Matter Door Lock sample fails after changing PRODUCT_ID to 0x8007 (NCS 3.0.2)
I’m working with the Matter Door Lock sample in NCS 3.0.2. With the default PRODUCT_ID = 0x8006, everything works as expected: commissioning to Apple Home and Google Home succeeds, and chip-tool operates without issues. However, when I change the PRODUCT_ID to 0x8007, it stops working.
I also tested with a custom DAC (PID 0x8006) generated via the PKI provider. The DAC, private key, and related artifacts appear to be correctly linked by the Matter build scripts.
What could be causing this behavior? Below are chip-tool logs from a build configured with PID 0x8007.
Lukasz
[1756729182.855] [4637:4665] [DL] ConnectDevice retry: 1 out of 4
[1756729183.135] [4637:4665] [DL] ConnectDevice complete
[1756729183.135] [4637:4665] [BLE] New device connected: F8:11:F3:72:95:B3
[1756729184.193] [4637:4665] [DL] CHIP service found
[1756729184.193] [4637:4665] [DL] Valid C2 characteristic found
[1756729184.193] [4637:4665] [DL] Valid C1 characteristic found
[1756729184.193] [4637:4665] [DL] New BLE connection: conn=0x559d170f30 device=F8:11:F3:72:95:B3 path=/org/bluez/hci0/dev_F8_11_F3_72_95_B3
[1756729184.193] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16387
[1756729184.193] [4637:4666] [DIS] Closing all BLE connections
[1756729184.194] [4637:4666] [IN] BleConnectionComplete: endPoint 0x5586c61980
[1756729184.194] [4637:4666] [IN] SecureSession[0x7f8c013400]: Allocated Type:1 LSID:55443
[1756729184.195] [4637:4666] [SC] Assigned local session key ID 55443
[1756729184.195] [4637:4666] [EM] <<< [E:62475i S:0 M:104807131] (U) Msg TX from 7BAB2C28A239BDC5 to 0:0000000000000000 [0000] [BLE] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:98)
[1756729184.196] [4637:4666] [IN] Message appended to BLE send queue
[1756729184.196] [4637:4666] [SC] Sent PBKDF param request [II:500ms AI:300ms AT:4000ms)
[1756729184.572] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729184.663] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16390
[1756729184.663] [4637:4666] [BLE] subscribe complete, ep = 0x5586c61980
[1756729184.665] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729184.665] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729184.665] [4637:4666] [BLE] peripheral chose BTP version 4; central expected between 4 and 4
[1756729184.665] [4637:4666] [BLE] using BTP fragment sizes rx 244 / tx 244.
[1756729184.665] [4637:4666] [BLE] local and remote recv window size = 5
[1756729184.666] [4637:4666] [IN] BLE EndPoint 0x5586c61980 Connection Complete
[1756729184.797] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729184.846] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729184.846] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729184.846] [4637:4666] [EM] >>> [E:62475i S:0 M:83346254] (U) Msg RX from 0:0000000000000000 [0000] to 7BAB2C28A239BDC5 --- Type 0000:21 (SecureChannel:PBKDFParamResponse) (B:154)
[1756729184.846] [4637:4666] [EM] Found matching exchange: 62475i, Delegate: 0x7f8c041d08
[1756729184.847] [4637:4666] [SC] Received PBKDF param response
[1756729184.847] [4637:4666] [SC] Peer assigned session ID 31551
[1756729184.847] [4637:4666] [SC] Found MRP parameters in the message
[1756729184.862] [4637:4666] [EM] <<< [E:62475i S:0 M:104807132] (U) Msg TX from 7BAB2C28A239BDC5 to 0:0000000000000000 [0000] [BLE] --- Type 0000:22 (SecureChannel:PASE_Pake1) (B:92)
[1756729184.863] [4637:4666] [SC] Sent spake2p msg1
[1756729184.977] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729185.158] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.158] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.158] [4637:4666] [EM] >>> [E:62475i S:0 M:83346255] (U) Msg RX from 0:0000000000000000 [0000] to 7BAB2C28A239BDC5 --- Type 0000:23 (SecureChannel:PASE_Pake2) (B:127)
[1756729185.158] [4637:4666] [EM] Found matching exchange: 62475i, Delegate: 0x7f8c041d08
[1756729185.158] [4637:4666] [SC] Received spake2p msg2
[1756729185.161] [4637:4666] [EM] <<< [E:62475i S:0 M:104807133] (U) Msg TX from 7BAB2C28A239BDC5 to 0:0000000000000000 [0000] [BLE] --- Type 0000:24 (SecureChannel:PASE_Pake3) (B:59)
[1756729185.162] [4637:4666] [SC] Sent spake2p msg3
[1756729185.247] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729185.249] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.250] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.250] [4637:4666] [EM] >>> [E:62475i S:0 M:83346256] (U) Msg RX from 0:0000000000000000 [0000] to 7BAB2C28A239BDC5 --- Type 0000:40 (SecureChannel:StatusReport) (B:30)
[1756729185.250] [4637:4666] [EM] Found matching exchange: 62475i, Delegate: 0x7f8c041d08
[1756729185.250] [4637:4666] [SC] SecureSession[0x7f8c013400, LSID:55443]: State change 'kEstablishing' --> 'kActive'
[1756729185.250] [4637:4666] [IN] SecureSession[0x7f8c013400]: Activated - Type:1 LSID:55443
[1756729185.250] [4637:4666] [IN] New secure session activated for device <FFFFFFFB00000000, 0>, LSID:55443 PSID:31551!
[1756729185.250] [4637:4666] [CTL] Remote device completed SPAKE2+ handshake
[1756729185.250] [4637:4666] [TOO] Pairing Success
[1756729185.250] [4637:4666] [TOO] PASE establishment successful
[1756729185.250] [4637:4666] [CTL] Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
[1756729185.250] [4637:4666] [CTL] Performing next commissioning step 'ReadCommissioningInfo'
[1756729185.250] [4637:4666] [CTL] Sending read requests for commissioning information
[1756729185.251] [4637:4666] [DMG] SendReadRequest ReadClient[0x7f8c017800]: Sending Read Request
[1756729185.251] [4637:4666] [DMG] 0 data version filters provided, 0 not relevant, 0 encoded, 0 skipped due to lack of space
[1756729185.251] [4637:4666] [EM] <<< [E:62476i S:55443 M:88078146] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:02 (IM:ReadRequest) (B:134)
[1756729185.252] [4637:4666] [DMG] MoveToState ReadClient[0x7f8c017800]: Moving to [AwaitingIn]
[1756729185.252] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 32792
[1756729185.382] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729185.473] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.473] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.564] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.564] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.564] [4637:4666] [EM] >>> [E:62476i S:55443 M:189832959] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:05 (IM:ReportData) (B:257)
[1756729185.564] [4637:4666] [EM] Found matching exchange: 62476i, Delegate: 0x7f8c017810
[1756729185.565] [4637:4666] [DMG] ReportDataMessage =
[1756729185.565] [4637:4666] [DMG] {
[1756729185.565] [4637:4666] [DMG]      AttributeReportIBs =
[1756729185.565] [4637:4666] [DMG]      [
[1756729185.565] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.565] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.565] [4637:4666] [DMG]                              DataVersion = 0x96cc64bf,
[1756729185.565] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.565] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.565] [4637:4666] [DMG]                                      Cluster = 0x31,
[1756729185.565] [4637:4666] [DMG]                                      Attribute = 0x0000_FFFC,
[1756729185.565] [4637:4666] [DMG]                              }
[1756729185.565] [4637:4666] [DMG]                              Data = 2 (unsigned),
[1756729185.565] [4637:4666] [DMG]                      },
[1756729185.566] [4637:4666] [DMG]                              DataVersion = 0xb0fb55ae,
[1756729185.566] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.566] [4637:4666] [DMG]                              {
[1756729185.566] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.566] [4637:4666] [DMG]                                      Cluster = 0x28,
[1756729185.566] [4637:4666] [DMG]                                      Attribute = 0x0000_0004,
[1756729185.566] [4637:4666] [DMG]                              }
[1756729185.566] [4637:4666] [DMG]                              Data = 32775 (unsigned),
[1756729185.566] [4637:4666] [DMG]                      },
[1756729185.566] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.566] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.566] [4637:4666] [DMG]                                      Attribute = 0x0000_0002,
[1756729185.566] [4637:4666] [DMG]                              Data = 65521 (unsigned),
[1756729185.566] [4637:4666] [DMG]                              DataVersion = 0x8c803ba9,
[1756729185.566] [4637:4666] [DMG]                                      Cluster = 0x30,
[1756729185.566] [4637:4666] [DMG]                                      Attribute = 0x0000_0003,
[1756729185.566] [4637:4666] [DMG]                              Data = 0 (unsigned),
[1756729185.567] [4637:4666] [DMG]                      {
[1756729185.567] [4637:4666] [DMG]                              DataVersion = 0x8c803ba9,
[1756729185.567] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.567] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.567] [4637:4666] [DMG]                                      Cluster = 0x30,
[1756729185.567] [4637:4666] [DMG]                                      Attribute = 0x0000_0002,
[1756729185.567] [4637:4666] [DMG]                              }
[1756729185.567] [4637:4666] [DMG]                              Data = 0 (unsigned),
[1756729185.567] [4637:4666] [DMG]                      },
[1756729185.567] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.568] [4637:4666] [DMG]              {
[1756729185.568] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.568] [4637:4666] [DMG]                              DataVersion = 0x8c803ba9,
[1756729185.568] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.568] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.568] [4637:4666] [DMG]                                      Cluster = 0x30,
[1756729185.568] [4637:4666] [DMG]                                      Attribute = 0x0000_0001,
[1756729185.569] [4637:4666] [DMG]                              }
[1756729185.569] [4637:4666] [DMG]                              Data =
[1756729185.569] [4637:4666] [DMG]                              {
[1756729185.569] [4637:4666] [DMG]                                      0x0 = 60 (unsigned),
[1756729185.569] [4637:4666] [DMG]                                      0x1 = 900 (unsigned),
[1756729185.569] [4637:4666] [DMG]                              },
[1756729185.569] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.569] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.569] [4637:4666] [DMG]                              DataVersion = 0x8c803ba9,
[1756729185.569] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.569] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.569] [4637:4666] [DMG]                                      Cluster = 0x30,
[1756729185.569] [4637:4666] [DMG]                                      Attribute = 0x0000_0000,
[1756729185.569] [4637:4666] [DMG]                              Data = 0 (unsigned),
[1756729185.569] [4637:4666] [DMG]                                      Attribute = 0x0000_0004,
[1756729185.569] [4637:4666] [DMG]                              Data = true,
[1756729185.569] [4637:4666] [DMG]      ],
[1756729185.570] [4637:4666] [DMG]
[1756729185.570] [4637:4666] [DMG]      SuppressResponse = true,
[1756729185.570] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729185.570] [4637:4666] [DMG] }
[1756729185.571] [4637:4666] [DMG] SendReadRequest ReadClient[0x7f8c017800]: Sending Read Request
[1756729185.571] [4637:4666] [DMG] 0 data version filters provided, 0 not relevant, 0 encoded, 0 skipped due to lack of space
[1756729185.572] [4637:4666] [EM] <<< [E:62477i S:55443 M:88078147] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:02 (IM:ReadRequest) (B:103)
[1756729185.573] [4637:4666] [DMG] MoveToState ReadClient[0x7f8c017800]: Moving to [AwaitingIn]
[1756729185.697] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729185.790] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.790] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.790] [4637:4666] [EM] >>> [E:62477i S:55443 M:189832960] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:05 (IM:ReportData) (B:192)
[1756729185.791] [4637:4666] [EM] Found matching exchange: 62477i, Delegate: 0x7f8c017810
[1756729185.791] [4637:4666] [DMG] ReportDataMessage =
[1756729185.791] [4637:4666] [DMG] {
[1756729185.791] [4637:4666] [DMG]      AttributeReportIBs =
[1756729185.791] [4637:4666] [DMG]      [
[1756729185.791] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.791] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.791] [4637:4666] [DMG]                              DataVersion = 0xd11f275b,
[1756729185.791] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.791] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.791] [4637:4666] [DMG]                                      Cluster = 0x46,
[1756729185.791] [4637:4666] [DMG]                                      Attribute = 0x0000_0002,
[1756729185.791] [4637:4666] [DMG]                              }
[1756729185.791] [4637:4666] [DMG]                              Data = 300 (unsigned),
[1756729185.792] [4637:4666] [DMG]                      },
[1756729185.792] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.792] [4637:4666] [DMG]              {
[1756729185.792] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.792] [4637:4666] [DMG]                              DataVersion = 0xd11f275b,
[1756729185.792] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.792] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.792] [4637:4666] [DMG]                                      Cluster = 0x46,
[1756729185.792] [4637:4666] [DMG]                                      Attribute = 0x0000_0001,
[1756729185.792] [4637:4666] [DMG]                              Data = 300 (unsigned),
[1756729185.792] [4637:4666] [DMG]                                      Attribute = 0x0000_0000,
[1756729185.792] [4637:4666] [DMG]                              Data = 120 (unsigned),
[1756729185.792] [4637:4666] [DMG]                      AttributeStatusIB =
[1756729185.792] [4637:4666] [DMG]                                      Attribute = 0x0000_0007,
[1756729185.793] [4637:4666] [DMG]                              StatusIB =
[1756729185.793] [4637:4666] [DMG]                              {
[1756729185.793] [4637:4666] [DMG]                                      status = 0x86 (UNSUPPORTED_ATTRIBUTE),
[1756729185.793] [4637:4666] [DMG]                              },
[1756729185.793] [4637:4666] [DMG]              AttributeReportIB =
[1756729185.793] [4637:4666] [DMG]                      AttributeStatusIB =
[1756729185.793] [4637:4666] [DMG]                              AttributePathIB =
[1756729185.793] [4637:4666] [DMG]                                      Endpoint = 0x0,
[1756729185.793] [4637:4666] [DMG]                                      Cluster = 0x46,
[1756729185.793] [4637:4666] [DMG]                                      Attribute = 0x0000_0006,
[1756729185.793] [4637:4666] [DMG]                      AttributeDataIB =
[1756729185.793] [4637:4666] [DMG]                              DataVersion = 0x96cc64bf,
[1756729185.793] [4637:4666] [DMG]                                      Cluster = 0x31,
[1756729185.793] [4637:4666] [DMG]                                      Attribute = 0x0000_0003,
[1756729185.793] [4637:4666] [DMG]                              Data = 20 (unsigned),
[1756729185.794] [4637:4666] [DMG]      ],
[1756729185.794] [4637:4666] [DMG]      SuppressResponse = true,
[1756729185.794] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729185.794] [4637:4666] [DMG] }
[1756729185.795] [4637:4666] [CTL] NetworkCommissioning Features: has Thread. endpointid = 0
[1756729185.795] [4637:4666] [SVR] OnReadCommissioningInfo - vendorId=0xFFF1 productId=0x8007
[1756729185.795] [4637:4666] [SVR] OnReadCommissioningInfo ICD - IdleModeDuration=0 activeModeDuration=0 activeModeThreshold=0
[1756729185.795] [4637:4666] [CTL] Successfully finished commissioning step 'ReadCommissioningInfo'
[1756729185.795] [4637:4666] [CTL] Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
[1756729185.795] [4637:4666] [CTL] Performing next commissioning step 'ArmFailSafe'
[1756729185.795] [4637:4666] [CTL] Arming failsafe (60 seconds)
[1756729185.795] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729185.795] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729185.796] [4637:4666] [EM] <<< [E:62478i S:55443 M:88078148] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
[1756729185.797] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729185.877] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729185.880] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729185.880] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729185.881] [4637:4666] [EM] >>> [E:62478i S:55443 M:189832961] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
[1756729185.881] [4637:4666] [EM] Found matching exchange: 62478i, Delegate: 0x7f8c008628
[1756729185.881] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729185.881] [4637:4666] [DMG] InvokeResponseMessage =
[1756729185.881] [4637:4666] [DMG] {
[1756729185.881] [4637:4666] [DMG]      suppressResponse = false,
[1756729185.881] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729185.881] [4637:4666] [DMG]      [
[1756729185.881] [4637:4666] [DMG]              InvokeResponseIB =
[1756729185.881] [4637:4666] [DMG]                      CommandDataIB =
[1756729185.881] [4637:4666] [DMG]                              CommandPathIB =
[1756729185.881] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729185.881] [4637:4666] [DMG]                                      ClusterId = 0x30,
[1756729185.881] [4637:4666] [DMG]                                      CommandId = 0x1,
[1756729185.881] [4637:4666] [DMG]                              },
[1756729185.881] [4637:4666] [DMG]                              CommandFields =
[1756729185.881] [4637:4666] [DMG]                                      0x0 = 0 (unsigned),
[1756729185.881] [4637:4666] [DMG]                                      0x1 = "" (0 chars),
[1756729185.881] [4637:4666] [DMG]      ],
[1756729185.881] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729185.882] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1756729185.882] [4637:4666] [CTL] Received ArmFailSafe response errorCode=0
[1756729185.882] [4637:4666] [CTL] Successfully finished commissioning step 'ArmFailSafe'
[1756729185.882] [4637:4666] [CTL] Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
[1756729185.882] [4637:4666] [CTL] Performing next commissioning step 'ConfigRegulatory'
[1756729185.882] [4637:4666] [CTL] Setting Regulatory Config
[1756729185.882] [4637:4666] [CTL] Device does not support configurable regulatory location
[1756729185.882] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729185.882] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729185.882] [4637:4666] [EM] <<< [E:62479i S:55443 M:88078149] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:70)
[1756729185.883] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729185.883] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729186.012] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729186.060] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.061] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.061] [4637:4666] [EM] >>> [E:62479i S:55443 M:189832962] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
[1756729186.061] [4637:4666] [EM] Found matching exchange: 62479i, Delegate: 0x7f8c008478
[1756729186.061] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729186.061] [4637:4666] [DMG] InvokeResponseMessage =
[1756729186.061] [4637:4666] [DMG] {
[1756729186.061] [4637:4666] [DMG]      suppressResponse = false,
[1756729186.061] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729186.061] [4637:4666] [DMG]      [
[1756729186.061] [4637:4666] [DMG]              InvokeResponseIB =
[1756729186.061] [4637:4666] [DMG]                      CommandDataIB =
[1756729186.061] [4637:4666] [DMG]                              CommandPathIB =
[1756729186.061] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729186.062] [4637:4666] [DMG]                                      ClusterId = 0x30,
[1756729186.062] [4637:4666] [DMG]                                      CommandId = 0x3,
[1756729186.062] [4637:4666] [DMG]                              },
[1756729186.062] [4637:4666] [DMG]                              CommandFields =
[1756729186.062] [4637:4666] [DMG]                              {
[1756729186.062] [4637:4666] [DMG]                                      0x0 = 0 (unsigned),
[1756729186.062] [4637:4666] [DMG]                                      0x1 = "" (0 chars),
[1756729186.062] [4637:4666] [DMG]      ],
[1756729186.062] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729186.062] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
[1756729186.062] [4637:4666] [CTL] Received SetRegulatoryConfig response errorCode=0
[1756729186.062] [4637:4666] [CTL] Successfully finished commissioning step 'ConfigRegulatory'
[1756729186.062] [4637:4666] [CTL] Commissioning stage next step: 'ConfigRegulatory' -> 'ConfigureTCAcknowledgments'
[1756729186.062] [4637:4666] [CTL] Performing next commissioning step 'ConfigureTCAcknowledgments'
[1756729186.062] [4637:4666] [CTL] Setting Terms and Conditions
[1756729186.062] [4637:4666] [CTL] Setting Terms and Conditions: Skipped
[1756729186.062] [4637:4666] [CTL] Successfully finished commissioning step 'ConfigureTCAcknowledgments'
[1756729186.062] [4637:4666] [CTL] Commissioning stage next step: 'ConfigureTCAcknowledgments' -> 'SendPAICertificateRequest'
[1756729186.062] [4637:4666] [CTL] Performing next commissioning step 'SendPAICertificateRequest'
[1756729186.062] [4637:4666] [CTL] Sending request for PAI certificate
[1756729186.062] [4637:4666] [CTL] Sending Certificate Chain request to 0x7f8c041cb0 device
[1756729186.062] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729186.062] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729186.062] [4637:4666] [EM] <<< [E:62480i S:55443 M:88078150] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
[1756729186.063] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729186.063] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729186.147] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729186.241] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.241] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.376] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.376] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.464] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.465] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.465] [4637:4666] [EM] >>> [E:62480i S:55443 M:189832963] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:527)
[1756729186.465] [4637:4666] [EM] Found matching exchange: 62480i, Delegate: 0x7f8c008628
[1756729186.465] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729186.465] [4637:4666] [DMG] InvokeResponseMessage =
[1756729186.465] [4637:4666] [DMG] {
[1756729186.465] [4637:4666] [DMG]      suppressResponse = false,
[1756729186.465] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729186.465] [4637:4666] [DMG]      [
[1756729186.465] [4637:4666] [DMG]              InvokeResponseIB =
[1756729186.465] [4637:4666] [DMG]                      CommandDataIB =
[1756729186.465] [4637:4666] [DMG]                              CommandPathIB =
[1756729186.465] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729186.465] [4637:4666] [DMG]                                      ClusterId = 0x3e,
[1756729186.465] [4637:4666] [DMG]                                      CommandId = 0x3,
[1756729186.465] [4637:4666] [DMG]                              },
[1756729186.465] [4637:4666] [DMG]                              CommandFields =
[1756729186.465] [4637:4666] [DMG]                                      0x0 = [
[1756729186.466] [4637:4666] [DMG]                                                      0x30, 0x82, 0x01, 0xcb, 0x30, 0x82, 0x01, 0x71, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x56, 0xad, 0x82, 0x22, 0xad, 0x94, 0x5b, 0x64, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x30, 0x31, 0x18, 0x30, 0x16, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0f, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x54, 0x65, 0x73, 0x74, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x41, 0x9a, 0x93, 0x15, 0xc2, 0x17, 0x3e, 0x0c, 0x8c, 0x87, 0x6d, 0x03, 0xcc, 0xfc, 0x94, 0x48, 0x52, 0x64, 0x7f, 0x7f, 0xec, 0x5e, 0x50, 0x82, 0xf4, 0x05, 0x99, 0x28, 0xec, 0xa8, 0x94, 0xc5, 0x94, 0x15, 0x13, 0x09, 0xac, 0x63, 0x1e, 0x4c, 0xb0, 0x33, 0x92, 0xaf, 0x68, 0x4b, 0x0b, 0xaf, 0xb7, 0xe6, 0x5b, 0x3b, 0x81, 0x62, 0xc2, 0xf5, 0x2b, 0xf9, 0x31, 0xb8, 0xe7, 0x7a, 0xaa, 0x82, 0xa3, 0x66, 0x30, 0x64, 0x30, 0x12, 0x06, 0x03, 0x55, 0x1d, 0x
[1756729186.466] [4637:4666] [DMG]                                      ] (463 bytes)
[1756729186.466] [4637:4666] [DMG]                              },
[1756729186.466] [4637:4666] [DMG]      ],
[1756729186.466] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729186.466] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1756729186.466] [4637:4666] [CTL] Received certificate chain from the device
[1756729186.466] [4637:4666] [CTL] Successfully finished commissioning step 'SendPAICertificateRequest'
[1756729186.466] [4637:4666] [CTL] Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
[1756729186.466] [4637:4666] [CTL] Performing next commissioning step 'SendDACCertificateRequest'
[1756729186.466] [4637:4666] [CTL] Sending request for DAC certificate
[1756729186.466] [4637:4666] [CTL] Sending Certificate Chain request to 0x7f8c041cb0 device
[1756729186.466] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729186.466] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729186.466] [4637:4666] [EM] <<< [E:62481i S:55443 M:88078151] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
[1756729186.467] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729186.467] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729186.552] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729186.645] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.646] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.781] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.781] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.870] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729186.871] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729186.871] [4637:4666] [EM] >>> [E:62481i S:55443 M:189832964] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:555)
[1756729186.871] [4637:4666] [EM] Found matching exchange: 62481i, Delegate: 0x7f8c008478
[1756729186.871] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729186.871] [4637:4666] [DMG] InvokeResponseMessage =
[1756729186.871] [4637:4666] [DMG] {
[1756729186.871] [4637:4666] [DMG]      suppressResponse = false,
[1756729186.871] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729186.872] [4637:4666] [DMG]      [
[1756729186.872] [4637:4666] [DMG]              InvokeResponseIB =
[1756729186.872] [4637:4666] [DMG]              {
[1756729186.872] [4637:4666] [DMG]                      CommandDataIB =
[1756729186.872] [4637:4666] [DMG]                              CommandPathIB =
[1756729186.872] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729186.872] [4637:4666] [DMG]                                      ClusterId = 0x3e,
[1756729186.872] [4637:4666] [DMG]                                      CommandId = 0x3,
[1756729186.872] [4637:4666] [DMG]                              },
[1756729186.872] [4637:4666] [DMG]                              CommandFields =
[1756729186.872] [4637:4666] [DMG]                                      0x0 = [
[1756729186.872] [4637:4666] [DMG]                                                      0x30, 0x82, 0x01, 0xe7, 0x30, 0x82, 0x01, 0x8e, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x58, 0x48, 0xb6, 0x4f, 0xbd, 0x0c, 0x9a, 0x6b, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x53, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x44, 0x41, 0x43, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x2f, 0x30, 0x78, 0x38, 0x30, 0x30, 0x37, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x37, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x1b, 0x68, 0x65, 0x0f, 0x97, 0xaa, 0xda, 0x54, 0x62, 0xa0, 0xd4, 0xdb, 0x5f, 0xd7, 0x84, 0x41, 0xb1, 0x48, 0x95, 0xd8, 0xd3, 0xc6, 0x20, 0x18, 0x33, 0x7f, 0x15, 0x23, 0xbb, 0xea, 0xb6, 0xd5, 0xf0, 0xdd, 0x6e, 0xed, 0x28, 0x83, 0x2e, 0x
[1756729186.872] [4637:4666] [DMG]                                      ] (491 bytes)
[1756729186.872] [4637:4666] [DMG]      ],
[1756729186.872] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729186.872] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1756729186.872] [4637:4666] [CTL] Received certificate chain from the device
[1756729186.872] [4637:4666] [CTL] Successfully finished commissioning step 'SendDACCertificateRequest'
[1756729186.872] [4637:4666] [CTL] Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
[1756729186.873] [4637:4666] [CTL] Performing next commissioning step 'SendAttestationRequest'
[1756729186.873] [4637:4666] [CTL] Sending Attestation Request to the device.
[1756729186.873] [4637:4666] [CTL] Sending Attestation request to 0x7f8c041cb0 device
[1756729186.873] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729186.873] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729186.873] [4637:4666] [EM] <<< [E:62482i S:55443 M:88078152] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:94)
[1756729186.874] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729186.874] [4637:4666] [CTL] Sent Attestation request, waiting for the Attestation Information
[1756729186.874] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729187.092] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729187.186] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729187.186] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729187.321] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729187.321] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729187.456] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729187.457] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729187.457] [4637:4666] [EM] >>> [E:62482i S:55443 M:189832965] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:716)
[1756729187.457] [4637:4666] [EM] Found matching exchange: 62482i, Delegate: 0x7f8c008628
[1756729187.457] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729187.457] [4637:4666] [DMG] InvokeResponseMessage =
[1756729187.457] [4637:4666] [DMG] {
[1756729187.457] [4637:4666] [DMG]      suppressResponse = false,
[1756729187.457] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729187.457] [4637:4666] [DMG]      [
[1756729187.457] [4637:4666] [DMG]              InvokeResponseIB =
[1756729187.457] [4637:4666] [DMG]                      CommandDataIB =
[1756729187.457] [4637:4666] [DMG]                              CommandPathIB =
[1756729187.457] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729187.457] [4637:4666] [DMG]                                      ClusterId = 0x3e,
[1756729187.457] [4637:4666] [DMG]                                      CommandId = 0x1,
[1756729187.457] [4637:4666] [DMG]                              },
[1756729187.457] [4637:4666] [DMG]                              CommandFields =
[1756729187.458] [4637:4666] [DMG]                                      0x0 = [
[1756729187.458] [4637:4666] [DMG]                                                      0x15, 0x31, 0x01, 0x1d, 0x02, 0x30, 0x82, 0x02, 0x19, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x82, 0x02, 0x0a, 0x30, 0x82, 0x02, 0x06, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x82, 0x01, 0x71, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x82, 0x01, 0x62, 0x04, 0x82, 0x01, 0x5e, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0xf1, 0xff, 0x36, 0x02, 0x05, 0x00, 0x80, 0x05, 0x01, 0x80, 0x05, 0x02, 0x80, 0x05, 0x03, 0x80, 0x05, 0x04, 0x80, 0x05, 0x05, 0x80, 0x05, 0x06, 0x80, 0x05, 0x07, 0x80, 0x05, 0x08, 0x80, 0x05, 0x09, 0x80, 0x05, 0x0a, 0x80, 0x05, 0x0b, 0x80, 0x05, 0x0c, 0x80, 0x05, 0x0d, 0x80, 0x05, 0x0e, 0x80, 0x05, 0x0f, 0x80, 0x05, 0x10, 0x80, 0x05, 0x11, 0x80, 0x05, 0x12, 0x80, 0x05, 0x13, 0x80, 0x05, 0x14, 0x80, 0x05, 0x15, 0x80, 0x05, 0x16, 0x80, 0x05, 0x17, 0x80, 0x05, 0x18, 0x80, 0x05, 0x19, 0x80, 0x05, 0x1a, 0x80, 0x05, 0x1b, 0x80, 0x05, 0x1c, 0x80, 0x05, 0x1d, 0x80, 0x05, 0x1e, 0x80, 0x05, 0x1f, 0x80, 0x05, 0x20, 0x80, 0x05, 0x21, 0x80, 0x05, 0x22, 0x80, 0x05, 0x23, 0x80, 0x05, 0x24, 0x80, 0x05, 0x25, 0x80, 0x05, 0x26, 0x80, 0x05, 0x27, 0x80, 0x05, 0x28, 0x80, 0x05, 0x29, 0x80, 0x05, 0x2a, 0x80, 0x05, 0x2b, 0x80, 0x05, 0x2c, 0x80, 0x05, 0x2d, 0x80, 0x05, 0x2e, 0x80, 0x05, 0x2f, 0x80, 0x05, 0x30, 0x80, 0x05, 0x31, 0x80, 0x05, 0x32, 0x80, 0x05, 0x33, 0x80, 0x05, 0x34, 0x80, 0x05, 0x35, 0x80, 0x05, 0x36, 0x80, 0x05, 0x37, 0x80, 0x05, 0x38, 0x80, 0x05, 0x39, 0x80, 0x05, 0x3a, 0x80, 0x05, 0x3b, 0x80, 0x05, 0x3c, 0x80, 0x05, 0x3d, 0x80, 0x05, 0x3e, 0x80, 0x05, 0x3f, 0x80, 0x05, 0x40, 0x80, 0x05, 0x41, 0x80, 0x05, 0x42, 0x80, 0x05, 0x43, 0x80, 0x
[1756729187.458] [4637:4666] [DMG]                                      ] (585 bytes)
[1756729187.458] [4637:4666] [DMG]                                      0x1 = [
[1756729187.458] [4637:4666] [DMG]                                                      0x9f, 0x45, 0x9e, 0x15, 0xa5, 0x84, 0x57, 0xe4, 0xfa, 0x27, 0x5f, 0x76, 0xef, 0x1a, 0x9a, 0xa3, 0xec, 0xb5, 0x5f, 0x3a, 0xd2, 0x23, 0xd6, 0x5d, 0x68, 0x89, 0xa2, 0x28, 0x93, 0x62, 0x51, 0x76, 0x05, 0x50, 0x47, 0xb4, 0x9d, 0xe8, 0x78, 0x4b, 0x03, 0x2b, 0x07, 0x58, 0xcc, 0x0b, 0x18, 0x0f, 0x46, 0xbf, 0xbf, 0x1a, 0x20, 0xd9, 0x9c, 0xde, 0x03, 0xf1, 0x53, 0x32, 0xff, 0x52, 0x5a, 0xb4,
[1756729187.458] [4637:4666] [DMG]                                      ] (64 bytes)
[1756729187.458] [4637:4666] [DMG]                              },
[1756729187.458] [4637:4666] [DMG]      ],
[1756729187.458] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729187.458] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
[1756729187.458] [4637:4666] [CTL] Received Attestation Information from the device
[1756729187.458] [4637:4666] [CTL] Successfully finished commissioning step 'SendAttestationRequest'
[1756729187.458] [4637:4666] [CTL] AutoCommissioner setting attestationElements buffer size 585/585
[1756729187.458] [4637:4666] [CTL] Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
[1756729187.458] [4637:4666] [CTL] Performing next commissioning step 'AttestationVerification'
[1756729187.458] [4637:4666] [CTL] Verifying Device Attestation information received from the device
[1756729187.478] [4637:4666] [-] Device candidate DAC chain details:
[1756729187.478] [4637:4666] [-] --> DAC's VID: 0xFFF1, PID: 0x8007
[1756729187.478] [4637:4666] [-] ==== DAC certificate considered (491 bytes) ====
[1756729187.478] [4637:4666] [-] -----BEGIN CERTIFICATE-----
[1756729187.478] [4637:4666] [-] MIIB5zCCAY6gAwIBAgIIWEi2T70MmmswCgYIKoZIzj0EAwIwPTElMCMGA1UEAwwc
[1756729187.478] [4637:4666] [-] TWF0dGVyIERldiBQQUkgMHhGRkYxIG5vIFBJRDEUMBIGCisGAQQBgqJ8AgEMBEZG
[1756729187.478] [4637:4666] [-] RjEwIBcNMjIwMjA1MDAwMDAwWhgPOTk5OTEyMzEyMzU5NTlaMFMxJTAjBgNVBAMM
[1756729187.478] [4637:4666] [-] HE1hdHRlciBEZXYgREFDIDB4RkZGMS8weDgwMDcxFDASBgorBgEEAYKifAIBDARG
[1756729187.478] [4637:4666] [-] RkYxMRQwEgYKKwYBBAGConwCAgwEODAwNzBZMBMGByqGSM49AgEGCCqGSM49AwEH
[1756729187.478] [4637:4666] [-] A0IABBtoZQ+XqtpUYqDU21/XhEGxSJXY08YgGDN/FSO76rbV8N1u7SiDLvlIiRuX
[1756729187.478] [4637:4666] [-] aoMb6oLbmnfj6klHtB2Hagji3WKjYDBeMAwGA1UdEwEB/wQCMAAwDgYDVR0PAQH/
[1756729187.478] [4637:4666] [-] BAQDAgeAMB0GA1UdDgQWBBShgQsewlHhuLRFNTSRqRhdV1IRRzAfBgNVHSMEGDAW
[1756729187.478] [4637:4666] [-] gBRjVA5H9kscONE4hKRi0WwZXY/7PDAKBggqhkjOPQQDAgNHADBEAiBIldL+9SOX
[1756729187.478] [4637:4666] [-] PHjbxgV9RPzHbiHjUlNuiRDzLuwZ/im8JAIgCMwbPSElYHRxX7xZ6Qdn/iLuXxW7
[1756729187.478] [4637:4666] [-] +glAsd/WUkT1UWM=
[1756729187.478] [4637:4666] [-] -----END CERTIFICATE-----
[1756729187.481] [4637:4666] [-] --> DAC certificate SKID: A1:81:0B:1E:C2:51:E1:B8:B4:45:35:34:91:A9:18:5D:57:52:11:47
[1756729187.483] [4637:4666] [-] --> DAC certificate AKID: 63:54:0E:47:F6:4B:1C:38:D1:38:84:A4:62:D1:6C:19:5D:8F:FB:3C
[1756729187.483] [4637:4666] [-] ==== PAI certificate considered (463 bytes) ====
[1756729187.483] [4637:4666] [-] -----BEGIN CERTIFICATE-----
[1756729187.483] [4637:4666] [-] MIIByzCCAXGgAwIBAgIIVq2CIq2UW2QwCgYIKoZIzj0EAwIwMDEYMBYGA1UEAwwP
[1756729187.483] [4637:4666] [-] TWF0dGVyIFRlc3QgUEFBMRQwEgYKKwYBBAGConwCAQwERkZGMTAgFw0yMjAyMDUw
[1756729187.483] [4637:4666] [-] MDAwMDBaGA85OTk5MTIzMTIzNTk1OVowPTElMCMGA1UEAwwcTWF0dGVyIERldiBQ
[1756729187.483] [4637:4666] [-] QUkgMHhGRkYxIG5vIFBJRDEUMBIGCisGAQQBgqJ8AgEMBEZGRjEwWTATBgcqhkjO
[1756729187.483] [4637:4666] [-] PQIBBggqhkjOPQMBBwNCAARBmpMVwhc+DIyHbQPM/JRIUmR/f+xeUIL0BZko7KiU
[1756729187.483] [4637:4666] [-] xZQVEwmsYx5MsDOSr2hLC6+35ls7gWLC9Sv5MbjneqqCo2YwZDASBgNVHRMBAf8E
[1756729187.483] [4637:4666] [-] CDAGAQH/AgEAMA4GA1UdDwEB/wQEAwIBBjAdBgNVHQ4EFgQUY1QOR/ZLHDjROISk
[1756729187.483] [4637:4666] [-] YtFsGV2P+zwwHwYDVR0jBBgwFoAUav0idx9RH+y/FkGXZxDc3DGhcX4wCgYIKoZI
[1756729187.483] [4637:4666] [-] zj0EAwIDSAAwRQIhALLvJ/Sa6bUPuR7qyUxNC9u415KcbLiPrOUpNo0SBUwMAiBl
[1756729187.483] [4637:4666] [-] Xckrhr2QmIKmxiF3uCXX0F7b58Ivn+pxIg5+pwP4kQ==
[1756729187.483] [4637:4666] [-] -----END CERTIFICATE-----
[1756729187.486] [4637:4666] [-] --> PAI certificate SKID: 63:54:0E:47:F6:4B:1C:38:D1:38:84:A4:62:D1:6C:19:5D:8F:FB:3C
[1756729187.488] [4637:4666] [-] --> PAI certificate AKID: 6A:FD:22:77:1F:51:1F:EC:BF:16:41:97:67:10:DC:DC:31:A1:71:7E
[1756729187.495] [4637:4666] [CTL] Error on commissioning step 'AttestationVerification': 'src/controller/CHIPDeviceController.cpp:1291: CHIP Error 0x00000020: Failed Device Attestation'
[1756729187.495] [4637:4666] [CTL] Failed verifying attestation information. Now checking DAC chain revoked status.
[1756729187.495] [4637:4666] [CTL] Commissioning stage next step: 'AttestationVerification' -> 'AttestationRevocationCheck'
[1756729187.495] [4637:4666] [CTL] Performing next commissioning step 'AttestationRevocationCheck' with completion status = 'src/controller/CHIPDeviceController.cpp:1291: CHIP Error 0x00000020: Failed Device Attestation'
[1756729187.495] [4637:4666] [CTL] Verifying the device's DAC chain revocation status
[1756729187.495] [4637:4666] [-] WARNING: No revocation delegate available. Revocation checks will be skipped!
[1756729187.495] [4637:4666] [CTL] Failed in verifying 'Attestation Information' command received from the device: err 500 (Attestation signature failed to validate against DAC subject public key)
[1756729187.495] [4637:4666] [CTL] Error on commissioning step 'AttestationRevocationCheck': 'src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation'
[1756729187.495] [4637:4666] [CTL] Going from commissioning step 'AttestationRevocationCheck' with lastErr = 'src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation' -> 'Cleanup'
[1756729187.495] [4637:4666] [CTL] Performing next commissioning step 'Cleanup' with completion status = 'src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation'
[1756729187.496] [4637:4666] [CTL] Disarming failsafe on device 0x7f8c041cb0
[1756729187.496] [4637:4666] [DMG] ICR moving to [AddingComm]
[1756729187.496] [4637:4666] [DMG] ICR moving to [AddedComma]
[1756729187.496] [4637:4666] [EM] <<< [E:62483i S:55443 M:88078153] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
[1756729187.497] [4637:4666] [DMG] ICR moving to [AwaitingRe]
[1756729187.497] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729187.588] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16389
[1756729187.592] [4637:4665] [DL] Indication received, conn = 0x559d170f30
[1756729187.592] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16391
[1756729187.593] [4637:4666] [EM] >>> [E:62483i S:55443 M:189832966] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
[1756729187.593] [4637:4666] [EM] Found matching exchange: 62483i, Delegate: 0x7f8c008478
[1756729187.593] [4637:4666] [DMG] ICR moving to [ResponseRe]
[1756729187.593] [4637:4666] [DMG] InvokeResponseMessage =
[1756729187.593] [4637:4666] [DMG] {
[1756729187.593] [4637:4666] [DMG]      suppressResponse = false,
[1756729187.593] [4637:4666] [DMG]      InvokeResponseIBs =
[1756729187.593] [4637:4666] [DMG]      [
[1756729187.593] [4637:4666] [DMG]              InvokeResponseIB =
[1756729187.593] [4637:4666] [DMG]                      CommandDataIB =
[1756729187.593] [4637:4666] [DMG]                              CommandPathIB =
[1756729187.594] [4637:4666] [DMG]                                      EndpointId = 0x0,
[1756729187.594] [4637:4666] [DMG]                                      ClusterId = 0x30,
[1756729187.594] [4637:4666] [DMG]                                      CommandId = 0x1,
[1756729187.594] [4637:4666] [DMG]                              },
[1756729187.594] [4637:4666] [DMG]                              CommandFields =
[1756729187.594] [4637:4666] [DMG]                              {
[1756729187.594] [4637:4666] [DMG]                                      0x0 = 0 (unsigned),
[1756729187.594] [4637:4666] [DMG]                                      0x1 = "" (0 chars),
[1756729187.594] [4637:4666] [DMG]      ],
[1756729187.594] [4637:4666] [DMG]      InteractionModelRevision = 12
[1756729187.595] [4637:4666] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1756729187.595] [4637:4666] [CTL] Failsafe disarmed
[1756729187.595] [4637:4666] [CTL] Successfully finished commissioning step 'Cleanup'
[1756729187.595] [4637:4666] [DIS] Closing all BLE connections
[1756729187.595] [4637:4666] [IN] Clearing BLE pending packets.
[1756729187.597] [4637:4666] [BLE] Auto-closing end point's BLE connection.
[1756729187.597] [4637:4666] [DL] Closing BLE GATT connection (con 0x559d170f30)
[1756729187.597] [4637:4665] [DL] Close BLE connection: peer=F8:11:F3:72:95:B3
[1756729187.818] [4637:4666] [IN] SecureSession[0x7f8c013400]: MarkForEviction Type:1 LSID:55443
[1756729187.818] [4637:4666] [SC] SecureSession[0x7f8c013400, LSID:55443]: State change 'kActive' --> 'kPendingEviction'
[1756729187.818] [4637:4666] [CTL] Commissioning complete for node ID 0x0000000000000001: src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation
[1756729187.818] [4637:4666] [TOO] Device commissioning Failure: src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation
[1756729187.818] [4637:4666] [TOO] Run command failure: src/controller/CHIPDeviceController.cpp:1338: CHIP Error 0x00000020: Failed Device Attestation
[1756729187.818] [4637:4666] [DMG] ICR moving to [AwaitingDe]
[1756729187.818] [4637:4666] [IN] SecureSession[0x7f8c013400]: Released - Type:1 LSID:55443
[1756729187.818] [4637:4666] [DL] Long dispatch time: 226 ms, for event type 16391
[1756729187.819] [4637:4666] [DL] HandlePlatformSpecificBLEEvent 16390
[1756729187.819] [4637:4666] [BLE] No endpoint for unsubscribe complete
[1756729187.822] [4637:4665] [DL] BLE connection closed: conn=0x559d170f30
[1756729187.823] [4637:4666] [BLE] No endpoint for connection error
