sysbuild + mcuboot and board specific signature keys
Hello.
I'm currently migrating our existing application code to the NCS 3.1.0 SDK. As far as I have recognized, with sysbuild the child image build has been replaced. We are building our source code together with mcuboot. I managed to add mcuboot by adding
SB_CONFIG_BOOTLOADER_MCUBOOT=y
it to sysbuild.conf file.
We are building the image for different boards and we want to sign the update image for mcuboot with different keys. The documentation tells us to add a
sysbuild/mcuboot/boards/
directory with different board configurations. I thought it should be possible to overwrite the key file for each board with different
CONFIG_BOOT_SIGNATURE_KEY_FILE="<pem file>"
But this config is not taken into account. Always the dev keys are used for signing. Only way I managed to use our own key is to add the
SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="<pem file>"
to the "sysbuild.conf" file. But in this case, I have the same key for every board.
I also found another thread ( RE: Migrating child/parent image to sysbuild - MCUBoot with different keys for different board ) discussing this and I'm wondering if there is already a solution/fix for this. The workaround in this thread isn't really satisfying.
Thanks for your help and best regards,
Andreas
