How to set TX power in PAwR mode of nrf5340 and read TX power value back by nrf54l15?
nrf5340 net core Konfig
CONFIG_BT_EXT_ADV=y
CONFIG_BT_PER_ADV=y
CONFIG_BT_PER_ADV_RSP=y
CONFIG_BT_PER_ADV_SYNC=y
CONFIG_BT_PER_ADV_SYNC_RSP=y
#CONFIG_BT_CTLR_ADV_EXT=y
CONFIG_BT_PER_ADV_SYNC_BUF_SIZE=247
CONFIG_BT_PER_ADV_SYNC_TRANSFER_SENDER=y
CONFIG_BT_PER_ADV_SYNC_TRANSFER_RECEIVER=y
CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
CONFIG_BT_CTLR_TX_PWR_ANTENNA=3
nrf5340 main.c code below, I changed options
static const struct bt_le_per_adv_param per_adv_params = {
	.interval_min = 0x0190,
	.interval_max = 0x0190,
	// .options = 0,
	.options = BT_LE_ADV_OPT_EXT_ADV | BT_LE_ADV_OPT_USE_TX_POWER,
	.num_subevents = NUM_SUBEVENTS,
	.subevent_interval = 0x30,
	.response_slot_delay = 0x05,
	.response_slot_spacing = 0x05,
	.num_response_slots = NUM_RSP_SLOTS,
nrf54l15 main.c is below
static void recv_cb(struct bt_le_per_adv_sync *sync,
		    const struct bt_le_per_adv_sync_recv_info *info, struct net_buf_simple *buf)
	int err;
	/* info->tx_power = AP(dBm) */
    	printk("recv_cb -> PAwR rx: rssi=%d dBm, ap_tx=%d dBm\n", info->rssi, info->tx_power);
I add the tx power print in PAwR recv_cb function.
Below is 54l15 RTT comments, ap_tx is always print 127dBm
00> Indication: subevent 1, responding in slot 0
00> LED blue is now OFF
00>     0xFF: 59000012
00> recv_cb -> PAwR rx: rssi=-39 dBm, ap_tx=127 dBm
00>     0xFF: 59000014
00> recv_cb -> PAwR rx: rssi=-38 dBm, ap_tx=127 dBm
00>     0xFF: 59000016
00>     0xFF: 59000018
00> recv_cb -> PAwR rx: rssi=-40 dBm, ap_tx=127 dBm
00>     0xFF: 5900001A
So, my questions are
1. How to adjust TX power of PAwR on AP end? I hope it can be dynamically adjusted based on rssi value
2. Why can't nrf54l15 read the tx power value during PAwR process? How?
Besides, I am using NCS 3.1 and PAwR samples copy from SDK
