I am developing an LTE-M application on nRF9151, using offloaded sockets to modem, including DTLS.
Everything works great - can connect to network, and communicate with a server over CoAP.
However, in my prj.conf, CONFIG_NET_NATIVE=y (enabled).
I am aware that this should be disabled typically for offloaded socket configuration. However this does not work for me.
When I set CONFIG_NET_NATIVE=n, I get this error during the connect phase:
[00:00:00.745,208] <dbg> nrf_modem_lib_netif: lte_net_if_connect: Connecting to LTE [00:00:03.404,663] <dbg> nrf_modem_lib_netif: pdn_event_handler: PDN connection activated [00:00:03.405,670] <err> nrf_modem_lib_netif: ipv4_addr_add, error: -19 [00:00:03.405,700] <dbg> nrf_modem_lib_netif: lte_net_if_disconnect: Disconnecting from LTE
here is my full network config:
# Network Config CONFIG_NETWORKING=y CONFIG_NET_SOCKETS=y CONFIG_POSIX_API=y CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_NATIVE=y CONFIG_NET_UDP=y CONFIG_NET_IPV4=y # Zephyr Network Connection Manager CONFIG_NET_CONNECTION_MANAGER=y CONFIG_NET_CONNECTION_MANAGER_MONITOR_STACK_SIZE=1024 # nRF91 Modem CONFIG_NRF_MODEM_LIB=y CONFIG_NRF_MODEM_LIB_NET_IF=y CONFIG_NRF_MODEM_LIB_NET_IF_LOG_LEVEL_DBG=y # Disable Duplicate Address Detection (DAD) # due to not being properly implemented for offloaded interfaces. CONFIG_NET_IPV6_NBR_CACHE=n CONFIG_NET_IPV6_MLD=n # Network status monitoring CONFIG_INYO_LTE_NETWORK_AT_MONITOR=n
I believe having CONFIG_NET_UDP=y & CONFIG_NET_IPV4=y are actually not necessary but they are enabled for now.
Despite not setting CONFIG_NET_NATIVE=n, I can still see the sockets being offloaded to modem lib and things work fine.
I would just like to understand what causes this issue since it should work with CONFIG_NET_NATIVE=n.
(I am using NCS v3.1.0, modem firwmare = mfw_nrf91x1_2.0.2)
Thanks in advance,
Jason
