vscode nrf connect
When programming my NRF52832 target card with VScode, if I don't use debug play, the code doesn't execute. What could be the reason? I don't have this problem in Segger Studio.
    What target card are you using? Is it a DK or a custom board (or 3rd party board)?
    I suspect the reset pin is not connected to the debugger. Is it? If not, does "nrfjprog --reset" work after you have programmed the device?
    What board did you build your application for? Do you have custom board files, or are you using the DK's board files?
    Edvin
