I can not able to send more than 15 bytes of data in SPI21 in nrf54L15
I am working with St7789v driver based RGB565 Display . I have chosen SPI21 configured at 8Mhz and if I send 15 bytes chunk of image bitmaps, I can see the image in the display .
if i increase it to more than 15 bytes , the image is distorted and showing like garbage .
I have kept the image bitmaps in RAM and trying to display the image .
even if I send 15 bytes chunks and decrease the SPI clock to 4Mhz , this time also I can not see the actual image .
here is the code for reference
static struct spi_config spi_cfg = {
    .frequency = 8000000,
    .operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB | SPI_OP_MODE_MASTER,
    .slave = 0,
    .cs = NULL,
int spi_send(const uint8_t *data, size_t len,char continuous)
    struct spi_buf tx_buf = {
        .buf = (void *)data,
        .len = len,
    struct spi_buf_set tx = {
        .buffers = &tx_buf,
        .count = 1,
    gpio_pin_set(spi_cs_spec.port, spi_cs_spec.pin, 0); // CS = 0 to select the device
    int ret = spi_write(spi_dev, &spi_cfg, &tx);
    if (continuous == 0)
        gpio_pin_set(spi_cs_spec.port, spi_cs_spec.pin, 1); // CS = 1 to deselect the device
    if (ret)
        LOG_ERR("SPI write failed: %d", ret);
    return ret;
Function used to display the image
static void DE_vDrawBuffer(const Position_t *pos,  uint8_t *buffer, size_t bufSize)
    const uint32_t w = pos->width;
    const uint32_t h = pos->height;
    const uint32_t total = w * h * 2u; // RGB565 = 2 bytes/pixel
    const int x0 = pos->x;
    const int y0 = pos->y;
    const int x1 = x0 + (int)w - 1;
    const int y1 = y0 + (int)h - 1;
    DE_vSetWindow(x0, y0, x1, y1);
    write_command(ST77XX_RAMWR); // 0x2C: start GRAM write
    int readData = 0;
   #define CHUNK_SIZE (12)
   //kb TOBO: why can not i increase above 15 bytes of chunk size?
   //if i send above 15 bytes, the display shows garbage
    uint8_t temp[CHUNK_SIZE];
    while (readData <= total)
        int toRead = total - readData > CHUNK_SIZE ? CHUNK_SIZE : total - readData;
        memcpy(temp, &buffer[readData], toRead);
        write_data(temp, toRead,1);
        readData += toRead;
    SetCSHigh();
