lte_lc: Could not send AT command, error: 65536
After gradually increasing up to ncs 3.1.0, the following issue occured:
After:
    LOG_INF("Initializing modem library");
    err = nrf_modem_lib_init();
    if (err) {
        LOG_ERR("Failed to initialize the modem library, error: %d", err);
        return err;
I observe:
[00:00:05.978,454] <inf> main: Initializing modem library
[00:00:06.132,019] <dbg> nrf_modem: nrf_modem_lib_init: Modem init callback: 0x62a3d
[00:00:06.132,049] <dbg> nrf_modem: nrf_modem_lib_init: Modem init callback: 0x6354d
[00:00:06.132,446] <err> lte_lc: Could not send AT command, error: 65536
[00:00:06.132,446] <err> lte_lc: Failed to set system mode and mode preference, err -14
Here is my prj.conf:
# prj.conf
# Copyright (c) 2020 Nordic Semiconductor ASA
### wrk
# Keep the exact same LTE events you handled in v2.7
CONFIG_LTE_LC_PSM_MODULE=y
CONFIG_LTE_LC_EDRX_MODULE=y
CONFIG_LTE_LC_TAU_PRE_WARNING_MODULE=y
CONFIG_LTE_LC_NEIGHBOR_CELL_MEAS_MODULE=y
CONFIG_LTE_LC_MODEM_SLEEP_MODULE=y
### LTE
#CONFIG_LTE_NETWORK_MODE_LTE_M=y
#CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT=n
CONFIG_LTE_LINK_CONTROL=y
#CONFIG_LTE_MODE_PREFERENCE_AUTO=y
#CONFIG_LTE_PSM_REQ=n
#CONFIG_LTE_EDRX_REQ=n
#CONFIG_LTE_RAI_REQ=n
#CONFIG_LTE_NETWORK_TIMEOUT=60
#CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS=n
CONFIG_AT_HOST_LIBRARY=n
### watchdog
CONFIG_WATCHDOG=y
CONFIG_WDT_LOG_LEVEL_INF=y # Or DBG for more verbose watchdog logs
### tune networking
CONFIG_NET_TCP_RETRY_COUNT=1
CONFIG_MQTT_KEEPALIVE=30
### modem
CONFIG_AT_MONITOR=y
CONFIG_NRF_MODEM_LIB=y
# CONFIG_NRF_MODEM_LIB_ON_FAULT_RESET_MODEM=y
CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DBG=y
### (do not) reset on fatal error
CONFIG_RESET_ON_FATAL_ERROR=y
### debug optimizations (-Og)
CONFIG_DEBUG=y
CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_DEBUG_THREAD_INFO=y
CONFIG_NVS_LOG_LEVEL_DBG=y
## debug network timing
# CONFIG_NET_LOG=y
## debug MQTT timing (add both below)
# CONFIG_MQTT_LOG_LEVEL_DBG=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=3000
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
### coredump debug
# CONFIG_DEBUG_COREDUMP=y
# CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
### higher LOG buffer not to drop LOG messages
CONFIG_LOG_BUFFER_SIZE=2300
#CONFIG_LOG_MODE_DEFERRED=y
#CONFIG_LOG_PROCESS_THREAD=y
### debugging threads
CONFIG_THREAD_ANALYZER=n
CONFIG_THREAD_ANALYZER_AUTO=n
### trying to manage priorities
# CONFIG_SYSTEM_WORKQUEUE_PRIORITY=10
### Admin uart helpers
#CONFIG_UART_2_NRF_HW_ASYNC=y
#CONFIG_UART_2_NRF_HW_ASYNC_TIMER=1
CONFIG_UART_NRFX_UARTE_ENHANCED_RX=y
### uart
CONFIG_UART_ASYNC_API=y
# ! the following must be done not to loosing RX characters: assigning timer 2 to RX processing:
CONFIG_UART_NRFX=y
#CONFIG_UART_1_NRF_HW_ASYNC=y
#CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
# dynamic uart configuration needed
CONFIG_UART_USE_RUNTIME_CONFIGURE=y
### Networking
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_POSIX_API=y
# CONFIG_NET_SOCKETS_POSIX_API=y
CONFIG_NET_SOCKETS=y
# CONFIG_NET_TCP_ACK_TIMEOUT=100
CONFIG_NEWLIB_LIBC=y
CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=4096
CONFIG_NET_TCP=y
CONFIG_NET_IPV4=y
### Floating point support
CONFIG_CBPRINTF_FP_SUPPORT=y
#### logging
CONFIG_LOG_MODE_IMMEDIATE=n
CONFIG_LOG_RUNTIME_FILTERING=y
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=y
### CPU load
#CONFIG_CPU_LOAD=
#CONFIG_CPU_LOAD_LOG_PERIODIC=y
#CONFIG_CPU_LOAD_LOG_INTERVAL=1000
### SECURE TFM logging
### disabling logging of TF-M
# CONFIG_TFM_LOG_LEVEL_SILENCE=y
# try to increase MODEM library heap size:
# CONFIG_NRF_MODEM_LIB_HEAP_SIZE=4096
### forward TF-M secure logging to the same UART as application logging (comment the previous)
# CONFIG_TFM_SECURE_UART=y
# CONFIG_TFM_SECURE_UART_SHARE_INSTANCE=y
# CONFIG_TFM_SECURE_UART0=y
# CONFIG_TFM_PARTITION_LOG_LEVEL_DEBUG=y
# CONFIG_TFM_SPM_LOG_LEVEL_DEBUG=y
# Dump exception info. Must be combined with enabling log output.
# CONFIG_TFM_EXCEPTION_INFO_DUMP=y
# CONFIG_TFM_CRYPTO_KEY_DERIVATION_MODULE_ENABLED=y
### NVS
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_NVS=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_FLASH_MAP=y
CONFIG_REBOOT=y
# Enable snprintf float
### Possible solution for Fatal error:
# Don't use the minimal TF-M configuration as that doesn't support logging
CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
### Memory
CONFIG_MAIN_STACK_SIZE=3000
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_ISR_STACK_SIZE=4096
### MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_CLEAN_SESSION=y
### ADC
CONFIG_ADC=y
### I2C, IMU
CONFIG_I2C=y
CONFIG_I2C_CALLBACK=y
CONFIG_I2C_LOG_LEVEL_DBG=y
### others
CONFIG_CLOCK_CONTROL=y
What puzzles me is that even reflashing older versions does not seem to reset the appropriate modem behavior as had been observed before. (How) can it happen?
