Unable to install SDK via VS Code
I have installed nRF connect 2025.9.732 on my VS code Version: 1.103.2 on Ubuntu 22.04.
I am able to install the toolchains successful but I am getting this weird error message
[14:05:44] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Install toolchain v3.1.0
[14:05:44] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Toolchain with version v3.1.0 already installed: success
[14:05:44] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Calculating SDK checksum
[14:05:53] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Verified previously download file: success
[14:05:53] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Unpack SDK v3.1.0
[14:06:06] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Unpacked SDK tarball: success
[west]: usage: west [-h] [-z ZEPHYR_BASE] [-v] [-q] [-V] <command> ...
[west]: west: unknown command "zephyr-export"; workspace /home/akshay/ncs/v3.1.0 does not define this extension command -- try "west help" and "west -vv status"
[west]: exited with code 1.
[west]: FATAL ERROR: failed manifest import in zephyr (zephyr):
[west]:   Failed importing "west.yml" from revision "ncs-v3.1.0"
[west]:   Hint: zephyr must be cloned, owned by the user and its manifest-rev ref must point to a commit with the import data
[west]:   To fix, run "west update. If it still fails, try "west -vv ..."
I have west installed globally via pip, but I do NOT have ZEPHYR os installed in ~/zephyrproject.
I am not sure what that error is, do I have to go to /home/akshay/ncs/v3.1.0 and type west update?
  • OK I tried it using both vs code and `nrfutil` and it fails here
    > nrfutil sdk-manager install v3.1.0
    [00:07:28] ###### 100% [Download toolchain v3.1.0] Toolchain downloaded
    [00:00:13] ###### 100% [Unpack toolchain v3.1.0] Toolchain unpacked to /home/akshay/ncs/tmp/.tmpZnVlnP
    [00:00:00] ###### 100% [Install toolchain v3.1.0] Toolchain installed at /home/akshay/ncs/toolchains/c5be9c56c7
    [00:18:26] ###### 100% [Download SDK v3.1.0] Download SDK v3.1.0
    [00:00:06] ###### 100% [Calculating SDK checksum] Verified download
    [00:00:13] ###### 100% [Unpack SDK v3.1.0] Unpacked SDK tarball
    Error: Failed to run west zephyr-export in SDK directory '/home/akshay/ncs/v3.1.0'. Check the log for details.
    And the log file shows the same thing
    [2025-09-10T22:13:11.418Z] [771139] ERROR - [nrfutil_sdk_manager::sdk::register] Failed to run 'west zephyr-export' in SDK directory.
    Exit status: Some(1)
    I am using west v1.4.0
  • Excellent work. Thank you. I know that must have taken ages. I am up and running again using a previous version (3.0.2). So I'm happy enough for now
  • Thank you everyone for your inputs. We will take a look at this.
    -Priyanka
  • Here is a debug log from nrfutil-sdk-manager.log
    [2025-09-12T05:41:44.822Z] [43933] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.6.2, platform = x86_64-unknown-linux-gnu, classification = nrf-external) invoked with install v3.1.0 --log-level debug
    [2025-09-12T05:41:44.822Z] [43933] INFO - [nrfutil_sdk_manager::config::file] Loading config from default location
    [2025-09-12T05:41:44.822Z] [43933] INFO - [nrfutil_sdk_manager::config::file] Resolving configuration
    [2025-09-12T05:41:44.822Z] [43933] INFO - [kms_common] Environment variable 'NRFUTIL_SDK_MANAGER_TOOLCHAIN_REMOTE_CONFIG_TOKEN' not found for token access
    [2025-09-12T05:41:44.822Z] [43933] DEBUG - [ureq_proto::client] Call<Prepare>
    [2025-09-12T05:41:44.822Z] [43933] DEBUG - [ureq::run] GET https://files.nordicsemi.com/******
    [2025-09-12T05:41:45.093Z] [43933] DEBUG - [ureq::unversioned::resolver] Resolved: ArrayVec { len: 1, arr: [108.141.12.92:443] }
    [2025-09-12T05:41:45.358Z] [43933] DEBUG - [ureq::unversioned::transport::tcp] Connected TcpStream to 108.141.12.92:443
    [2025-09-12T05:41:45.364Z] [43933] DEBUG - [rustls::webpki::anchors] add_parsable_certificates processed 147 valid and 0 invalid certs
    [2025-09-12T05:41:45.364Z] [43933] DEBUG - [rustls_platform_verifier::verification::others] Loaded 147 CA root certificates from the system
    [2025-09-12T05:41:45.364Z] [43933] DEBUG - [rustls::client::hs] No cached session for DnsName("files.nordicsemi.com")
    [2025-09-12T05:41:45.364Z] [43933] DEBUG - [rustls::client::hs] Not resuming any session
    [2025-09-12T05:41:45.364Z] [43933] DEBUG - [ureq::tls::rustls] Wrapped TLS
    [2025-09-12T05:41:45.364Z] [43933] DEBUG - [ureq_proto::client] Call<SendRequest>
    [2025-09-12T05:41:45.364Z] [43933] DEBUG - [ureq::run] Request { method: GET, uri: https://files.nordicsemi.com/******, version: HTTP/1.1, headers: {"accept-encoding": "gzip", "user-agent": "ureq/3.1.0", "accept": "*/*", "host": "files.nordicsemi.com"} }
    [2025-09-12T05:41:45.698Z] [43933] DEBUG - [rustls::client::hs] ALPN protocol is None
    [2025-09-12T05:41:45.698Z] [43933] DEBUG - [rustls::client::hs] Using ciphersuite TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    [2025-09-12T05:41:45.699Z] [43933] DEBUG - [rustls::client::tls12] ECDHE curve is EcParameters { curve_type: NamedCurve, named_group: X25519 }
    [2025-09-12T05:41:45.699Z] [43933] DEBUG - [rustls::client::tls12] Server DNS name is DnsName("files.nordicsemi.com")
    [2025-09-12T05:41:46.107Z] [43933] DEBUG - [ureq_proto::client] Call<RecvResponse>
    [2025-09-12T05:41:46.388Z] [43933] DEBUG - [ureq_proto::client] Call<RecvBody>
    [2025-09-12T05:41:46.388Z] [43933] DEBUG - [ureq::run] Response { status: 200, version: HTTP/1.1, headers: {"date": "Fri, 12 Sep 2025 05:41:46 GMT", "content-type": "application/json", "content-length": "1750", "connection": "keep-alive", "<NOTICE>": "12 HEADERS ARE REDACTED"} }
    [2025-09-12T05:41:46.388Z] [43933] DEBUG - [ureq_proto::client] Call<Cleanup>
    [2025-09-12T05:41:46.388Z] [43933] DEBUG - [ureq::pool] Pool gone: PoolKey { scheme: "https", authority: files.nordicsemi.com, proxy: None }
    [2025-09-12T05:41:46.388Z] [43933] INFO - [kms_common] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access
    [2025-09-12T05:41:46.388Z] [43933] DEBUG - [ureq_proto::client] Call<Prepare>
    [2025-09-12T05:41:46.388Z] [43933] DEBUG - [ureq::run] GET https://files.nordicsemi.com/******
    [2025-09-12T05:41:46.393Z] [43933] DEBUG - [ureq::unversioned::resolver] Resolved: ArrayVec { len: 1, arr: [108.141.12.92:443] }
    [2025-09-12T05:41:46.722Z] [43933] DEBUG - [ureq::unversioned::transport::tcp] Connected TcpStream to 108.141.12.92:443
    [2025-09-12T05:41:46.730Z] [43933] DEBUG - [rustls::webpki::anchors] add_parsable_certificates processed 147 valid and 0 invalid certs
    [2025-09-12T05:41:46.730Z] [43933] DEBUG - [rustls_platform_verifier::verification::others] Loaded 147 CA root certificates from the system
    [2025-09-12T05:41:46.730Z] [43933] DEBUG - [rustls::client::hs] No cached session for DnsName("files.nordicsemi.com")
    [2025-09-12T05:41:46.730Z] [43933] DEBUG - [rustls::client::hs] Not resuming any session
    [2025-09-12T05:41:46.730Z] [43933] DEBUG - [ureq::tls::rustls] Wrapped TLS
    [2025-09-12T05:41:46.730Z] [43933] DEBUG - [ureq_proto::client] Call<SendRequest>
    [2025-09-12T05:41:46.730Z] [43933] DEBUG - [ureq::run] Request { method: GET, uri: https://files.nordicsemi.com/******, version: HTTP/1.1, headers: {"accept-encoding": "gzip", "user-agent": "ureq/3.1.0", "accept": "*/*", "host": "files.nordicsemi.com"} }
    [2025-09-12T05:41:47.131Z] [43933] DEBUG - [rustls::client::hs] ALPN protocol is None
    [2025-09-12T05:41:47.131Z] [43933] DEBUG - [rustls::client::hs] Using ciphersuite TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    [2025-09-12T05:41:47.131Z] [43933] DEBUG - [rustls::client::tls12] ECDHE curve is EcParameters { curve_type: NamedCurve, named_group: X25519 }
    [2025-09-12T05:41:47.131Z] [43933] DEBUG - [rustls::client::tls12] Server DNS name is DnsName("files.nordicsemi.com")
    [2025-09-12T05:41:47.439Z] [43933] DEBUG - [ureq_proto::client] Call<RecvResponse>
    [2025-09-12T05:41:47.746Z] [43933] DEBUG - [ureq_proto::client] Call<RecvBody>
    [2025-09-12T05:41:47.746Z] [43933] DEBUG - [ureq::run] Response { status: 200, version: HTTP/1.1, headers: {"date": "Fri, 12 Sep 2025 05:41:47 GMT", "content-type": "application/json", "content-length": "1044", "connection": "keep-alive", "<NOTICE>": "13 HEADERS ARE REDACTED"} }
    [2025-09-12T05:41:47.746Z] [43933] DEBUG - [ureq_proto::client] Call<Cleanup>
    [2025-09-12T05:41:47.746Z] [43933] DEBUG - [ureq::pool] Pool gone: PoolKey { scheme: "https", authority: files.nordicsemi.com, proxy: None }
    [2025-09-12T05:41:47.746Z] [43933] INFO - [nrfutil_sdk_manager::sdk::package_index] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json
    [2025-09-12T05:41:47.746Z] [43933] DEBUG - [ureq_proto::client] Call<Prepare>
    [2025-09-12T05:41:47.746Z] [43933] DEBUG - [ureq::run] GET https://files.nordicsemi.com/******
    [2025-09-12T05:41:47.752Z] [43933] DEBUG - [ureq::unversioned::resolver] Resolved: ArrayVec { len: 1, arr: [108.141.12.92:443] }
    [2025-09-12T05:41:48.020Z] [43933] DEBUG - [ureq::unversioned::transport::tcp] Connected TcpStream to 108.141.12.92:443
    [2025-09-12T05:41:48.028Z] [43933] DEBUG - [rustls::webpki::anchors] add_parsable_certificates processed 147 valid and 0 invalid certs
    [2025-09-12T05:41:48.028Z] [43933] DEBUG - [rustls_platform_verifier::verification::others] Loaded 147 CA root certificates from the system
    [2025-09-12T05:41:48.028Z] [43933] DEBUG - [rustls::client::hs] No cached session for DnsName("files.nordicsemi.com")
    [2025-09-12T05:41:48.028Z] [43933] DEBUG - [rustls::client::hs] Not resuming any session
    [2025-09-12T05:41:48.028Z] [43933] DEBUG - [ureq::tls::rustls] Wrapped TLS
    [2025-09-12T05:41:48.028Z] [43933] DEBUG - [ureq_proto::client] Call<SendRequest>
    [2025-09-12T05:41:48.028Z] [43933] DEBUG - [ureq::run] Request { method: GET, uri: https://files.nordicsemi.com/******, version: HTTP/1.1, headers: {"accept-encoding": "gzip", "user-agent": "ureq/3.1.0", "accept": "*/*", "host": "files.nordicsemi.com"} }
    [2025-09-12T05:41:48.304Z] [43933] DEBUG - [rustls::client::hs] ALPN protocol is None
    [2025-09-12T05:41:48.304Z] [43933] DEBUG - [rustls::client::hs] Using ciphersuite TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    [2025-09-12T05:41:48.306Z] [43933] DEBUG - [rustls::client::tls12] ECDHE curve is EcParameters { curve_type: NamedCurve, named_group: X25519 }
    [2025-09-12T05:41:48.306Z] [43933] DEBUG - [rustls::client::tls12] Server DNS name is DnsName("files.nordicsemi.com")
    [2025-09-12T05:41:48.667Z] [43933] DEBUG - [ureq_proto::client] Call<RecvResponse>
    [2025-09-12T05:41:48.981Z] [43933] DEBUG - [ureq_proto::client] Call<RecvBody>
    [2025-09-12T05:41:48.981Z] [43933] DEBUG - [ureq::run] Response { status: 200, version: HTTP/1.1, headers: {"date": "Fri, 12 Sep 2025 05:41:48 GMT", "content-type": "application/json", "content-length": "16280", "connection": "keep-alive", "<NOTICE>": "13 HEADERS ARE REDACTED"} }
    [2025-09-12T05:41:49.283Z] [43933] DEBUG - [ureq_proto::client] Call<Cleanup>
    [2025-09-12T05:41:49.283Z] [43933] DEBUG - [ureq::pool] Pool gone: PoolKey { scheme: "https", authority: files.nordicsemi.com, proxy: None }
    [2025-09-12T05:41:49.283Z] [43933] INFO - [toolchain_manager_core::sdk] Retrieving toolchains from file /home/akshay/ncs/toolchains/toolchains.json
    [2025-09-12T05:41:49.283Z] [43933] INFO - [toolchain_manager_core::index] Downloading from https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-linux-x86_64.json
    [2025-09-12T05:41:49.283Z] [43933] DEBUG - [ureq_proto::client] Call<Prepare>
    [2025-09-12T05:41:49.283Z] [43933] DEBUG - [ureq::run] GET https://files.nordicsemi.com/******
    [2025-09-12T05:41:49.289Z] [43933] DEBUG - [ureq::unversioned::resolver] Resolved: ArrayVec { len: 1, arr: [108.141.12.92:443] }
    [2025-09-12T05:41:49.589Z] [43933] DEBUG - [ureq::unversioned::transport::tcp] Connected TcpStream to 108.141.12.92:443
    [2025-09-12T05:41:49.595Z] [43933] DEBUG - [rustls::webpki::anchors] add_parsable_certificates processed 147 valid and 0 invalid certs
    [2025-09-12T05:41:49.595Z] [43933] DEBUG - [rustls_platform_verifier::verification::others] Loaded 147 CA root certificates from the system
    [2025-09-12T05:41:49.596Z] [43933] DEBUG - [rustls::client::hs] No cached session for DnsName("files.nordicsemi.com")
    [2025-09-12T05:41:49.596Z] [43933] DEBUG - [rustls::client::hs] Not resuming any session
    [2025-09-12T05:41:49.596Z] [43933] DEBUG - [ureq::tls::rustls] Wrapped TLS
    [2025-09-12T05:41:49.596Z] [43933] DEBUG - [ureq_proto::client] Call<SendRequest>
    [2025-09-12T05:41:49.596Z] [43933] DEBUG - [ureq::run] Request { method: GET, uri: https://files.nordicsemi.com/******, version: HTTP/1.1, headers: {"accept-encoding": "gzip", "user-agent": "ureq/3.1.0", "accept": "*/*", "host": "files.nordicsemi.com"} }
    [2025-09-12T05:41:49.896Z] [43933] DEBUG - [rustls::client::hs] ALPN protocol is None
    [2025-09-12T05:41:49.897Z] [43933] DEBUG - [rustls::client::hs] Using ciphersuite TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    [2025-09-12T05:41:49.897Z] [43933] DEBUG - [rustls::client::tls12] ECDHE curve is EcParameters { curve_type: NamedCurve, named_group: X25519 }
    [2025-09-12T05:41:49.897Z] [43933] DEBUG - [rustls::client::tls12] Server DNS name is DnsName("files.nordicsemi.com")
    [2025-09-12T05:41:50.204Z] [43933] DEBUG - [ureq_proto::client] Call<RecvResponse>
    [2025-09-12T05:41:50.614Z] [43933] DEBUG - [ureq_proto::client] Call<RecvBody>
    [2025-09-12T05:41:50.614Z] [43933] DEBUG - [ureq::run] Response { status: 200, version: HTTP/1.1, headers: {"date": "Fri, 12 Sep 2025 05:41:50 GMT", "content-type": "application/json", "content-length": "56182", "connection": "keep-alive", "<NOTICE>": "12 HEADERS ARE REDACTED"} }
    [2025-09-12T05:41:50.614Z] [43933] INFO - [toolchain_manager_core::index] Get request to https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-linux-x86_64.json returned status code 200: OK
    [2025-09-12T05:41:51.229Z] [43933] DEBUG - [ureq_proto::client] Call<Cleanup>
    [2025-09-12T05:41:51.229Z] [43933] DEBUG - [ureq::pool] Pool gone: PoolKey { scheme: "https", authority: files.nordicsemi.com, proxy: None }
    [2025-09-12T05:41:51.229Z] [43933] INFO - [toolchain_manager_core::index] Download finished
    [2025-09-12T05:41:51.231Z] [43933] DEBUG - [toolchain_manager_core::install] Downloading version v3.1.0 from index
    [2025-09-12T05:41:51.232Z] [43933] INFO - [toolchain_manager_core::index] Downloading from https://publicburan.blob.core.windows.net/artifactory/NCS/external/bundles/v3/ncs-toolchain-x86_64-linux-c5be9c56c7.tar.gz to /home/akshay/ncs/downloads/ncs-toolchain-x86_64-linux-c5be9c56c7.tar.gz
    [2025-09-12T05:41:51.232Z] [43933] INFO - [nrfutil_http::download] No '-part' file found for resumable download
    [2025-09-12T05:41:51.232Z] [43933] DEBUG - [ureq_proto::client] Call<Prepare>
    [2025-09-12T05:41:51.232Z] [43933] DEBUG - [ureq::run] GET https://publicburan.blob.core.windows.net/******
    [2025-09-12T05:41:51.308Z] [43933] DEBUG - [ureq::unversioned::resolver] Resolved: ArrayVec { len: 1, arr: [20.150.37.196:443] }
    [2025-09-12T05:41:51.573Z] [43933] DEBUG - [ureq::unversioned::transport::tcp] Connected TcpStream to 20.150.37.196:443
    [2025-09-12T05:41:51.579Z] [43933] DEBUG - [rustls::webpki::anchors] add_parsable_certificates processed 147 valid and 0 invalid certs
    [2025-09-12T05:41:51.579Z] [43933] DEBUG - [rustls_platform_verifier::verification::others] Loaded 147 CA root certificates from the system
    [2025-09-12T05:41:51.579Z] [43933] DEBUG - [rustls::client::hs] No cached session for DnsName("publicburan.blob.core.windows.net")
    [2025-09-12T05:41:51.579Z] [43933] DEBUG - [rustls::client::hs] Not resuming any session
    [2025-09-12T05:41:51.579Z] [43933] DEBUG - [ureq::tls::rustls] Wrapped TLS
    [2025-09-12T05:41:51.579Z] [43933] DEBUG - [ureq_proto::client] Call<SendRequest>
    [2025-09-12T05:41:51.579Z] [43933] DEBUG - [ureq::run] Request { method: GET, uri: https://publicburan.blob.core.windows.net/******, version: HTTP/1.1, headers: {"accept-encoding": "gzip", "user-agent": "ureq/3.1.0", "accept": "*/*", "host": "publicburan.blob.core.windows.net"} }
    [2025-09-12T05:41:52.252Z] [43933] DEBUG - [rustls::client::hs] Using ciphersuite TLS13_AES_256_GCM_SHA384
    [2025-09-12T05:41:52.252Z] [43933] DEBUG - [rustls::client::tls13] Not resuming
    [2025-09-12T05:41:52.254Z] [43933] DEBUG - [rustls::client::tls13] TLS1.3 encrypted extensions: ServerExtensions { unknown_extensions: {}, .. }
    [2025-09-12T05:41:52.254Z] [43933] DEBUG - [rustls::client::hs] ALPN protocol is None
    [2025-09-12T05:41:52.254Z] [43933] DEBUG - [ureq_proto::client] Call<RecvResponse>
    [2025-09-12T05:41:52.577Z] [43933] DEBUG - [ureq_proto::client] Call<RecvBody>
    [2025-09-12T05:41:52.577Z] [43933] DEBUG - [ureq::run] Response { status: 200, version: HTTP/1.1, headers: {"content-length": "1094183885", "content-type": "application/octet-stream", "server": "Windows-Azure-Blob/1.0 Microsoft-HTTPAPI/2.0", "date": "Fri, 12 Sep 2025 05:41:52 GMT", "<NOTICE>": "6 HEADERS ARE REDACTED"} }
    [2025-09-12T05:41:52.577Z] [43933] INFO - [nrfutil_http::download] Server doesn't support partial content (status: 200, accept-ranges: None) - switching to complete download
    [2025-09-12T08:45:33.098Z] [43933] DEBUG - [ureq_proto::client] Call<Cleanup>
    [2025-09-12T08:45:33.098Z] [43933] DEBUG - [ureq::pool] Pool gone: PoolKey { scheme: "https", authority: publicburan.blob.core.windows.net, proxy: None }
    [2025-09-12T08:45:33.098Z] [43933] INFO - [toolchain_manager_core::index] Download finished
    [2025-09-12T08:45:33.098Z] [43933] INFO - [toolchain_manager_core::index] Verifying toolchain tarball /home/akshay/ncs/downloads/ncs-toolchain-x86_64-linux-c5be9c56c7.tar.gz
    [2025-09-12T08:45:46.663Z] [43933] INFO - [toolchain_manager_core::sdk] Retrieving toolchains from file /home/akshay/ncs/toolchains/toolchains.json
    [2025-09-12T08:45:46.663Z] [43933] INFO - [toolchain_manager_core] Registering the NcsToolchainConfig.cmake package
    [2025-09-12T08:45:46.669Z] [43933] DEBUG - [toolchain_manager_core] CMake stdout:
    [2025-09-12T08:45:46.670Z] [43933] DEBUG - [toolchain_manager_core] CMake stderr:
    [2025-09-12T08:45:46.670Z] [43933] INFO - [nrfutil_sdk_manager::sdk::package_index] Attempting download from 'https://publicburan.blob.core.windows.net/artifactory/ncs-src-mirror/external/sdk-nrf/v3.1.0/src.tar.gz'
    [2025-09-12T08:45:46.670Z] [43933] INFO - [nrfutil_http::download] No '-part' file found for resumable download
    [2025-09-12T08:45:46.670Z] [43933] DEBUG - [ureq_proto::client] Call<Prepare>
    [2025-09-12T08:45:46.670Z] [43933] DEBUG - [ureq::run] GET https://publicburan.blob.core.windows.net/******
    [2025-09-12T08:45:46.732Z] [43933] DEBUG - [ureq::unversioned::resolver] Resolved: ArrayVec { len: 1, arr: [20.150.37.196:443] }
    [2025-09-12T08:45:47.024Z] [43933] DEBUG - [ureq::unversioned::transport::tcp] Connected TcpStream to 20.150.37.196:443
    [2025-09-12T08:45:47.031Z] [43933] DEBUG - [rustls::webpki::anchors] add_parsable_certificates processed 147 valid and 0 invalid certs
    [2025-09-12T08:45:47.031Z] [43933] DEBUG - [rustls_platform_verifier::verification::others] Loaded 147 CA root certificates from the system
    [2025-09-12T08:45:47.031Z] [43933] DEBUG - [rustls::client::hs] No cached session for DnsName("publicburan.blob.core.windows.net")
    [2025-09-12T08:45:47.031Z] [43933] DEBUG - [rustls::client::hs] Not resuming any session
    [2025-09-12T08:45:47.031Z] [43933] DEBUG - [ureq::tls::rustls] Wrapped TLS
    [2025-09-12T08:45:47.031Z] [43933] DEBUG - [ureq_proto::client] Call<SendRequest>
    [2025-09-12T08:45:47.031Z] [43933] DEBUG - [ureq::run] Request { method: GET, uri: https://publicburan.blob.core.windows.net/******, version: HTTP/1.1, headers: {"accept-encoding": "gzip", "user-agent": "ureq/3.1.0", "accept": "*/*", "host": "publicburan.blob.core.windows.net"} }
    [2025-09-12T08:45:47.638Z] [43933] DEBUG - [rustls::client::hs] Using ciphersuite TLS13_AES_256_GCM_SHA384
    [2025-09-12T08:45:47.638Z] [43933] DEBUG - [rustls::client::tls13] Not resuming
    [2025-09-12T08:45:47.639Z] [43933] DEBUG - [rustls::client::tls13] TLS1.3 encrypted extensions: ServerExtensions { unknown_extensions: {}, .. }
    [2025-09-12T08:45:47.639Z] [43933] DEBUG - [rustls::client::hs] ALPN protocol is None
    [2025-09-12T08:45:47.640Z] [43933] DEBUG - [ureq_proto::client] Call<RecvResponse>
    [2025-09-12T08:45:48.003Z] [43933] DEBUG - [ureq_proto::client] Call<RecvBody>
    [2025-09-12T08:45:48.003Z] [43933] DEBUG - [ureq::run] Response { status: 200, version: HTTP/1.1, headers: {"content-length": "2688115278", "content-type": "application/octet-stream", "server": "Windows-Azure-Blob/1.0 Microsoft-HTTPAPI/2.0", "date": "Fri, 12 Sep 2025 08:45:47 GMT", "<NOTICE>": "6 HEADERS ARE REDACTED"} }
    [2025-09-12T08:45:48.003Z] [43933] INFO - [nrfutil_http::download] Server doesn't support partial content (status: 200, accept-ranges: None) - switching to complete download
    [2025-09-12T11:35:10.593Z] [43933] ERROR - [nrfutil_sdk_manager::sdk::package_index] Source 'https://publicburan.blob.core.windows.net/artifactory/ncs-src-mirror/external/sdk-nrf/v3.1.0/src.tar.gz' returned unexpected error: I/O Error:
    [2025-09-12T11:35:10.593Z] [43933] INFO - [nrfutil_sdk_manager::sdk::package_index] Attempting download from 'https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-nrf/v3.1.0/src.tar.gz'
    [2025-09-12T11:35:10.737Z] [43933] INFO - [nrfutil_http::download] Found '-part' file for resumable download: /home/akshay/ncs/downloads/sdk-nrf-bundle-v3.1.0.tar.gz-part
    [2025-09-12T11:35:10.737Z] [43933] DEBUG - [ureq_proto::client] Call<Prepare>
    [2025-09-12T11:35:10.737Z] [43933] DEBUG - [ureq::run] GET https://files.nordicsemi.com/******
    [2025-09-12T11:35:10.897Z] [43933] DEBUG - [ureq::unversioned::resolver] Resolved: ArrayVec { len: 1, arr: [108.141.12.92:443] }
    [2025-09-12T11:35:11.200Z] [43933] DEBUG - [ureq::unversioned::transport::tcp] Connected TcpStream to 108.141.12.92:443
    [2025-09-12T11:35:11.203Z] [43933] DEBUG - [rustls::webpki::anchors] add_parsable_certificates processed 147 valid and 0 invalid certs
    [2025-09-12T11:35:11.203Z] [43933] DEBUG - [rustls_platform_verifier::verification::others] Loaded 147 CA root certificates from the system
    [2025-09-12T11:35:11.203Z] [43933] DEBUG - [rustls::client::hs] No cached session for DnsName("files.nordicsemi.com")
    [2025-09-12T11:35:11.203Z] [43933] DEBUG - [rustls::client::hs] Not resuming any session
    [2025-09-12T11:35:11.203Z] [43933] DEBUG - [ureq::tls::rustls] Wrapped TLS
    [2025-09-12T11:35:11.203Z] [43933] DEBUG - [ureq_proto::client] Call<SendRequest>
    [2025-09-12T11:35:11.203Z] [43933] DEBUG - [ureq::run] Request { method: GET, uri: https://files.nordicsemi.com/******, version: HTTP/1.1, headers: {"accept-encoding": "gzip", "user-agent": "ureq/3.1.0", "accept": "*/*", "host": "files.nordicsemi.com"} }
    [2025-09-12T11:35:11.480Z] [43933] DEBUG - [rustls::client::hs] ALPN protocol is None
    [2025-09-12T11:35:11.480Z] [43933] DEBUG - [rustls::client::hs] Using ciphersuite TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    [2025-09-12T11:35:11.480Z] [43933] DEBUG - [rustls::client::tls12] ECDHE curve is EcParameters { curve_type: NamedCurve, named_group: X25519 }
    [2025-09-12T11:35:11.481Z] [43933] DEBUG - [rustls::client::tls12] Server DNS name is DnsName("files.nordicsemi.com")
    [2025-09-12T11:35:11.816Z] [43933] DEBUG - [ureq_proto::client] Call<RecvResponse>
    [2025-09-12T11:35:12.121Z] [43933] DEBUG - [ureq_proto::client] Call<RecvBody>
    [2025-09-12T11:35:12.121Z] [43933] DEBUG - [ureq::run] Response { status: 200, version: HTTP/1.1, headers: {"date": "Fri, 12 Sep 2025 11:35:11 GMT", "content-type": "application/x-gzip", "content-length": "2688115278", "connection": "keep-alive", "<NOTICE>": "13 HEADERS ARE REDACTED"} }
    [2025-09-12T11:35:12.121Z] [43933] INFO - [nrfutil_http::download] Server supported partial content to resumable downloads are possible
    [2025-09-12T12:16:21.250Z] [43933] DEBUG - [ureq_proto::client] Call<Cleanup>
    [2025-09-12T12:16:21.250Z] [43933] DEBUG - [ureq::pool] Pool gone: PoolKey { scheme: "https", authority: files.nordicsemi.com, proxy: None }
    [2025-09-12T12:16:40.442Z] [43933] INFO - [toolchain_manager_core::sdk] Retrieving toolchains from file /home/akshay/ncs/toolchains/toolchains.json
    [2025-09-12T12:16:41.187Z] [43933] ERROR - [nrfutil_sdk_manager::sdk::register] Failed to run 'west zephyr-export' in SDK directory.
    Stdout:
    Stderr: usage: west [-h] [-z ZEPHYR_BASE] [-v] [-q] [-V] <command> ...
    And nrfutil.log has only one line
    [2025-09-12T05:41:44.820Z] [43932] INFO - [nrfutil_common::logger] nrfutil (version = 8.1.1, platform = x86_64-unknown-linux-gnu, classification = nrf-external) invoked with sdk-manager install v3.1.0 --log-level debug
    Could you try to do nrfutil sdk-manager toolchain launch --ncs-version v3.1.0 --shell and run west zephyr-export from the root of the SDK v3.1.0 directory with that. That's all sdk-manager is doing.
    Also, as of sdk-manager v1.6.0 there is a separate sdk register command which runs this west zephyr-export command. The same underlying function is called as in the last step of the install. So you can try to run nrfutil sdk-manager sdk register v3.1.0 and report back on that too.
    -Priyanka
