Zephyr file system (FAT_FILESYSTEM_ELM) is not thread safe ?
Hello, I'm using an nRF9151 DK with an SPI attached SD card and SDK 3.1.0.
SD card is accessed using FAT_FILESYSTEM_ELM.
Using a single thread approach everything is working as expected. I'm able to create directories, files, and navigate in the directory structure without any unexpected behavior.
Then I started to use the Zephyr settings subsystem.
CONFIG_SETTINGS=y
CONFIG_SETTINGS_FILE=y
CONFIG_SETTINGS_FILE_PATH="/SD:/settings"
When I started to accessing the settings subsystem from a thread which is running concurrently with respect to the thread writing and reading from the SD card I started to get errors and inexplicable behaviors. I then discovered that FATFS by default is not reentrant, but it can be made reentrant by setting:
CONFIG_FS_FATFS_REENTRANT=y
At least this was the hope... although making FATFS reentrant do not removed the misbehavior. The only mean I'm able to get proper operation is by protecting the access to the SD card using a Mutex. This is a work around which fixes the issue but isn't really justified for a truly reentrant file system.
My question: is this an expected behavior ? is Zephyr file system (or the settings subsystem acceding the file system) not fully thread safe ?
Here is the code I used to test the reentrancy of the file system:
#include <zephyr/kernel.h>
#include <zephyr/settings/settings.h>
#include <zephyr/fs/fs.h>
#include <zephyr/storage/disk_access.h>
#include <zephyr/kernel/thread.h>
#include <ff.h>
#include <stdio.h>
LOG_MODULE_REGISTER(main);
K_MUTEX_DEFINE(test_mutex);
#define STACKSIZE 2048
K_THREAD_STACK_DEFINE(logger_stack, STACKSIZE);
struct k_thread logger_thread;
FATFS gfat_fs;
struct fs_mount_t mp = {.type = FS_FATFS , .fs_data= &gfat_fs, .mnt_point = "/SD:"};
struct fs_file_t mSessionFile;
bool gRunning = true;
static int foo_settings_set(const char *name, size_t len, settings_read_cb read_cb, void *cb_arg);
#define DEFAULT_FOO_VAL_VALUE 0
static uint8_t foo_val = DEFAULT_FOO_VAL_VALUE;
struct settings_handler my_conf = {
    .name = "foo",
    .h_set = foo_settings_set
    const char *next;
    int rc;
    if (settings_name_steq(name, "bar", &next) && !next) {
        if (len != sizeof(foo_val)) {
            return -EINVAL;
        rc = read_cb(cb_arg, &foo_val, sizeof(foo_val));
        if (rc >= 0) {
            return 0;
        return rc;
    return -ENOENT;
void InitFs()
	int32_t lRes;
    struct fs_dir_t lDirp;
    fs_dir_t_init(&lDirp);
	k_mutex_lock(&test_mutex, K_FOREVER);
    // Checkif data repository to check if it exists
    if ((lRes = fs_opendir(&lDirp, "/SD:/GNSS_DATA")))
        if (lRes == -2) // Path do not exists
            if ((lRes = fs_mkdir( "/SD:/GNSS_DATA")) != 0)
                LOG_ERR("Failed to create dir %s", "/SD:/GNSS_DATA");
				k_mutex_unlock(&test_mutex);
                return ;
            LOG_INF("Data repository was missing. Created %s", "/SD:/GNSS_DATA");
            LOG_ERR("Error opening dir %s [%d]", "/SD:/GNSS_DATA", lRes);
            return ;
        LOG_INF("Directory opened sucessfully %s ", "/SD:/GNSS_DATA");
    fs_closedir(&lDirp);
static void LoggerThread(void *arg1, void *arg2, void *arg3)
 	InitFs();
	while(gRunning)
		k_sleep(K_MSEC(1000));
 	int32_t lRes;
	// Mount the SD card
    if ((lRes = fs_mount(&mp) )!= FR_OK)
        LOG_ERR("Error mounting SD Card.");
        return lRes;
	// Create the cuncurrent access to the file system
    k_thread_create(&logger_thread,logger_stack , STACKSIZE, (k_thread_entry_t)LoggerThread, NULL, NULL, NULL, K_PRIO_COOP(7), 0, K_NO_WAIT);
	// Init the logging subsystem pointing to /SD:settings file (cuncurrent to LoggerThread)
    settings_subsys_init();
    settings_register(&my_conf);
    settings_load();
    foo_val++;
    settings_save_one("foo/bar", &foo_val, sizeof(foo_val));
	LOG_INF("foo_val %d",foo_val);
	for( int lcount=0; lcount<10; lcount++)
	gRunning = false;
   	k_thread_join(&logger_thread, K_FOREVER);
    lRes = fs_unmount(&mp);
	return 0;
Here the config file:
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=n
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_MAX_LEVEL=3
CONFIG_PRINTK=y
CONFIG_DEBUG=y
CONFIG_SPI=y
CONFIG_SERIAL=y
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_DISK_ACCESS=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_FS_FATFS_LFN=y
CONFIG_DISK_DRIVERS=y
CONFIG_DISK_DRIVER_SDMMC=y
CONFIG_DISK_LOG_LEVEL_DBG=y
CONFIG_SPI=y
CONFIG_FILE_SYSTEM_MKFS=y
CONFIG_SHELL=y
CONFIG_FILE_SYSTEM_SHELL=y
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_SETTINGS=y
and here the nrf9151dk_nrf9151_ns.overlay
&spi3 {
    cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>, /* D10 */
               <&gpio0          20 GPIO_ACTIVE_LOW>;
    sdhc0: sd@0 { // SPI SD card
        compatible = "zephyr,sdhc-spi-slot";
        reg = <0>; // First chip select in the spi3 definition
        status = "okay";
        reg = <0>;
        spi-max-frequency = <8000000>; // 1 MHz
        mmc {
            compatible = "zephyr,sdmmc-disk";
            status = "okay";
            disk-name = "SD";
&uart1 {
	status = "okay";
	current-speed = <460800>;
	pinctrl-0 = <&uart1_default>;
	pinctrl-1 = <&uart1_sleep>;
Referring to the test code, anomalous behavior means  InitFs() isn't able to open the directory nor create any directory... The error can be avoided by delaying the settings subsystem or using the mutex as shown in the test code.
Cheers, Joel
