having issues with saving coredump to flash or at all
Hi Nordic
I am working with nrf52840 and nrf52832 using ncs v2.8.0
I am trying to save coredump to flash according to instructions on this link - https://docs.nordicsemi.com/bundle/ncs-2.8.0/page/zephyr/services/debugging/coredump.html
I added this to my pm_static_my_board.yml
coredump_partition:
  address: 0xCF000
  region: flash_primary
And this to my_board.overlay
&flash0 {
     * For more information, see:
     * http: //docs.zephyrproject.org/latest/guides/dts/index.html#flash-partitions
    partitions {
        #address-cells = <1>;
        #size-cells = <1>;
        coredump_partition: partition@000080000 { //THIS IS NOT LEGIT ADDRESS(END OF FLASH) BUT IT IS NOT TAKEN TO ACOUNT BECAUS PM_STATIC IS
            label = "coredump-partition";
            reg = <0x000080000 DT_SIZE_K(4)>;
A side note is that this is strange that I need to set it in the overlay which is basically ignored because pm_static partitions is the one that actually matters (unless i got something wrong ? )
And this configs to my prj.conf
# Coredump
CONFIG_DEBUG_COREDUMP=y
CONFIG_DEBUG_COREDUMP_BACKEND_FLASH_PARTITION=y
CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_THREADS=y
In my my_board/my_app/zephyr/.config i see this coredump related configs
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
# CONFIG_COREDUMP_DEVICE is not set
CONFIG_DEBUG_THREAD_INFO=y
# CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING is not set
# CONFIG_DEBUG_COREDUMP_BACKEND_OTHER is not set
# CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN is not set
# CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_LINKER_RAM is not set
CONFIG_DEBUG_COREDUMP_FLASH_CHUNK_SIZE=64
CONFIG_DEBUG_COREDUMP_THREADS_METADATA=y
I am generating a coredump using this implementation
void trigger_coredump(void)
    __ASSERT(0, "Forcing coredump");
When i try to read the flash area after generating the coredump with nrfjprog --memrd 0xCF000 --w 32 --n 0x8000
i get all 0xFF
what i am missing ?
I also tried to check myself by replacing CONFIG_DEBUG_COREDUMP_BACKEND_FLASH_PARTITION=y
With CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
Hopping to see the coredump on my open rtt but nothing .. when coredump is triggered prints just stop
  1. What am I missing? Why can't I find a coredump on the flash partition or in the rtt log ?
  2. Can it be that the device does not have the time to write the coredump before the actual crash ? If so, how can I manage that ?
  3. Is there some auto deletion of the flash partition with the coredump so new coredumps can be saved or is it something i have to manage myself after i read the coredump from flash ?
Hope to read you soon
Best regards
Ziv
  • Please post a code snippet showing how you have implemented this function.
    i have managed to get it to overwrite, it basically overwrote before as well just it seems that i don't always get to that function being called and this is what i tried to ask here :
    1. according to log ahead, it seems that z_arm_fault precede z_fatal_error() which calls for coredump() and only after that calls for  k_sys_fatal_error_handler()  .. so i don't understand if memfault's implementation is overwriting this function to handle the crash data collection, it is done after coredump so why does it not get stuck even when asserts are enabled .... is it related to  CONFIG_DEBUG_COREDUMP_BACKEND_OTHER though i don't see it used in coredump_backend_flash_partition.c ?  or if i want to get to that handler i need to CONFIG_DEBUG_COREDUMP=n  and only then i will get to this handler before system hults ? and in it i can call for the coredump save ? ?
    2. i tried to add logs in nrf/modules/memfault-firmware-sdk/memfault_flash_coredump_storage.c to follow how memfault saves the coredump but when memfault is on i do not get any logs, even when i add LOG_PANIC() i just get the first call to z_arm_fault and after that it resets so i am not even sure it gets to the call of k_sys_fatal_error_handler() and if not, then which crash api memfault use to overwrite and take control of the flow ?
    p.s.
    I expect all but zero latency interrupts to be masked at this point.
    seems like it is loggs latency and not an actual interrupt being called while coredump operation is on
    hope to read you soon
    best regards
    Ziv
  • Yes, if the coredump backend triggers a fault or an assertion program will crash again before reaching your error handler. You can imagine what happens if the error handler calls something that triggers another error and keeps invoking itself. But you should be able to catch faults occurring in the error handler if you debug your code in VS code. A cpu lockup in debug mode will not trigger a reset but instead halt the program:
    The logger will not work in the case of a cpu lockup so it is not possible to rely on logging in this case.
    When using LOG_MODE_DEFERRED logs are buffered and processed in the logger thread or when you call LOG_PANIC()
    EDITadding a test sample I created store the stack frame and error reason (you can add other things here too) from the error handler to ram in case you are interested. This is without CD and it will therefore have a lower memory footprint.
    crash_save.zip
  • hi Vidar
    well thanks for the patient and the sample
    i found the issue with the PR of coredump_backend_nrf_flash_partition.c that caused the data to be saved partially and managed to save CD to flash Hugging.. however according to git i see this bug is already fixed (so i'll keep searching for other opportunities for me to contribute Upside down )
    basically it was this lines
    for (uint32_t i = 0; i < size; i += sizeof(uint32_t)) {
    		nrfx_nvmc_word_write(PARTITION_OFFSET + offset + i, UNALIGNED_GET(&data[i]));
    	data is uint8_t* type and jumping 4 bytes each time in the loop it losses 3 byts of data
    	so my solution and also in git was to cast it like so :
    	nrfx_nvmc_word_write(PARTITION_OFFSET + offset + i, UNALIGNED_GET((const uint32_t *)&data[i]));
    now i am a bit struggling with decoding of the coredump .. there are some python scripts in zephyr for that but they don't seem to work so well for example i get this error when running coredump_gdbserver.py
    python3 coredump_gdbserver.py /../app/build_b/app/zephyr/zephyr.elf /../coredump/coredump_flash.bin
      File "/.../ncs/v2.8.0/zephyr/scripts/coredump/coredump_gdbserver.py", line 14, in <module>
        from coredump_parser.elf_parser import CoredumpElfFile
      File "/.../ncs/v2.8.0/zephyr/scripts/coredump/coredump_parser/elf_parser.py", line 10, in <module>
        import elftools
    ModuleNotFoundError: No module named 'elftools'
    update: the above can be solve by installing "pip install pyelftools" (there are still errors cause i am not using a log file but a saved bytes hex string like)
    is there a script like coredump_serial_log_parser.py that accepts the flash saved bytes instead of a log file to make it binary or is there a way to save CD initially as binary (this can probably save space on flash and less data to transfer OTA)?
    another thing is big/little endien .. i notice that in the log the bytes are saved in this order ' 5a450100' (taken from log example in https://docs.zephyrproject.org/latest/services/debugging/coredump.html#:~:text=5a4501000100050000000000)
    but in the file i read from flash they are saved like this 0002455A what is the correct way of byte order for it to be parsed ?
    i would actually like to have one script that does all (giving it the zephyr.elf and coredump and an output file) and it will output a human readable parsing of coredump .. wonder if there is something like that ??
    p.s. if you like i can open the CD parsing questions on a new thread and close this one
    best regards
    Ziv
  • well, feeling a little neglected here Upside downman shrugging: light skin tone
    anyway things i figured out so far:
    1. what is saved to flash is actually a binary, but when using " nefjprog --memrd " to read it and save to a file it is converted to ascci hex (this can also be varified by the size of the saved file which is larger then the actual flash partition). to save the binary from flash this commands can be used:
    JLinkExe -device nRF52840_xxAA -if swd -speed 4000 -autoconnect 1
    followed by : savebin coredump.bin,0xED000,0x8000 from within JLink.
    2. following instruction for coredump debug,  here https://docs.zephyrproject.org/latest/services/debugging/coredump.html#:~:text=Run%20the%20core%20dump%20serial%20log%20converter%3A or here https://docs.nordicsemi.com/bundle/ncs-2.8.0/page/zephyr/services/debugging/coredump.html#:~:text=Run%20the%20core%20dump%20serial%20log%20converter%3A
    the py script coredump_serial_log_parser.py is designed to take a .log file (not sure where i get it, maybe by copying my rtt output remove the timestamp and log file name etc. all the way to '#CD' and save to a file Thinking ) .. any way, since i know how to get a binary i don't need this converter which is not really working with normal coredump cause normal coredump is missing the "BEGIN" bytes or the "#CD" and also contain a header before the CD initials 'ZE' .. so ..i can take my binary coredump parse the first 4 words to the header, get the size of coredump and then saved this size of bytes from after the header .. the reason that the bin file should not contain the header is that coredump_gdbserver.py calls for log_parser.py which expects to find 'ZE' in the first line.
    p.s. in the CD saved to flash the bytes seems to be in reverse order from the way it seems in the log prints in the rtt, i think it is just a matter of how the tools present the ascii cause the bin file without any reverse operation is read by the log_parser.py and 'ZE' is found.
    so far this is what i got working and understood..   please correct me if i am wrong somewhere there.
    the issue i am running this  "/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb build/zephyr/zephyr.elf" (instead of non existing <path to SDK>/x86_64-zephyr-elf/bin/x86_64-zephyr-elf-gdb ) and trying to connect, then i get this error
    (gdb)  target remote localhost:1234
    localhost:1234
    : cannot resolve name: Servname not supported for ai_socktype
    localhost:1234
    : No such file or directory.
    even though coredump_gdbserver.py is running on another terminal
    any idea why ? update - seems like it was related to order of things server must run before opening the gdb client even if the attempt to conect inside gdb is after the server start running ..
    are there more debug options other then "info registers" and "bt" in order to get more information on running threads and stack ?
    i'll mention that i am working with a coredump bin which is generated with normal building mechanism (
    CONFIG_DEBUG_COREDUMP=y,
    CONFIG_DEBUG_COREDUMP_BACKEND_FLASH_PARTITION=y,
    CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_THREADS=y,
    CONFIG_ASSERT=n )
    and i'll also mention that it is very strange to me that there is no clear tool or support for flash saved CD parsing / debugging
    best regards
    Ziv
