Wake from SystemOFF with LPCOMP ANADETECT, varying VDD
I'm using the board RAK19007 with its RAK4630 nrf52840, meant for solar and battery, where the AIN3 (P0.05) comes from a voltage divider of VBAT, where AIN3 = VBAT*(1.5M/2.5M). The Thevenin equivalent resistor should be 600KOhm.
The nrf52840 is powered in High Voltage mode, where VDDH=VBAT. I noticed that VDD=MAX(3v3,VDDH) with a multimeter. We use the default LDO in regulators; I tried using the DC/DC converters but I cannot observe any difference.
I'm telling the system to go off (sd_power_system_off()) when VBAT < 3.1V (using ADC read in AIN3), but before system off, I program LPCOMP like this:
        nrf_lpcomp_config_t c;
        /* We have AIN3 with a VBAT divider so AIN3 = VBAT * (1.5/2.5)
         * We have the device going deep sleep under 3.1V, which is AIN3 = 1.86V
         * So we can wake up when VBAT>=VDD is restored to 3.3V, where AIN3 = 1.98V
         * 1.98/3.3 = 6/10, but that's close to the VBAT divider, so we
         * pick 6/8VDD, which means VBAT=4.1V */
        c.reference = NRF_LPCOMP_REF_SUPPLY_6_8;
        c.detection = NRF_LPCOMP_DETECT_UP;
        c.hyst = NRF_LPCOMP_HYST_NOHYST;
        nrf_lpcomp_configure(NRF_LPCOMP, &c);
        nrf_lpcomp_input_select(NRF_LPCOMP, NRF_LPCOMP_INPUT_3); // RAK4630 AIN0 = nrf52840 AIN3 = Pin 5
        nrf_lpcomp_enable(NRF_LPCOMP);
        /* Disable RAM retention in System OFF, otherwise the
         * system does not reboot well, part of config reset */
        for(int i=0; i < 9; ++i)
            nrf_power_rampower_mask_off(NRF_POWER, i,
                    NRF_POWER_RAMPOWER_S0RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S1RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S2RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S3RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S4RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S5RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S7RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S8RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S9RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S10RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S11RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S12RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S13RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S14RETENTION_MASK |
                    NRF_POWER_RAMPOWER_S15RETENTION_MASK
        auto ok = sd_power_system_off();
I would expect that if I set VBAT=2.5V for example (with a regulable power supply), the system will go off. It does, but it reboots immediately. It reboots, then goes off, then reboots, then goes off, ...
I checked that it has to be the LPCOMP resetting the system, because if I don't program LPCOMP the system never resets.
Why LPCOMP does wake the device up immediately after SystemOff?
VBAT=VDD=2.5V, that means that AIN3 = 1.5V < 6/8*VDD = 1.875V, set in LPCOMP. The ANADETECT signal should not be triggered.
Is there a problem with the high resistance of the voltage divider? Is there something I wrote wrong?
In another test I changed the LPCOMP input to AIN7, which is Not Connected to anywhere, and it also reboots automatically.
    You can try to disable global interrupts before executing this, and in that case also use directly NRF_POWER->SYSTEMOFF = 1; (if I remember correctly). On wakeup you can try to double check that it's waking up from system off reset (and not a soft reset due to fatal error or similar) by reading the RESETREAS register:
    https://docs.nordicsemi.com/bundle/ps_nrf52840/page/power.html#ariaid-title35
    Maybe it's another wakeup source happening here.
    Kenneth
  • I already removed the ram retention part and now it doesn't reset.
    I tried LPCOMP + ANADETECT, and reset does not occur for me (code in prev post).
    I also tried GPIO as well, without success. No reset when I connect the pin to 3V3:
            NRF_P0->PIN_CNF[31] = ((uint32_t)GPIO_PIN_CNF_DIR_Input        << GPIO_PIN_CNF_DIR_Pos)
                               | ((uint32_t)GPIO_PIN_CNF_INPUT_Connect    << GPIO_PIN_CNF_INPUT_Pos)
                               | ((uint32_t)GPIO_PIN_CNF_PULL_Pulldown    << GPIO_PIN_CNF_PULL_Pos)
                               | ((uint32_t)GPIO_PIN_CNF_DRIVE_S0S1       << GPIO_PIN_CNF_DRIVE_Pos)
                               | ((uint32_t)GPIO_PIN_CNF_SENSE_High   << GPIO_PIN_CNF_SENSE_Pos);
            NRF_P0->DETECTMODE = 0;
    Am I missing something in LPCOMP or GPIO to get the wakeup?
    Do I need to set up interrupts in any particular way?
  • I finally solved the situation.
    To get LPCOMP ANADETECT to work I missed two steps before the system off: START the task, and wait for its READY event.
    When GPIO DETECT was not working for me is because I was not getting into system-off, due to some other complex bug of the whole software. Once I solved that, GPIO DETECT worked fine as well.
    I cannot tell about the unexpected reset sources I had while I was doing all this. Other pieces of the whole software I don't know about, probably.
