Matter Door Lock sample fails after changing PRODUCT_ID to 0x8007 (NCS 3.0.2)
I’m working with the Matter Door Lock sample in NCS 3.0.2. With the default PRODUCT_ID = 0x8006, everything works as expected: commissioning to Apple Home and Google Home succeeds, and chip-tool operates without issues. However, when I change the PRODUCT_ID to 0x8007, it stops working.
I also tested with a custom DAC (PID 0x8006) generated via the PKI provider. The DAC, private key, and related artifacts appear to be correctly linked by the Matter build scripts.
What could be causing this behavior? Below are chip-tool logs from a build configured with PID 0x8007.
Lukasz
[1756729182.855] [4637:4665] [DL] ConnectDevice retry: 1 out of 4
[1756729183.135] [4637:4665] [DL] ConnectDevice complete
[1756729183.135] [4637:4665] [BLE] New device connected: F8:11:F3:72:95:B3
[1756729184.193] [4637:4665] [DL] CHIP service found
[1756729184.193] [4637:4665] [DL] Valid C2 characteristic found
[1756729184.193] [4637:4665] [DL] Valid C1 characteristic found
[1756729184.193] [4637:4665] [DL] New BLE connection: conn=0x559d170f30 device=F8:11:F3:72:95:B3 path=/org/bluez/hci0/dev_F8_11_F3_72_95_B3
[1756729184.193] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16387
[1756729184.193] [4637:4666] [DIS] Closing all BLE connections
[1756729184.194] [4637:4666] [IN] BleConnectionComplete: endPoint 0x5586c61980
[1756729184.194] [4637:4666] [IN] SecureSession[0x7f8c013400]: Allocated Type:1 LSID:55443
[1756729184.195] [4637:4666] [SC] Assigned local session key ID 55443
[1756729184.195] [4637:4666] [EM] <<< [E:62475i S:0 M:104807131] (U) Msg TX from 7BAB2C28A239BDC5 to 0:0000000000000000 [0000] [BLE] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:98)
[1756729184.196] [4637:4666] [IN] Message appended to BLE send queue
[1756729184.196] [4637:4666] [SC] Sent PBKDF param request [II:500ms AI:300ms AT:4000ms)
[1756729184.572] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729184.663] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16390
[1756729184.663] [4637:4666] [BLE] subscribe complete, ep = 0x5586c61980
[1756729184.665] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729184.665] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729184.665] [4637:4666] [BLE] peripheral chose BTP version 4; central expected between 4 and 4
[1756729184.665] [4637:4666] [BLE] using BTP fragment sizes rx 244 / tx 244.
[1756729184.665] [4637:4666] [BLE] local and remote recv window size = 5
[1756729184.666] [4637:4666] [IN] BLE EndPoint 0x5586c61980 Connection Complete
[1756729184.797] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729184.846] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729184.846] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729184.846] [4637:4666] [EM] >>> [E:62475i S:0 M:83346254] (U) Msg RX from 0:0000000000000000 [0000] to 7BAB2C28A239BDC5 --- Type 0000:21 (SecureChannel:PBKDFParamResponse) (B:154)
[1756729184.846] [4637:4666] [EM] Found matching exchange: 62475i, Delegate: 0x7f8c041d08
[1756729184.847] [4637:4666] [SC] Received PBKDF param response
[1756729184.847] [4637:4666] [SC] Peer assigned session ID 31551
[1756729184.847] [4637:4666] [SC] Found MRP parameters in the message
[1756729184.862] [4637:4666] [EM] <<< [E:62475i S:0 M:104807132] (U) Msg TX from 7BAB2C28A239BDC5 to 0:0000000000000000 [0000] [BLE] --- Type 0000:22 (SecureChannel:PASE_Pake1) (B:92)
[1756729184.863] [4637:4666] [SC] Sent spake2p msg1
[1756729184.977] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729185.158] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.158] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.158] [4637:4666] [EM] >>> [E:62475i S:0 M:83346255] (U) Msg RX from 0:0000000000000000 [0000] to 7BAB2C28A239BDC5 --- Type 0000:23 (SecureChannel:PASE_Pake2) (B:127)
[1756729185.158] [4637:4666] [EM] Found matching exchange: 62475i, Delegate: 0x7f8c041d08
[1756729185.158] [4637:4666] [SC] Received spake2p msg2
[1756729185.161] [4637:4666] [EM] <<< [E:62475i S:0 M:104807133] (U) Msg TX from 7BAB2C28A239BDC5 to 0:0000000000000000 [0000] [BLE] --- Type 0000:24 (SecureChannel:PASE_Pake3) (B:59)
[1756729185.162] [4637:4666] [SC] Sent spake2p msg3
[1756729185.247] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729185.249] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.250] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.250] [4637:4666] [EM] >>> [E:62475i S:0 M:83346256] (U) Msg RX from 0:0000000000000000 [0000] to 7BAB2C28A239BDC5 --- Type 0000:40 (SecureChannel:StatusReport) (B:30)
[1756729185.250] [4637:4666] [EM] Found matching exchange: 62475i, Delegate: 0x7f8c041d08
[1756729185.250] [4637:4666] [SC] SecureSession[0x7f8c013400, LSID:55443]: State change 'kEstablishing' --> 'kActive'
[1756729185.250] [4637:4666] [IN] SecureSession[0x7f8c013400]: Activated - Type:1 LSID:55443
[1756729185.250] [4637:4666] [IN] New secure session activated for device <FFFFFFFB00000000, 0>, LSID:55443 PSID:31551!
[1756729185.250] [4637:4666] [CTL] Remote device completed SPAKE2+ handshake
[1756729185.250] [4637:4666] [TOO] Pairing Success
[1756729185.250] [4637:4666] [TOO] PASE establishment successful
[1756729185.250] [4637:4666] [CTL] Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
[1756729185.250] [4637:4666] [CTL] Performing next commissioning step 'ReadCommissioningInfo'
[1756729185.250] [4637:4666] [CTL] Sending read requests for commissioning information
[1756729185.251] [4637:4666] [DMG] SendReadRequest ReadClient[0x7f8c017800]: Sending Read Request
[1756729185.251] [4637:4666] [DMG] 0 data version filters provided, 0 not relevant, 0 encoded, 0 skipped due to lack of space
[1756729185.251] [4637:4666] [EM] <<< [E:62476i S:55443 M:88078146] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:02 (IM:ReadRequest) (B:134)
[1756729185.252] [4637:4666] [DMG] MoveToState ReadClient[0x7f8c017800]: Moving to [AwaitingIn]
[1756729185.252] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 32792
[1756729185.382] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729185.473] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.473] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.564] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.564] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.564] [4637:4666] [EM] >>> [E:62476i S:55443 M:189832959] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:05 (IM:ReportData) (B:257)
[1756729185.564] [4637:4666] [EM] Found matching exchange: 62476i, Delegate: 0x7f8c017810
[1756729185.565] [4637:4666] [DMG] ReportDataMessage =
[1756729185.565] [4637:4666] [DMG] {
[1756729185.565] [4637:4666] [DMG]      AttributeReportIBs =
[1756729185.565] [4637:4666] [DMG]      [
[1756729185.565] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.565] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.565] [4637:4666] [DMG]                              DataVersion = 0x96cc64bf,
[1756729185.565] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.565] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.565] [4637:4666] [DMG]                                      Cluster = 0x31,
[1756729185.565] [4637:4666] [DMG]                                      Attribute = 0x0000_FFFC,
[1756729185.565] [4637:4666] [DMG]                              }
[1756729185.565] [4637:4666] [DMG]                              Data = 2 (unsigned),
[1756729185.565] [4637:4666] [DMG]                      },
[1756729185.566] [4637:4666] [DMG]                              DataVersion = 0xb0fb55ae,
[1756729185.566] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.566] [4637:4666] [DMG]                              {
[1756729185.566] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.566] [4637:4666] [DMG]                                      Cluster = 0x28,
[1756729185.566] [4637:4666] [DMG]                                      Attribute = 0x0000_0004,
[1756729185.566] [4637:4666] [DMG]                              }
[1756729185.566] [4637:4666] [DMG]                              Data = 32775 (unsigned),
[1756729185.566] [4637:4666] [DMG]                      },
[1756729185.566] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.566] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.566] [4637:4666] [DMG]                                      Attribute = 0x0000_0002,
[1756729185.566] [4637:4666] [DMG]                              Data = 65521 (unsigned),
[1756729185.566] [4637:4666] [DMG]                              DataVersion = 0x8c803ba9,
[1756729185.566] [4637:4666] [DMG]                                      Cluster = 0x30,
[1756729185.566] [4637:4666] [DMG]                                      Attribute = 0x0000_0003,
[1756729185.566] [4637:4666] [DMG]                              Data = 0 (unsigned),
[1756729185.567] [4637:4666] [DMG]                      {
[1756729185.567] [4637:4666] [DMG]                              DataVersion = 0x8c803ba9,
[1756729185.567] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.567] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.567] [4637:4666] [DMG]                                      Cluster = 0x30,
[1756729185.567] [4637:4666] [DMG]                                      Attribute = 0x0000_0002,
[1756729185.567] [4637:4666] [DMG]                              }
[1756729185.567] [4637:4666] [DMG]                              Data = 0 (unsigned),
[1756729185.567] [4637:4666] [DMG]                      },
[1756729185.567] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.568] [4637:4666] [DMG]              {
[1756729185.568] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.568] [4637:4666] [DMG]                              DataVersion = 0x8c803ba9,
[1756729185.568] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.568] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.568] [4637:4666] [DMG]                                      Cluster = 0x30,
[1756729185.568] [4637:4666] [DMG]                                      Attribute = 0x0000_0001,
[1756729185.569] [4637:4666] [DMG]                              }
[1756729185.569] [4637:4666] [DMG]                              Data =
[1756729185.569] [4637:4666] [DMG]                              {
[1756729185.569] [4637:4666] [DMG]                                      0x0 = 60 (unsigned),
[1756729185.569] [4637:4666] [DMG]                                      0x1 = 900 (unsigned),
[1756729185.569] [4637:4666] [DMG]                              },
[1756729185.569] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.569] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.569] [4637:4666] [DMG]                              DataVersion = 0x8c803ba9,
[1756729185.569] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.569] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.569] [4637:4666] [DMG]                                      Cluster = 0x30,
[1756729185.569] [4637:4666] [DMG]                                      Attribute = 0x0000_0000,
[1756729185.569] [4637:4666] [DMG]                              Data = 0 (unsigned),
[1756729185.569] [4637:4666] [DMG]                                      Attribute = 0x0000_0004,
[1756729185.569] [4637:4666] [DMG]                              Data = true,
[1756729185.569] [4637:4666] [DMG]      ],
[1756729185.570] [4637:4666] [DMG]
[1756729185.570] [4637:4666] [DMG]      SuppressResponse = true,
[1756729185.570] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729185.570] [4637:4666] [DMG] }
[1756729185.571] [4637:4666] [DMG] SendReadRequest ReadClient[0x7f8c017800]: Sending Read Request
[1756729185.571] [4637:4666] [DMG] 0 data version filters provided, 0 not relevant, 0 encoded, 0 skipped due to lack of space
[1756729185.572] [4637:4666] [EM] <<< [E:62477i S:55443 M:88078147] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:02 (IM:ReadRequest) (B:103)
[1756729185.573] [4637:4666] [DMG] MoveToState ReadClient[0x7f8c017800]: Moving to [AwaitingIn]
[1756729185.697] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729185.790] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.790] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.790] [4637:4666] [EM] >>> [E:62477i S:55443 M:189832960] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:05 (IM:ReportData) (B:192)
[1756729185.791] [4637:4666] [EM] Found matching exchange: 62477i, Delegate: 0x7f8c017810
[1756729185.791] [4637:4666] [DMG] ReportDataMessage =
[1756729185.791] [4637:4666] [DMG] {
[1756729185.791] [4637:4666] [DMG]      AttributeReportIBs =
[1756729185.791] [4637:4666] [DMG]      [
[1756729185.791] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.791] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.791] [4637:4666] [DMG]                              DataVersion = 0xd11f275b,
[1756729185.791] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.791] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.791] [4637:4666] [DMG]                                      Cluster = 0x46,
[1756729185.791] [4637:4666] [DMG]                                      Attribute = 0x0000_0002,
[1756729185.791] [4637:4666] [DMG]                              }
[1756729185.791] [4637:4666] [DMG]                              Data = 300 (unsigned),
[1756729185.792] [4637:4666] [DMG]                      },
[1756729185.792] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.792] [4637:4666] [DMG]              {
[1756729185.792] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.792] [4637:4666] [DMG]                              DataVersion = 0xd11f275b,
[1756729185.792] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.792] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.792] [4637:4666] [DMG]                                      Cluster = 0x46,
[1756729185.792] [4637:4666] [DMG]                                      Attribute = 0x0000_0001,
[1756729185.792] [4637:4666] [DMG]                              Data = 300 (unsigned),
[1756729185.792] [4637:4666] [DMG]                                      Attribute = 0x0000_0000,
[1756729185.792] [4637:4666] [DMG]                              Data = 120 (unsigned),
[1756729185.792] [4637:4666] [DMG]                      AttributeStatusIB =
[1756729185.792] [4637:4666] [DMG]                                      Attribute = 0x0000_0007,
[1756729185.793] [4637:4666] [DMG]                              StatusIB =
[1756729185.793] [4637:4666] [DMG]                              {
[1756729185.793] [4637:4666] [DMG]                                      status = 0x86 (UNSUPPORTED_ATTRIBUTE),
[1756729185.793] [4637:4666] [DMG]                              },
[1756729185.793] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.793] [4637:4666] [DMG]                      AttributeStatusIB =
[1756729185.793] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.793] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.793] [4637:4666] [DMG]                                      Cluster = 0x46,
[1756729185.793] [4637:4666] [DMG]                                      Attribute = 0x0000_0006,
[1756729185.793] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.793] [4637:4666] [DMG]                              DataVersion = 0x96cc64bf,
[1756729185.793] [4637:4666] [DMG]                                      Cluster = 0x31,
[1756729185.793] [4637:4666] [DMG]                                      Attribute = 0x0000_0003,
[1756729185.793] [4637:4666] [DMG]                              Data = 20 (unsigned),
[1756729185.794] [4637:4666] [DMG]      ],
[1756729185.794] [4637:4666] [DMG]      SuppressResponse = true,
[1756729185.794] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729185.794] [4637:4666] [DMG] }
[1756729185.795] [4637:4666] [CTL] NetworkCommissioning Features: has Thread. endpointid = 0
[1756729185.795] [4637:4666] [SVR] OnReadCommissioningInfo - vendorId=0xFFF1 productId=0x8007
[1756729185.795] [4637:4666] [SVR] OnReadCommissioningInfo ICD - IdleModeDuration=0 activeModeDuration=0 activeModeThreshold=0
[1756729185.795] [4637:4666] [CTL] Successfully finished commissioning step 'ReadCommissioningInfo'
[1756729185.795] [4637:4666] [CTL] Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
[1756729185.795] [4637:4666] [CTL] Performing next commissioning step 'ArmFailSafe'
[1756729185.795] [4637:4666] [CTL] Arming failsafe (60 seconds)
[1756729185.795] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729185.795] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729185.796] [4637:4666] [EM] <<< [E:62478i S:55443 M:88078148] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
[1756729185.797] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729185.877] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729185.880] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.880] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.881] [4637:4666] [EM] >>> [E:62478i S:55443 M:189832961] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
[1756729185.881] [4637:4666] [EM] Found matching exchange: 62478i, Delegate: 0x7f8c008628
[1756729185.881] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729185.881] [4637:4666] [DMG] InvokeResponseMessage =
[1756729185.881] [4637:4666] [DMG] {
[1756729185.881] [4637:4666] [DMG]      suppressResponse = false,
[1756729185.881] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729185.881] [4637:4666] [DMG]      [
[1756729185.881] [4637:4666] [DMG]              InvokeResponseIB =
[1756729185.881] [4637:4666] [DMG]                      CommandDataIB =
[1756729185.881] [4637:4666] [DMG]                              CommandPathIB =
[1756729185.881] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729185.881] [4637:4666] [DMG]                                      ClusterId = 0x30,
[1756729185.881] [4637:4666] [DMG]                                      CommandId = 0x1,
[1756729185.881] [4637:4666] [DMG]                              },
[1756729185.881] [4637:4666] [DMG]                              CommandFields =
[1756729185.881] [4637:4666] [DMG]                                      0x0 = 0 (unsigned),
[1756729185.881] [4637:4666] [DMG]                                      0x1 = "" (0 chars),
[1756729185.881] [4637:4666] [DMG]      ],
[1756729185.881] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729185.882] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1756729185.882] [4637:4666] [CTL] Received ArmFailSafe response errorCode=0
[1756729185.882] [4637:4666] [CTL] Successfully finished commissioning step 'ArmFailSafe'
[1756729185.882] [4637:4666] [CTL] Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
[1756729185.882] [4637:4666] [CTL] Performing next commissioning step 'ConfigRegulatory'
[1756729185.882] [4637:4666] [CTL] Setting Regulatory Config
[1756729185.882] [4637:4666] [CTL] Device does not support configurable regulatory location
[1756729185.882] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729185.882] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729185.882] [4637:4666] [EM] <<< [E:62479i S:55443 M:88078149] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:70)
[1756729185.883] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729185.883] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729186.012] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729186.060] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.061] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.061] [4637:4666] [EM] >>> [E:62479i S:55443 M:189832962] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
[1756729186.061] [4637:4666] [EM] Found matching exchange: 62479i, Delegate: 0x7f8c008478
[1756729186.061] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729186.061] [4637:4666] [DMG] InvokeResponseMessage =
[1756729186.061] [4637:4666] [DMG] {
[1756729186.061] [4637:4666] [DMG]      suppressResponse = false,
[1756729186.061] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729186.061] [4637:4666] [DMG]      [
[1756729186.061] [4637:4666] [DMG]              InvokeResponseIB =
[1756729186.061] [4637:4666] [DMG]                      CommandDataIB =
[1756729186.061] [4637:4666] [DMG]                              CommandPathIB =
[1756729186.061] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729186.062] [4637:4666] [DMG]                                      ClusterId = 0x30,
[1756729186.062] [4637:4666] [DMG]                                      CommandId = 0x3,
[1756729186.062] [4637:4666] [DMG]                              },
[1756729186.062] [4637:4666] [DMG]                              CommandFields =
[1756729186.062] [4637:4666] [DMG]                              {
[1756729186.062] [4637:4666] [DMG]                                      0x0 = 0 (unsigned),
[1756729186.062] [4637:4666] [DMG]                                      0x1 = "" (0 chars),
[1756729186.062] [4637:4666] [DMG]      ],
[1756729186.062] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729186.062] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
[1756729186.062] [4637:4666] [CTL] Received SetRegulatoryConfig response errorCode=0
[1756729186.062] [4637:4666] [CTL] Successfully finished commissioning step 'ConfigRegulatory'
[1756729186.062] [4637:4666] [CTL] Commissioning stage next step: 'ConfigRegulatory' -> 'ConfigureTCAcknowledgments'
[1756729186.062] [4637:4666] [CTL] Performing next commissioning step 'ConfigureTCAcknowledgments'
[1756729186.062] [4637:4666] [CTL] Setting Terms and Conditions
[1756729186.062] [4637:4666] [CTL] Setting Terms and Conditions: Skipped
[1756729186.062] [4637:4666] [CTL] Successfully finished commissioning step 'ConfigureTCAcknowledgments'
[1756729186.062] [4637:4666] [CTL] Commissioning stage next step: 'ConfigureTCAcknowledgments' -> 'SendPAICertificateRequest'
[1756729186.062] [4637:4666] [CTL] Performing next commissioning step 'SendPAICertificateRequest'
[1756729186.062] [4637:4666] [CTL] Sending request for PAI certificate
[1756729186.062] [4637:4666] [CTL] Sending Certificate Chain request to 0x7f8c041cb0 device
[1756729186.062] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729186.062] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729186.062] [4637:4666] [EM] <<< [E:62480i S:55443 M:88078150] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
[1756729186.063] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729186.063] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729186.147] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729186.241] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.241] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.376] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.376] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.464] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.465] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.465] [4637:4666] [EM] >>> [E:62480i S:55443 M:189832963] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:527)
[1756729186.465] [4637:4666] [EM] Found matching exchange: 62480i, Delegate: 0x7f8c008628
[1756729186.465] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729186.465] [4637:4666] [DMG] InvokeResponseMessage =
[1756729186.465] [4637:4666] [DMG] {
[1756729186.465] [4637:4666] [DMG]      suppressResponse = false,
[1756729186.465] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729186.465] [4637:4666] [DMG]      [
[1756729186.465] [4637:4666] [DMG]              InvokeResponseIB =
[1756729186.465] [4637:4666] [DMG]                      CommandDataIB =
[1756729186.465] [4637:4666] [DMG]                              CommandPathIB =
[1756729186.465] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729186.465] [4637:4666] [DMG]                                      ClusterId = 0x3e,
[1756729186.465] [4637:4666] [DMG]                                      CommandId = 0x3,
[1756729186.465] [4637:4666] [DMG]                              },
[1756729186.465] [4637:4666] [DMG]                              CommandFields =
[1756729186.465] [4637:4666] [DMG]                                      0x0 = [
[1756729186.466] [4637:4666] [DMG]                                                      0x30, 0x82, 0x01, 0xcb, 0x30, 0x82, 0x01, 0x71, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x56, 0xad, 0x82, 0x22, 0xad, 0x94, 0x5b, 0x64, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x30, 0x31, 0x18, 0x30, 0x16, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0f, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x54, 0x65, 0x73, 0x74, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x41, 0x9a, 0x93, 0x15, 0xc2, 0x17, 0x3e, 0x0c, 0x8c, 0x87, 0x6d, 0x03, 0xcc, 0xfc, 0x94, 0x48, 0x52, 0x64, 0x7f, 0x7f, 0xec, 0x5e, 0x50, 0x82, 0xf4, 0x05, 0x99, 0x28, 0xec, 0xa8, 0x94, 0xc5, 0x94, 0x15, 0x13, 0x09, 0xac, 0x63, 0x1e, 0x4c, 0xb0, 0x33, 0x92, 0xaf, 0x68, 0x4b, 0x0b, 0xaf, 0xb7, 0xe6, 0x5b, 0x3b, 0x81, 0x62, 0xc2, 0xf5, 0x2b, 0xf9, 0x31, 0xb8, 0xe7, 0x7a, 0xaa, 0x82, 0xa3, 0x66, 0x30, 0x64, 0x30, 0x12, 0x06, 0x03, 0x55, 0x1d, 0x
[1756729186.466] [4637:4666] [DMG]                                      ] (463 bytes)
[1756729186.466] [4637:4666] [DMG]                              },
[1756729186.466] [4637:4666] [DMG]      ],
[1756729186.466] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729186.466] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1756729186.466] [4637:4666] [CTL] Received certificate chain from the device
[1756729186.466] [4637:4666] [CTL] Successfully finished commissioning step 'SendPAICertificateRequest'
[1756729186.466] [4637:4666] [CTL] Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
[1756729186.466] [4637:4666] [CTL] Performing next commissioning step 'SendDACCertificateRequest'
[1756729186.466] [4637:4666] [CTL] Sending request for DAC certificate
[1756729186.466] [4637:4666] [CTL] Sending Certificate Chain request to 0x7f8c041cb0 device
[1756729186.466] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729186.466] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729186.466] [4637:4666] [EM] <<< [E:62481i S:55443 M:88078151] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
[1756729186.467] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729186.467] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729186.552] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729186.645] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.646] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.781] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.781] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.870] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.871] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.871] [4637:4666] [EM] >>> [E:62481i S:55443 M:189832964] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:555)
[1756729186.871] [4637:4666] [EM] Found matching exchange: 62481i, Delegate: 0x7f8c008478
[1756729186.871] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729186.871] [4637:4666] [DMG] InvokeResponseMessage =
[1756729186.871] [4637:4666] [DMG] {
[1756729186.871] [4637:4666] [DMG]      suppressResponse = false,
[1756729186.871] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729186.872] [4637:4666] [DMG]      [
[1756729186.872] [4637:4666] [DMG]              InvokeResponseIB =
[1756729186.872] [4637:4666] [DMG]              {
[1756729186.872] [4637:4666] [DMG]                      CommandDataIB =
[1756729186.872] [4637:4666] [DMG]                              CommandPathIB =
[1756729186.872] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729186.872] [4637:4666] [DMG]                                      ClusterId = 0x3e,
[1756729186.872] [4637:4666] [DMG]                                      CommandId = 0x3,
[1756729186.872] [4637:4666] [DMG]                              },
[1756729186.872] [4637:4666] [DMG]                              CommandFields =
[1756729186.872] [4637:4666] [DMG]                                      0x0 = [
[1756729186.872] [4637:4666] [DMG]                                                      0x30, 0x82, 0x01, 0xe7, 0x30, 0x82, 0x01, 0x8e, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x58, 0x48, 0xb6, 0x4f, 0xbd, 0x0c, 0x9a, 0x6b, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x53, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x44, 0x41, 0x43, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x2f, 0x30, 0x78, 0x38, 0x30, 0x30, 0x37, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x37, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x1b, 0x68, 0x65, 0x0f, 0x97, 0xaa, 0xda, 0x54, 0x62, 0xa0, 0xd4, 0xdb, 0x5f, 0xd7, 0x84, 0x41, 0xb1, 0x48, 0x95, 0xd8, 0xd3, 0xc6, 0x20, 0x18, 0x33, 0x7f, 0x15, 0x23, 0xbb, 0xea, 0xb6, 0xd5, 0xf0, 0xdd, 0x6e, 0xed, 0x28, 0x83, 0x2e, 0x
[1756729186.872] [4637:4666] [DMG]                                      ] (491 bytes)
[1756729186.872] [4637:4666] [DMG]      ],
[1756729186.872] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729186.872] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1756729186.872] [4637:4666] [CTL] Received certificate chain from the device
[1756729186.872] [4637:4666] [CTL] Successfully finished commissioning step 'SendDACCertificateRequest'
[1756729186.872] [4637:4666] [CTL] Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
[1756729186.873] [4637:4666] [CTL] Performing next commissioning step 'SendAttestationRequest'
[1756729186.873] [4637:4666] [CTL] Sending Attestation Request to the device.
[1756729186.873] [4637:4666] [CTL] Sending Attestation request to 0x7f8c041cb0 device
[1756729186.873] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729186.873] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729186.873] [4637:4666] [EM] <<< [E:62482i S:55443 M:88078152] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:94)
[1756729186.874] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729186.874] [4637:4666] [CTL] Sent Attestation request, waiting for the Attestation Information
[1756729186.874] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729187.092] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729187.186] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729187.186] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729187.321] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729187.321] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729187.456] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729187.457] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729187.457] [4637:4666] [EM] >>> [E:62482i S:55443 M:189832965] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:716)
[1756729187.457] [4637:4666] [EM] Found matching exchange: 62482i, Delegate: 0x7f8c008628
[1756729187.457] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729187.457] [4637:4666] [DMG] InvokeResponseMessage =
[1756729187.457] [4637:4666] [DMG] {
[1756729187.457] [4637:4666] [DMG]      suppressResponse = false,
[1756729187.457] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729187.457] [4637:4666] [DMG]      [
[1756729187.457] [4637:4666] [DMG]              InvokeResponseIB =
[1756729187.457] [4637:4666] [DMG]                      CommandDataIB =
[1756729187.457] [4637:4666] [DMG]                              CommandPathIB =
[1756729187.457] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729187.457] [4637:4666] [DMG]                                      ClusterId = 0x3e,
[1756729187.457] [4637:4666] [DMG]                                      CommandId = 0x1,
[1756729187.457] [4637:4666] [DMG]                              },
[1756729187.457] [4637:4666] [DMG]                              CommandFields =
[1756729187.458] [4637:4666] [DMG]                                      0x0 = [
[1756729187.458] [4637:4666] [DMG]                                                      0x15, 0x31, 0x01, 0x1d, 0x02, 0x30, 0x82, 0x02, 0x19, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x82, 0x02, 0x0a, 0x30, 0x82, 0x02, 0x06, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x82, 0x01, 0x71, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x82, 0x01, 0x62, 0x04, 0x82, 0x01, 0x5e, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0xf1, 0xff, 0x36, 0x02, 0x05, 0x00, 0x80, 0x05, 0x01, 0x80, 0x05, 0x02, 0x80, 0x05, 0x03, 0x80, 0x05, 0x04, 0x80, 0x05, 0x05, 0x80, 0x05, 0x06, 0x80, 0x05, 0x07, 0x80, 0x05, 0x08, 0x80, 0x05, 0x09, 0x80, 0x05, 0x0a, 0x80, 0x05, 0x0b, 0x80, 0x05, 0x0c, 0x80, 0x05, 0x0d, 0x80, 0x05, 0x0e, 0x80, 0x05, 0x0f, 0x80, 0x05, 0x10, 0x80, 0x05, 0x11, 0x80, 0x05, 0x12, 0x80, 0x05, 0x13, 0x80, 0x05, 0x14, 0x80, 0x05, 0x15, 0x80, 0x05, 0x16, 0x80, 0x05, 0x17, 0x80, 0x05, 0x18, 0x80, 0x05, 0x19, 0x80, 0x05, 0x1a, 0x80, 0x05, 0x1b, 0x80, 0x05, 0x1c, 0x80, 0x05, 0x1d, 0x80, 0x05, 0x1e, 0x80, 0x05, 0x1f, 0x80, 0x05, 0x20, 0x80, 0x05, 0x21, 0x80, 0x05, 0x22, 0x80, 0x05, 0x23, 0x80, 0x05, 0x24, 0x80, 0x05, 0x25, 0x80, 0x05, 0x26, 0x80, 0x05, 0x27, 0x80, 0x05, 0x28, 0x80, 0x05, 0x29, 0x80, 0x05, 0x2a, 0x80, 0x05, 0x2b, 0x80, 0x05, 0x2c, 0x80, 0x05, 0x2d, 0x80, 0x05, 0x2e, 0x80, 0x05, 0x2f, 0x80, 0x05, 0x30, 0x80, 0x05, 0x31, 0x80, 0x05, 0x32, 0x80, 0x05, 0x33, 0x80, 0x05, 0x34, 0x80, 0x05, 0x35, 0x80, 0x05, 0x36, 0x80, 0x05, 0x37, 0x80, 0x05, 0x38, 0x80, 0x05, 0x39, 0x80, 0x05, 0x3a, 0x80, 0x05, 0x3b, 0x80, 0x05, 0x3c, 0x80, 0x05, 0x3d, 0x80, 0x05, 0x3e, 0x80, 0x05, 0x3f, 0x80, 0x05, 0x40, 0x80, 0x05, 0x41, 0x80, 0x05, 0x42, 0x80, 0x05, 0x43, 0x80, 0x
[1756729187.458] [4637:4666] [DMG]                                      ] (585 bytes)
[1756729187.458] [4637:4666] [DMG]                                      0x1 = [
[1756729187.458] [4637:4666] [DMG]                                                      0x9f, 0x45, 0x9e, 0x15, 0xa5, 0x84, 0x57, 0xe4, 0xfa, 0x27, 0x5f, 0x76, 0xef, 0x1a, 0x9a, 0xa3, 0xec, 0xb5, 0x5f, 0x3a, 0xd2, 0x23, 0xd6, 0x5d, 0x68, 0x89, 0xa2, 0x28, 0x93, 0x62, 0x51, 0x76, 0x05, 0x50, 0x47, 0xb4, 0x9d, 0xe8, 0x78, 0x4b, 0x03, 0x2b, 0x07, 0x58, 0xcc, 0x0b, 0x18, 0x0f, 0x46, 0xbf, 0xbf, 0x1a, 0x20, 0xd9, 0x9c, 0xde, 0x03, 0xf1, 0x53, 0x32, 0xff, 0x52, 0x5a, 0xb4,
[1756729187.458] [4637:4666] [DMG]                                      ] (64 bytes)
[1756729187.458] [4637:4666] [DMG]                              },
[1756729187.458] [4637:4666] [DMG]      ],
[1756729187.458] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729187.458] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
[1756729187.458] [4637:4666] [CTL] Received Attestation Information from the device
[1756729187.458] [4637:4666] [CTL] Successfully finished commissioning step 'SendAttestationRequest'
[1756729187.458] [4637:4666] [CTL] AutoCommissioner setting attestationElements buffer size 585/585
[1756729187.458] [4637:4666] [CTL] Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
[1756729187.458] [4637:4666] [CTL] Performing next commissioning step 'AttestationVerification'
[1756729187.458] [4637:4666] [CTL] Verifying Device Attestation information received from the device
[1756729187.478] [4637:4666] [-] Device candidate DAC chain details:
[1756729187.478] [4637:4666] [-] --> DAC's VID: 0xFFF1, PID: 0x8007
[1756729187.478] [4637:4666] [-] ==== DAC certificate considered (491 bytes) ====
[1756729187.478] [4637:4666] [-] -----BEGIN CERTIFICATE-----
[1756729187.478] [4637:4666] [-] MIIB5zCCAY6gAwIBAgIIWEi2T70MmmswCgYIKoZIzj0EAwIwPTElMCMGA1UEAwwc
[1756729187.478] [4637:4666] [-] TWF0dGVyIERldiBQQUkgMHhGRkYxIG5vIFBJRDEUMBIGCisGAQQBgqJ8AgEMBEZG
[1756729187.478] [4637:4666] [-] RjEwIBcNMjIwMjA1MDAwMDAwWhgPOTk5OTEyMzEyMzU5NTlaMFMxJTAjBgNVBAMM
[1756729187.478] [4637:4666] [-] HE1hdHRlciBEZXYgREFDIDB4RkZGMS8weDgwMDcxFDASBgorBgEEAYKifAIBDARG
[1756729187.478] [4637:4666] [-] RkYxMRQwEgYKKwYBBAGConwCAgwEODAwNzBZMBMGByqGSM49AgEGCCqGSM49AwEH
[1756729187.478] [4637:4666] [-] A0IABBtoZQ+XqtpUYqDU21/XhEGxSJXY08YgGDN/FSO76rbV8N1u7SiDLvlIiRuX
[1756729187.478] [4637:4666] [-] aoMb6oLbmnfj6klHtB2Hagji3WKjYDBeMAwGA1UdEwEB/wQCMAAwDgYDVR0PAQH/
[1756729187.478] [4637:4666] [-] BAQDAgeAMB0GA1UdDgQWBBShgQsewlHhuLRFNTSRqRhdV1IRRzAfBgNVHSMEGDAW
[1756729187.478] [4637:4666] [-] gBRjVA5H9kscONE4hKRi0WwZXY/7PDAKBggqhkjOPQQDAgNHADBEAiBIldL+9SOX
[1756729187.478] [4637:4666] [-] PHjbxgV9RPzHbiHjUlNuiRDzLuwZ/im8JAIgCMwbPSElYHRxX7xZ6Qdn/iLuXxW7
[1756729187.478] [4637:4666] [-] +glAsd/WUkT1UWM=
[1756729187.478] [4637:4666] [-] -----END CERTIFICATE-----
[1756729187.481] [4637:4666] [-] --> DAC certificate SKID: A1:81:0B:1E:C2:51:E1:B8:B4:45:35:34:91:A9:18:5D:57:52:11:47
[1756729187.483] [4637:4666] [-] --> DAC certificate AKID: 63:54:0E:47:F6:4B:1C:38:D1:38:84:A4:62:D1:6C:19:5D:8F:FB:3C
[1756729187.483] [4637:4666] [-] ==== PAI certificate considered (463 bytes) ====
[1756729187.483] [4637:4666] [-] -----BEGIN CERTIFICATE-----
[1756729187.483] [4637:4666] [-] MIIByzCCAXGgAwIBAgIIVq2CIq2UW2QwCgYIKoZIzj0EAwIwMDEYMBYGA1UEAwwP
[1756729187.483] [4637:4666] [-] TWF0dGVyIFRlc3QgUEFBMRQwEgYKKwYBBAGConwCAQwERkZGMTAgFw0yMjAyMDUw
[1756729187.483] [4637:4666] [-] MDAwMDBaGA85OTk5MTIzMTIzNTk1OVowPTElMCMGA1UEAwwcTWF0dGVyIERldiBQ
[1756729187.483] [4637:4666] [-] QUkgMHhGRkYxIG5vIFBJRDEUMBIGCisGAQQBgqJ8AgEMBEZGRjEwWTATBgcqhkjO
[1756729187.483] [4637:4666] [-] PQIBBggqhkjOPQMBBwNCAARBmpMVwhc+DIyHbQPM/JRIUmR/f+xeUIL0BZko7KiU
[1756729187.483] [4637:4666] [-] xZQVEwmsYx5MsDOSr2hLC6+35ls7gWLC9Sv5MbjneqqCo2YwZDASBgNVHRMBAf8E
[1756729187.483] [4637:4666] [-] CDAGAQH/AgEAMA4GA1UdDwEB/wQEAwIBBjAdBgNVHQ4EFgQUY1QOR/ZLHDjROISk
[1756729187.483] [4637:4666] [-] YtFsGV2P+zwwHwYDVR0jBBgwFoAUav0idx9RH+y/FkGXZxDc3DGhcX4wCgYIKoZI
[1756729187.483] [4637:4666] [-] zj0EAwIDSAAwRQIhALLvJ/Sa6bUPuR7qyUxNC9u415KcbLiPrOUpNo0SBUwMAiBl
[1756729187.483] [4637:4666] [-] Xckrhr2QmIKmxiF3uCXX0F7b58Ivn+pxIg5+pwP4kQ==
[1756729187.483] [4637:4666] [-] -----END CERTIFICATE-----
[1756729187.486] [4637:4666] [-] --> PAI certificate SKID: 63:54:0E:47:F6:4B:1C:38:D1:38:84:A4:62:D1:6C:19:5D:8F:FB:3C
[1756729187.488] [4637:4666] [-] --> PAI certificate AKID: 6A:FD:22:77:1F:51:1F:EC:BF:16:41:97:67:10:DC:DC:31:A1:71:7E
[1756729187.495] [4637:4666] [CTL] Error on commissioning step 'AttestationVerification': 'src/controller/CHIPDeviceController.cpp:1291: CHIP Error 0x00000020: Failed Device Attestation'
[1756729187.495] [4637:4666] [CTL] Failed verifying attestation information. Now checking DAC chain revoked status.
[1756729187.495] [4637:4666] [CTL] Commissioning stage next step: 'AttestationVerification' -> 'AttestationRevocationCheck'
[1756729187.495] [4637:4666] [CTL] Performing next commissioning step 'AttestationRevocationCheck' with completion status = 'src/controller/CHIPDeviceController.cpp:1291: CHIP Error 0x00000020: Failed Device Attestation'
[1756729187.495] [4637:4666] [CTL] Verifying the device's DAC chain revocation status
[1756729187.495] [4637:4666] [-] WARNING: No revocation delegate available. Revocation checks will be skipped!
[1756729187.495] [4637:4666] [CTL] Failed in verifying 'Attestation Information' command received from the device: err 500 (Attestation signature failed to validate against DAC subject public key)
[1756729187.495] [4637:4666] [CTL] Error on commissioning step 'AttestationRevocationCheck': 'src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation'
[1756729187.495] [4637:4666] [CTL] Going from commissioning step 'AttestationRevocationCheck' with lastErr = 'src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation' -> 'Cleanup'
[1756729187.495] [4637:4666] [CTL] Performing next commissioning step 'Cleanup' with completion status = 'src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation'
[1756729187.496] [4637:4666] [CTL] Disarming failsafe on device 0x7f8c041cb0
[1756729187.496] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729187.496] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729187.496] [4637:4666] [EM] <<< [E:62483i S:55443 M:88078153] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
[1756729187.497] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729187.497] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729187.588] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729187.592] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729187.592] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729187.593] [4637:4666] [EM] >>> [E:62483i S:55443 M:189832966] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
[1756729187.593] [4637:4666] [EM] Found matching exchange: 62483i, Delegate: 0x7f8c008478
[1756729187.593] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729187.593] [4637:4666] [DMG] InvokeResponseMessage =
[1756729187.593] [4637:4666] [DMG] {
[1756729187.593] [4637:4666] [DMG]      suppressResponse = false,
[1756729187.593] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729187.593] [4637:4666] [DMG]      [
[1756729187.593] [4637:4666] [DMG]              InvokeResponseIB =
[1756729187.593] [4637:4666] [DMG]                      CommandDataIB =
[1756729187.593] [4637:4666] [DMG]                              CommandPathIB =
[1756729187.594] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729187.594] [4637:4666] [DMG]                                      ClusterId = 0x30,
[1756729187.594] [4637:4666] [DMG]                                      CommandId = 0x1,
[1756729187.594] [4637:4666] [DMG]                              },
[1756729187.594] [4637:4666] [DMG]                              CommandFields =
[1756729187.594] [4637:4666] [DMG]                              {
[1756729187.594] [4637:4666] [DMG]                                      0x0 = 0 (unsigned),
[1756729187.594] [4637:4666] [DMG]                                      0x1 = "" (0 chars),
[1756729187.594] [4637:4666] [DMG]      ],
[1756729187.594] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729187.595] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1756729187.595] [4637:4666] [CTL] Failsafe disarmed
[1756729187.595] [4637:4666] [CTL] Successfully finished commissioning step 'Cleanup'
[1756729187.595] [4637:4666] [DIS] Closing all BLE connections
[1756729187.595] [4637:4666] [IN] Clearing BLE pending packets.
[1756729187.597] [4637:4666] [BLE] Auto-closing end point's BLE connection.
[1756729187.597] [4637:4666] [DL] Closing BLE GATT connection (con 0x559d170f30)
[1756729187.597] [4637:4665] [DL] Close BLE connection: peer=F8:11:F3:72:95:B3
[1756729187.818] [4637:4666] [IN] SecureSession[0x7f8c013400]: MarkForEviction Type:1 LSID:55443
[1756729187.818] [4637:4666] [SC] SecureSession[0x7f8c013400, LSID:55443]: State change 'kActive' --> 'kPendingEviction'
[1756729187.818] [4637:4666] [CTL] Commissioning complete for node ID 0x0000000000000001: src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation
[1756729187.818] [4637:4666] [TOO] Device commissioning Failure: src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation
[1756729187.818] [4637:4666] [TOO] Run command failure: src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation
[1756729187.818] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729187.818] [4637:4666] [IN] SecureSession[0x7f8c013400]: Released - Type:1 LSID:55443
[1756729187.818] [4637:4666] [DL] Long dispatch time: 226 ms, for event type 16391
[1756729187.819] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16390
[1756729187.819] [4637:4666] [BLE] No endpoint for unsubscribe complete
[1756729187.822] [4637:4665] [DL] BLE connection closed: conn=0x559d170f30
[1756729187.823] [4637:4666] [BLE] No endpoint for connection error
  • I've generated new DAC via chip-cert tool using following command with cert and keys that are placed in sdk v3.0.2/modules/lib/matter/credentials/development/attestation/. That files are used by default via build system to create factory data partition.
    ./chip-cert gen-att-cert --type d --subject-cn "Matter Dev DAC 0xFFF1/0x8006" --subject-vid FFF1 --subject-pid 8006 --valid-from "2025-08-15 14:23:43" --lifetime 7305 --ca-key /home/lukasz/v3.0.2/modules/lib/matter/credentials/development/attestation/Matter-Development-PAI-FFF1-noPID-Key.pem --ca-cert /home/lukasz/v3.0.2/modules/lib/matter/credentials/development/attestation/Matter-Development-PAI-FFF1-noPID-Cert.pem --key /home/lukasz/v3.0.2/modules/lib/matter/credentials/development/attestation/Matter-Development-DAC-FFF1-8006-Key.pem --out Chip-DAC-Cert-8006.pem
    And here is newly generated Chip-DAC-Cert-8006 cert in pem format. I have even setup the same subject cn name.
    MIIB5jCCAYygAwIBAgIIODSISV+9ydswCgYIKoZIzj0EAwIwPTElMCMGA1UEAwwc
    RjEwHhcNMjUwODE1MTQyMzQzWhcNNDUwODE1MTQyMzQyWjBTMSUwIwYDVQQDDBxN
    YXR0ZXIgRGV2IERBQyAweEZGRjEvMHg4MDA2MRQwEgYKKwYBBAGConwCAQwERkZG
    MTEUMBIGCisGAQQBgqJ8AgIMBDgwMDYwWTATBgcqhkjOPQIBBggqhkjOPQMBBwNC
    AAReke2SUBbMgmcZegkLdTPlVOJciwk83cqer8unR/64tbjceJ8PnbDY/K6sbP2D
    nFGzvQ5Lx2lOYIac+Ooed7cYo2AwXjAMBgNVHRMBAf8EAjAAMA4GA1UdDwEB/wQE
    AwIHgDAdBgNVHQ4EFgQU0kT0plnYDVd2HuUJT3SHWJZJWEMwHwYDVR0jBBgwFoAU
    Y1QOR/ZLHDjROISkYtFsGV2P+zwwCgYIKoZIzj0EAwIDSAAwRQIgcGkNoChnMbgs
    EN7ARu8J515ttkkfKXdgTRvtzi6mQ60CIQCcOf3pLmiMBZnUvhq44c7vfXCSEIwN
    LsVhNI+aAXu1Ow==
    Repro will take only 15mins ;)
  • LukaWer said:
    Questions
    1. Besides CONFIG_CHIP_DEVICE_PRODUCT_ID, are there other Kconfig/CMake/factory-data items that must be kept in sync (e.g., PID/VID in factory data, certificate templates, Certification Declaration, or build-time attestation artifacts)?
    2. Are there any known limitations or issues in NCS 3.0.2 when changing PID between samples?
    3. What would help most for diagnosis?
    Doc Generating CD:https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/protocols/matter/end_product/configuring_cd.html
    you can look at example of configuration: https://github.com/nrfconnect/sdk-nrf/blob/main/samples/matter/common/src/certification/thread_platform/overlay-thread_platform.conf
    also https://github.com/nrfconnect/sdk-nrf/blob/main/samples/matter/common/src/certification/chip_project_config.h
    1. This config need to be synced, so CD need to be generated with this PID argument, set the same CONFIG in kConfig, also generate Attestation chain using this PID too.
    2. We are not aware of such limitation.
    3. Please provide information how the Attestation chain has been generated (shell command), how has the CD been generated (shell command), and what are the values of VID  and PID in the Kconfig
    Given that you have the hardware required present.
    Andreas
  • Please provide information how the Attestation chain has been generated (shell command), how has the CD been generated (shell command), and what are the values of VID  and PID in the Kconfig
    I didn't generate full Attestation chain in that case (using sample apps). I've used that one available in matter repo at :
    What I've did now was just try to generate "the same" DAC certificate byself as that one present in repo: Matter-Development-DAC-FFF1-8006-Cert.pem.
    I've used following command:
    and received below output:
    LsVhNI+aAXu1Ow==
    To sum up: I've even used the same private/public key which is used in original DAC placed in Matter repo.
  • Sorry for the confusion, but case from my previous message works. Whenever I use v3.0.2\modules\lib\matter\credentials\development\attestation\Matter-Development-DAC-FFF1-8006-Key.pem for new cert generation via chip-cert tool then Attestation of Matter lock sample works.
    When I want to generate CERT with NEW keypair via following commands:
    ./chip-cert gen-att-cert --type d --subject-cn "Matter Dev DAC 0xFFF1/0x8006" --subject-vid FFF1 --subject-pid 8006 --valid-from "2025-08-15 14:23:43" --lifetime 7305 --ca-key /home/lukasz/v3.0.2/modules/lib/matter/credentials/development/attestation/Matter-Development-PAI-FFF1-noPID-Key.pem --ca-cert /home/lukasz/v3.0.2/modules/lib/matter/credentials/development/attestation/Matter-Development-PAI-FFF1-noPID-Cert.pem --out Chip-DAC-Cert-8006.pem --out-key Chip-DAC-Cert-8006-key.pem
    ./chip-cert convert-cert -d Chip-DAC-Cert-8006.pem Chip-DAC-Cert-8006.der
    ./chip-cert convert-key -d Chip-DAC-Cert-8006-key.pem Chip-DAC-Cert-8006-key.der
    Generate new Factory data partition via:
    python generate_nrfconnect_chip_factory_data.py --sn 11223344556677889900 --date 2022-01-01 --vendor_id 65521 --product_id 32774 --vendor_name "Nordic Semiconductor ASA" --product_name not-specified --hw_ver 0 --hw_ver_str prerelease --dac_cert Chip-DAC-Cert-8006.der --dac_key tChip-DAC-Cert-8006-key.der --pai_cert C:/ncs/v3.0.2/modules/lib/matter/credentials/development/attestation/Matter-Development-PAI-FFF1-noPID-Cert.der --spake2_it 1000 --spake2_salt U1BBS0UyUCBLZXkgU2FsdA== --discriminator 0xF00 --passcode 20202021 --include_passcode --overwrite --product_finish other --generate_onboarding --enable_key 00112233445566778899AABBCCDDEEFF -o C:/ncs/v3.0.2/nrf/samples/matter/lock/build/lock/zephyr/factory_data -s C:/ncs/v3.0.2/modules/lib/matter/scripts/tools/nrfconnect/nrfconnect_factory_data.schema --offset 0xf7000 --size 0xf7000
    In that scenario I'm not able to Attestate device cause of: [CTL] Failed in verifying 'Attestation Information' command received from the device: err 500 (Attestation signature failed to validate against DAC subject public key). Log from chip-tool.
    I attach zipped certificate, key and factory data partition I've generated.
    Chip-DAC-Cert-8006.zip
    It seems like some hardcoded key in example firmware that is not readed from FactoryData partition.
  • Hi  , any updates on the commissioning/attestation failures in that case?
    Lukasz
