Verification of Temperature Ratings on Potted nRF52840 Device
Description:
We are qualifying a potted device which uses the nRF52840 and is intended to run in ambients up to 50 °C external air temperature.
The nRF52840 uses its PWM outputs to switch high-current loads, which generates heat in nearby PCB shunt resistors. Because the unit is fully encapsulated in a thermally conductive potting compound, we would like to confirm that our thermal test methodology and acceptance criteria are aligned with Nordic’s specifications.
Parameters (per nRF52840 Product Specification – Recommended Operating Conditions):
  • Max Operating Ambient Temperature (TA): 85 °C
    • The maximum permissible temperature surrounding the chip.
  • Max Junction Temperature (Tj): 90 °C
    • Measured via the internal temperature sensor inside the nRF52840.
Test Setup:
  • Thermocouple placement (before potting):
    • T1: Directly on top of the nRF52840 package (primary reference).
    • T2.x: On top of the shunt resistors (reference).
    • T3: On the enclosure surface (reference).
  • Chamber conditions:
    • Device operated in a thermal chamber at 50 °C external ambient.
    • Worst-case load applied:
      • Maximum sustained current through shunts.
      • nRF52840 operating at high RF duty cycle & TX power.
Acceptance Criteria:
  • Measurements taken during steady-state after at least 45 minutes of thermal soak.
  • T1 (above the MCU) remains less than 85 °C, demonstrating that the local effective ambient around the chip is within the 85 °C spec.
  • The internal temperature sensor reports less than 90 °C, ensuring the junction temperature is within specification.
Request:
Could you please confirm that:
  1. Using 90 °C as the maximum allowed junction temperature is correct for continuous operation of the nRF52840.
  2. This test method is a valid approach to verify compliance with device specifications.
Thanks!
