NCS v3.1.0 Matter light bulb sample / cluster-enums-check.h:151:10: fatal error: clusters/TotalVolatileOrganicCompoundsConcentrationMeasurement/EnumsCheck.h: No such file or directory
I am facing an issue building the NCS v3.1.0 Matter light bulb sample for nRF52840-DK:
I am on a Windows 11 environment.
Could you help me to fix it and add the missing file?
Logs
In file included from c:\ncs\v3.1.0\modules\lib\matter\src\app\data-model\decode.h:21,
from c:\ncs\v3.1.0\modules\lib\matter\src\app\data-model\list.h:21,
from c:\ncs\v3.1.0\modules\lib\matter\src\app\attributereportbuilder.h:22,
from c:\ncs\v3.1.0\modules\lib\matter\src\app\attributevalueencoder.h:21,
from c:\ncs\v3.1.0\modules\lib\matter\src\app\globalattributes.h:21,
from c:\ncs\v3.1.0\modules\lib\matter\src\app\globalattributes.cpp:17:
c:\ncs\v3.1.0\modules\lib\matter\zzz_generated\app-common\app-common\zap-generated\cluster-enums-check.h:151:10: fatal error: clusters/TotalVolatileOrganicCompoundsConcentrationMeasurement/EnumsCheck.h: No such file or directory
151 | #include <clusters/TotalVolatileOrganicCompoundsConcentrationMeasurement/EnumsCheck.h>
compilation terminated.
[20/352] c++ obj/src/app/command-handler.CommandHandler.cpp.o
FAILED: modules/connectedhomeip/src/chip-gn-stamp/chip-gn-build modules/connectedhomeip/args.gn modules/connectedhomeip/build.ninja modules/connectedhomeip/.ninja_deps modules/connectedhomeip/build.ninja.stamp modules/connectedhomeip/lib/libCHIP.a modules/connectedhomeip/lib/libMatterDeviceInfoProviderExample.a C:/Users/User/Documents/Dev/Nordic/3.1.0/light_bulb/build/light_bulb/modules/connectedhomeip/src/chip-gn-stamp/chip-gn-build C:/Users/User/Documents/Dev/Nordic/3.1.0/light_bulb/build/light_bulb/modules/connectedhomeip/args.gn C:/Users/User/Documents/Dev/Nordic/3.1.0/light_bulb/build/light_bulb/modules/connectedhomeip/build.ninja C:/Users/User/Documents/Dev/Nordic/3.1.0/light_bulb/build/light_bulb/modules/connectedhomeip/.ninja_deps C:/Users/User/Documents/Dev/Nordic/3.1.0/light_bulb/build/light_bulb/modules/connectedhomeip/build.ninja.stamp C:/Users/User/Documents/Dev/Nordic/3.1.0/light_bulb/build/light_bulb/modules/connectedhomeip/lib/libCHIP.a C:/Users/User/Documents/Dev/Nordic/3.1.0/light_bulb/build/light_bulb/modules/connectedhomeip/lib/libMatterDeviceInfoProviderExample.a
cmd.exe /C "cd /D C:\Users\User\Documents\Dev\Nordic\3.1.0\light_bulb\build\light_bulb\modules\connectedhomeip && C:\ncs\toolchains\b8b84efebd\opt\bin\cmake.exe -E echo "Starting Matter library build in C:/Users/User/Documents/Dev/Nordic/3.1.0/light_bulb/build/light_bulb/modules/connectedhomeip" && C:\ncs\toolchains\b8b84efebd\opt\bin\python.exe C:/ncs/v3.1.0/modules/lib/matter/config/common/cmake/make_gn_args.py @args.tmp > args.gn.tmp && ( C:\ncs\toolchains\b8b84efebd\opt\bin\cmake.exe -E compare_files args.gn.tmp args.gn || C:/ncs/toolchains/b8b84efebd/opt/bin/cmake.exe -E rename args.gn.tmp args.gn ) && C:\ncs\toolchains\b8b84efebd\opt\bin\gn.exe --root=C:/ncs/v3.1.0/modules/lib/matter --root-target=C:/ncs/v3.1.0/modules/lib/matter/config/nrfconnect/chip-gn --dotfile=C:/ncs/v3.1.0/modules/lib/matter/config/nrfconnect/chip-gn/.gn --script-executable=C:/ncs/toolchains/b8b84efebd/opt/bin/python.exe gen --check --fail-on-unused-args C:/Users/User/Documents/Dev/Nordic/3.1.0/light_bulb/build/light_bulb/modules/connectedhomeip --export-compile-commands && ninja && C:\ncs\toolchains\b8b84efebd\opt\bin\cmake.exe -E echo "Matter library build complete""
[15/23] cmd.exe /C "cd /D C:\Users\User\Documents\Dev\Nordic\3.1.0\light_bulb\build\_sysbuild && C:\ncs\toolchains\b8b84efebd\opt\bin\cmake.exe -E true"
FAILED: _sysbuild/sysbuild/images/light_bulb-prefix/src/light_bulb-stamp/light_bulb-build C:/Users/User/Documents/Dev/Nordic/3.1.0/light_bulb/build/_sysbuild/sysbuild/images/light_bulb-prefix/src/light_bulb-stamp/light_bulb-build
cmd.exe /C "cd /D C:\Users\User\Documents\Dev\Nordic\3.1.0\light_bulb\build\light_bulb && C:\ncs\toolchains\b8b84efebd\opt\bin\cmake.exe --build ."
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b8b84efebd\opt\bin\cmake.EXE' --build C:/Users/User/Documents/Dev/Nordic/3.1.0/light_bulb/build
Regards
