Cannot transmit and then receive in timeslot
Hi there, I am trying to implement scanning feature based on timeslots (with BLE). I can receive and transmit my packets in timeslot. However I need to send PACKET_A and then wait for nodes response. My PACKET_A is transmitting correctly, so in (case: NRF_RADIO_CALLBACK_SIGNAL_TYPE_RADIO) I set the radio to receive data from nodes. Unfortuanetely this part of the code gets stuck timeslot execution. Even NRF_RADIO_CALLBACK_SIGNAL_TYPE_TIMER0 is not calling, but the BLE works fine (MCU running). Is there a limitation that does not allow to transmit and receive in the same timeslot execution?
    switch(signal_type)
    case NRF_RADIO_CALLBACK_SIGNAL_TYPE_START:
        //Start of the timeslot - set up timer interrupt
        signal_callback_return_param.params.request.p_next = NULL;
        signal_callback_return_param.callback_action = NRF_RADIO_SIGNAL_CALLBACK_ACTION_NONE;
        NRF_TIMER0->INTENSET = TIMER_INTENSET_COMPARE0_Msk;
        NRF_TIMER0->CC[0] = m_slot_length - 1000;
        NVIC_EnableIRQ(TIMER0_IRQn);
					timer_init();
					radio_init(0xA541A68F);
					network_time_operations();
    case NRF_RADIO_CALLBACK_SIGNAL_TYPE_RADIO:
					radio_state_t radio_state =  RADIO_timeslot_IRQHandler();
					switch (radio_state)
					case RADIO_STATE_RX:
							printf("Radio RX \r\n");
					case RADIO_STATE_TX:
							printf("Radio TX \r\n");
							if(g_global_network_state == INITIALIZE_NEW_NETWORK)
								printf("Start sniffing \r\n");
								printf("<%d>\n", NRF_TIMER0->CC[0]);
								//network_time_operations();
								network_sniffing_state(0);
							//	radio_disable();
							} else{
								printf("No sniff \r\n");
								configure_next_event_normal();
								signal_callback_return_param.params.request.p_next = &m_timeslot_request;
								signal_callback_return_param.callback_action = NRF_RADIO_SIGNAL_CALLBACK_ACTION_REQUEST_AND_END;
								radio_disable();
					case RADIO_STATE_DISABLED:
							printf("Radio disabled \r\n");
    case NRF_RADIO_CALLBACK_SIGNAL_TYPE_TIMER0:
        //Timer interrupt - do graceful shutdown - schedule next timeslot
					radio_disable();
					printf("Timer interrupt - should deinitialize ts \r\n");
    case NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_SUCCEEDED:
        //No implementation needed
					printf("Extended timeslot \r\n");
    case NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_FAILED:
        //Try scheduling a new timeslot
					printf("Session extension failed, \r\n");
        configure_next_event_earliest();
return (&signal_callback_return_param);
