISO_PERIPHERAL is not set # CONFIG_BT_ISO_BROADCASTER is not set # # Bluetooth buffer configuration # # end of Bluetooth buffer configuration # # Bluetooth Host # # # L2CAP Options # # end of L2CAP Options # # ATT and GATT Options # # end of ATT and GATT Options # # GATT Services # # end of GATT Services # # Bluetooth Classic Options # # end of Bluetooth Classic Options # end of Bluetooth Host CONFIG_BT_CTLR_ENTROPY_SUPPORT=y CONFIG_BT_CTLR_CRYPTO_SUPPORT=y CONFIG_BT_CTLR_LE_ENC_SUPPORT=y CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y CONFIG_BT_CTLR_PRIVACY_SUPPORT=y CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y CONFIG_BT_CTLR_PHY_2M_SUPPORT=y CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y CONFIG_BT_CTLR_ADV_EXT_CODING_SELECTION_SUPPORT=y CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y CONFIG_BT_CTLR_ADV_PERIODIC_RSP_SUPPORT=y CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y CONFIG_BT_CTLR_SYNC_PERIODIC_RSP_SUPPORT=y CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y CONFIG_BT_CTLR_LE_POWER_CONTROL_SUPPORT=y CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING_SUPPORT=y CONFIG_BT_CTLR_SUBRATING_SUPPORT=y CONFIG_BT_CTLR_CHANNEL_SOUNDING_SUPPORT=y CONFIG_HAS_BT_CTLR=y CONFIG_BT_CTLR_HCI=y # # Bluetooth Controller configuration # CONFIG_BT_CTLR_ENTROPY=y CONFIG_BT_CTLR_CRYPTO=y CONFIG_BT_CTLR_HCI_VS_BUILD_INFO="" # CONFIG_BT_CTLR_TX_PWR_PLUS_8 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_7 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_6 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_5 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_1 is not set CONFIG_BT_CTLR_TX_PWR_0=y # CONFIG_BT_CTLR_TX_PWR_MINUS_1 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_2 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_3 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_5 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_6 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_7 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_9 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_10 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_14 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_26 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_46 is not set CONFIG_BT_CTLR_TX_PWR_DBM=0 CONFIG_BT_CTLR_TX_PWR_ANTENNA=0 # CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set # # Bluetooth Controller features # CONFIG_BT_CTLR_LE_ENC=y CONFIG_BT_CTLR_EXT_REJ_IND=y CONFIG_BT_CTLR_LE_PING=y CONFIG_BT_CTLR_DATA_LENGTH=y CONFIG_BT_CTLR_PHY=y # CONFIG_BT_CTLR_CONN_RSSI is not set # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set # CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING is not set # CONFIG_BT_CTLR_FILTER_ACCEPT_LIST is not set # CONFIG_BT_CTLR_PRIVACY is not set CONFIG_BT_CTLR_PHY_2M=y # CONFIG_BT_CTLR_PHY_CODED is not set CONFIG_BT_CTLR_CHAN_SEL_2=y # CONFIG_BT_CTLR_ADV_EXT is not set # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set # CONFIG_BT_CTLR_PERIPHERAL_ISO is not set # CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set # CONFIG_BT_CTLR_SUBRATING is not set CONFIG_BT_CTLR_DF_CTE_TX_SUPPORT=y # CONFIG_BT_CTLR_ASSERT_HANDLER is not set # CONFIG_BT_CTLR_VS_SCAN_REQ_RX is not set # CONFIG_BT_EAD is not set # # Bluetooth logging # # # Common # # end of Common # # Libraries # # end of Libraries # # Host # # end of Host # # Services # # end of Services # end of Bluetooth logging # # Controller Area Network (CAN) bus subsystem # # end of Controller Area Network (CAN) bus subsystem # CONFIG_CONSOLE_SUBSYS is not set # CONFIG_DAP is not set # # System Monitoring Options # # CONFIG_THREAD_ANALYZER is not set # end of System Monitoring Options # # Debugging Options # # CONFIG_DEBUG is not set # CONFIG_STACK_USAGE is not set # CONFIG_STACK_SENTINEL is not set CONFIG_PRINTK=y CONFIG_EARLY_CONSOLE=y CONFIG_ASSERT_LEVEL=2 CONFIG_SPIN_VALIDATE=y # CONFIG_FORCE_NO_ASSERT is not set CONFIG_ASSERT_VERBOSE=y # CONFIG_ASSERT_NO_FILE_INFO is not set CONFIG_ASSERT_NO_COND_INFO=y CONFIG_ASSERT_NO_MSG_INFO=y # CONFIG_ASSERT_TEST is not set # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set # CONFIG_DEBUG_INFO is not set CONFIG_DEBUG_THREAD_INFO=y # CONFIG_DEBUG_COREDUMP is not set # CONFIG_SYMTAB is not set # end of Debugging Options # CONFIG_MIPI_STP_DECODER is not set # CONFIG_CS_TRACE_DEFMT is not set CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE=0x5000 CONFIG_IMG_BLOCK_BUF_SIZE=512 # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y CONFIG_IMG_MANAGER_LOG_LEVEL=3 # CONFIG_DISK_ACCESS is not set # CONFIG_DSP is not set # CONFIG_EMUL is not set # CONFIG_CHARACTER_FRAMEBUFFER is not set # # File Systems # # CONFIG_FILE_SYSTEM_LIB_LINK is not set # CONFIG_FILE_SYSTEM is not set # CONFIG_FCB is not set # end of File Systems # # Inter Processor Communication # # CONFIG_RPMSG_SERVICE is not set # CONFIG_IPC_SERVICE is not set # end of Inter Processor Communication # CONFIG_JWT is not set # CONFIG_LLEXT is not set # # Linkable loadable Extension Development Kit (EDK) # CONFIG_LLEXT_EDK_NAME="llext-edk" # CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set # end of Linkable loadable Extension Development Kit (EDK) # # Logging # CONFIG_LOG_CORE_INIT_PRIORITY=0 CONFIG_LOG_MODE_DEFERRED=y # CONFIG_LOG_MODE_IMMEDIATE is not set # CONFIG_LOG_MODE_MINIMAL is not set # CONFIG_LOG_FRONTEND is not set # CONFIG_LOG_FRONTEND_OPT_API is not set # CONFIG_LOG_CUSTOM_HEADER is not set # CONFIG_LOG_MULTIDOMAIN is not set # # Logging levels filtering # # CONFIG_LOG_RUNTIME_FILTERING is not set CONFIG_LOG_DEFAULT_LEVEL=3 CONFIG_LOG_OVERRIDE_LEVEL=0 CONFIG_LOG_MAX_LEVEL=4 # end of Logging levels filtering # # Processing # CONFIG_LOG_PRINTK=y CONFIG_LOG_MODE_OVERFLOW=y # CONFIG_LOG_BLOCK_IN_THREAD is not set CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10 CONFIG_LOG_PROCESS_THREAD=y CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0 CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000 CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048 # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y # CONFIG_LOG_TIMESTAMP_64BIT is not set # CONFIG_LOG_SPEED is not set # end of Processing # # Output Formatting # # # Prepend non-hexdump log message with function name # # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y # end of Prepend non-hexdump log message with function name # CONFIG_LOG_MIPI_SYST_ENABLE is not set # CONFIG_LOG_THREAD_ID_PREFIX is not set # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set CONFIG_LOG_BACKEND_SHOW_COLOR=y # CONFIG_LOG_INFO_COLOR_GREEN is not set # CONFIG_LOG_DBG_COLOR_BLUE is not set CONFIG_LOG_TAG_MAX_LEN=0 CONFIG_LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP=y CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y CONFIG_LOG_OUTPUT_FORMAT_TIME_TIMESTAMP=y # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set # end of Output Formatting # # Backends # # CONFIG_LOG_BACKEND_BLE is not set CONFIG_LOG_BACKEND_UART=y CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1 CONFIG_LOG_BACKEND_UART_AUTOSTART=y CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y # CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set # CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0 # CONFIG_LOG_BACKEND_IPC_SERVICE is not set # end of Backends # # Misc # CONFIG_LOG_USE_VLA=y CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y # CONFIG_LOG_ALWAYS_RUNTIME is not set # CONFIG_LOG_FMT_SECTION is not set # CONFIG_LOG_FMT_STRING_VALIDATE is not set # CONFIG_LOG_MEM_UTILIZATION is not set CONFIG_LOG_FAILURE_REPORT_PERIOD=1000 # end of Misc CONFIG_LOG_OUTPUT=y # end of Logging CONFIG_MEM_ATTR=y # CONFIG_MEM_ATTR_HEAP is not set # # Device Management # # # Host command handler subsystem # # CONFIG_EC_HOST_CMD is not set # end of Host command handler subsystem CONFIG_MCUMGR=y # CONFIG_MCUMGR_LOG_LEVEL_OFF is not set # CONFIG_MCUMGR_LOG_LEVEL_ERR is not set # CONFIG_MCUMGR_LOG_LEVEL_WRN is not set # CONFIG_MCUMGR_LOG_LEVEL_INF is not set # CONFIG_MCUMGR_LOG_LEVEL_DBG is not set CONFIG_MCUMGR_LOG_LEVEL_DEFAULT=y CONFIG_MCUMGR_LOG_LEVEL=3 # CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS is not set # CONFIG_MCUMGR_MGMT_HANDLER_USER_DATA is not set # CONFIG_MCUMGR_MGMT_CUSTOM_PAYLOAD is not set CONFIG_MCUMGR_SMP_CBOR_MAX_MAIN_MAP_ENTRIES=15 CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVELS=2 CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_2=y CONFIG_MCUMGR_SMP_CBOR_MAX_DECODING_LEVELS=2 CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVELS=0 CONFIG_MCUMGR_SMP_CBOR_MAX_ENCODING_LEVELS=0 CONFIG_MCUMGR_SMP_SUPPORT_ORIGINAL_PROTOCOL=y # CONFIG_MCUMGR_SMP_VERBOSE_ERR_RESPONSE is not set # CONFIG_MCUMGR_SMP_LEGACY_RC_BEHAVIOUR is not set # # SMP Client # # CONFIG_SMP_CLIENT is not set # end of SMP Client # # Command Handlers # CONFIG_MCUMGR_GRP_IMG=y CONFIG_MCUMGR_GRP_IMG_UPDATABLE_IMAGE_NUMBER=1 # CONFIG_MCUMGR_GRP_IMG_VERBOSE_ERR is not set CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_SECONDARY=y # CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_ANY is not set CONFIG_MCUMGR_GRP_IMG_ALLOW_ERASE_PENDING=y # CONFIG_MCUMGR_GRP_IMG_DIRECT_UPLOAD is not set # CONFIG_MCUMGR_GRP_IMG_REJECT_DIRECT_XIP_MISMATCHED_SLOT is not set # CONFIG_MCUMGR_GRP_IMG_FRUGAL_LIST is not set # CONFIG_MCUMGR_GRP_IMG_VERSION_CMP_USE_BUILD_NUMBER is not set # CONFIG_MCUMGR_GRP_IMG_MUTEX is not set CONFIG_MCUMGR_GRP_IMG_TOO_LARGE_DISABLED=y # CONFIG_MCUMGR_GRP_IMG_TOO_LARGE_SYSBUILD is not set CONFIG_MCUMGR_GRP_IMG_IMAGE_SLOT_STATE_STATES=15 # CONFIG_MCUMGR_GRP_IMG_SLOT_INFO is not set # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_OFF is not set # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_ERR is not set # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_WRN is not set # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_INF is not set # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DBG is not set CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DEFAULT=y CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL=3 CONFIG_MCUMGR_GRP_OS=y CONFIG_MCUMGR_GRP_OS_RESET_MS=250 # CONFIG_MCUMGR_GRP_OS_TASKSTAT is not set CONFIG_MCUMGR_GRP_OS_ECHO=y # CONFIG_MCUMGR_GRP_OS_INFO is not set CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO=y # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_OFF is not set # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_ERR is not set # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_WRN is not set # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_INF is not set # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DBG is not set CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DEFAULT=y CONFIG_MCUMGR_GRP_OS_LOG_LEVEL=3 # CONFIG_MCUMGR_GRP_ENUM is not set # end of Command Handlers # # Transports and Transport Related Configuration Options # CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE=2048 CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_THREAD_PRIO=3 CONFIG_MCUMGR_TRANSPORT_REASSEMBLY=y CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT=4 CONFIG_MCUMGR_TRANSPORT_NETBUF_MIN_USER_DATA_SIZE=8 CONFIG_MCUMGR_TRANSPORT_NETBUF_USER_DATA_SIZE=8 # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_OFF is not set # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_ERR is not set # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_WRN is not set # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_INF is not set # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DBG is not set CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DEFAULT=y CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL=3 CONFIG_MCUMGR_TRANSPORT_BT=y CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW=y CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MIN_INT=6 CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MAX_INT=9 CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_LATENCY=0 CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_TIMEOUT=42 CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RESTORE_TIME=5000 CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RETRY_TIME=1000 # end of Transports and Transport Related Configuration Options # CONFIG_OSDP is not set # end of Device Management # CONFIG_MODBUS is not set # CONFIG_MODEM_MODULES is not set # # Networking # # CONFIG_NETWORKING is not set # end of Networking # # Power Management # # CONFIG_PM_POLICY_LATENCY_STANDALONE is not set # end of Power Management # # Portability # # end of Portability # CONFIG_PROFILING is not set # # Random Number Generators # # CONFIG_TEST_RANDOM_GENERATOR is not set CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789 # CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set CONFIG_XOSHIRO_RANDOM_GENERATOR=y CONFIG_CSPRNG_AVAILABLE=y CONFIG_CSPRNG_ENABLED=y CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y # end of Random Number Generators # CONFIG_RTIO is not set # # SD # # CONFIG_MMC_STACK is not set # CONFIG_SDMMC_STACK is not set # CONFIG_SDIO_STACK is not set # end of SD # CONFIG_SECURE_STORAGE is not set # CONFIG_SETTINGS is not set # CONFIG_SHELL is not set # CONFIG_STATS is not set # # Storage # CONFIG_FLASH_MAP=y # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set # CONFIG_FLASH_MAP_LABELS is not set CONFIG_STREAM_FLASH=y CONFIG_STREAM_FLASH_INSPECT=y CONFIG_STREAM_FLASH_POST_WRITE_CALLBACK=y CONFIG_STREAM_FLASH_ERASE=y # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y CONFIG_STREAM_FLASH_LOG_LEVEL=3 # end of Storage # CONFIG_TASK_WDT is not set # # Testing # # CONFIG_ZTEST is not set # CONFIG_ZTEST_MOCKING is not set # CONFIG_ZTRESS is not set # CONFIG_TEST is not set # CONFIG_FORCE_COVERAGE is not set # CONFIG_TEST_USERSPACE is not set # end of Testing # CONFIG_TIMING_FUNCTIONS is not set # CONFIG_TRACING is not set # CONFIG_USB_DEVICE_STACK is not set # CONFIG_USB_DEVICE_STACK_NEXT is not set # CONFIG_USB_HOST_STACK is not set # CONFIG_USBC_STACK is not set # CONFIG_ZBUS is not set # CONFIG_MODULES is not set # end of Subsystems and OS Services CONFIG_TOOLCHAIN_ZEPHYR_0_17=y CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y # # Build and Link Features # # # Linker Options # # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set CONFIG_LINKER_ORPHAN_SECTION_WARN=y # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set CONFIG_FLASH_LOAD_SIZE=0x51000 CONFIG_ROM_END_OFFSET=0x5000 CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y CONFIG_LD_LINKER_TEMPLATE=y # CONFIG_CMAKE_LINKER_GENERATOR is not set # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set CONFIG_LINKER_SORT_BY_ALIGNMENT=y # # Linker Sections # # CONFIG_LINKER_USE_BOOT_SECTION is not set # CONFIG_LINKER_USE_PINNED_SECTION is not set CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y CONFIG_LINKER_LAST_SECTION_ID=y CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015 CONFIG_LINKER_USE_RELAX=y # end of Linker Sections CONFIG_LINKER_ITERABLE_SUBALIGN=4 CONFIG_LINKER_DEVNULL_SUPPORT=y # CONFIG_LINKER_DEVNULL_MEMORY is not set # end of Linker Options # # Compiler Options # # CONFIG_STD_C90 is not set CONFIG_STD_C99=y # CONFIG_STD_C11 is not set # CONFIG_STD_C17 is not set # CONFIG_STD_C23 is not set CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y # CONFIG_GNU_C_EXTENSIONS is not set # CONFIG_CODING_GUIDELINE_CHECK is not set # CONFIG_COMPILER_FREESTANDING is not set # CONFIG_SIZE_OPTIMIZATIONS is not set # CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set # CONFIG_SPEED_OPTIMIZATIONS is not set CONFIG_DEBUG_OPTIMIZATIONS=y # CONFIG_NO_OPTIMIZATIONS is not set # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set # CONFIG_COMPILER_SAVE_TEMPS is not set CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y CONFIG_COMPILER_COLOR_DIAGNOSTICS=y # CONFIG_FORTIFY_SOURCE_NONE is not set CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set CONFIG_COMPILER_OPT="" # CONFIG_MISRA_SANE is not set # end of Compiler Options # CONFIG_ASSERT_ON_ERRORS is not set # CONFIG_NO_RUNTIME_CHECKS is not set CONFIG_RUNTIME_ERROR_CHECKS=y # # Build Options # CONFIG_KERNEL_BIN_NAME="zephyr" CONFIG_OUTPUT_STAT=y # CONFIG_OUTPUT_SYMBOLS is not set # CONFIG_OUTPUT_DISASSEMBLY is not set CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set CONFIG_BUILD_GAP_FILL_PATTERN=0xFF # CONFIG_BUILD_NO_GAP_FILL is not set # CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set # CONFIG_BUILD_OUTPUT_EXE is not set # CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set # CONFIG_BUILD_OUTPUT_UF2 is not set # CONFIG_BUILD_OUTPUT_STRIPPED is not set # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set # CONFIG_BUILD_ALIGN_LMA is not set # CONFIG_APPLICATION_DEFINED_SYSCALL is not set # CONFIG_MAKEFILE_EXPORTS is not set # CONFIG_BUILD_OUTPUT_META is not set CONFIG_BUILD_OUTPUT_STRIP_PATHS=y CONFIG_CHECK_INIT_PRIORITIES=y # CONFIG_EMIT_ALL_SYSCALLS is not set # end of Build Options CONFIG_WARN_DEPRECATED=y CONFIG_ENFORCE_ZEPHYR_STDINT=y # end of Build and Link Features # # Boot Options # # CONFIG_IS_BOOTLOADER is not set # CONFIG_BOOTLOADER_BOSSA is not set # end of Boot Options # # Compatibility # CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y # end of Compatibility
