Unable to install SDK via VS Code
I have installed nRF connect 2025.9.732 on my VS code Version: 1.103.2 on Ubuntu 22.04.
I am able to install the toolchains successful but I am getting this weird error message
[14:05:44] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Install toolchain v3.1.0
[14:05:44] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Toolchain with version v3.1.0 already installed: success
[14:05:44] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Calculating SDK checksum
[14:05:53] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Verified previously download file: success
[14:05:53] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Unpack SDK v3.1.0
[14:06:06] nrfutil-sdk-manager install,v3.1.0,--sdk-path,/home/akshay/ncs/v3.1.0,--type,nrf: Unpacked SDK tarball: success
[west]: usage: west [-h] [-z ZEPHYR_BASE] [-v] [-q] [-V] <command> ...
[west]: west: unknown command "zephyr-export"; workspace /home/akshay/ncs/v3.1.0 does not define this extension command -- try "west help" and "west -vv status"
[west]: exited with code 1.
[west]: FATAL ERROR: failed manifest import in zephyr (zephyr):
[west]:   Failed importing "west.yml" from revision "ncs-v3.1.0"
[west]:   Hint: zephyr must be cloned, owned by the user and its manifest-rev ref must point to a commit with the import data
[west]:   To fix, run "west update. If it still fails, try "west -vv ..."
I have west installed globally via pip, but I do NOT have ZEPHYR os installed in ~/zephyrproject.
I am not sure what that error is, do I have to go to /home/akshay/ncs/v3.1.0 and type west update?
  • For your first suggestion, this is what I did-
    1. nrfutil sdk-manager toolchain launch --ncs-version v3.1.0 --shell
    2. cd ~/ncs/v3.1.0
    3. west zephyr-export
    And I get
    This is on west v1.4.0
    For your second suggestion, this is the error:
    Error: Failed to run west zephyr-export in SDK directory '/home/akshay/ncs/v3.1.0'. Check the log for details.
    The log shows
    [2025-09-16T07:17:42.613Z] [25258] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.6.2, platform = x86_64-unknown-linux-gnu, classification = nrf-external) invoked with sdk register v3.1.0
    [2025-09-16T07:17:42.613Z] [25258] INFO - [nrfutil_sdk_manager::config::file] Loading config from default location
    [2025-09-16T07:17:42.613Z] [25258] INFO - [toolchain_manager_core::sdk] Retrieving toolchains from file /home/akshay/ncs/toolchains/toolchains.json
    [2025-09-16T07:17:42.791Z] [25258] ERROR - [nrfutil_sdk_manager::sdk::register] Failed to run 'west zephyr-export' in SDK directory.
    Exit status: Some(1)
    Stdout:
    Stderr: usage: west [-h] [-z ZEPHYR_BASE] [-v] [-q] [-V] <command> ...
    I feel there seems to be a west version mismatch. Is there a specific version you want me to install?
  • Hi Akshay,
    I have reported this internally and we are trying to find the issue. I have also been able to reproduce similar issue on Windows.
    Will keep you updated.
    -Priyanka
  • Thank you. Just to let you know that v3.1.1 has the same issue
    nrfutil sdk-manager install v3.1.1
    [02:22:49] ###### 100% [Download toolchain v3.1.1] Toolchain downloaded
    [00:00:12] ###### 100% [Unpack toolchain v3.1.1] Toolchain unpacked to /home/akshay/ncs/tmp/.tmpZTFdDa
    [00:00:00] ###### 100% [Install toolchain v3.1.1] Toolchain installed at /home/akshay/ncs/toolchains/b2ecd2435d
    [01:21:55] ###### 100% [Download SDK v3.1.1] Download SDK v3.1.1
    [00:00:06] ###### 100% [Calculating SDK checksum] Verified download
    [00:00:14] ###### 100% [Unpack SDK v3.1.1] Unpacked SDK tarball
    Error: Failed to run west zephyr-export in SDK directory '/home/akshay/ncs/v3.1.1'. Check the log for details.
  • Hi Akshay,
    Could you provide the detailed logs for this as well?
    Also, maybe it could be that you have a topdir that shadows these path. Could you open a terminal with any toolchain available and go in the target folder and check topdir:
    $ nrfutil sdk-manager toolchain launch --shell --ncs-version v3.1.1
    $ cd /home/akshay/ncs/v3.1.1
    $ west topdir
    <strong>/home/akshay/ncs/v3.1.1</strong>
    -Priyanka
  • Here is a full debug log for installing the SDK. FYI I had the binaries already downloaded, I uninstalled the SDK and reinstalled it with debug flag, so you may not see anything downloading
    [2025-09-19T07:51:59.513Z] [14744] INFO - [nrfutil_common::logger] nrfutil-sdk-manager (version = 1.6.2, platform = x86_64-unknown-linux-gnu, classification = nrf-external) invoked with install v3.1.1 --log-level debug
    [2025-09-19T07:51:59.513Z] [14744] INFO - [nrfutil_sdk_manager::config::file] Loading config from default location
    [2025-09-19T07:51:59.513Z] [14744] INFO - [nrfutil_sdk_manager::config::file] Resolving configuration
    [2025-09-19T07:51:59.513Z] [14744] INFO - [kms_common] Environment variable 'NRFUTIL_SDK_MANAGER_TOOLCHAIN_REMOTE_CONFIG_TOKEN' not found for token access
    [2025-09-19T07:51:59.515Z] [14744] DEBUG - [ureq_proto::client] Call<Prepare>
    [2025-09-19T07:51:59.515Z] [14744] DEBUG - [ureq::run] GET https://files.nordicsemi.com/******
    [2025-09-19T07:51:59.614Z] [14744] DEBUG - [ureq::unversioned::resolver] Resolved: ArrayVec { len: 1, arr: [108.141.12.92:443] }
    [2025-09-19T07:51:59.879Z] [14744] DEBUG - [ureq::unversioned::transport::tcp] Connected TcpStream to 108.141.12.92:443
    [2025-09-19T07:51:59.895Z] [14744] DEBUG - [rustls::webpki::anchors] add_parsable_certificates processed 147 valid and 0 invalid certs
    [2025-09-19T07:51:59.895Z] [14744] DEBUG - [rustls_platform_verifier::verification::others] Loaded 147 CA root certificates from the system
    [2025-09-19T07:51:59.896Z] [14744] DEBUG - [rustls::client::hs] No cached session for DnsName("files.nordicsemi.com")
    [2025-09-19T07:51:59.896Z] [14744] DEBUG - [rustls::client::hs] Not resuming any session
    [2025-09-19T07:51:59.897Z] [14744] DEBUG - [ureq::tls::rustls] Wrapped TLS
    [2025-09-19T07:51:59.897Z] [14744] DEBUG - [ureq_proto::client] Call<SendRequest>
    [2025-09-19T07:51:59.897Z] [14744] DEBUG - [ureq::run] Request { method: GET, uri: https://files.nordicsemi.com/******, version: HTTP/1.1, headers: {"accept-encoding": "gzip", "user-agent": "ureq/3.1.0", "accept": "*/*", "host": "files.nordicsemi.com"} }
    [2025-09-19T07:52:00.203Z] [14744] DEBUG - [rustls::client::hs] ALPN protocol is None
    [2025-09-19T07:52:00.203Z] [14744] DEBUG - [rustls::client::hs] Using ciphersuite TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    [2025-09-19T07:52:00.211Z] [14744] DEBUG - [rustls::client::tls12] ECDHE curve is EcParameters { curve_type: NamedCurve, named_group: X25519 }
    [2025-09-19T07:52:00.211Z] [14744] DEBUG - [rustls::client::tls12] Server DNS name is DnsName("files.nordicsemi.com")
    [2025-09-19T07:52:00.508Z] [14744] DEBUG - [ureq_proto::client] Call<RecvResponse>
    [2025-09-19T07:52:00.816Z] [14744] DEBUG - [ureq_proto::client] Call<RecvBody>
    [2025-09-19T07:52:00.816Z] [14744] DEBUG - [ureq::run] Response { status: 200, version: HTTP/1.1, headers: {"date": "Fri, 19 Sep 2025 07:52:00 GMT", "content-type": "application/json", "content-length": "1750", "connection": "keep-alive", "<NOTICE>": "12 HEADERS ARE REDACTED"} }
    [2025-09-19T07:52:00.816Z] [14744] DEBUG - [ureq_proto::client] Call<Cleanup>
    [2025-09-19T07:52:00.816Z] [14744] DEBUG - [ureq::pool] Pool gone: PoolKey { scheme: "https", authority: files.nordicsemi.com, proxy: None }
    [2025-09-19T07:52:00.817Z] [14744] INFO - [kms_common] Environment variable 'NRFUTIL_SDK_MANAGER_SDK_REMOTE_CONFIG_TOKEN' not found for token access
    [2025-09-19T07:52:00.817Z] [14744] DEBUG - [ureq_proto::client] Call<Prepare>
    [2025-09-19T07:52:00.817Z] [14744] DEBUG - [ureq::run] GET https://files.nordicsemi.com/******
    [2025-09-19T07:52:00.822Z] [14744] DEBUG - [ureq::unversioned::resolver] Resolved: ArrayVec { len: 1, arr: [108.141.12.92:443] }
    [2025-09-19T07:52:01.124Z] [14744] DEBUG - [ureq::unversioned::transport::tcp] Connected TcpStream to 108.141.12.92:443
    [2025-09-19T07:52:01.131Z] [14744] DEBUG - [rustls::webpki::anchors] add_parsable_certificates processed 147 valid and 0 invalid certs
    [2025-09-19T07:52:01.131Z] [14744] DEBUG - [rustls_platform_verifier::verification::others] Loaded 147 CA root certificates from the system
    [2025-09-19T07:52:01.131Z] [14744] DEBUG - [rustls::client::hs] No cached session for DnsName("files.nordicsemi.com")
    [2025-09-19T07:52:01.131Z] [14744] DEBUG - [rustls::client::hs] Not resuming any session
    [2025-09-19T07:52:01.131Z] [14744] DEBUG - [ureq::tls::rustls] Wrapped TLS
    [2025-09-19T07:52:01.131Z] [14744] DEBUG - [ureq_proto::client] Call<SendRequest>
    [2025-09-19T07:52:01.131Z] [14744] DEBUG - [ureq::run] Request { method: GET, uri: https://files.nordicsemi.com/******, version: HTTP/1.1, headers: {"accept-encoding": "gzip", "user-agent": "ureq/3.1.0", "accept": "*/*", "host": "files.nordicsemi.com"} }
    [2025-09-19T07:52:01.430Z] [14744] DEBUG - [rustls::client::hs] ALPN protocol is None
    [2025-09-19T07:52:01.430Z] [14744] DEBUG - [rustls::client::hs] Using ciphersuite TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    [2025-09-19T07:52:01.430Z] [14744] DEBUG - [rustls::client::tls12] ECDHE curve is EcParameters { curve_type: NamedCurve, named_group: X25519 }
    [2025-09-19T07:52:01.430Z] [14744] DEBUG - [rustls::client::tls12] Server DNS name is DnsName("files.nordicsemi.com")
    [2025-09-19T07:52:01.738Z] [14744] DEBUG - [ureq_proto::client] Call<RecvResponse>
    [2025-09-19T07:52:02.017Z] [14744] DEBUG - [ureq_proto::client] Call<RecvBody>
    [2025-09-19T07:52:02.017Z] [14744] DEBUG - [ureq::run] Response { status: 200, version: HTTP/1.1, headers: {"date": "Fri, 19 Sep 2025 07:52:01 GMT", "content-type": "application/json", "content-length": "1044", "connection": "keep-alive", "<NOTICE>": "13 HEADERS ARE REDACTED"} }
    [2025-09-19T07:52:02.017Z] [14744] DEBUG - [ureq_proto::client] Call<Cleanup>
    [2025-09-19T07:52:02.017Z] [14744] DEBUG - [ureq::pool] Pool gone: PoolKey { scheme: "https", authority: files.nordicsemi.com, proxy: None }
    [2025-09-19T07:52:02.018Z] [14744] INFO - [nrfutil_sdk_manager::sdk::package_index] Downloading SDK package index from: https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json
    [2025-09-19T07:52:02.018Z] [14744] DEBUG - [ureq_proto::client] Call<Prepare>
    [2025-09-19T07:52:02.018Z] [14744] DEBUG - [ureq::run] GET https://files.nordicsemi.com/******
    [2025-09-19T07:52:02.023Z] [14744] DEBUG - [ureq::unversioned::resolver] Resolved: ArrayVec { len: 1, arr: [108.141.12.92:443] }
    [2025-09-19T07:52:02.356Z] [14744] DEBUG - [ureq::unversioned::transport::tcp] Connected TcpStream to 108.141.12.92:443
    [2025-09-19T07:52:02.362Z] [14744] DEBUG - [rustls::webpki::anchors] add_parsable_certificates processed 147 valid and 0 invalid certs
    [2025-09-19T07:52:02.362Z] [14744] DEBUG - [rustls_platform_verifier::verification::others] Loaded 147 CA root certificates from the system
    [2025-09-19T07:52:02.362Z] [14744] DEBUG - [rustls::client::hs] No cached session for DnsName("files.nordicsemi.com")
    [2025-09-19T07:52:02.362Z] [14744] DEBUG - [rustls::client::hs] Not resuming any session
    [2025-09-19T07:52:02.362Z] [14744] DEBUG - [ureq::tls::rustls] Wrapped TLS
    [2025-09-19T07:52:02.362Z] [14744] DEBUG - [ureq_proto::client] Call<SendRequest>
    [2025-09-19T07:52:02.362Z] [14744] DEBUG - [ureq::run] Request { method: GET, uri: https://files.nordicsemi.com/******, version: HTTP/1.1, headers: {"accept-encoding": "gzip", "user-agent": "ureq/3.1.0", "accept": "*/*", "host": "files.nordicsemi.com"} }
    [2025-09-19T07:52:02.659Z] [14744] DEBUG - [rustls::client::hs] ALPN protocol is None
    [2025-09-19T07:52:02.659Z] [14744] DEBUG - [rustls::client::hs] Using ciphersuite TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    [2025-09-19T07:52:02.659Z] [14744] DEBUG - [rustls::client::tls12] ECDHE curve is EcParameters { curve_type: NamedCurve, named_group: X25519 }
    [2025-09-19T07:52:02.659Z] [14744] DEBUG - [rustls::client::tls12] Server DNS name is DnsName("files.nordicsemi.com")
    [2025-09-19T07:52:02.928Z] [14744] DEBUG - [ureq_proto::client] Call<RecvResponse>
    [2025-09-19T07:52:03.276Z] [14744] DEBUG - [ureq_proto::client] Call<RecvBody>
    [2025-09-19T07:52:03.276Z] [14744] DEBUG - [ureq::run] Response { status: 200, version: HTTP/1.1, headers: {"date": "Fri, 19 Sep 2025 07:52:03 GMT", "content-type": "application/json", "content-length": "16984", "connection": "keep-alive", "<NOTICE>": "13 HEADERS ARE REDACTED"} }
    [2025-09-19T07:52:03.581Z] [14744] DEBUG - [ureq_proto::client] Call<Cleanup>
    [2025-09-19T07:52:03.581Z] [14744] DEBUG - [ureq::pool] Pool gone: PoolKey { scheme: "https", authority: files.nordicsemi.com, proxy: None }
    [2025-09-19T07:52:03.581Z] [14744] INFO - [toolchain_manager_core::sdk] Retrieving toolchains from file /home/akshay/ncs/toolchains/toolchains.json
    [2025-09-19T07:52:03.581Z] [14744] INFO - [toolchain_manager_core::index] Downloading from https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-linux-x86_64.json
    [2025-09-19T07:52:03.581Z] [14744] DEBUG - [ureq_proto::client] Call<Prepare>
    [2025-09-19T07:52:03.581Z] [14744] DEBUG - [ureq::run] GET https://files.nordicsemi.com/******
    [2025-09-19T07:52:03.587Z] [14744] DEBUG - [ureq::unversioned::resolver] Resolved: ArrayVec { len: 1, arr: [108.141.12.92:443] }
    [2025-09-19T07:52:03.888Z] [14744] DEBUG - [ureq::unversioned::transport::tcp] Connected TcpStream to 108.141.12.92:443
    [2025-09-19T07:52:03.894Z] [14744] DEBUG - [rustls::webpki::anchors] add_parsable_certificates processed 147 valid and 0 invalid certs
    [2025-09-19T07:52:03.894Z] [14744] DEBUG - [rustls_platform_verifier::verification::others] Loaded 147 CA root certificates from the system
    [2025-09-19T07:52:03.894Z] [14744] DEBUG - [rustls::client::hs] No cached session for DnsName("files.nordicsemi.com")
    [2025-09-19T07:52:03.894Z] [14744] DEBUG - [rustls::client::hs] Not resuming any session
    [2025-09-19T07:52:03.894Z] [14744] DEBUG - [ureq::tls::rustls] Wrapped TLS
    [2025-09-19T07:52:03.894Z] [14744] DEBUG - [ureq_proto::client] Call<SendRequest>
    [2025-09-19T07:52:03.894Z] [14744] DEBUG - [ureq::run] Request { method: GET, uri: https://files.nordicsemi.com/******, version: HTTP/1.1, headers: {"accept-encoding": "gzip", "user-agent": "ureq/3.1.0", "accept": "*/*", "host": "files.nordicsemi.com"} }
    [2025-09-19T07:52:04.197Z] [14744] DEBUG - [rustls::client::hs] ALPN protocol is None
    [2025-09-19T07:52:04.197Z] [14744] DEBUG - [rustls::client::hs] Using ciphersuite TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    [2025-09-19T07:52:04.197Z] [14744] DEBUG - [rustls::client::tls12] ECDHE curve is EcParameters { curve_type: NamedCurve, named_group: X25519 }
    [2025-09-19T07:52:04.197Z] [14744] DEBUG - [rustls::client::tls12] Server DNS name is DnsName("files.nordicsemi.com")
    [2025-09-19T07:52:04.502Z] [14744] DEBUG - [ureq_proto::client] Call<RecvResponse>
    [2025-09-19T07:52:04.781Z] [14744] DEBUG - [ureq_proto::client] Call<RecvBody>
    [2025-09-19T07:52:04.781Z] [14744] DEBUG - [ureq::run] Response { status: 200, version: HTTP/1.1, headers: {"date": "Fri, 19 Sep 2025 07:52:04 GMT", "content-type": "application/json", "content-length": "57395", "connection": "keep-alive", "<NOTICE>": "12 HEADERS ARE REDACTED"} }
    [2025-09-19T07:52:04.781Z] [14744] INFO - [toolchain_manager_core::index] Get request to https://files.nordicsemi.com/artifactory/NCS/external/bundles/v3/index-linux-x86_64.json returned status code 200: OK
    [2025-09-19T07:52:05.424Z] [14744] DEBUG - [ureq_proto::client] Call<Cleanup>
    [2025-09-19T07:52:05.424Z] [14744] DEBUG - [ureq::pool] Pool gone: PoolKey { scheme: "https", authority: files.nordicsemi.com, proxy: None }
    [2025-09-19T07:52:05.425Z] [14744] INFO - [toolchain_manager_core::index] Download finished
    [2025-09-19T07:52:05.431Z] [14744] DEBUG - [toolchain_manager_core::install] Downloading version v3.1.1 from index
    [2025-09-19T07:52:05.432Z] [14744] INFO - [toolchain_manager_core::index] Toolchain tarball /home/akshay/ncs/downloads/ncs-toolchain-x86_64-linux-b2ecd2435d.tar.gz already exists, checking if it has the correct sha512 checksum
    [2025-09-19T07:52:08.295Z] [14744] INFO - [toolchain_manager_core::index] Previously downloaded file /home/akshay/ncs/downloads/ncs-toolchain-x86_64-linux-b2ecd2435d.tar.gz passed the checksum verification
    [2025-09-19T07:52:19.863Z] [14744] INFO - [toolchain_manager_core::sdk] Retrieving toolchains from file /home/akshay/ncs/toolchains/toolchains.json
    [2025-09-19T07:52:19.863Z] [14744] INFO - [toolchain_manager_core] Registering the NcsToolchainConfig.cmake package
    [2025-09-19T07:52:19.871Z] [14744] DEBUG - [toolchain_manager_core] CMake stdout:
    [2025-09-19T07:52:19.871Z] [14744] DEBUG - [toolchain_manager_core] CMake stderr:
    [2025-09-19T07:52:39.004Z] [14744] INFO - [toolchain_manager_core::sdk] Retrieving toolchains from file /home/akshay/ncs/toolchains/toolchains.json
    [2025-09-19T07:52:39.632Z] [14744] ERROR - [nrfutil_sdk_manager::sdk::register] Failed to run 'west zephyr-export' in SDK directory.
    Stdout:
    west: unknown command "zephyr-export"; workspace /home/akshay/ncs/v3.1.1 does not define this extension command -- try "west help" and "west -vv status"
    For your second check, I have my top dir as - /home/akshay/ncs/v3.1.1
